path: root/lib/ldiv.c
2013-07-24Add LGPL-2.0+ SPDX-License-Identifier to source filesWolfgang Denk
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
