path: root/lib/at91
2017-09-14lib: at91: Add logo files used via API of DM_VIDEOWenyou Yang
In order to display the company's logo via the API of DM_VIDEO, and add the logo files of both Atmel and Microchip. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com> Reviewed-by: Simon Glass <sjg@chromium.org>
