path: root/lib/fdtdec.c
2018-03-05libfdt: move headers to <linux/libfdt.h> and <linux/libfdt_env.h>Masahiro Yamada
Thomas reported U-Boot failed to build host tools if libfdt-devel package is installed because tools include libfdt headers from /usr/include/ instead of using internal ones. This commit moves the header code: include/libfdt.h -> include/linux/libfdt.h include/libfdt_env.h -> include/linux/libfdt_env.h and replaces include directives: #include <libfdt.h> -> #include <linux/libfdt.h> #include <libfdt_env.h> -> #include <linux/libfdt_env.h> Reported-by: Thomas Petazzoni <thomas.petazzoni@bootlin.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-01-21lib: fdtdec: Fix some style violationsMario Six
Fix some style violations in fdtdec.c, and reduce the scope of some variables. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-01-21lib: fdtdec: Fix whitespace style violationsMario Six
Fix some whitespace-related style violations in fdtdec.c. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-01-15fdtdec: allow board to provide fdt for CONFIG_OF_SEPARATERob Clark
Similar to CONFIG_OF_BOARD, but in this case the fdt is still built by u-boot build. This allows the board to patch the fdt, etc. In the specific case of dragonboard 410c, we pass the u-boot generated fdt to the previous stage of bootloader (by embedding it in the u-boot.img that is loaded by lk/aboot), which patches the fdt and passes it back to u-boot. Signed-off-by: Rob Clark <robdclark@gmail.com> [trini: Update board_fdt_blob_setup #if check] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-11-30Merge branch 'rmobile-mx' of git://git.denx.de/u-boot-shTom Rini
2017-11-29spl: make CONFIG_OF_EMBED pass dts through fdtgrepGoldschmidt Simon
Building spl with CONFIG_OF_EMBED enabled results in an error message on my board: "SPL image too big". This is because the fdtgrep build step is only executed for CONFIG_OF_SEPARATE. Fix this by moving the fdtgrep build step ('cmd_fdtgreo') from scripts/Makefile.spl to dts/Makefile so that the reduced dtb is available for all kinds of spl builds. The resulting variable name for the embedded device tree blob changes, too, which is why common.h and fdtdec.c have tiny changes. Signed-off-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-11-30fdtdec: Support parsing multiple /memory nodesMarek Vasut
It is legal to have multiple /memory nodes in a device tree . Currently, fdtdec_setup_memory_size() only supports parsing the first node . This patch extends the function such that if a particular /memory node does no longer have further "reg" entries and CONFIG_NR_DRAM_BANKS still allows for more DRAM banks, the code moves on to the next memory node and checks it's "reg"s. This makes it possible to handle both systems with single memory node with multiple entries and systems with multiple memory nodes with single entry. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Tom Rini <trini@konsulko.com> Cc: Simon Glass <sjg@chromium.org>
2017-11-26fdt: Add compatible strings for Arria 10Tien Fong Chee
Add compatible strings for Intel Arria 10 SoCFPGA device. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com>
2017-10-06spl: dm: Make it possible for the SPL to pick its own DTB from a FITJean-Jacques Hiblot
u-boot can be embedded within a FIT image with multiple DTBs. It then selects at run-time which one is best suited for the platform. Use the same principle here for the SPL: put the DTBs in a FIT image, compress it (LZO, GZIP, or no compression) and append it at the end of the SPL. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> [trini: Move default y of SPL_MULTI_DTB_FIT_DYN_ALLOC to it being the default choice if SYS_MALLOC_F, drop spl.h include from lib/fdtdec.c it's unused.] Signed-off-by Tom Rini <trini@konsulko.com>
2017-10-05fdtdec: sort include filesJean-Jacques Hiblot
Sort include files in accordance to U-Boot coding style. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2017-10-05dts: renamed FIT_EMBED to MULTI_DTB_FIT and moved it to the dts KconfigJean-Jacques Hiblot
CONFIG_FIT_EMBED might be confused with CONFIG_OF_EMBED, rename it MULTI_DTB_FIT as it is able to get a DTB from a FIT image containing multiple DTBs. Also move the option to the Kconfig dedicated to the DTS options and create a README for this feature. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename getenv_hex(), getenv_yesno(), getenv_ulong()Simon Glass
We are now using an env_ prefix for environment functions. Rename these for consistency. Also add function comments in common.h. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-07-28fdtdec: Drop old compatible valuesSimon Glass
These are not needed now since the drivers now use driver model. Drop them. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Tested-on: Beaver, Jetson-TK1 Tested-by: Stephen Warren <swarren@nvidia.com>
2017-07-10fdt: Enable selecting correct DTB from appended FIT ImageCooper Jr., Franklin
This patch gives U-boot the runtime support to have the board specific code decide which FDT to use. This is especially useful for devices that need this type of runtime determination and also doesn't use SPL. Signed-off-by: Franklin S Cooper Jr <fcooper@ti.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-06-02fdt: Correct cast for sandbox in fdtdec_setup_memory_size()Simon Glass
This gives a warning with some native compilers: lib/fdtdec.c:1203:8: warning: format ‘%llx’ expects argument of type ‘long long unsigned int’, but argument 3 has type ‘long unsigned int’ [-Wformat=] Fix it with a cast. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-01cros_ec: Convert to support live treeSimon Glass
Convert this driver to support the live device tree and remove the old fdtdec support. The keyboard is not yet converted. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-01dm: core: Add a place to put extra device-tree reading functionsSimon Glass
Some functions deal with structured data rather than simple data types. It makes sense to have these in their own file. For now this just has a function to read a flashmap entry. Move the data types also. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-09Allow boards to initialize the DT at runtime.Alex Deymo
In some boards like the Raspberry Pi the initial bootloader will pass a DT to the kernel. When using U-Boot as such kernel, the board code in U-Boot should be able to provide U-Boot with this, already assembled device tree blob. This patch introduces a new config option CONFIG_OF_BOARD to use instead of CONFIG_OF_EMBED or CONFIG_OF_SEPARATE which will initialize the DT from a board-specific funtion instead of bundling one with U-Boot or as a separated file. This allows boards like the Raspberry Pi to reuse the device tree passed from the bootcode.bin and start.elf firmware files, including the run-time selected device tree overlays. Signed-off-by: Alex Deymo <deymo@google.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-04-14fdt: Add compatible strings for Arria 10Ley Foon Tan
Add compatible strings for Intel Arria 10 SoCFPGA device. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com>
2017-03-26libfdt: use CONFIG_IS_ENABLED for OF_LIBFDTVignesh R
Use CONFIG_IS_ENABLED() macro to check whether OF_TRANSLATE is enabled, so that code block is compiled irrespective of SPL or U-Boot build and fdt address translation is used. Signed-off-by: Vignesh R <vigneshr@ti.com>
2016-12-20fdt: add memory bank decoding functions for board setupNathan Rossi
Add two functions for use by board implementations to decode the memory banks of the /memory node so as to populate the global data with ram_size and board info for memory banks. The fdtdec_setup_memory_size() function decodes the first memory bank and sets up the gd->ram_size with the size of the memory bank. This function should be called from the boards dram_init(). The fdtdec_setup_memory_banksize() function decode the memory banks (up to the CONFIG_NR_DRAM_BANKS) and populates the base address and size into the gd->bd->bi_dram array of banks. This function should be called from the boards dram_init_banksize(). Signed-off-by: Nathan Rossi <nathan@nathanrossi.com> Cc: Simon Glass <sjg@chromium.org> Cc: Michal Simek <monstr@monstr.eu> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-10-13libfdt: Sync fdt_for_each_subnode() with upstreamSimon Glass
The signature for this macro has changed. Bring in the upstream version and adjust U-Boot's usages to suit. Signed-off-by: Simon Glass <sjg@chromium.org> Update to drivers/power/pmic/palmas.c: Signed-off-by: Keerthy <j-keerthy@ti.com> Change-Id: I6cc9021339bfe686f9df21d61a1095ca2b3776e8
2016-10-13libfdt: Bring in upstream stringlist functionsSimon Glass
These have now landed upstream. The naming is different and in one case the function signature has changed. Update the code to match. This applies the following upstream commits by Thierry Reding <treding@nvidia.com> : 604e61e fdt: Add functions to retrieve strings 8702bd1 fdt: Add a function to get the index of a string 2218387 fdt: Add a function to count strings Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-14usb: uniphier: remove UniPhier xHCI driver and select DM_USBMasahiro Yamada
This driver has not been converted to Driver Model, and it is an obstacle to migrate other block device drivers. Remove it for now. The UniPhier SoCs already use a DM-based EHCI driver, so now ARCH_UNIPHIER can select DM_USB. These two changes must be done atomically because removing the legacy driver causes a build error. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Marek Vasut <marex@denx.de>
2016-08-12fdt: allow fdtdec_get_addr_size_*() to translate addressesStephen Warren
Some code may want to read reg values from DT, but from nodes that aren't associated with DM devices, so using dev_get_addr_index() isn't appropriate. In this case, fdtdec_get_addr_size_*() are the functions to use. However, "translation" (via the chain of ranges properties in parent nodes) may still be desirable. Add a function parameter to request that, and implement it. Update all call sites to default to the original behaviour. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Squashed in build fix from Stephen: Signed-off-by: Simon Glass <sjg@chromium.org>
2016-07-24mtd: nand: Add the sunxi NAND controller driverBoris Brezillon
We already have an SPL driver for the sunxi NAND controller, now add the normal/standard one. The source has been copied from Linux 4.6 with a few changes to make it work in u-boot. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Acked-by: Hans de Goede <hdegoede@redhat.com>
2016-07-11sandbox: Find keyboard driver using driver modelSimon Glass
The cros-ec keyboard is always a child of the cros-ec node. Rather than searching the device tree, looking at the children. Remove the compat string which is now unused. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-07-11fdt: x86: Tidy up a few COMPAT string definitionsSimon Glass
The 'COMPAT_' part should appear only once so drop the duplicate part. It is ignored anyway, but let's keep things consistent. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-07-11fdt: Add a note to avoid adding new compatible stringsSimon Glass
The list is shrinking and we should avoid adding new things. Instead, a proper driver should be created with driver model. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-07-11fdt: Drop unused exynos compatible stringsSimon Glass
A few drivers have moved to driver model, so we can drop these strings. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Jaehoon Chung <jh80.chung@samsung.com>
2016-07-11x86: fdt: Drop the unused compatible strings in fdtdecSimon Glass
We have drivers for several more devices now, so drop the strings which are no-longer used. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-07-05fdt: Drop some unused compatible stringsSimon Glass
We have driver-model drivers for some of these now, so drop them. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-06-12fdt: Correct return value in fdtdec_decode_display_timing()Simon Glass
This should return a non-zero value if there is a missing property. Update the return value accordingly. The only expected error is -FDT_ERR_NOTFOUND. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Andreas Bießmann <andreas@biessmann.org>
2016-05-31mmc: tegra: add basic Tegra186 supportStephen Warren
Tegra186's MMC controller needs to be explicitly identified. Add another compatible value for it. Tegra186 will use an entirely different clock/reset control mechanism to existing chips, and will use standard clock/reset APIs rather than the existing Tegra-specific custom APIs. The driver support for that isn't ready yet, so simply disable all clock/reset usage if compiling for Tegra186. This must happen at compile time rather than run-time since the custom APIs won't even be compiled in on Tegra186. In the long term, the plan would be to convert the existing custom APIs to standard APIs and get rid of the ifdefs completely. The system's main eMMC will work without any clock/reset support, since the firmware will have already initialized the controller in order to load U-Boot. Hence the driver is useful even in this apparently crippled state. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-03-17x86: dts: Drop memory SPD compatible stringSimon Glass
This is not needed now that the memory controller driver has the SPD data in its own node. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-03-17x86: Drop all the old pin configuration codeSimon Glass
We don't need this anymore - we can use device tree and the new pinconfig driver instead. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-03-14dm: fdtdec: Correct a sandbox build warningSimon Glass
Adjust the cast to avoid a warning when stdint.h is used. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-02-16tegra: nyan-big: Move the LCD driver to driver modelSimon Glass
Adjust the driver to use driver model. The SOR becomes a bridge device. We use the normal simple_panel driver to handle the display itself. We also need to enable some options such as regulators, PWMs and DM_VIDEO itself. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-02-06fdt: introduce fdtdec_get_child_countPeng Fan
Introduce fdtdec_get_child_count for get the number of subnodes of one parent node. Signed-off-by: Peng Fan <van.freenix@gmail.com> Cc: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2016-01-24x86: Drop the irq router compatible stringSimon Glass
We use driver model for this now, so we don't need this string. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-01-20dm: video: sandbox: Convert sandbox to use driver model for videoSimon Glass
Now that driver model support is available, convert sandbox over to use it. We can remove a few of the special hooks that sandbox currently has. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de>
2016-01-14Merge branch 'master' of git://git.denx.de/u-boot-x86Tom Rini
2016-01-13fdtdec: Add compatible string for Intel IvyBridge FSPBin Meng
Use "intel,ivybridge-fsp" for Intel IvyBridge FSP compatible string. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2016-01-12dm: serial: Convert ns16550 driver to use driver model PCI APISimon Glass
Use the driver model version of the function to find the BAR. This updates the fdtdec function, of which ns16550 is the only user. The fdtdec_get_pci_bdf() function is dropped for several reasons: - with driver model we should use 'struct udevice *' rather than passing the device tree offset explicitly - there are no other users in the tree - the function parses for information which is already available in the PCI device structure (specifically struct pci_child_platdata which is available at dev_get_parent_platdata(dev) Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2015-12-20arm: socfpga: Allow DWC2 UDC probing from OFMarek Vasut
The USB gadget framework does not support DM yet, so add this bit to let DWC2 UDC probe from OF on platforms which support it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Lukasz Majewski <l.majewski@majess.pl> Cc: Lukasz Majewski <l.majewski@samsung.com>
2015-12-01dm: tegra: pci: Convert tegra boards to driver model for PCISimon Glass
Adjust the Tegra PCI driver to support driver model and move all boards over at the same time. This can make use of some generic driver model code, such as the range-decoding logic. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Stephen Warren <swarren@nvidia.com>
2015-11-19dm: tegra: Convert keyboard driver to driver modelSimon Glass
Adjust the tegra keyboard driver to support driver model, using the new uclass. Make this the default for all Tegra boards so that those that use a keyboard will build correctly with this driver. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-11-12pci: tegra: add/enable support for Tegra210Stephen Warren
This needs a separate compatible value from Tegra124 since the new HW version has bugs that would prevent a driver for previous HW versions from operating at all. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-11-04dm: spl: Support device tree when BSS is in a different sectionSimon Glass
At present in SPL we place the device tree immediately after BSS. This avoids needing to copy it out of the way before BSS can be used. However on some boards BSS is not placed with the image - e.g. it can be in RAM if available. Add an option to tell U-Boot that the device tree should be placed at the end of the image binary (_image_binary_end) instead of at the end of BSS. Note: A common reason to place BSS in RAM is to support the FAT filesystem. We should update the code so that it does not use so much BSS. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-11-04fdt: Add a function to look up a /chosen propertySimon Glass
It is sometimes useful to find a property in the chosen node. Add a function for this. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
