path: root/lib/efi_loader/efi_device_path.c
2019-08-30efi_loader: efi_dp_from_file() expect UTF-8 pathHeinrich Schuchardt
Properly convert UTF-8 file names to UTF-16. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-04-23efi_loader: check length in CreateDeviceNode()Heinrich Schuchardt
When creating a device path node ensure that the size of the allocated memory at lest matches the size of the node header. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-04-23efi_loader: efi_setup_loaded_image() handle missing file nameAKASHI Takahiro
This is a preparatory patch. efi_dp_split_file_path() is used to create device_path and file_path from file_path for efi_setup_loaded_image(). In a special case, however, of HARDWARE_DEVICE/MEMORY, it doesn't work expectedly since this path doesn't contain any FILE_PATH sub-type. This patch makes a workaround. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Adjust the logic such that for all paths that do no end on a media file path we return NULL as file_path. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-04-12efi_loader: add protection for block_devPatrick Delaunay
Check the value of block_dev before to use this pointer. This patch solves problem for the command "load" when ubifs is previously mounted: in this case the function blk_get_device_part_str("ubi 0") don't return error but return block_dev = NULL and then data abort. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-04-12efi_loader: remove stray #define LOG_CATEGORY LOGL_ERRHeinrich Schuchardt
The statement '#define LOG_CATEGORY LOGL_ERR' makes not sense. LOGL_ERR is not a LOG_CATEGORY. Remove the statement. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-03-02efi_loader: do not add \ in efi_fs_from_name()Heinrich Schuchardt
In the `efidebug boot add` command we do not want an unsolicited leading backslash added to the file name. There is no good reason to mark a loaded file with a backslash as absolute. Anyway when reading files the file name will be interpreted as relative to root directory of the device. So let's get rid of this backslash. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-02-16efi_loader: efi_dp_split_file_path() error handlingHeinrich Schuchardt
If the path passed to efi_dp_split_file_path() does not contain a reference to a file it returns EFI_OUT_OF_RESOURCES. This does not properly indicate the kind of the problem that occurred. Return EFI_INVALID_PARAMETER instead. Update function description. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2018-12-03efi_loader: allow device == NULL in efi_dp_from_name()AKASHI Takahiro
This is a preparatory patch for use in efi_serialize_load_option() as a load option's file_path should have both a device path and a file path. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-12-02efi_loader: fix typos in efi_device_path.cHeinrich Schuchardt
Fix some typos in comments. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-12-02efi_loader: add efi_dp_from_name()AKASHI Takahiro
Factor out efi_set_bootdev() and extract efi_dp_from_name(). This function will be used to set a boot device in efishell command. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-12-02efi_loader: eliminate handle memberHeinrich Schuchardt
A pointer to a struct efi_object is a handle. We do not need any handle member in this structure. Let's eliminate it. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-10-16efi_loader: efi_dp_get_next_instance() superfluous statementHeinrich Schuchardt
Remove a superfluous statement in efi_dp_get_next_instance(). Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-09-23efi_loader: create root nodeHeinrich Schuchardt
Currently we assign a lot of protocols to loaded images though these protocols are not related to them. Instead they should be installed on a separate handle. Via the device path it is the parent to the devices like the network adapter. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-09-10Remove <inttypes.h> includes and PRI* usages in printf() entirelyMasahiro Yamada
In int-ll64.h, we always use the following typedefs: typedef unsigned int u32; typedef unsigned long uintptr_t; typedef unsigned long long u64; This does not need to match to the compiler's <inttypes.h>. Do not include it. The use of PRI* makes the code super-ugly. You can simply use "l" for printing uintptr_t, "ll" for u64, and no modifier for u32. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-04-23efi_loader: complete EFI_DEVICE_PATH_UTILITIES_PROTOCOLHeinrich Schuchardt
The missing services of the EFI_DEVICE_PATH_UTILITIES_PROTOCOL are implemented. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-04-23efi_loader: correcty determine total device path lengthHeinrich Schuchardt
Device paths may consist of multiple instances. Up to now we have only considered the size of the first instance. For the services of the EFI_DEVICE_PATH_UTILITIES_PROTOCOL in most cases the total length of the device path is relevant. So let's rename efi_dp_size() to efi_dp_instance_size() and create a new function efi_dp_size() that calculates the total device path length. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-04-23efi_loader: correctly determine length of empty device pathHeinrich Schuchardt
efi_dp_size() is meant to return the device path length without the end node. The length of a device path containing only an end node was incorrectly reported as 4. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-04-23efi_loader: fix AppendDevicePathHeinrich Schuchardt
The logic of the AppendDevicePath service of the EFI_DEVICE_PATH_UTILITIES_PROTOCOL is incorrectly implemented: * if both paths are NULL an end node has to be returned * if both paths are not NULL the end node of the second device path has to be kept Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-04-23efi_loader: implement CreateDeviceNodeHeinrich Schuchardt
Implement the CreateDeviceNode service of the device path utility protocol. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-04-13Revert "Kconfig: cmd: Make networking command dependent on NET"Joe Hershberger
This reverts the parts of commit 3b3ea2c56ec4bc5588281fd103c744e608f8b25c where it changed the EFI dependency on NET. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Duncan Hare <dh@synoia.com>
2018-04-04efi_loader: initialize device path on allocPatrick Wildt
Since the backing memory for a new device path can contain stale data we have to make sure that we zero the buffer. Otherwise some code paths that don't set all fields in a structure backed by this device path might contain unwanted stale data. Signed-off-by: Patrick Wildt <patrick@blueri.se> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-04-04efi_loader: Fix network DP with DM_ETHAlexander Graf
When CONFIG_DM_ETH is set, we assemble the device path properly with a full device hierarchy. Our helper function dp_fill() even put the MAC node itself in it for us. However, for non-DM compatibility we also have code in that added the MAC node manually. That code now runs on top of the existing MAC node: Handle 0x3db2f6b0 /HardwareVendor(e61d73b9-a384-4acc-aeab-82e828f3628b)[0: ] /USBClass(0,0,9,0,0)/USBClass(424,9514,9,0,2)/MacAddr(b8:27:eb:e1:81:47,1) /MacAddr(b8:27:eb:e1:81:47,57)/EndEntire We obviously don't need the additional node and in fact, grub chokes on it and fails to match the DP against the ethernet device node. So this patch moves the additional MAC node into the non-DM code path: Handle 0x3db3fde0 /HardwareVendor(e61d73b9-a384-4acc-aeab-82e828f3628b)[0: ] /USBClass(0,0,9,0,0)/USBClass(424,9514,9,0,2)/MacAddr(b8:27:eb:e1:81:47,1) /EndEntire While at it, we also mark the non-DM MAC node as ethernet. Fixes: b66c60dde9d ("efi_loader: add device-path utils") Signed-off-by: Alexander Graf <agraf@suse.de>
2018-02-27Kconfig: cmd: Make networking command dependent on NETMichal Simek
Enable networking command only when NET is enabled. And remove selecting NET for CMD_NET Signed-off-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2018-01-22efi_loader: allow creation of more device part nodesHeinrich Schuchardt
Create device path nodes for UCLASS_ETH udevices. Create device path nodes of block device children of UCLASS_MMC udevices. Consistently use debug for unsupported nodes. Set the log level to error. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> [agraf: Fix build failure by adding #ifdef CONFIG_DM_ETH] Signed-off-by: Alexander Graf <agraf@suse.de>
2018-01-22efi_loader: provide function to get last node of a device pathHeinrich Schuchardt
On a block device and its partitions the same protocols can be installed. To tell the apart we can use the type of the last node of the device path which is not the end node. The patch provides a utility function to find this last node. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-01-22efi_loader: provide a function to create a partition nodeHeinrich Schuchardt
Provide new function efi_dp_part_node() to create a device node for a partition. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-01-22efi_loader: return NULL from device path functionsHeinrich Schuchardt
For the construction of device paths we need to call the AllocatePool service. We should not ignore if it fails due to an out of memory situation. This patch changes the device path functions to return NULL if the memory allocation fails. Additional patches will be needed to fix the callers. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-01-22efi_loader: support device path for IDE and SCSI disksHeinrich Schuchardt
Correctly create the device path for IDE and SCSI disks. Support for SATA remains to be done in a future patch. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-01-22efi_loader: create full device path for block devicesHeinrich Schuchardt
When creating the device path of a block device it has to comprise the block device itself and should not end at its parent. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2017-12-16efi_loader: comments for dp_part_fill()Heinrich Schuchardt
Add a description for dp_part_fill(). Reword a comment in the function. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2017-12-16efi_loader: correctly setup device paths for block devicesHeinrich Schuchardt
According to the UEFI spec the numbering of partitions has to start with 1. Partion number 0 is reserved for the optional device path for the complete block device. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2017-12-16efi_loader: correctly determine if an MMC device is an SD-cardHeinrich Schuchardt
The SD cards and eMMC devices have different device nodes. The current coding interpretes all MMC devices as eMMC. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2017-12-16efi_loader: Ensure efi_dp_find_obj() finds exact matchesAlexander Graf
When calling efi_dp_find_obj(), we usually want to find the *exact* match of an object for a given device path. However, I ran into a nasty corner case where I had the following objects with paths available: Handle 0x9feffa70 /HardwareVendor(e61d73b9-a384-4acc-aeab-82e828f3628b)[0: ]/USB(6,0)/EndEntire Handle 0x9feffb58 /HardwareVendor(e61d73b9-a384-4acc-aeab-82e828f3628b)[0: ]/USB(6,0)/HD(1,800,32000,2de808cb00000000,1,1)/EndEntire and was searching for /HardwareVendor(e61d73b9-a384-4acc-aeab-82e828f3628b)[0: ]/USB(6,0)/HD(1,800,32000,2de808cb00000000,1,1)/EndEntire But because our device path search looked for any substring match, it would return /HardwareVendor(e61d73b9-a384-4acc-aeab-82e828f3628b)[0: ]/USB(6,0)/EndEntire because that path is a full substring of the path we were searching for. So this patch adapts the device path search logic to always look for exact matches first. The way we distinguish between those cases is by looking at whether our caller actually deals with remainders. As a side effect, the code as is from all I can tell now never does a substring match anymore, because it always gets called with rem=NULL, so we always only do exact matches now. Reported-by: Jonathan Gray <jsg@jsg.id.au> Signed-off-by: Alexander Graf <agraf@suse.de>
2017-12-01efi_loader: simplify find_objHeinrich Schuchardt
Use function efi_search_protocol(). Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2017-12-01efi_loader: initialise partition_signature memoryJonathan Gray
Zero partition_signature in the efi_device_path_hard_drive_path structure when signature_type is 0 (no signature) as required by the UEFI specification. This is required so that efi_dp_match() will work as expected when doing memcmp() comparisons. Previously uninitialised memory would cause it not match nodes when it should have when the signature type was not GUID. Corrects a problem where the loaded image protocol would not return a device path with MEDIA_DEVICE causing the OpenBSD bootloader to fail on rpi_3 and other targets. v2: Also handle signature_type 1 (MBR) as described in the specification Signed-off-by: Jonathan Gray <jsg@jsg.id.au> Tested-by: Artturi Alm <artturi.alm@gmail.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2017-12-01efi_loader: efi_dp_match should have const argumentsHeinrich Schuchardt
efi_dp_match does not change its arguments. So they should be marked as const. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2017-10-12efi_loader: Add mem-mapped for fallbackRob Clark
When we don't have a real device/image path, such as 'bootefi hello', construct a mem-mapped device-path. This fixes 'bootefi hello' after devicepath refactoring. Fixes: 95c5553ea2 ("efi_loader: refactor boot device and loaded_image handling") Signed-off-by: Rob Clark <robdclark@gmail.com> Acked-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2017-09-20efi_loader: add device-path utilsRob Clark
Helpers to construct device-paths from devices, partitions, files, and for parsing and manipulating device-paths. For non-legacy devices, this will use u-boot's device-model to construct device-paths which include bus hierarchy to construct device-paths. For legacy devices we still fake it, but slightly more convincingly. Signed-off-by: Rob Clark <robdclark@gmail.com> Signed-off-by: Alexander Graf <agraf@suse.de>
