At present we use wide characters for unicode but this is not necessary.
Change the code to use the 'u' literal instead. This helps to fix build
warnings for sandbox on rpi.
Suggested-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
This adds support for new RISCV_EFI_BOOT_PROTOCOL to
communicate the boot hart ID to bootloader/kernel on RISC-V
UEFI platforms.
The specification of the protocol is hosted at:
https://github.com/riscv-non-isa/riscv-uefi
Signed-off-by: Sunil V L <sunilvl@ventanamicro.com>
Reviewed-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
This commit modify efi_tcg2_register() to return the
appropriate error.
With this fix, sandbox will not boot because efi_tcg2_register()
fails due to some missing feature in GetCapabilities.
So disable sandbox if EFI_TCG2_PROTOCOL is enabled.
UEFI secure boot variable measurement is not directly related
to TCG2 protocol installation, tcg2_measure_secure_boot_variable()
is moved to the separate function.
Signed-off-by: Masahisa Kojima <masahisa.kojima@linaro.org>
Reviewed-by: Ilias Apalodimas <ilias.apalodimas@linaro.org>
If we call efi_clear_os_indications() before initializing the memory store
for UEFI variables a NULL pointer dereference occurs.
The error was observed on the sandbox with:
usb start
host bind 0 sandbox.img
load host 0:1 $kernel_addr_r helloworld.efi
bootefi $kernel_addr_r
Here efi_resister_disk() failed due to an error in the BTRFS implementation.
Move the logic to clear EFI_OS_INDICATIONS_FILE_CAPSULE_DELIVERY_SUPPORTED
to the rest of the capsule code.
If CONFIG_EFI_IGNORE_OSINDICATIONS=y, we should still clear the flag.
If OsIndications does not exist, we should not create it as it is owned by
the operating system.
Fixes: 149108a3eb59 ("efi_loader: clear OsIndications")
Signed-off-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
Acked-by: Ilias Apalodimas <ilias.apalodimas@linaro.org>
After each reboot we must clear flag
EFI_OS_INDICATIONS_FILE_CAPSULE_DELIVERY_SUPPORTED in variable
OsIndications.
We only install FMPs if a CapsuleUpdate is requested. Since we now have an
ESRT table which relies on FMPs to build the required information, it
makes more sense to unconditionally install them. This will allow userspace
applications (e.g fwupd) to make use of the ERST and provide us with files
we can use to run CapsuleUpdate on-disk
Signed-off-by: Ilias Apalodimas <ilias.apalodimas@linaro.org>
The ESRT is initialised during efi_init_objlist after
efi_initialize_system_table().
The ESRT is recreated from scratch at the following events:
- successful UpdateCapsule;
- FMP instance install.
The code ensures that every ESRT entry has a unique fw_class value.
Limitations:
- The ESRT is not updated if an FMP instance is uninstalled;
- the fields image_type and flags are in the current implementation left
undefined. Setting these values will require a per-platform function
that returns the image_type/flags as a function of the image fw_class.
CC: Heinrich Schuchardt <xypron.glpk@gmx.de>
CC: Sughosh Ganu <sughosh.ganu@linaro.org>
CC: AKASHI Takahiro <takahiro.akashi@linaro.org>
CC: Ilias Apalodimas <ilias.apalodimas@linaro.org>
CC: Andre Przywara <andre.przywara@arm.com>
CC: Alexander Graf <agraf@csgraf.de>
CC: nd@arm.com
Signed-off-by: Jose Marinho <jose.marinho@arm.com>
Remove two EFI_CALL() indirections.
Move ESRT GUID in efidebug's list of GUIDs.
Some ARMv7 boards using PSCI require to be in secure-mode when booted via
'bootz' or 'bootm'. During distro-boot 'bootefi bootmgr' is called to check
if booting via UEFI is possible.
With the change we change the switch from secure mode to non-secure mode is
moved from the UEFI subsystem setup to just before calling StartImage().
Cc: Jernej Škrabec <jernej.skrabec@gmail.com>
Reported by: Andre Przywara <andre.przywara@arm.com>
Up to now we install the EFI_LOAD_FILE2_PROTOCOL to load an initrd
unconditionally. Although we correctly return various EFI exit codes
depending on the file status (i.e EFI_NO_MEDIA, EFI_NOT_FOUND etc), the
kernel loader only falls back to the cmdline interpreted initrd if the
protocol is not installed.
This creates a problem for EFI installers, since they won't be able to
load their own initrd and start the installation.
A following patch introduces a different logic where we search for an
initrd path defined in an EFI variable named 'Initrd####'.
If the bootmgr is used to launch the EFI payload, we'll will try to match
the BootCurrent value and find the corresponding initrd
(i.e Boot0000 -> Initrd0000 etc). If the file is found, we'll install
the required protocol which the kernel's efi-stub can use and load our
initrd.
A capsule tagged with the guid, EFI_FIRMWARE_MANAGEMENT_CAPSULE_ID_GUID,
is handled as a firmware update object.
What efi_update_capsule() basically does is to load any firmware management
protocol (or fmp) drivers contained in a capsule, find out an appropriate
fmp driver and then invoke its set_image() interface against each binary
in a capsule.
In this commit, however, loading drivers is not supported.
The result of applying a capsule is set to be stored in "CapsuleXXXX"
variable, but its implementation is deferred to a fmp driver.
Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
Capsule data can be loaded into the system either via UpdateCapsule
runtime service or files on a file system (of boot device).
The latter case is called "capsules on disk", and actual updates will
take place at the next boot time.
In this commit, we will support capsule on disk mechanism.
Please note that U-Boot itself has no notion of "boot device" and
all the capsule files to be executed will be detected only if they
are located in a specific directory, \EFI\UpdateCapsule, on a device
that is identified as a boot device by "BootXXXX" variables.
In this commit, skeleton functions for capsule-related API's are
added under CONFIG_EFI_UPDATE_CAPSULE configuration.
Detailed implementation for a specific capsule type will be added
in the succeeding patches.
In the previous patches we only introduced a minimal subset of the
EFI_TCG2_PROTOCOL protocol implementing GetCapability().
So let's continue adding features to it, introducing the
GetEventLog() and HashLogExtendEvent() functions.
In order to do that we first need to construct the eventlog in memory,
specifically in EFI_BOOT_SERVICES_DATA memory and a configuration table
from EFI_ACPI_MEMORY_NVS.
U-Boot won't currently add any events to the log or measure any
components, but will expose the necessary EFI APIs for applications
to do so.
Since U-boot EFI implementation is getting richer it makes sense to
add support for EFI_TCG2_PROTOCOL taking advantage of any hardware TPM
available on the device.
This is the initial implementation of the protocol which only adds
support for GetCapability(). It's limited in the newer and safer
TPMv2 devices.
Acked-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
Having an EFI_RNG_PROTOCOL without a backing RNG device leads to failure
to boot Linux 5.8.
Only install the EFI_RNG_PROTOCOL if we have a RNG device.
Reported-by: Scott K Logan <logans@cottsay.net>
Cc: Neil Armstrong <narmstrong@baylibre.com>
Cc: Ard Biesheuvel <ardb@kernel.org>
UEFI variables OsIndicationsSupported, PlatformLangCodes should be read
only.
Avoid EFI_CALL() for SetVariable().
Export the UEFI sub-system initialization state. This will allow to treat
the setting of UEFI variables during and after initialization differently.
The simplest solution to revert the commit b32ac16f9a32 ("test/py: fix
test_efi_secboot/conftest.py") is to move efi_console_register()
forward before efi_disk_register().
Reviewed by: Heinrich Schuchardt <xypron.glpk@gmx.de>
With commit 16ad946f41d3 ("efi_loader: change setup sequence") the
detection of block device was moved to the start of the initialization
sequence. In the case of virtio devices two handles with the same device
path being created.
The root node handle should be created before anything else.
Reported-by: Ard Biesheuvel <ardb@kernel.org>
Fixes: 16ad946f41d3 ("efi_loader: change setup sequence")
If we want to restore variables from disk, we need to initialize block
devices before variables.
EFI_STATUS is unsigned (UINTN). Hence it cannot be negative.
Correct comments for 'Return:'.
The following variable is exported as UEFI specification defines:
SignatureSupport: array of GUIDs representing the type of signatures
supported by the platform firmware
Following kernel's proposal for an arch-agnostic initrd loading
mechanism [1] let's implement the U-boot counterpart.
This new approach has a number of advantages compared to what we did up
to now. The file is loaded into memory only when requested limiting the
area of TOCTOU attacks. Users will be allowed to place the initramfs
file on any u-boot accessible partition instead of just the ESP one.
Finally this is an attempt of a generic interface across architectures
in the linux kernel so it makes sense to support that.
The file location is intentionally only supported as a config option
argument(CONFIG_EFI_INITRD_FILESPEC), in an effort to enhance security.
Although U-boot is not responsible for verifying the integrity of the
initramfs, we can enhance the offered security by only accepting a
built-in option, which will be naturally verified by UEFI Secure Boot.
This can easily change in the future if needed and configure that via ENV
or UEFI variable.
[1] https://lore.kernel.org/linux-efi/20200207202637.GA3464906@rani.riverdale.lan/T/#m4a25eb33112fab7a22faa0fd65d4d663209af32f
UEFI spec 2.8 errata A replaces the RuntimeServicesSupported variable
defined in UEFI spec 2.8 by the configuration table
EFI_RT_PROPERTIES_TABLE. So let's follow suit.
Tested-by: Ard Biesheuvel <ardb@kernel.org>
Provide an initialization routine for variable services.
This variable is defined in UEFI specification 2.8, section 8.1.
Its value should be updated whenever we add any usable runtime services
function.
Currently we only support SetVirtualAddress() for all systems and
ResetSystem() for some.
allow_unaligned(), switch_to_non_secure_mode(), and efi_init_obj_list() are
called in sequence in multiple places.
Move calls to allow_unaligned() and switch_to_non_secure_mode() to
efi_init_obj_list().
Remove unused includes.
UEFI variables should be installed using well-defined API.
Currently we don't support much, but the value of OsIndicationsSupported
will be updated once some features are added in the future.
Add comments. Rename a variable.
The UEFI variables PlatformLang and PlatformLangCodes specify the current
firmware language and the list of all available languages.
Currently their values are hard coded. With the patch a new configuration
variable EFI_PLATFORM_LANG_CODES is provided.
When initializing the UEFI subsystem this configuration variable is used to
initialize PlatformLangCodes. The value of variable PlatformLang is read.
If it is not set, the first language specified in EFI_PLATFORM_LANG_CODES
is used to initialize PlatformLang.
Suggested-by: Takahiro Akashi <takahiro.akashi@linaro.org>
The first functions of the UEFI sub-system are invoked before reaching the
U-Boot shell, e.g. efi_set_bootdev(), efi_dp_from_name(),
efi_dp_from_file(). We should be able to print out device paths for
debugging purposes here.
When printing device paths via printf("%pD\n", dp) this invokes functions
defined as EFIAPI. So efi_save_gd() must be called beforehand.
So let's move the efi_save_gd() call to function initr_reloc_global_data(()
in board_r.c.
Since TianoCore EDK2 commit d65f2cea36d1 ("ShellPkg/CommandLib: Locate
proper UnicodeCollation instance") in edk2 the UEFI Shell crashes if EFI
variable PlatformLang is not defined.
As this variable is anyway prescribed in the UEFI 2.7 spec let's define it
to L"en-US". Use the same value for PlatformLangCodes that defines the list
of all supported languages.
The function, efi_init_obj_list(), can be shared in different pseudo efi
applications, like bootefi/bootmgr as well as my efishell. Moreover, it
will be utilized to extend efi initialization, for example, my "removable
disk support" patch and "capsule-on-disk support" patch in the future.
So with this patch, it will be moved to a new file, efi_setup.c, under
lib/efi_loader and exported, making no changes in functionality.
Remove lines deactivated by #if 1 #else
