path: root/lib/image-sparse.c
2018-05-30mmc: Separate "mmc swrite" from fastbootAlex Kiernan
Introduce CONFIG_IMAGE_SPARSE and CONFIG_CMD_MMC_SWRITE so the "mmc swrite" command is separated from the fastboot code. Move image-sparse from common to lib so it's clear it's library code. Rename CONFIG_FASTBOOT_FLASH_FILLBUF_SIZE to CONFIG_IMAGE_SPARSE_FILLBUF_SIZE and migrate it to Kconfig. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Acked-by: Jassi Brar <jaswinder.singh@linaro.org> Reviewed-by: Simon Glass <sjg@chromium.org>
