Before adding one more function, create a separate header to help reduce
the size of common.h. Add the missing function comments and tidy up.
Use inttypes.h and uint64_t to correct the code so that it will not issue
warnings on 64-bit machines where 'uint64_t' is 'unsigned long'.
Add 64-bit data for memory commands, such as md, mw, mm, cmp. The new
size ".q " is introduced.
For 64-bit architecture, 64-bit data is enabled by default, by detecting
compiler __LP64__. It is optional for other architectures.
Signed-off-by: York Sun <yorksun@freescale.com>
[trini: Fixup common/cmd_io.c]
This patch adds whitespace to the printed hex numbers to have an aligned ASCII
printout at the end of the line.
This changes for example the md output from:
---8<---
OMAP3 Tricorder # md.l $loadaddr 5
82000000: 30200109 20a4028c 90010000 08a00000 .. 0... ........
82000010: 01010000 ....
--->8---
to
---8<---
--->8---
The cost of this is about 72 byte .text increase (tested with at91 build).
The buffer cannot be changed by this function, so change the buffer
pointer to a const. This allows callers with const pointer to use the
function without a cast.
This patch removes the architecture specific implementation of
version_string where possible. Some architectures use a special place
and therefore we provide U_BOOT_VERSION_STRING definition and a common
weak symbol version_string.
CC: Mike Frysinger <vapier@gentoo.org>
CC: Peter Pan <pppeterpppan@gmail.com>
use a union to cause necessary alignment per architecture
Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
Applying a little creative format string allows us to shrink the initial
data read & display loop by only calling printf once. Re-using the local
data buffer to generate the string we want to display then allows us to
output everything with just one printf call instead of multiple calls to
the putc function.
The local stack buffer needs increasing by 1 byte, but the resulting code
shrink and speed up is worth it I think.
Modification of print_size to avoid use of divides and especially
long long divides. Keep the binary scale factor in terms of bit
shifts instead. This should be faster, since the previous code
gave the compiler no clues that the divides where always powers
of two, preventing optimisation.
Signed-off-by: Nick Thompson <nick.thompson@ge.com>
Acked-by: Timur Tabi <timur@freescale.com>
Modify print_size() so that it can accept numbers larger than 4GB on 32-bit
systems.
Add support for display terabyte, petabyte, and exabyte sizes. Change the
output to use International Electrotechnical Commission binary prefix standard.
In print_size(), the math that calculates the fractional remainder of a number
used the same integer size as a physical address. However, the "10 *" factor
of the algorithm means that a large number (e.g. 1.5GB) can overflow the
integer if we're running on a 32-bit system. Therefore, we need to
disassociate this function from the size of a physical address.
Now that the other architecture-specific lib directories have been
moved out of the top-level directory there's not much reason to have the
'_generic' suffix on the common lib directory.
