path: root/lib/efi
2022-10-31Rename CONFIG_SYS_TEXT_BASE to CONFIG_TEXT_BASESimon Glass
The current name is inconsistent with SPL which uses CONFIG_SPL_TEXT_BASE and this makes it imposible to use CONFIG_VAL(). Rename it to resolve this problem. Signed-off-by: Simon Glass <sjg@chromium.org>
2022-05-03lib: fix selection of CONFIG_CHARSETHeinrich Schuchardt
lib/charset.c is not optional for EFI_APP || EFI_LOADER || UFS || UT_UNICODE. These must select CONFIG_CHARSET. Fixes: 726cd9836db0 ("efi: Make unicode printf available to the app") Signed-off-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
2022-04-29efi: fix devpath_is_partition()Heinrich Schuchardt
If the path consists only of an end node, it does not refer to a partition. Avoid returning a random value from the stack in this case. Signed-off-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
2022-01-19doc: replace @return by Return:Heinrich Schuchardt
Sphinx expects Return: and not @return to indicate a return value. find . -name '*.c' -exec \ sed -i 's/^\(\s\)\*\(\s*\)@return\(\s\)/\1*\2Return:\3/' {} \; find . -name '*.h' -exec \ sed -i 's/^\(\s\)\*\(\s*\)@return\(\s\)/\1*\2Return:\3/' {} \; Signed-off-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
2022-01-15efi: Support the efi command in the appSimon Glass
At present the 'efi' command only works in the EFI payload. Update it to work in the app too, so the memory map can be examined. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
2022-01-15efi: Move exit_boot_services into a functionSimon Glass
At present this code is inline in the app and stub. But they do the same thing. The difference is that the stub does it immediately and the app doesn't want to do it until the end (when it boots a kernel) or not at all, if returning to UEFI. Move it into a function so it can be called as needed. Add a comment showing how to store the memory map so that it can be accessed within the app if needed, for debugging purposes only. The map can change without notice. Signed-off-by: Simon Glass <sjg@chromium.org>
2021-12-31efi: Show when allocated pages are usedSimon Glass
Add a message here so that both paths of memory allocation are reported. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
2021-12-31efi: Check for failure when initing the appSimon Glass
The stub checks for failure with efi_init(). Add this for the app as well. It is unlikely that anything can be done, but we may as well stop. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
2021-12-31efi: Share struct efi_priv between the app and stub codeSimon Glass
At present each of these has its own static variable and helper functions. Move them into a shared file. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
2021-12-31efi: Add a few comments to the stubSimon Glass
Comment some functions that need more information. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
2021-12-31efi: Locate all block devices in the appSimon Glass
When starting the app, locate all block devices and make them available to U-Boot. This allows listing partitions and accessing files in filesystems. EFI also has the concept of 'disks', meaning boot media. For now, this is not obviously useful in U-Boot, but add code to at least locate these. This can be expanded later as needed. We cannot use printf() in the early stub or app since it is not compiled in Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
2021-11-07efi: Add a way to obtain boot services in the appSimon Glass
Add a function to return this information along with a stub for the efi_info_get() function, since calling it otherwise hangs U-Boot. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2021-11-07x86: Don't duplicate global_ptr in 64-bit EFI appSimon Glass
This variable is already defined by the EFI code. Drop the duplicate definition when building a 64-bit EFI app. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2021-11-07x86: Create a 32/64-bit selection for the appSimon Glass
Most EFI implementations use 64-bit but U-Boot only supports running as a 32-bit app at present. While efi-x86_payload64 does boot from 64-bit UEFI it immediately changes back to 32-bit before starting U-Boot. In order to support a 64-bit U-Boot app, update the Kconfig to add an option for 32/64 bit. Update the prompt for the existing option so it is clear it relates to the stub. Move both up to just under the choice that controls them, since this looks better and the menu. Use CONFIG_EFI_APP in the Makefile instead of CONFIG_TARGET_EFI_APP, since the latter is specific to a single target and we will have two. Memory size is set to 32MB for now so that it can run on qemu without increasing the default memory size. We may need to increase the default later. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2021-02-02common: Drop asm/global_data.h from common headerSimon Glass
Move this out of the common header and include it only where needed. In a number of cases this requires adding "struct udevice;" to avoid adding another large header or in other cases replacing / adding missing header files that had been pulled in, very indirectly. Finally, we have a few cases where we did not need to include <asm/global_data.h> at all, so remove that include. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2021-01-05serial: Update NS16550_t and struct NS16550Simon Glass
Typedefs should not be used in U-Boot and structs should be lower case. Update the code to use struct ns16550 consistently. Put a header guard on the file while we are here. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
2020-05-18common: Drop init.h from common headerSimon Glass
Move this uncommon header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-02-05dm: core: Create a new header file for 'compat' featuresSimon Glass
At present dm/device.h includes the linux-compatible features. This requires including linux/compat.h which in turn includes a lot of headers. One of these is malloc.h which we thus end up including in every file in U-Boot. Apart from the inefficiency of this, it is problematic for sandbox which needs to use the system malloc() in some files. Move the compatibility features into a separate header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-01-17common: Move reset_cpu() to the CPU headerSimon Glass
Move this function out of common.h and into a relevant header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-12-15x86: timer: use a timer base of 0Simon Glass
On x86 platforms the timer is reset to 0 when the SoC is reset. Having this as the timer base is useful since it provides an indication of how long it takes before U-Boot is running. When U-Boot sets the timer base to something else, time is lost and we no-longer have an accurate account of the time since reset. This particularly affects bootstage. Change the default to not read the timer base, leaving it at 0. Add an option for when U-Boot is the secondary bootloader. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-04-23efi_loader: consistent naming of protocol GUIDsHeinrich Schuchardt
We should consistently use the same name for protocol GUIDs as defined in the UEFI specification. Not adhering to this rule has led to duplicate definitions for the EFI_LOADED_IMAGE_PROTOCOL_GUID. Adjust misnamed protocol GUIDs. Adjust the text for the graphics output protocol in the output of the `efidebug dh` command. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2018-12-02efi_loader: typedef struct efi_object *efi_handle_tHeinrich Schuchardt
All our handles point to a struct efi_object. So let's define the efi_handle_t accordingly. This helps us to discover coding errors much more easily. This becomes evident by the corrections to the usage of handles in this patch. Rename variable image_handle to image_obj where applicable. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-11-14sysreset: Remove DM_FLAG_PRE_RELOC flag in various driversBin Meng
When a driver declares DM_FLAG_PRE_RELOC flag, it wishes to be bound before relocation. However due to a bug in the DM core, the flag only takes effect when devices are statically declared via U_BOOT_DEVICE(). This bug has been fixed recently by commit "dm: core: Respect drivers with the DM_FLAG_PRE_RELOC flag in lists_bind_fdt()", but with the fix, it has a side effect that all existing drivers that declared DM_FLAG_PRE_RELOC flag will be bound before relocation now. This may expose potential boot failure on some boards due to insufficient memory during the pre-relocation stage. To mitigate this potential impact, the following changes are implemented: - Remove DM_FLAG_PRE_RELOC flag in the driver, if the driver only supports configuration from device tree (OF_CONTROL) - Keep DM_FLAG_PRE_RELOC flag in the driver only if the device is statically declared via U_BOOT_DEVICE() - Surround DM_FLAG_PRE_RELOC flag with OF_CONTROL check, for drivers that support both statically declared devices and configuration from device tree Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-08-30efi: stub: Pass EFI system table address to U-Boot payloadBin Meng
This updates the EFI stub codes to pass UEFI BIOS's system table address to U-Boot payload so that U-Boot can utilize it. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-07-20efi: app: Add a sysreset driverBin Meng
This adds the DM sysreset driver for EFI application support. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-06-24efi: stub: Move the use_uart assignment immediately after ↵Bin Meng
exit_boot_services() call The use_uart assignment should follow immediately after the call to exit_boot_services(), in case we want some debug output after that. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-06-24efi.h: Do not use config optionsAlexander Graf
Currently efi.h determines a few bits of its environment according to config options. This falls apart with the efi stub support which may result in efi.h getting pulled into the stub as well as real U-Boot code. In that case, one may be 32bit while the other one is 64bit. This patch changes the conditionals to use compiler provided defines instead. That way we always adhere to the build environment we're in and the definitions adjust automatically. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com> [bmeng: added some comments to describe the __x86_64__ check] Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-06-17efi: stub: Pass EFI GOP information to U-Boot payloadBin Meng
If UEFI BIOS has the graphics output protocol (GOP), let's pass its information to U-Boot payload so that U-Boot can utilize it (eg: an EFI framebuffer driver). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-06-17x86: use EFI calling convention for efi_main on x86_64Ivan Gorinov
UEFI specifies the calling convention used in Microsoft compilers; first arguments of a function are passed in (%rcx, %rdx, %r8, %r9). All other compilers use System V ABI by default, passing first integer arguments of a function in (%rdi, %rsi, %rdx, %rcx, %r8, %r9). These ABI also specify different sets of registers that must be preserved across function calls (callee-saved). GCC allows using the Microsoft calling convention by adding the ms_abi attribute to a function declaration. Current EFI implementation in U-Boot specifies EFIAPI for efi_main() in the test apps but uses default calling convention in lib/efi. Save efi_main() arguments in the startup code on x86_64; use EFI calling convention for _relocate() on x86_64; consistently use EFI calling convention for efi_main() everywhere. Signed-off-by: Ivan Gorinov <ivan.gorinov@intel.com> Reviewed-by: Alexander Graf <agraf@suse.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2018-06-13x86: efi: payload: Minor clean up on error message outputBin Meng
If GetMemoryMap() fails, we really want to know EFI_BITS_PER_LONG instead of BITS_PER_LONG. A space and LF are added in places where error message is output to improve readability. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-06-13x86: efi: payload: Enforce toolchain to generate 64-bit EFI payload stub codesBin Meng
Attempting to use a toolchain that is preconfigured to generate code for the 32-bit architecture (i386), for example, the i386-linux-gcc toolchain on kernel.org, to compile the 64-bit EFI payload does not build. This updates the makefile fragments to ensure '-m64' is passed to toolchain when building the 64-bit EFI payload stub codes. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-04-27Remove unnecessary instances of DECLARE_GLOBAL_DATA_PTRTom Rini
We have a large number of places where while we historically referenced gd in the code we no longer do, as well as cases where the code added that line "just in case" during development and never dropped it. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-03-30efi_stub: Fix GDT_NOTSYS checkAlexander Graf
The get_codeseg32() wants to know if a passed in descriptor has flag GDT_NOTSYS set (desc & GDT_NOTSYS), not whether desc and GDT_NOTSYS are not != 0 (desk && GDT_NOTSYS). This is an obvious typo. Fix it up. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-12-05efi_stub: Use efi_uintn_tAlexander Graf
Commit f5a2a93892f ("efi_loader: consistently use efi_uintn_t in boot services") changed the internal EFI API header without adapting its existing EFI stub users. Let's adapt the EFI stub as well. Fixes: f5a2a93892f ("efi_loader: consistently use efi_uintn_t in boot services") Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2017-07-27spl: make SPL and normal u-boot stage use independent SYS_MALLOC_F_LENAndy Yan
Some platforms have very limited SRAM to run SPL code, so there may not be the same amount space for a malloc pool before relocation in the SPL stage as the normal U-Boot stage. Make SPL and (the full) U-Boot stage use independent SYS_MALLOC_F_LEN, so the size of pre-relocation malloc pool can be configured memory space independently. Signed-off-by: Andy Yan <andy.yan@rock-chips.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> [fixed up commit-message:] Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2016-11-14x86: Tidy up selection of building the EFI stubSimon Glass
At present we use a CONFIG option in efi.h to determine whether we are building the EFI stub or not. This means that the same header cannot be used for EFI_LOADER support. The CONFIG option will be enabled for the whole build, even when not building the stub. Use a different define instead, set up just for the files that make up the stub. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2016-08-30x86: efi: payload: Make EFI payload build againBin Meng
Since commit 73c5c39 "Makefile: Drop unnecessary -dtb suffixes", EFI payload does not build anymore. This fixes the build. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-03-27efi_stub: Move carriage return before line feed in putc()Bin Meng
A carriage return needs to execute before a line feed. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-10-21debug_uart: Adjust the declaration of debug_uart_init()Simon Glass
We want to be able to add other common code to this function. So change the driver's version to have an underscore before it, just like _debug_uart_putc(). Define debug_uart_init() to call this version. Update all drivers to this new method. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-05efi: Add functions for decoding the EFI tablesSimon Glass
The EFI stub can pass a table to U-Boot with information about the memory map Potentially other things will follow. Add a way to access this table. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-05efi: Add 64-bit payload supportSimon Glass
Most EFI implementations use 64-bit. Add a way to build U-Boot as a 64-bit EFI payload. The payload unpacks a (32-bit) U-Boot and starts it. This can be enabled for x86 boards at present. Signed-off-by: Simon Glass <sjg@chromium.org> Improvements to how the payload is built: Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-05efi: Add support for loading U-Boot through an EFI stubSimon Glass
It is useful to be able to load U-Boot onto a board even if is it already running EFI. This can allow access to the U-Boot command interface, flexible booting options and easier development. The easiest way to do this is to build U-Boot as a binary blob and have an EFI stub copy it into RAM. Add support for this feature, targeting 32-bit initially. Also add a way to detect when U-Boot has been loaded via a stub. This goes in common.h since it needs to be widely available so that we avoid redoing initialisation that should be skipped. Signed-off-by: Simon Glass <sjg@chromium.org> Improvements to how the payload is built: Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-05efi: Add start-up library codeSimon Glass
When running as an EFI application, U-Boot must request memory from EFI, and provide access to the boot services U-Boot needs. Add library code to perform these tasks. This includes efi_main() which is the entry point from EFI. U-Boot is built as a shared library. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
