path: root/lib/Makefile
2022-04-06MLK-18591-4 android: iot: Import ql-tipc lib for Trusty OSHaoran.Wang
The lib provided ql-tipc communication channel with Trusty OS. Also the AVB, Keymaster, hwcrypto and SecureStorage service tipc client implement in this lib. Change-Id: I0ab1ec9ee1b6f272b960c2e944008283c2c9249a Signed-off-by: Haoran.Wang <elven.wang@nxp.com> (cherry picked from commit 8fb370dd80fbb293b58115d2e7fc4970813773c7) (cherry picked from commit 0ccdd527a794c2b450658980361a7857ce7495c9) (cherry picked from commit ffca28682c5a9375c29b3036a156aff190341960) (cherry picked from commit de2d7e7bff9fe8fd8e9d3cc9cb0022cc1f70ac70) (cherry picked from commit eda2e7fe38b6dc977e102871b3e08e5a07cc7d9d) (cherry picked from commit 2688e5fa5bb98fede641c895569acc52c2117847)
2022-04-06MLK-18591-1 android: Add the AVB libraryYe Li
Porting the android AVB lib from imx u-boot v2018.03. Since 2019 u-boot has added latest AVB library, try to reuse it. Signed-off-by: Ye Li <ye.li@nxp.com> (cherry picked from commit 2105662ada738a271e12a81d775134a5821dc38f) (cherry picked from commit f7291d86c4183ce2e299ad271aa5618c71507ffc) (cherry picked from commit b871714c519e1bda3de6afbd354bee2cb246e4b7) (cherry picked from commit 64520f3e5f495ecce79177fba11e3d41299529b2) (cherry picked from commit 076fe5bc4d29deaf6d008e579b5cfe7408bc4525) (cherry picked from commit 5c5c11b5eb2f185aeb6ae432520093b0ef684b26) (cherry picked from commit 6afb9ebcce19079981344822211b3b8c4bfce635)
2022-01-27Merge tag 'dm-pull-26jan22' of ↵Tom Rini
https://source.denx.de/u-boot/custodians/u-boot-dm acpi refactoring to allow non-x86 use binman support for bintools (binary tools) minor tools improvements in preparation for FDT signing various minor fixes and improvements
2022-01-26lib/circbuf: Make circbuf selectable symbolLoic Poulain
It is currenly only used from usbtty driver but make it properly selectable via Kconfig symbol, for future usage. Signed-off-by: Loic Poulain <loic.poulain@linaro.org>
2022-01-25acpi: Use finer-grained control of ACPI-table generationSimon Glass
Rather than keying everything off ACPIGEN, use the main GENERATE_ACPI_TABLE option to determine whether the core ACPI code is included. Make sure these option are not enabled in SPL/TPL since we never generate tables there. Signed-off-by: Simon Glass <sjg@chromium.org>
2022-01-18lib: add BLAKE2 hash supportQu Wenruo
The code is cross-ported from BLAKE2 reference implementation (https://github.com/BLAKE2/BLAKE2). With minimal change to remove unused macros/features. Currently there is only one user inside U-boot (btrfs), and since it only utilize BLAKE2B, all other favors are all removed. Signed-off-by: Qu Wenruo <wqu@suse.com> [trini: Rename ROUND to R to avoid clash with <linux/bitops.h> Signed-off-by: Tom Rini <trini@konsulko.com>
2021-10-08image: Use the correct checks for CRC32Simon Glass
Add a host Kconfig for CRC32. With this we can use CONFIG_IS_ENABLED(CRC32) directly in the host build, so drop the unnecessary indirection. Add a few more conditions to SPL_CRC32 to avoid build failures as well as TPL_CRC32. Also update hash.c to make crc32 optional and to actually take notice of SPL_CRC32. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Alexandru Gagniuc <mr.nuke.me@gmail.com>
2021-10-08Add support for an owned bufferSimon Glass
When passing a data buffer back from a function, it is not always clear who owns the buffer, i.e. who is responsible for freeing the memory used. An example of this is where multiple files are decompressed from the firmware image, using a temporary buffer for reading (since the compressed data has to live somewhere) and producing a temporary or permanent buffer with the resuilts. Where the firmware image can be memory-mapped, as on x86, the compressed data does not need to be buffered, but the complexity of having a buffer which is either allocated or not, makes the code hard to understand. Introduce a new 'abuf' which supports simple buffer operations: - encapsulating a buffer and its size - either allocated with malloc() or not - able to be reliably freed if necessary - able to be converted to an allocated buffer if needed This simple API makes it easier to deal with allocated and memory-mapped buffers. Signed-off-by: Simon Glass <sjg@chromium.org>
2021-10-05lib: optee: remove the duplicate CONFIG_OPTEEPatrick Delaunay
The configuration CONFIG_OPTEE is defined 2 times: 1- in lib/optee/Kconfig for support of OPTEE images loaded by bootm command 2- in drivers/tee/optee/Kconfig for support of OP-TEE driver. It is abnormal to have the same CONFIG define for 2 purpose; and it is difficult to managed correctly their dependencies. Moreover CONFIG_SPL_OPTEE is defined in common/spl/Kconfig to manage OPTEE image load in SPL. This definition causes an issue with the macro CONFIG_IS_ENABLED(OPTEE) to test the availability of the OP-TEE driver. This patch cleans the configuration dependency with: - CONFIG_OPTEE_IMAGE (renamed) => support of OP-TEE image in U-Boot - CONFIG_SPL_OPTEE_IMAGE (renamed) => support of OP-TEE image in SPL - CONFIG_OPTEE (same) => support of OP-TEE driver in U-Boot - CONFIG_OPTEE_LIB (new) => support of OP-TEE library After this patch, the macro have the correct behavior: - CONFIG_IS_ENABLED(OPTEE_IMAGE) => Load of OP-TEE image is supported - CONFIG_IS_ENABLED(OPTEE) => OP-TEE driver is supported Signed-off-by: Patrick Delaunay <patrick.delaunay@foss.st.com>
2021-09-25fdt: Update Makefile rules with the new OF_REAL KconfigSimon Glass
Simplify some of the Makefile rules using this Kconfig. Signed-off-by: Simon Glass <sjg@chromium.org>
2021-09-16Merge tag 'v2021.10-rc4' into nextTom Rini
Prepare v2021.10-rc4 Signed-off-by: Tom Rini <trini@konsulko.com> # gpg: Signature made Tue 14 Sep 2021 06:58:32 PM EDT # gpg: using RSA key 1A3C7F70E08FAB1707809BBF147C39FF9634B72C # gpg: Good signature from "Thomas Rini <trini@konsulko.com>" [ultimate] # Conflicts: # board/Arcturus/ucp1020/spl.c # cmd/mvebu/Kconfig # common/Kconfig.boot # common/image-fit.c # configs/UCP1020_defconfig # configs/sifive_unmatched_defconfig # drivers/pci/Kconfig # include/configs/UCP1020.h # include/configs/sifive-unmatched.h # lib/Makefile # scripts/config_whitelist.txt
2021-09-08common/spl: Drop [ST]PL_HASH_SUPPORT in favor of [ST]PL_HASHAlexandru Gagniuc
All of these configs exist. Stick to using CONFIG_[ST]PL_HASH, and drop all references to CONFIG_[ST]PL_HASH_SUPPORT. This means we need for CHAIN_OF_TRUST to select SPL_HASH now. Signed-off-by: Alexandru Gagniuc <mr.nuke.me@gmail.com> [trini: Add TPL case, fix CHAIN_OF_TRUST, other tweaks] Signed-off-by: Tom Rini <trini@konsulko.com>
2021-09-08lib: Drop SHA512_ALGO in lieu of SHA512Alexandru Gagniuc
SHA512_ALGO was used as a "either SHA512 or SHA384", although the implementations of these two algorithms share a majority of code. From a Kconfig interface perspective, it makes sense to present two distinct options. This requires #ifdefing out the SHA512 implementation from sha512.c. The latter doesn't make any sense. It's reasonable to say in Kconfig that SHA384 depends on SHA512, and seems to be the more polite way to handle the selection. Thus, automatically select SHA512 when SHA384 is enabled. Signed-off-by: Alexandru Gagniuc <mr.nuke.me@gmail.com>
2021-09-02lib: add crc16.o if CONFIG_MMC_SPI_CRC_ON for SPL buildAndreas Schwab
CONFIG_MMC_SPI_CRC_ON needs the crc16 functions, but it was not included in an SPL build. For non-SPL builds, crc16.o is already added unconditionally. This also removes CONFIG_SPL_YMODEM_SUPPORT from the sifive board configs, which is only relevant for some ARM boards and was only set for its side effect of adding crc16.o.
2021-08-16lib: ecdsa: Implement UCLASS_ECDSA verification on targetAlexandru Gagniuc
Implement the crypto_algo .verify() function for ecdsa256. Because it backends on UCLASS_ECDSA, this change is focused on parsing the keys from devicetree and passing this information to the specific UCLASS driver. Signed-off-by: Alexandru Gagniuc <mr.nuke.me@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Patrick Delaunay <patrick.delaunay@foss.st.com>
2021-07-28lib: Create a new Kconfig option for charset conversionSimon Glass
Rather than looking at two KConfig options in the Makefile, create a new Kconfig option for compiling lib/charset.c Enable it for UFS also, which needs this support. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2021-07-23lib: add crypt subsystemSteffen Jaeckel
Add the basic functionality required to support the standard crypt format. The files crypt-sha256.c and crypt-sha512.c originate from libxcrypt and their formatting is therefor retained. The integration is done via a crypt_compare() function in crypt.c. ``` libxcrypt $ git describe --long --always --all tags/v4.4.17-0-g6b110bc ``` Signed-off-by: Steffen Jaeckel <jaeckel-floss@eyet-services.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Heiko Schocher <hs@denx.de>
2021-07-14lib: move rtc-lib.c to libHeinrich Schuchardt
Function rtc_to_tm() is needed for FAT file system support even if we don't have a real time clock. So move it from drivers/ to lib/. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2021-06-11lib: rational: copy the rational fraction lib routines from LinuxTero Kristo
Copy the best rational approximation calculation routines from Linux. Typical usecase for these routines is to calculate the M/N divider values for PLLs to reach a specific clock rate. This is based on linux kernel commit: "lib/math/rational.c: fix possible incorrect result from rational fractions helper" (sha1: 323dd2c3ed0641f49e89b4e420f9eef5d3d5a881) Signed-off-by: Tero Kristo <t-kristo@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Tero Kristo <kristo@kernel.org>
2021-05-28efi_loader: Work-around build issue due to missing hash_calculate()Alexandru Gagniuc
The hash_calculate() symbol is provided by hash-checksum.c. It depends on hash_progressive_lookup_algo(), provided when CONFIG_HASH=y. The issue is that hash_calculate() is used by the efi_loader, irregardless of CONFIG_FIT_SIGNATURE. As pointed out in commit 87316da05f2f ("lib: introduce HASH_CALCULATE option"), enabling hash_calculate() based on CONFIG_FIT_SIGNATURE is incorrect. To resolve this, use CONFIG_HASH as the compile switch for hash-checksum.c. This ensures that all dependencies are compiled, and is the most natural Kconfig to use. There is the issue of having to 'select HASH' in a couple of places that already 'select SHA256'. This is a deeper problem with how hashes are organized, and fixing it is beyonf the scope of this change. Signed-off-by: Alexandru Gagniuc <mr.nuke.me@gmail.com> Acked-by: Masahisa Kojima <masahisa.kojima@linaro.org>
2021-05-28Revert "lib: introduce HASH_CALCULATE option"Alexandru Gagniuc
When we think of Kconfig, we usually think of features that we like to enable or not. Ideally, we wouldn't use Kconfig to fix a build issue, although sometimes it might make sense. With Kconfig it's hard to guarantee that the fix is universal. We can only say that it works for the set of tested configurations. In the majority of cases, it's preferable to let the linker figure things out for us. The reverted commit attempted to fix a build issue by adding an invisible Kconfig option. This is wrong in several ways: It invents a new Kconfig variable when CONFIG_HASH already exists for the same purpose. Second, hash-checksum.c makes use of the hash_progressive_lookup_algo() symbol, which is only provided with CONFIG_HASH, but this dependency was not expressed in the reverted patch. It feels like Kconfig is turning into a listing of all available source files, and a buffet to 'select' which ones to compile. The purpose of this revert is to enable the next change to make use of CONFIG_HASH instead of adding to Kconfig. This reverts commit 87316da05f2fd49d3709275e64ef0c5980366ade. Signed-off-by: Alexandru Gagniuc <mr.nuke.me@gmail.com> Acked-by: Masahisa Kojima <masahisa.kojima@linaro.org>
2021-05-18lib: introduce HASH_CALCULATE optionMasahisa Kojima
Build error occurs when CONFIG_EFI_SECURE_BOOT or CONFIG_EFI_CAPSULE_AUTHENTICATE is enabled, because hash-checksum.c is not compiled. Since hash_calculate() implemented in hash-checksum.c can be commonly used aside from FIT image signature verification, this commit itroduces HASH_CALCULATE option to decide if hash-checksum.c shall be compiled. Signed-off-by: Masahisa Kojima <masahisa.kojima@linaro.org> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2021-04-14lib: Rename rsa-checksum.c to hash-checksum.cAlexandru Gagniuc
rsa-checksum.c sontains the hash_calculate() implementations. Despite the "rsa-" file prefix, this function is useful for other algorithms. To prevent confusion, move this file to lib/, and rename it to hash-checksum.c, to give it a more "generic" feel. Signed-off-by: Alexandru Gagniuc <mr.nuke.me@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2021-03-02tpm: Switch TPMv1 over to use the new APISimon Glass
Take over the plain 'tpm_...' functions for use by the new TPM API. Rename all the TPMv1 functions so they are called from the API. Update the TPMv1 functions so that they are called from the API. Change existing users to use the tpm1_ prefix so they don't need to go through the API, which might introduce uncertainty. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Ilias Apalodimas <ilias.apalodimas@linaro.org>
2021-01-27crc32: Exclude crc32 from TPLSimon Glass
Unfortunately the toolchain often brings in the crc32 table even if the function is not actually used. For now, exclude it from the TPL build, which is very sensitive to size. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-11-05smbios: add parsing APIChristian Gmeiner
Add a very simple API to be able to access SMBIOS strings like vendor, model and bios version. Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2020-10-30lib: Add getoptSean Anderson
Some commands can get very unweildy if they have too many positional arguments. Adding options makes them easier to read, remember, and understand. This implementation of getopt has been taken from barebox, which has had option support for quite a while. I have made a few modifications to their version, such as the removal of opterr in favor of a separate getopt_silent function. In addition, I have moved all global variables into struct getopt_context. The getopt from barebox also re-orders the arguments passed to it so that non-options are placed last. This allows users to specify options anywhere. For example, `ls -l foo/ -R` would be re-ordered to `ls -l -R foo/` as getopt parsed the options. However, this feature conflicts with the const argv in cmd_tbl->cmd. This was originally added in 54841ab50c ("Make sure that argv[] argument pointers are not modified."). The reason stated in that commit is that hush requires argv to stay unmodified. Has this situation changed? Barebox also uses hush, and does not have this problem. Perhaps we could use their fix? I have assigned maintenance of getopt to Simon Glass, as it is currently only used by the log command. I would also be fine maintaining it. Signed-off-by: Sean Anderson <seanga2@gmail.com>
2020-08-14lib: sscanf: add sscanf implementationAndrii Anisov
Port sscanf implementation from mini-os and introduce new Kconfig option to enable it: CONFIG_SSCANF. Disable by default. Signed-off-by: Andrii Anisov <andrii_anisov@epam.com> Signed-off-by: Anastasiia Lukianenko <anastasiia_lukianenko@epam.com> Signed-off-by: Oleksandr Andrushchenko <oleksandr_andrushchenko@epam.com>
2020-06-12Add support for SHA384 and SHA512Reuben Dowle
The current recommendation for best security practice from the US government is to use SHA384 for TOP SECRET [1]. This patch adds support for SHA384 and SHA512 in the hash command, and also allows FIT images to be hashed with these algorithms, and signed with sha384,rsaXXXX and sha512,rsaXXXX The SHA implementation is adapted from the linux kernel implementation. [1] Commercial National Security Algorithm Suite http://www.iad.gov/iad/programs/iad-initiatives/cnsa-suite.cfm Signed-off-by: Reuben Dowle <reuben.dowle@4rf.com>
2020-06-04lib: Makefile: build crc7.c when CONFIG_MMC_SPIPragnesh Patel
When build U-Boot SPL, meet an issue of undefined reference to 'crc7' for drivers/mmc/mmc_spi.c, so let's compile crc7.c when CONFIG_MMC_SPI selected. Signed-off-by: Pragnesh Patel <pragnesh.patel@sifive.com> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Jagan Teki <jagan@amarulasolutions.com>
2020-05-15lib: Allow MD5 to be enabled in SPLSimon Glass
At present the MD5 option cannot be enabled by board configs since it has no Kconfig name. It is generally enabled, so long as FIT support is present. But not all boards use FIT, particularly in SPL Fix this and add an option for SPL as well. This allows board code to call md5() even if FIT support is not enabled. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-04-27lib: enable lzma decompression support for SPL buildWeijie Gao
This patch enables LZMA decompression support for SPL build Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Weijie Gao <weijie.gao@mediatek.com>
2020-04-24lib: do not build OID registry in SPLHeinrich Schuchardt
The OID registry is only used by crypto functions that are not built in SPL. So we should not build it in SPL. Fixes: a9b45e6e8382 ("lib: add oid registry utility") Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2020-04-16acpi: Add a central location for table version numbersSimon Glass
Each ACPI table has its own version number. Add the version numbers in a single function so we can keep them consistent and easily see what versions are supported. Start a new acpi_table file in a generic directory to house this function. We can move things over to this file from x86 as needed. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Wolfgang Wallner <wolfgang.wallner@br-automation.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2020-03-03lib: elf: Move the generic elf loading/validating functions to libKeerthy
Move the generic elf loading/validating functions to lib/ so that they can be re-used and accessed by code existing outside cmd. While at it remove the duplicate static version of load_elf_image_phdr under arch/arm/mach-imx/imx_bootaux.c. Signed-off-by: Keerthy <j-keerthy@ti.com> Suggested-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Reviewed-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
2020-01-25lib: rsa: consider CONFIG_SPL_RSAHeinrich Schuchardt
CONFIG_SPL_RSA is meant to control if lib/rsa/* is used for SPL. Adjust lib/Makefile to consider this setting. This was correctly setup with commit 51c14cd128f4 ("verified-boot: Minimal support for booting U-Boot proper from SPL") and got lost with commit 089df18bfe9d ("lib: move hash CONFIG options to Kconfig"). Fixes: 089df18bfe9d ("lib: move hash CONFIG options to Kconfig") Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2020-01-17u-boot: fit: add support to decrypt fit with aesPhilippe Reynes
This commit add to u-boot the support to decrypt fit image encrypted with aes. The FIT image contains the key name and the IV name. Then u-boot look for the key and IV in his device tree and decrypt images before moving to the next stage. Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com>
2019-12-15net: Move the checksum functions to lib/Simon Glass
These functions are used by code outside the network support, so move them to lib/ to be more accessible. Without this, the functions are only accessible in SPL/TPL only if CONFIG_SPL/TPL_NET are defined. Many boards do not enable those option but still want to do checksums in this format. Fix up a few code-style nits while we are here. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-12-15binman: Add a library to access binman entriesSimon Glass
SPL and TPL can access information about binman entries using link-time symbols but this is not available in U-Boot proper. Of course it could be made available, but the intention is to just read the device tree. Add support for this, so that U-Boot can locate entries. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-12-06lib: crypto: add x509 parserAKASHI Takahiro
Imported from linux kernel v5.3: x509.asn1 without changes x509_akid.asn1 without changes x509_parser.h without changes x509_cert_parser.c with changes marked as __UBOOT__ x509_public_key.c with changes marked as __UBOOT__ Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
2019-12-06lib: add oid registry utilityAKASHI Takahiro
Imported from linux kernel v5.3: build_OID_registry without changes oid_registry.h without changes oid_registry.c with changes marked as __UBOOT__ Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
2019-12-06lib: add asn1 decoderAKASHI Takahiro
Imported from linux kernel v5.3: lib/asn1_decoder.c with changes marked as __UBOOT__ Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
2019-12-06rtc: move date.c from drivers/rtc/ to lib/AKASHI Takahiro
In the next commit, rtc_mktime(), for compatibility with linux, will be implemented using rtc_mktime(), which is no longer drivers/rtc specific. So move this file under lib/. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
2019-12-02Move strtomhz() to vsprintf.hSimon Glass
At present this function sits in its own file but it does not really justify it. There are similar string functions in vsprintf.h, so move it there. Also add the missing function comment. Use the vsprintf.h include file explicitly where needed. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-10-08spl: Allow tiny printf() to be controlled in SPL and TPLSimon Glass
At present there is only one control for this and it is used for both SPL and TPL. But SPL might have a lot more space than TPL so the extra cost of a full printf() might be acceptable. Split the option into two, providing separate SPL and TPL controls. The TPL setting defaults to the same as SPL. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-06-21lib: Makefile: build fdtdec_common.c when OF_LIBFDT selectedPeng Fan
When build SPL_OF_PLATDATA on i.MX6, meet issue the fdtdec_get_int not defined, however fdtdec.c will use fdtdec_get_int, so let's compile fdtdec_common.c when OF_LIBFDT selected. Since there is also SPL_OF_LIBFDT, so need to use CONFIG_$(SPL_TPL_)OF_LIBFDT. Signed-off-by: Peng Fan <peng.fan@nxp.com>
2019-05-05lib: add Zstandard decompression supportMarek Behún
Add the zstd library from Linux kernel (only decompression support). There are minimal changes to build with U-Boot, otherwise the files are identical to Linux commit dc35da16 from March 2018, the files had not been touched since in kernel. Also SPDX lincese tags were added. Signed-off-by: Marek Behún <marek.behun@nic.cz>
2019-05-05lib: Add xxhash supportMarek Behún
This adds the xxhash support from Linux. Files are almost identical to those added to Linux in commit 5d240522 ("lib: Add xxhash module") (they haven't been touched since in Linux). The only difference is to add some includes to be compatible with U-Boot. Also SPDX lincese tags were added. Signed-off-by: Marek Behún <marek.behun@nic.cz>
2019-02-09initcall: Move to inline functionAlexander Graf
The board_r init function was complaining that we are looping through an array, calling all our tiny init stubs sequentially via indirect function calls (which can't be speculated, so they are slow). The solution to that is pretty easy though. All we need to do is inline the function that loops through the functions and the compiler will automatically convert almost all indirect calls into direct inlined code. With this patch, the overall code size drops (by 40 bytes on riscv64) and boot time should become measurably faster for every target. Signed-off-by: Alexander Graf <agraf@suse.de>
2019-01-16tftp: prevent overwriting reserved memorySimon Goldschmidt
This fixes CVE-2018-18439 ("insufficient boundary checks in network image boot") by using lmb to check for a valid range to store received blocks. Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> [trini: Always build lib/lmb.o on LMB and lib/fdtdec.o on OF_LIBFDT] Signed-off-by: Tom Rini <trini@konsulko.com>
