In the International System of Units (SI) the prefix kilo is abbreviated as
'k' not 'K'. 'K' is the symbol for Kelvin.
This is defined only when __lp64__ is defined. That means that ulong is
64 bits long. Therefore we don't need to use a separate u64 type on those
architectures.
Fix up the code to take advantage of that, removing the preprocessor
conditions.
Also include the missing header file that defines MEM_SUPPORT_64BIT_DATA
Fixes: 09140113108 ("command: Remove the cmd_tbl_t typedef")
Define this macro always so we don't need the preprocessor to check it.
Convert the users to #if instead of #ifdef.
Note that '#if MEM_SUPPORT_64BIT_DATA' does not give an error if the
macro is not define. It just assumes zero.
This displays incorrect data at present due to a missing header file
in display_options. Fix it.
This is not really a CONFIG since it is not intended to be set by boards.
Move it into the compiler header with other similar defines, and rename
it.
We don't have a console in SPL so it doesn't make sense to check for
Ctrl-C when printing a memory dump. Skip this so that print_buffer() can
be used in SPL.
display_options_get_banner_priv() overwrites bytes before the start of the
buffer if the buffer size is less then 3. This case occurs in the Sandbox
when executing the `ut_print` command.
Correctly handle small buffer sizes. Adjust the print unit test to catch
when bytes before the buffer are overwritten.
At present this function uses printf() format strings that are not
supported in SPL, so the output just consists of %llx strings on 64-bit.
machines. Fix this by adding a special case.
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
In int-ll64.h, we always use the following typedefs:
typedef unsigned int u32;
typedef unsigned long uintptr_t;
typedef unsigned long long u64;
This does not need to match to the compiler's <inttypes.h>.
Do not include it.
The use of PRI* makes the code super-ugly. You can simply use
"l" for printing uintptr_t, "ll" for u64, and no modifier for u32.
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
Move the display options code into a separate function so that the U-Boot
banner can be obtained from other code. Adjust the 'version' command to
use it.
Tested-by: Bin Meng <bmeng.cn@gmail.com>
Since common.h will always include this automatically, it is not needed.
The console includes a global variable and several functions that are only
used by a small subset of U-Boot files. Before adding more functions, move
the definitions into their own header file.
Build without CONFIG_SPL_SERIAL_SUPPORT does not print the cpu freq.
I have seen this in the odroid U3 board, where on boot one sees this:
CPU: Exynos4412 @ GHz
instead of:
CPU: Exynos4412 @ 1 GHz
I am assuming that this change was done to get rid of compiler
warnings related to unused variables when building with
CONFIG_SPL_SERIAL_SUPPORT not being defined in an SPL build.
Signed-off-by: Suriyan Ramasami <suriyan.r@gmail.com>
Acked-by: Heiko Schocher <hs@denx.de>
Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
This patch enables building SPL without
CONFIG_SPL_SERIAL_SUPPORT support.
[trini: Ensure we build arch/arm/imx-common on mx28]
This fixes a warning in the print_buffer() function with some toolchains.
Add a function similar to print_size() that works for frequencies. It can
handle from Hz to GHz.
Before adding one more function, create a separate header to help reduce
the size of common.h. Add the missing function comments and tidy up.
Use inttypes.h and uint64_t to correct the code so that it will not issue
warnings on 64-bit machines where 'uint64_t' is 'unsigned long'.
Add 64-bit data for memory commands, such as md, mw, mm, cmp. The new
size ".q " is introduced.
For 64-bit architecture, 64-bit data is enabled by default, by detecting
compiler __LP64__. It is optional for other architectures.
Signed-off-by: York Sun <yorksun@freescale.com>
[trini: Fixup common/cmd_io.c]
This patch adds whitespace to the printed hex numbers to have an aligned ASCII
printout at the end of the line.
This changes for example the md output from:
---8<---
OMAP3 Tricorder # md.l $loadaddr 5
82000000: 30200109 20a4028c 90010000 08a00000 .. 0... ........
82000010: 01010000 ....
--->8---
to
---8<---
--->8---
The cost of this is about 72 byte .text increase (tested with at91 build).
The buffer cannot be changed by this function, so change the buffer
pointer to a const. This allows callers with const pointer to use the
function without a cast.
This patch removes the architecture specific implementation of
version_string where possible. Some architectures use a special place
and therefore we provide U_BOOT_VERSION_STRING definition and a common
weak symbol version_string.
CC: Mike Frysinger <vapier@gentoo.org>
CC: Peter Pan <pppeterpppan@gmail.com>
use a union to cause necessary alignment per architecture
Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
Applying a little creative format string allows us to shrink the initial
data read & display loop by only calling printf once. Re-using the local
data buffer to generate the string we want to display then allows us to
output everything with just one printf call instead of multiple calls to
the putc function.
The local stack buffer needs increasing by 1 byte, but the resulting code
shrink and speed up is worth it I think.
Modification of print_size to avoid use of divides and especially
long long divides. Keep the binary scale factor in terms of bit
shifts instead. This should be faster, since the previous code
gave the compiler no clues that the divides where always powers
of two, preventing optimisation.
Signed-off-by: Nick Thompson <nick.thompson@ge.com>
Acked-by: Timur Tabi <timur@freescale.com>
Modify print_size() so that it can accept numbers larger than 4GB on 32-bit
systems.
Add support for display terabyte, petabyte, and exabyte sizes. Change the
output to use International Electrotechnical Commission binary prefix standard.
In print_size(), the math that calculates the fractional remainder of a number
used the same integer size as a physical address. However, the "10 *" factor
of the algorithm means that a large number (e.g. 1.5GB) can overflow the
integer if we're running on a 32-bit system. Therefore, we need to
disassociate this function from the size of a physical address.
Now that the other architecture-specific lib directories have been
moved out of the top-level directory there's not much reason to have the
'_generic' suffix on the common lib directory.
