path: root/lib/efi_selftest/efi_selftest.c
2018-12-02efi_selftest: rename setup_okHeinrich Schuchardt
The variable name setup_ok might suggest a boolean with true indicating OK. Let's avoid the misleading name. %s/setup_ok/setup_status/g Suggested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-12-02efi_selftest: do not write to linker generated arrayHeinrich Schuchardt
Linker generated arrays may be stored in code sections of memory that are not writable. So let's allocate setup_ok as an array at runtime. This avoids an illegal memory access observed in the sandbox. Reported-by: Simon Glass <sjg@chromium.org> Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-07-25efi_selftest: Clean up a few comments and messagesSimon Glass
Fix the 'amp' typo, expand on what 'steps' is and fix a few other minor things. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-04-23efi_selftest: do not execute test if setup failedHeinrich Schuchardt
Executing a test after failed setup may lead to unexpected behavior like an illegal memory access. So after a setup failure we should skip to teardown. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-01-22efi_selftest: colored test outputHeinrich Schuchardt
Add color coding to output: test section blue success green errors red todo yellow summary white others light gray Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org> [agraf: Fold in move of set_attribute before the print] Signed-off-by: Alexander Graf <agraf@suse.de>
2017-12-01efi_selftest: add missing line feedHeinrich Schuchardt
Add a missing line feed for an error message. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2017-12-01efi_loader: consistently use efi_uintn_t in boot servicesHeinrich Schuchardt
Consistenly use efi_uintn_t wherever the UEFI spec uses UINTN in boot services interfaces. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2017-12-01efi_selftest: allow to select a single test for executionHeinrich Schuchardt
Environment variable efi_selftest is passed as load options to the selftest application. It is used to select a single test to be executed. The load options are an UTF8 string. Yet I decided to keep the name propertiy of the tests as char[] to reduce code size. Special value 'list' displays a list of all available tests. Tests get an on_request property. If this property is set the tests are only executed if explicitly requested. The invocation of efi_selftest is changed to reflect that bootefi selftest with efi_selftest = 'list' will call the Exit bootservice. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2017-12-01efi_selftest: deduplicate codeHeinrich Schuchardt
Move duplicate code to the new function efi_st_do_tests. Suggested-by: Alexander Graf <agraf@suse.de> Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2017-12-01efi_selftest: reformat codeHeinrich Schuchardt
Remove superfluous spaces. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2017-10-09efi_selftest: make tests easier to readHeinrich Schuchardt
Rename counter to more illustrative names. Update notification function description. Simplify notification function. Add comment for arbitrary non-zero value. Document @return. Use constants for return values of setup, execute, teardown. Reported-by: Simon Glass <sjg@chromium.org> Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2017-10-09efi_selftest: use efi_st_error for all error messagesHeinrich Schuchardt
All error messages in the selftests should use efi_st_error. efi_st_error will print the file name and line number of the error. Splitting message texts due to lines being over 80 characters is avoided. This resolves the issue reported by Simon Glass in https://lists.denx.de/pipermail/u-boot/2017-September/307387.html Reported-by: Simon Glass <sjg@chromium.org> Fixes: 623b3a579765 efi_selftest: provide an EFI selftest application Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2017-09-18efi_selftest: provide an EFI selftest applicationHeinrich Schuchardt
A testing framework for the EFI API is provided. It can be executed with the 'bootefi selftest' command. It is coded in a way that at a later stage we may turn it into a standalone EFI application. The current build system does not allow this yet. All tests use a driver model and are run in three phases: setup, execute, teardown. A test may be setup and executed at boottime, it may be setup at boottime and executed at runtime, or it may be setup and executed at runtime. After executing all tests the system is reset. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
