path: root/lib/fdtdec.c
2018-11-20fdt: Fix uncompress_blob() for U-Boot properMarek Vasut
When U-Boot proper is compiled with CONFIG_MULTI_DTB_FIT and tries to call uncompress_blob(), it fails with -ENOTSUPP. This is because the full implementation of this function which includes compression is available only in SPL. In U-Boot proper or if the compression is not enabled, the blob is not compressed and thus can be passed to locate_dtb_in_fit() in fdtdec_setup() without any changes. Pass the blob without any changes if compression is not enabled instead of failing. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-10-15Revert "fdt: fdtdec_setup_memory_banksize() use livetree"Michal Simek
This reverts commit c35a7d375ec8f0a8ee343ae4868be3242172632e. This commit is breaking SPL on zc706. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Patrice Chotard <patrice.chotard@st.com> [on STM32F746-disco]
2018-10-09fdt: Remove fdtdec_decode_region() functionSimon Glass
This function is not used in U-Boot now. Remove it along with its 'memory' version. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-09-29fdt: fdtdec_setup_memory_banksize() use livetreeJens Wiklander
Converts fdtdec_setup_memory_banksize() to use ofnode functions instead. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Jens Wiklander <jens.wiklander@linaro.org>
2018-09-10Remove <inttypes.h> includes and PRI* usages in printf() entirelyMasahiro Yamada
In int-ll64.h, we always use the following typedefs: typedef unsigned int u32; typedef unsigned long uintptr_t; typedef unsigned long long u64; This does not need to match to the compiler's <inttypes.h>. Do not include it. The use of PRI* makes the code super-ugly. You can simply use "l" for printing uintptr_t, "ll" for u64, and no modifier for u32. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-09-10fdt: fix get_next_memory_node()Marek Vasut
The get_next_memory_node() always sets mem to -1 , which is incorrect, because then every iteration of memory bank parsing will start from the first memory bank instead of the previous one. On systems with 1 memory bank defined in DT and CONFIG_NR_DRAM_BANKS=4 , like ie. r8a77965-salvator-x , this will result in U-Boot incorrectly reporting four identical memory banks with the same memory configuration. Fix this by setting mem to startoffset value, which restores the behavior before the fixed patch was applied. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Jens Wiklander <jens.wiklander@linaro.org> Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@konsulko.com> Fixes: 452bc121027d ("fdt: fix fdtdec_setup_memory_banksize()") Tested-by: Michal Simek <michal.simek@xilinx.com> [on ZynqMP}
2018-07-26fdt: fix fdtdec_setup_memory_banksize()Jens Wiklander
Prior to this patch is fdtdec_setup_memory_banksize() incorrectly ignoring the "status" field. This patch fixes that by testing the status with fdtdec_get_is_enabled() before using a memory node. Signed-off-by: Jens Wiklander <jens.wiklander@linaro.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-07-19lib: fdtdec: Rename routine fdtdec_setup_memory_size()Siva Durga Prasad Paladugu
This patch renames the routine fdtdec_setup_memory_size() to fdtdec_setup_mem_size_base() as it now fills the mem base as well along with size. Signed-off-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-07-19lib: fdtdec: Update ram_base to store ram start adddressSiva Durga Prasad Paladugu
This patch updates the ram_base to store the start address of the first bank DRAM and the use this ram_base to calculate ram_top properly. This patch fixes the erroneous calculation of ram_top incase of non zero ram start address. Signed-off-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-07-10board: arm: Add support for Broadcom BCM7445Thomas Fitzsimmons
Add support for loading U-Boot on the Broadcom 7445 SoC. This port assumes Broadcom's BOLT bootloader is acting as the second stage bootloader, and U-Boot is acting as the third stage bootloader, loaded as an ELF program by BOLT. Signed-off-by: Thomas Fitzsimmons <fitzsim@fitzsim.org> Cc: Stefan Roese <sr@denx.de> Cc: Tom Rini <trini@konsulko.com> Cc: Florian Fainelli <f.fainelli@gmail.com>
2018-07-09fdt: Add device tree memory bindingsMichael Pratt
Support a default memory bank, specified in reg, as well as board-specific memory banks in subtree board-id nodes. This allows memory information to be provided in the device tree, rather than hard-coded in, which will make it simpler to handle similar devices with different memory banks, as the board-id values or masks can be used to match devices. Signed-off-by: Michael Pratt <mpratt@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Vadim Bendebury <vbendeb@chromium.org>
2018-05-18fdt: Add another Altera Arria10 clock init compatibleMarek Vasut
The DT bindings for the Arria10 clock init have changed, add another compatible to make them work with U-Boot until a proper clock driver gets written. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Tom Rini <trini@konsulko.com> Cc: Chin Liang See <chin.liang.see@intel.com> Cc: Dinh Nguyen <dinguyen@kernel.org>
2018-05-08lib: fdtdec: drop the old compatible about max77686Jaehoon Chung
Drop the old compatible about max77686. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Acked-by: Lukasz Majewski <lukma@denx.de>
2018-03-05libfdt: move headers to <linux/libfdt.h> and <linux/libfdt_env.h>Masahiro Yamada
Thomas reported U-Boot failed to build host tools if libfdt-devel package is installed because tools include libfdt headers from /usr/include/ instead of using internal ones. This commit moves the header code: include/libfdt.h -> include/linux/libfdt.h include/libfdt_env.h -> include/linux/libfdt_env.h and replaces include directives: #include <libfdt.h> -> #include <linux/libfdt.h> #include <libfdt_env.h> -> #include <linux/libfdt_env.h> Reported-by: Thomas Petazzoni <thomas.petazzoni@bootlin.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-01-21lib: fdtdec: Fix some style violationsMario Six
Fix some style violations in fdtdec.c, and reduce the scope of some variables. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-01-21lib: fdtdec: Fix whitespace style violationsMario Six
Fix some whitespace-related style violations in fdtdec.c. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-01-15fdtdec: allow board to provide fdt for CONFIG_OF_SEPARATERob Clark
Similar to CONFIG_OF_BOARD, but in this case the fdt is still built by u-boot build. This allows the board to patch the fdt, etc. In the specific case of dragonboard 410c, we pass the u-boot generated fdt to the previous stage of bootloader (by embedding it in the u-boot.img that is loaded by lk/aboot), which patches the fdt and passes it back to u-boot. Signed-off-by: Rob Clark <robdclark@gmail.com> [trini: Update board_fdt_blob_setup #if check] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-11-30Merge branch 'rmobile-mx' of git://git.denx.de/u-boot-shTom Rini
2017-11-29spl: make CONFIG_OF_EMBED pass dts through fdtgrepGoldschmidt Simon
Building spl with CONFIG_OF_EMBED enabled results in an error message on my board: "SPL image too big". This is because the fdtgrep build step is only executed for CONFIG_OF_SEPARATE. Fix this by moving the fdtgrep build step ('cmd_fdtgreo') from scripts/Makefile.spl to dts/Makefile so that the reduced dtb is available for all kinds of spl builds. The resulting variable name for the embedded device tree blob changes, too, which is why common.h and fdtdec.c have tiny changes. Signed-off-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-11-30fdtdec: Support parsing multiple /memory nodesMarek Vasut
It is legal to have multiple /memory nodes in a device tree . Currently, fdtdec_setup_memory_size() only supports parsing the first node . This patch extends the function such that if a particular /memory node does no longer have further "reg" entries and CONFIG_NR_DRAM_BANKS still allows for more DRAM banks, the code moves on to the next memory node and checks it's "reg"s. This makes it possible to handle both systems with single memory node with multiple entries and systems with multiple memory nodes with single entry. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Tom Rini <trini@konsulko.com> Cc: Simon Glass <sjg@chromium.org>
2017-11-26fdt: Add compatible strings for Arria 10Tien Fong Chee
Add compatible strings for Intel Arria 10 SoCFPGA device. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com>
2017-10-06spl: dm: Make it possible for the SPL to pick its own DTB from a FITJean-Jacques Hiblot
u-boot can be embedded within a FIT image with multiple DTBs. It then selects at run-time which one is best suited for the platform. Use the same principle here for the SPL: put the DTBs in a FIT image, compress it (LZO, GZIP, or no compression) and append it at the end of the SPL. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> [trini: Move default y of SPL_MULTI_DTB_FIT_DYN_ALLOC to it being the default choice if SYS_MALLOC_F, drop spl.h include from lib/fdtdec.c it's unused.] Signed-off-by Tom Rini <trini@konsulko.com>
2017-10-05fdtdec: sort include filesJean-Jacques Hiblot
Sort include files in accordance to U-Boot coding style. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2017-10-05dts: renamed FIT_EMBED to MULTI_DTB_FIT and moved it to the dts KconfigJean-Jacques Hiblot
CONFIG_FIT_EMBED might be confused with CONFIG_OF_EMBED, rename it MULTI_DTB_FIT as it is able to get a DTB from a FIT image containing multiple DTBs. Also move the option to the Kconfig dedicated to the DTS options and create a README for this feature. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename getenv_hex(), getenv_yesno(), getenv_ulong()Simon Glass
We are now using an env_ prefix for environment functions. Rename these for consistency. Also add function comments in common.h. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-07-28fdtdec: Drop old compatible valuesSimon Glass
These are not needed now since the drivers now use driver model. Drop them. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Tested-on: Beaver, Jetson-TK1 Tested-by: Stephen Warren <swarren@nvidia.com>
2017-07-10fdt: Enable selecting correct DTB from appended FIT ImageCooper Jr., Franklin
This patch gives U-boot the runtime support to have the board specific code decide which FDT to use. This is especially useful for devices that need this type of runtime determination and also doesn't use SPL. Signed-off-by: Franklin S Cooper Jr <fcooper@ti.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-06-02fdt: Correct cast for sandbox in fdtdec_setup_memory_size()Simon Glass
This gives a warning with some native compilers: lib/fdtdec.c:1203:8: warning: format ‘%llx’ expects argument of type ‘long long unsigned int’, but argument 3 has type ‘long unsigned int’ [-Wformat=] Fix it with a cast. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-01cros_ec: Convert to support live treeSimon Glass
Convert this driver to support the live device tree and remove the old fdtdec support. The keyboard is not yet converted. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-01dm: core: Add a place to put extra device-tree reading functionsSimon Glass
Some functions deal with structured data rather than simple data types. It makes sense to have these in their own file. For now this just has a function to read a flashmap entry. Move the data types also. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-09Allow boards to initialize the DT at runtime.Alex Deymo
In some boards like the Raspberry Pi the initial bootloader will pass a DT to the kernel. When using U-Boot as such kernel, the board code in U-Boot should be able to provide U-Boot with this, already assembled device tree blob. This patch introduces a new config option CONFIG_OF_BOARD to use instead of CONFIG_OF_EMBED or CONFIG_OF_SEPARATE which will initialize the DT from a board-specific funtion instead of bundling one with U-Boot or as a separated file. This allows boards like the Raspberry Pi to reuse the device tree passed from the bootcode.bin and start.elf firmware files, including the run-time selected device tree overlays. Signed-off-by: Alex Deymo <deymo@google.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-04-14fdt: Add compatible strings for Arria 10Ley Foon Tan
Add compatible strings for Intel Arria 10 SoCFPGA device. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com>
2017-03-26libfdt: use CONFIG_IS_ENABLED for OF_LIBFDTVignesh R
Use CONFIG_IS_ENABLED() macro to check whether OF_TRANSLATE is enabled, so that code block is compiled irrespective of SPL or U-Boot build and fdt address translation is used. Signed-off-by: Vignesh R <vigneshr@ti.com>
2016-12-20fdt: add memory bank decoding functions for board setupNathan Rossi
Add two functions for use by board implementations to decode the memory banks of the /memory node so as to populate the global data with ram_size and board info for memory banks. The fdtdec_setup_memory_size() function decodes the first memory bank and sets up the gd->ram_size with the size of the memory bank. This function should be called from the boards dram_init(). The fdtdec_setup_memory_banksize() function decode the memory banks (up to the CONFIG_NR_DRAM_BANKS) and populates the base address and size into the gd->bd->bi_dram array of banks. This function should be called from the boards dram_init_banksize(). Signed-off-by: Nathan Rossi <nathan@nathanrossi.com> Cc: Simon Glass <sjg@chromium.org> Cc: Michal Simek <monstr@monstr.eu> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-10-13libfdt: Sync fdt_for_each_subnode() with upstreamSimon Glass
The signature for this macro has changed. Bring in the upstream version and adjust U-Boot's usages to suit. Signed-off-by: Simon Glass <sjg@chromium.org> Update to drivers/power/pmic/palmas.c: Signed-off-by: Keerthy <j-keerthy@ti.com> Change-Id: I6cc9021339bfe686f9df21d61a1095ca2b3776e8
2016-10-13libfdt: Bring in upstream stringlist functionsSimon Glass
These have now landed upstream. The naming is different and in one case the function signature has changed. Update the code to match. This applies the following upstream commits by Thierry Reding <treding@nvidia.com> : 604e61e fdt: Add functions to retrieve strings 8702bd1 fdt: Add a function to get the index of a string 2218387 fdt: Add a function to count strings Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-14usb: uniphier: remove UniPhier xHCI driver and select DM_USBMasahiro Yamada
This driver has not been converted to Driver Model, and it is an obstacle to migrate other block device drivers. Remove it for now. The UniPhier SoCs already use a DM-based EHCI driver, so now ARCH_UNIPHIER can select DM_USB. These two changes must be done atomically because removing the legacy driver causes a build error. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Marek Vasut <marex@denx.de>
2016-08-12fdt: allow fdtdec_get_addr_size_*() to translate addressesStephen Warren
Some code may want to read reg values from DT, but from nodes that aren't associated with DM devices, so using dev_get_addr_index() isn't appropriate. In this case, fdtdec_get_addr_size_*() are the functions to use. However, "translation" (via the chain of ranges properties in parent nodes) may still be desirable. Add a function parameter to request that, and implement it. Update all call sites to default to the original behaviour. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Squashed in build fix from Stephen: Signed-off-by: Simon Glass <sjg@chromium.org>
2016-07-24mtd: nand: Add the sunxi NAND controller driverBoris Brezillon
We already have an SPL driver for the sunxi NAND controller, now add the normal/standard one. The source has been copied from Linux 4.6 with a few changes to make it work in u-boot. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Acked-by: Hans de Goede <hdegoede@redhat.com>
2016-07-11sandbox: Find keyboard driver using driver modelSimon Glass
The cros-ec keyboard is always a child of the cros-ec node. Rather than searching the device tree, looking at the children. Remove the compat string which is now unused. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-07-11fdt: x86: Tidy up a few COMPAT string definitionsSimon Glass
The 'COMPAT_' part should appear only once so drop the duplicate part. It is ignored anyway, but let's keep things consistent. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-07-11fdt: Add a note to avoid adding new compatible stringsSimon Glass
The list is shrinking and we should avoid adding new things. Instead, a proper driver should be created with driver model. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-07-11fdt: Drop unused exynos compatible stringsSimon Glass
A few drivers have moved to driver model, so we can drop these strings. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Jaehoon Chung <jh80.chung@samsung.com>
2016-07-11x86: fdt: Drop the unused compatible strings in fdtdecSimon Glass
We have drivers for several more devices now, so drop the strings which are no-longer used. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-07-05fdt: Drop some unused compatible stringsSimon Glass
We have driver-model drivers for some of these now, so drop them. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-06-12fdt: Correct return value in fdtdec_decode_display_timing()Simon Glass
This should return a non-zero value if there is a missing property. Update the return value accordingly. The only expected error is -FDT_ERR_NOTFOUND. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Andreas Bießmann <andreas@biessmann.org>
2016-05-31mmc: tegra: add basic Tegra186 supportStephen Warren
Tegra186's MMC controller needs to be explicitly identified. Add another compatible value for it. Tegra186 will use an entirely different clock/reset control mechanism to existing chips, and will use standard clock/reset APIs rather than the existing Tegra-specific custom APIs. The driver support for that isn't ready yet, so simply disable all clock/reset usage if compiling for Tegra186. This must happen at compile time rather than run-time since the custom APIs won't even be compiled in on Tegra186. In the long term, the plan would be to convert the existing custom APIs to standard APIs and get rid of the ifdefs completely. The system's main eMMC will work without any clock/reset support, since the firmware will have already initialized the controller in order to load U-Boot. Hence the driver is useful even in this apparently crippled state. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-03-17x86: dts: Drop memory SPD compatible stringSimon Glass
This is not needed now that the memory controller driver has the SPD data in its own node. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-03-17x86: Drop all the old pin configuration codeSimon Glass
We don't need this anymore - we can use device tree and the new pinconfig driver instead. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
