path: root/lib/efi_selftest/efi_selftest_console.c
2018-01-22efi_selftest: colored test outputHeinrich Schuchardt
Add color coding to output: test section blue success green errors red todo yellow summary white others light gray Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org> [agraf: Fold in move of set_attribute before the print] Signed-off-by: Alexander Graf <agraf@suse.de>
2018-01-22efi_selftest: do not cut off u16 strings when printingHeinrich Schuchardt
Device paths can be very long. Due to a limited output buffer the output for device paths is cut off. We can avoid this by directly calling the boottime service with the the device path string. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> [agraf: Remove coloring code change] Signed-off-by: Alexander Graf <agraf@suse.de>
2017-12-01efi_selftest: allow to select a single test for executionHeinrich Schuchardt
Environment variable efi_selftest is passed as load options to the selftest application. It is used to select a single test to be executed. The load options are an UTF8 string. Yet I decided to keep the name propertiy of the tests as char[] to reduce code size. Special value 'list' displays a list of all available tests. Tests get an on_request property. If this property is set the tests are only executed if explicitly requested. The invocation of efi_selftest is changed to reflect that bootefi selftest with efi_selftest = 'list' will call the Exit bootservice. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2017-10-09efi_selftest: allow printing MAC addressesHeinrich Schuchardt
Add %pm as format string to print a MAC address. This is helpful when analyzing network problems. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2017-09-18efi_selftest: provide an EFI selftest applicationHeinrich Schuchardt
A testing framework for the EFI API is provided. It can be executed with the 'bootefi selftest' command. It is coded in a way that at a later stage we may turn it into a standalone EFI application. The current build system does not allow this yet. All tests use a driver model and are run in three phases: setup, execute, teardown. A test may be setup and executed at boottime, it may be setup at boottime and executed at runtime, or it may be setup and executed at runtime. After executing all tests the system is reset. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
