path: root/lib/dhry
2020-05-18command: Remove the cmd_tbl_t typedefSimon Glass
We should not use typedefs in U-Boot. They cannot be used as forward declarations which means that header files must include the full header to access them. Drop the typedef and rename the struct to remove the _s suffix which is now not useful. This requires quite a few header-file additions. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-03-17cmd_dhry.c: Use lldiv for vax_mips calculation as wellTom Rini
Since dhry_per_sec is a u64 we must also use lldiv here when working with it. Otherwise: ../lib/dhry/cmd_dhry.c:(.text.do_dhry+0xd8): undefined reference to `__udivdi3' On some platforms. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-03-17dhry: Correct dhrystone calculation for fast machinesSimon Glass
At present samus reports about 5600 DMIPS. With the default iteration count this is OK, but if 10 million runs are performed it overflows. Fix it. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-07-21Add a dhrystone benchmark commandSimon Glass
Drystone provides a convenient sanity check that the CPU is running at full speed. Add this as a command which can be enabled as needed. Note: I investigated using Coremark for this but there was a license agreement and I could not work out if it was GPL-compatible. Signed-off-by: Simon Glass <sjg@chromium.org>
