path: root/lib/fdtdec_common.c
2018-03-05libfdt: move headers to <linux/libfdt.h> and <linux/libfdt_env.h>Masahiro Yamada
Thomas reported U-Boot failed to build host tools if libfdt-devel package is installed because tools include libfdt headers from /usr/include/ instead of using internal ones. This commit moves the header code: include/libfdt.h -> include/linux/libfdt.h include/libfdt_env.h -> include/linux/libfdt_env.h and replaces include directives: #include <libfdt.h> -> #include <linux/libfdt.h> #include <libfdt_env.h> -> #include <linux/libfdt_env.h> Reported-by: Thomas Petazzoni <thomas.petazzoni@bootlin.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-11-05lib, fdt: Adding fdtdec_get_uint functionChin Liang See
Adding fdtdec_get_uint function which is the unsigned version for fdtdec_get_int Signed-off-by: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Dinh Nguyen <dinh.linux@gmail.com> Cc: Marek Vasut <marex@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Vikas Manocha <vikas.manocha@st.com> Cc: Jagannadh Teki <jteki@openedev.com> Cc: Pavel Machek <pavel@denx.de> Cc: Heiko Schocher <hs@denx.de>
2014-06-23lib, fdt: move fdtdec_get_int() out of lib/fdtdec.cHeiko Schocher
move fdtdec_get_int() out of lib/fdtdec.c into lib/fdtdec_common.c as this function is also used, if CONFIG_OF_CONTROL is not used. Poped up on the ids8313 board using signed FIT images, and activating CONFIG_SYS_GENERIC_BOARD. Without this patch it shows on boot: No valid FDT found - please append one to U-Boot binary, use u-boot-dtb.bin or define CONFIG_OF_EMBED. For sandbox, use -d <file.dtb> With this patch, it boots again with CONFIG_SYS_GENERIC_BOARD enabled. Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@ti.com>
