path: root/lib/libfdt/fdt_overlay.c
2017-11-17lib: libfdt: wrap scripts/dtc/libfdt/* where possibleMasahiro Yamada
lib/libfdt/ and scripts/dtc/libfdt have the same copies for the followings 6 files: fdt.c fdt_addresses.c fdt_empty_tree.c fdt_overlay.c fdt_strerr.c fdt_sw.c Make them a wrapper of scripts/dtc/libfdt/*. This is exactly what Linux does to sync libfdt. In order to make is possible, import <linux/libfdt.h> and <linux/libfdt_env.h> from Linux 4.14-rc5. Unfortunately, U-Boot locally modified the following 3 files: fdt_ro.c fdt_wip.c fdt_rw.c The fdt_region.c is U-Boot own file. I did not touch them in order to avoid unpredictable impact. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-09-15fdt: Allow stacked overlays phandle referencesPantelis Antoniou
This patch enables an overlay to refer to a previous overlay's labels by performing a merge of symbol information at application time. In a nutshell it allows an overlay to refer to a symbol that a previous overlay has defined. It requires both the base and all the overlays to be compiled with the -@ command line switch so that symbol information is included. base.dts -------- /dts-v1/; / { foo: foonode { foo-property; }; }; $ dtc -@ -I dts -O dtb -o base.dtb base.dts bar.dts ------- /dts-v1/; /plugin/; / { fragment@1 { target = <&foo>; __overlay__ { overlay-1-property; bar: barnode { bar-property; }; }; }; }; $ dtc -@ -I dts -O dtb -o bar.dtb bar.dts baz.dts ------- /dts-v1/; /plugin/; / { fragment@1 { target = <&bar>; __overlay__ { overlay-2-property; baz: baznode { baz-property; }; }; }; }; $ dtc -@ -I dts -O dtb -o baz.dtb baz.dts Applying the overlays: $ fdtoverlay -i base.dtb -o target.dtb bar.dtb baz.dtb Dumping: $ fdtdump target.dtb / { foonode { overlay-1-property; foo-property; linux,phandle = <0x00000001>; phandle = <0x00000001>; barnode { overlay-2-property; phandle = <0x00000002>; linux,phandle = <0x00000002>; bar-property; baznode { phandle = <0x00000003>; linux,phandle = <0x00000003>; baz-property; }; }; }; __symbols__ { baz = "/foonode/barnode/baznode"; bar = "/foonode/barnode"; foo = "/foonode"; }; }; Signed-off-by: Pantelis Antoniou <pantelis.antoniou@konsulko.com> Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Acked-by: Simon Glass <sjg@chromium.org>
2017-04-10fdt: Bring in changes from v1.4.4Simon Glass
This a few minor changes down from upstream since the last sync. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-01-13libfdt: Correct fdt handling of overlays without fixups and base trees ↵David Gibson
without symbols The fdt_overlay_apply() function purports to support the edge cases where an overlay has no fixups to be applied, or a base tree which has no symbols (the latter can only work if the former is also true). However it gets it wrong in a couple of small ways: * In the no fixups case, it doesn't fail immediately, but will attempt fdt_for_each_property_offset() giving -FDT_ERR_NOTFOUND as the node offset, which will fail. Instead it should succeed immediately, since there's nothing to do. * In the case of no symbols, it again doesn't fail immediately. However if there is an actual fixup it will fail with an unexpected error, because -FDT_ERR_NOTFOUND is passed to fdt_getprop() when attempting to look up the symbols. We should instead return -FDT_ERR_NOTFOUND directly. Both of these errors lead to the code returning misleading error codes in failing cases. [ DTC commit: 7d8ef6e1db9794f72805a0855f4f7f12fadd03d3 ] Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-10-23libfdt: Sync overlay with upstreamMaxime Ripard
Now that the overlay code has been merge upstream, update our copy to what's been merged, since a significant number of issues have been fixed during the merge process. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-10-13libfdt: Sync fdt_for_each_subnode() with upstreamSimon Glass
The signature for this macro has changed. Bring in the upstream version and adjust U-Boot's usages to suit. Signed-off-by: Simon Glass <sjg@chromium.org> Update to drivers/power/pmic/palmas.c: Signed-off-by: Keerthy <j-keerthy@ti.com> Change-Id: I6cc9021339bfe686f9df21d61a1095ca2b3776e8
2016-08-20tests: Introduce DT overlay testsMaxime Ripard
This adds a bunch of unit tests for the "fdt apply" command. They've all been run successfully in the sandbox. However, as you still require an out-of-tree dtc with overlay support, this is disabled by default. Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Pantelis Antoniou <pantelis.antoniou@konsulko.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2016-08-20cmd: fdt: add fdt overlay application subcommandMaxime Ripard
The device tree overlays are a good way to deal with user-modifyable boards or boards with some kind of an expansion mechanism where we can easily plug new board in (like the BBB or the raspberry pi). However, so far, the usual mechanism to deal with it was to have in Linux some driver detecting the expansion boards plugged in and then request these overlays using the firmware interface. That works in most cases, but in some cases, you might want to have the overlays applied before the userspace comes in. Either because the new board requires some kind of an early initialization, or because your root filesystem is accessed through that expansion board. The easiest solution in such a case is to simply have the component before Linux applying that overlay, removing all these drawbacks. Reviewed-by: Stefan Agner <stefan@agner.ch> Acked-by: Pantelis Antoniou <pantelis.antoniou@konsulko.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2016-08-20libfdt: Add overlay application functionMaxime Ripard
The device tree overlays are a good way to deal with user-modifyable boards or boards with some kind of an expansion mechanism where we can easily plug new board in (like the BBB, the Raspberry Pi or the CHIP). Add a new function to merge overlays with a base device tree. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
