There is a number of users that use uclass_first_device to access the
first and (assumed) only device in uclass.
Some check the return value of uclass_first_device and also that a
device was returned which is exactly what uclass_first_device_err does.
Some are not checking that a device was returned and can potentially
crash if no device exists in the uclass. Finally there is one that
returns NULL on error either way.
Convert all of these to use uclass_first_device_err instead, the return
value will be removed from uclass_first_device in a later patch.
Signed-off-by: Michal Suchanek <msuchanek@suse.de>
MCFG tables are used on multiple arches. Move to common ACPI lib.
Signed-off-by: Moritz Fischer <moritzf@google.com>
Use sizeof(*mcfg) instead of sizeof(*header)
At present this list is used to collect items within the DSDT and SSDT
tables. It is useful for it to collect the whole tables as well, so there
is a list of what was created and which write created each one.
Refactor the code accordingly.
Move this over to use a writer file, moving the code from the x86
implementation.
There is no need to store a separate variable since we can simply access
the ACPI context.
With this, the original monolithic x86 function for writing ACPI tables
is gone.
Note that QEMU has its own implementation.
Move this over to use a writer function, moving the code from the x86
implementation.
Update this function to the newer style, so we can avoid passing and
returning an address through this function.
Also move this function out of the x86 code so it can be used by other
archs.
Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Move this table over to use a writer function, moving the code from the
x86 implementation.
x86 implementation.
x86 implementation.
Add a pointer to the DSDT in struct acpi_ctx so we can reference it later.
Disable this table for sandbox since we don't actually compile real ASL
code.
x86 implementation.
Use the new ACPI writer to write the base tables at the start of the area,
moving this code from the x86 implementation.
Use the new ACPI writer to write the ACPI tables. At present this is all
done in one monolithic function. Future work will split this out.
Unfortunately the QFW write_acpi_tables() function conflicts with the
'writer' version, so disable that for sandbox.
At present acpi_setup_base_tables() both sets up the ACPI context and
writes out the base tables.
We want to use an ACPI writer to write the base tables, so split this
function into two, with acpi_setup_ctx() doing the context set, and
acpi_setup_base_tables() just doing the base tables.
Disable the writer's write_acpi_tables() function for now, to avoid
build errors. It is enabled in a following patch.
At present we call lots of functions to generate the required ACPI tables.
It would be better to standardise these functions and allow them to be
automatically collected and used when needed.
Add a linker list to handle this.
Rather than keying everything off ACPIGEN, use the main
GENERATE_ACPI_TABLE option to determine whether the core ACPI code
is included. Make sure these option are not enabled in SPL/TPL since we
never generate tables there.
Allow this to be used on any arch. Also convert to using macros so that
we can check the CONFIG option in C code.
Sphinx expects Return: and not @return to indicate a return value.
find . -name '*.c' -exec \
sed -i 's/^\(\s\)\*\(\s*\)@return\(\s\)/\1*\2Return:\3/' {} \;
find . -name '*.h' -exec \
Signed-off-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
OEM_REVISION is 32-bit unsigned number. It should be increased only when
changing software version. Therefore it should not depend on build time.
Change calculation to use U-Boot version numbers and set this revision
to date number.
Prior this change OEM_REVISION was calculated from build date and stored in
the same format.
After this change macro U_BOOT_BUILD_DATE is not used in other files so
remove it from global autogenerated files and also from Makefile.
Signed-off-by: Pali Rohár <pali@kernel.org>
Header file version.h does not use anything from timestamp.h. Including of
timestamp.h has side effect which cause recompiling object file at every
make run because timestamp.h changes at every run.
So remove timestamp.h from version.h and include timestamp.h in files
which needs it.
This change reduce recompilation time of final U-Boot binary when U-Boot
source files were not changed as less source files needs to be recompiled.
[trini: Add in lib/acpi/acpi_table.c and test/dm/acpi.c, rework a few others]
Move this out of the common header and include it only where needed. In
a number of cases this requires adding "struct udevice;" to avoid adding
another large header or in other cases replacing / adding missing header
files that had been pulled in, very indirectly. Finally, we have a few
cases where we did not need to include <asm/global_data.h> at all, so
remove that include.
There is no-longer any need to check if sequence numbers are valid, since
this is ensured by driver model. Drop the unwanted logic.
Try to maintain some consistency between these variables by using _plat as
a suffix for them.
We use 'priv' for private data but often use 'platdata' for platform data.
We can't really use 'pdata' since that is ambiguous (it could mean private
or platform data).
Rename some of the latter variables to end with 'plat' for consistency.
If there is no reset line, this still emits ACPI code for the reset GPIO.
Fix it by updating the check.
At present all tables are placed starting at address f0000 in memory, and
can be up to 64KB in size. If the tables are very large, this may not
provide enough space.
Also if the tables point to other tables (such as console log or a ramoops
area) then we must allocate other memory anyway.
The bloblist is a nice place to put these tables since it is contiguous,
which makes it easy to reserve this memory for linux using the 820 tables.
Add an option to put some of the tables in the bloblist. For SMBIOS and
ACPI, create suitable pointers from the f0000 region to the new location
of the tables.
[bmeng: squashed in http://patchwork.ozlabs.org/project/uboot/patch/
20201105062407.1.I8091ad931cbbb5e3b6f6ababdf3f8d5db0d17bb9@changeid/]
Use the correct name of the ACPI structure being created.
This adds tables relating to P-States and C-States.
ACPI has a number of CPU-related tables. Add utility functions to write
out the basic packages.
Add an implementation of the DBG2 (Debug Port Table 2) ACPI table.
Adjust one of the header includes to be in the correct order, before
adding more.
Note that the DBG2 table is generic but the PCI UART is x86-specific at
present since it assumes an ns16550 UART. It can be generalised later
if necessary.
This function currently accepts the IRQ-polarity type. Fix it to use the
GPIO type instead.
Add a function to generate ACPI code for a _DSM method for a device.
This includes functions for starting and ending each part of the _DSM.
[bmeng: fix the "new blank line at EOF" git warning]
Add functions to support generating ACPI code for condition checks and
return values.
A 'Power Resource for Wake' list the resources a device depends on for
wake. Add a function to generate this.
Allow writing named integers and strings to the generated ACPI code.
Reviewed-by: Wolfgang Wallner <wolfgang.wallner@br-automation.com>
[bmeng: Fix the "new blank line at EOF" warning]
Allow writing an ACPI device to the generated ACPI code.
[bmeng: Fix build failures on Sandbox]
Allow writing out a generic register.
Add a function to write a scope to the generated ACPI code.
For many device types it is possible to figure out the name just by
looking at its uclass or parent. Add a function to handle this, since it
allows us to cover the vast majority of cases automatically.
However it is sometimes impossible to figure out an ACPI name for a device
just by looking at its uclass. For example a touch device may have a
vendor-specific name. Add a new "acpi,name" property to allow a custom
name to be created.
With this new feature we can drop the get_name() methods in the sandbox
I2C and SPI drivers. They were only added for testing purposes. Update the
tests to use the new values.
Add a way for devices to enable and disable themselves using ACPI code
that updates GPIOs. This takes several timing parameters and supports
enable, reset and stop.
Power to some devices is controlled by GPIOs. Add a way to generate ACPI
code to enable and disable a GPIO so that this can be handled within an
ACPI method.
These are used in ACPI to disable power to various pats of the system when
in sleep. Add a way to create a power resource, with the caller finishing
off the details.
Add more functions to handle some miscellaneous ACPI opcodes.
Some drivers in Linux support both device tree and ACPI. U-Boot itself
uses Linux device-tree bindings for its own configuration but does not use
ACPI.
It is convenient to copy these values over to the ACPI DP table for
passing to linux. Add some convenience functions to help with this.
Allowing writing out a reference to a GPIO within the ACPI output. This
can be used by ACPI code to access a GPIO at runtime.
More complex device properties can be provided to drivers via a
device-specific data (_DSD) object.
To create this we need to build it up in a separate data structure and
then generate the ACPI code, due to its recursive nature.
Add an implementation of this.
ACPI supports writing a UUID in a special format. Add a function to handle
this.
ACPI supports storing names which are made up of multiple path components.
Several special cases are supported. Add a function to emit a name.
ACPI supports storing a simple null-terminated string. Add support for
this.
ACPI supports storing integers in various ways. Add a function to handle
this.
A package collects together several elements. Add an easy way of writing
a package header and updating its length later.
