Use unsigned char for the parameter of efi_st_strcmp_16_8. This allows
comparing characters 0x80 - 0xff.
Signed-off-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
We can use efi_st_get_config_table() in multiple unit tests.
Export the function.
Export system-table and boot-services.
At present we use wide characters for unicode but this is not necessary.
Change the code to use the 'u' literal instead. This helps to fix build
warnings for sandbox on rpi.
Suggested-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
Function memcmp() is available in efi_freestanding.c. So we do not remove a
further implementation.
Replace all usages of efi_st_memcmp() by memcmp().
Move reusable utility functions to efi_selftest_util.c.
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
Environment variable efi_selftest is passed as load options
to the selftest application. It is used to select a single
test to be executed.
The load options are an UTF8 string. Yet I decided to keep
the name propertiy of the tests as char[] to reduce code
size.
Special value 'list' displays a list of all available tests.
Tests get an on_request property. If this property is set
the tests are only executed if explicitly requested.
The invocation of efi_selftest is changed to reflect that
bootefi selftest with efi_selftest = 'list' will call the
Exit bootservice.
If the compared memory areas match the return value should be 0.
We should not use the unrelated constant EFI_ST_SUCCESS.
If the memory regions are different efi_st_memcmp currently
returns the difference of the addresses. Insted the
difference of the first differing byte pair should be
returned.
This patch provides an EFI application to check the correct function
of the Simple Network Protocol implementation.
It sends a DHCP request and analyzes the DHCP offer.
Different error conditions including a 10s timeout are checked.
A successful execution will look like this:
=> bootefi nettest
Scanning disk ide.blk#0...
Found 1 disks
WARNING: Invalid device tree, expect boot to fail
Network test
DHCP Discover
DHCP reply received from 192.168.76.2 (52:55:c0:a8:4c:02)
as broadcast message.
OK. The test was completed successfully.
