path: root/lib/Makefile
2016-09-16Use separate options for TPL supportSimon Glass
At present TPL uses the same options as SPL support. In a few cases the board config enables or disables the SPL options depending on whether CONFIG_TPL_BUILD is defined. With the move to Kconfig, options are determined for the whole build and (without a hack like an #undef in a header file) cannot be controlled in this way. Create new TPL options for these and update users. This will allow Kconfig conversion to proceed for these boards. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-07-14dm: Don't include fdtdec functions when of-platdata is enabledSimon Glass
We cannot access the device tree in this case, so avoid compiling in the various device-tree helper functions. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-06-12verified-boot: Minimal support for booting U-Boot proper from SPLTeddy Reed
This allows a board to configure verified boot within the SPL using a FIT or FIT with external data. It also allows the SPL to perform signature verification without needing relocation. The board configuration will need to add the following feature defines: CONFIG_SPL_CRYPTO_SUPPORT CONFIG_SPL_HASH_SUPPORT CONFIG_SPL_SHA256 In this example, SHA256 is the only selected hashing algorithm. And the following booleans: CONFIG_SPL=y CONFIG_SPL_DM=y CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_FIT=y CONFIG_SPL_OF_CONTROL=y CONFIG_SPL_OF_LIBFDT=y CONFIG_SPL_FIT_SIGNATURE=y Signed-off-by: Teddy Reed <teddy.reed@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Andreas Dannenberg <dannenberg@ti.com> Acked-by: Sumit Garg <sumit.garg@nxp.com>
2016-06-06lib: make strmhz available in SPLChris Packham
When setting up a DDR controller it is useful to be able to display frequencies in a readable form. Make the strmhz() function available in SPL builds provided there is full vsprintf available. Reviewed-by: Tony O'Brien <tony.obrien@alliedtelesis.co.nz> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Chris Packham <judge.packham@gmail.com>
2016-03-15efi_loader: hook up in build environmentAlexander Graf
Now that we have all the bits and pieces ready for EFI payload loading support, hook them up in Makefiles and KConfigs so that we can build. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> [trini: Enable only when we of OF_LIBFDT, disable on kwb and colibri_pxa270] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-03-14fdt: Allow libfdt to be used in SPLSimon Glass
Add an option to enable libfdt in SPL. This can be useful when decoding FIT files in SPL. We need to make sure this option is not enabled in SPL by this change. Also this option needs to be enabled in host builds. Si add a new IMAGE_USE_LIBFDT #define which can be used in files that are built on the host but must also build for U-Boot and SPL. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-02-15Makefile: remove BUILD_TAG from KBUILD_CFLAGSStephen Warren
If BUILD_TAG is part of KBUILD_CFLAGS, then any time the value changes, all files get rebuilt. In a continuous integration environment, the value will change every build. This wastes time, assuming that incremental builds would otherwise occur. To solve this, remove BUILD_TAG from KBUILD_CFLAGS and add it to CFLAGS for just the one file that uses it. This does have the disadvantage that if any other files want to use the flag, we'll need to duplicate this custom CFLAGS setup logic. However, it seems unlikely we'll need this. An alternative would be to add BUILD_TAG to the "local version" and remove the special case code from display_options.c. However, that would affect the format of the U-Boot signon message, which may negatively affect people looking for specific data there. The approach of using file-specific CFLAGS was suggested by Masahiro Yamada. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-12-13lib: split out strtoxxxx functions out of vsprintf.cSjoerd Simons
To allow the various string to number conversion functions to be used when using tiny-printf,split them out into their own file which gets build regardless of what printf implementation is used. Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
2015-12-13lib: Split panic functions out of vsprintf.cSjoerd Simons
To allow panic and panic_str to still be used when using tiny-printf, split them out into their own file which gets build regardless of what printf implementation is used. Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
2015-11-23lib/tiny-printf.c: Add tiny printf function for space limited environmentsStefan Roese
This patch adds a small printf() version that supports all basic formats. Its intented to be used in U-Boot SPL versions on platforms with very limited internal RAM sizes. To enable it, just define CONFIG_USE_TINY_PRINTF in your defconfig. This will result in the SPL using this tiny function and the main U-Boot still using the full-blown printf() function. This code was copied from: http://www.sparetimelabs.com/printfrevisited With mostly only coding style related changes so that its checkpatch clean. The size reduction is about 2.5KiB. Here a comparison for the db-mv784mp-gp (Marvell AXP) SPL: Without this patch: 58963 18536 1928 79427 13643 ./spl/u-boot-spl With this patch: 56542 18536 1956 77034 12cea ./spl/u-boot-spl Note: To make it possible to compile tiny-printf.c instead of vsprintf.c when CONFIG_USE_TINY_PRINTF is defined, the functions printf() and vprintf() are moved from common/console.c into vsprintf.c in this patch. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Hans de Goede <hdegoede@redhat.com> Cc: Tom Rini <trini@konsulko.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net>
2015-11-19Add a circular memory buffer implementationSimon Glass
This will be used to support console recording. It provides for a circular buffer which can be written at the head and read from the tail. It supports avoiding data copying by providing raw access to the data. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-10-11Add support for LZ4 decompression algorithmJulius Werner
This patch adds support for LZ4-compressed FIT image contents. This algorithm has a slightly worse compression ration than LZO while being nearly twice as fast to decompress. When loading images from a fast storage medium this usually results in a boot time win. Sandbox-tested only since I don't have a U-Boot development system set up right now. The code was imported unchanged from coreboot where it's proven to work, though. I'm mostly interested in getting this recognized by mkImage for use in a downstream project. Signed-off-by: Julius Werner <jwerner@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2015-08-18of: clean up OF_CONTROL ifdef conditionalsMasahiro Yamada
We have flipped CONFIG_SPL_DISABLE_OF_CONTROL. We have cleansing devices, $(SPL_) and CONFIG_IS_ENABLED(), so we are ready to clear away the ugly logic in include/fdtdec.h: #ifdef CONFIG_OF_CONTROL # if defined(CONFIG_SPL_BUILD) && !defined(SPL_OF_CONTROL) # define OF_CONTROL 0 # else # define OF_CONTROL 1 # endif #else # define OF_CONTROL 0 #endif Now CONFIG_IS_ENABLED(OF_CONTROL) is the substitute. It refers to CONFIG_OF_CONTROL for U-boot proper and CONFIG_SPL_OF_CONTROL for SPL. Also, we no longer have to cancel CONFIG_OF_CONTROL in include/config_uncmd_spl.h and scripts/Makefile.spl. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2015-08-18of: flip CONFIG_SPL_DISABLE_OF_CONTROL into CONFIG_SPL_OF_CONTROLMasahiro Yamada
As we discussed a couple of times, negative CONFIG options make our life difficult; CONFIG_SYS_NO_FLASH, CONFIG_SYS_DCACHE_OFF, ... and here is another one. Now, there are three boards enabling OF_CONTROL on SPL: - socfpga_arria5_defconfig - socfpga_cyclone5_defconfig - socfpga_socrates_defconfig This commit adds CONFIG_SPL_OF_CONTROL for them and deletes CONFIG_SPL_DISABLE_OF_CONTROL from the other boards to invert the logic. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-08-05efi: Add start-up library codeSimon Glass
When running as an EFI application, U-Boot must request memory from EFI, and provide access to the boot services U-Boot needs. Add library code to perform these tasks. This includes efi_main() which is the entry point from EFI. U-Boot is built as a shared library. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-07-21Add rivest cipher 4 (rc4) implementationSimon Glass
Add an implementation of RC4. This will be used by Rockchip booting but may be useful in other situations. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-07-21Drop CONFIG_ERRNO_STR from SPLSimon Glass
This bloats the code size quite a bit and is less useful in SPL where there is no command line. Avoid including this code in SPL. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-07-21Add a dhrystone benchmark commandSimon Glass
Drystone provides a convenient sanity check that the CPU is running at full speed. Add this as a command which can be enabled as needed. Note: I investigated using Coremark for this but there was a license agreement and I could not work out if it was GPL-compatible. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-23fdt: Allow FDT functions to be built for SPLSimon Glass
Remove the implicit assumption that SPL does not support device tree. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-12-11lib: errno: introduce errno_str(): returns errno related messagePrzemyslaw Marczak
The functions error's numbers are standarized - but the error messages are not. The errors are often handled with unclear error messages, so why not use an errno standarized messages. Advantages: - This could decrease the binary size. - Appended with a detailed information, the error message will be clear. This commit introduces new function: - const char *errno_to_str(int errno) The functions returns a pointer to the errno corresponding text message: - if errno is null or positive number - a pointer to "Success" message - if errno is negative - a pointer to errno related message Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Reviewed-by: Tom Rini <trini@ti.com>
2014-12-08libfdt: move CONFIG_OF_LIBFDT and CONFIG_FIT to lib/MakefileMasahiro Yamada
2014-12-08libfdt: descend from lib/ to lib/libfdt/Masahiro Yamada
2014-12-08lib: bzip2: move bzip2 files to lib/bzip2/ directoryMasahiro Yamada
2014-08-25lib, linux: move linux specific defines to linux/compat.hHeiko Schocher
- move linux specific defines from usb and video code into linux/compat.h - move common linux specific defines from include/ubi_uboot.h to linux/compat.h - add for new mtd/ubi/ubifs sync new needed linux specific defines to linux/compat.h Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Marek Vasut <marex@denx.de> Cc: Anatolij Gustschin <agust@denx.de> [trini: Add spin_lock_irqsave/spin_unlock_irqrestore dummies from usb/lin_gadet_compat.h] Signed-off-by: Tom Rini <trini@ti.com>
2014-08-25lib, list_sort: add list_sort from linux 3.14Heiko Schocher
from linux 3.14: commit 455c6fdbd219161bd09b1165f11699d6d73de11c Author: Linus Torvalds <torvalds@linux-foundation.org> Date: Sun Mar 30 20:40:15 2014 -0700 Linux 3.14 Needed for the MTD/UBI/UBIFS resync Just copied the files from Linux, and added in the c-file the "#define __UBOOT__" for adding U-Boot special code. In this case we use this just for adding including U-Boot headers. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Marek Vasut <marex@denx.de> Cc: Sergey Lapin <slapin@ossfans.org> Cc: Scott Wood <scottwood@freescale.com> Cc: Tom Rini <trini@ti.com>
2014-06-23lib, fdt: move fdtdec_get_int() out of lib/fdtdec.cHeiko Schocher
move fdtdec_get_int() out of lib/fdtdec.c into lib/fdtdec_common.c as this function is also used, if CONFIG_OF_CONTROL is not used. Poped up on the ids8313 board using signed FIT images, and activating CONFIG_SYS_GENERIC_BOARD. Without this patch it shows on boot: No valid FDT found - please append one to U-Boot binary, use u-boot-dtb.bin or define CONFIG_OF_EMBED. For sandbox, use -d <file.dtb> With this patch, it boots again with CONFIG_SYS_GENERIC_BOARD enabled. Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@ti.com>
2014-05-23eMMC: add support for operations in RPMB partitionPierre Aubert
This patch adds functions for read, write and authentication key programming for the Replay Protected Memory Block partition in the eMMC. Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com> Signed-off-by: Pierre Aubert <p.aubert@staubli.com>
2014-04-02lib: uuid: add functions to generate UUID version 4Przemyslaw Marczak
This patch adds support to generate UUID (Universally Unique Identifier) in version 4 based on RFC4122, which is randomly. Source: https://www.ietf.org/rfc/rfc4122.txt Changes: - new configs: - CONFIG_LIB_UUID for compile lib/uuid.c - CONFIG_RANDOM_UUID for functions gen_rand_uuid() and gen_rand_uuid_str() - add configs dependency to include/config_fallbacks.h for lib uuid. lib/uuid.c: - add gen_rand_uuid() - this function writes 16 bytes len binary representation of UUID v4 to the memory at given address. - add gen_rand_uuid_str() - this function writes 37 bytes len hexadecimal ASCII string representation of UUID v4 to the memory at given address. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Stephen Warren <swarren@nvidia.com> Cc: Lukasz Majewski <l.majewski@samsung.com> [trini: Add CONFIG_EFI_PARTITION to fallbacks] Signed-off-by: Tom Rini <trini@ti.com>
2014-04-02part_efi: move uuid<->string conversion functions into lib/uuid.cPrzemyslaw Marczak
This commit introduces cleanup for uuid library. Changes: - move uuid<->string conversion functions into lib/uuid.c so they can be used by code outside part_efi.c. - rename uuid_string() to uuid_bin_to_str() for consistency with existing uuid_str_to_bin() - add an error return code to uuid_str_to_bin() - update existing code to the new library functions. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Stephen Warren <swarren@nvidia.com> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: trini@ti.com
2014-03-28lib: rand: introduce new configs: CONFIG_LIB_RAND and CONFIG_LIB_HW_RANDPrzemyslaw Marczak
New configs: - CONFIG_LIB_RAND - to enable implementation of rand library in lib/rand.c - CONFIG_LIB_HW_RAND - to enable hardware based implementations of lib rand Other changes: - add CONFIG_LIB_RAND to boards configs which needs rand() - put only one rand.o dependency in lib/Makefile CONFIG_LIB_HW_RAND should be defined for drivers which implements rand library (declared in include/common.h): - void srand(unsigned int seed) - unsigned int rand(void) - unsigned int rand_r(unsigned int *seedp) Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Michael Walle <michael@walle.cc> Cc: Tom Rini <trini@ti.com> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-03-07kbuild, blackfin: Add CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEEDMasahiro Yamada
Many (but not all) of Blackfin boards give -O2 option to compile under lib/ directory. That means lib/ should be speed-optimized, whereas other parts should be size-optimized. We want to keep the same behavior, but do not want to parse board/*/config.mk again and again. We've got no choice but to invent a new method. CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED, if it is enabled, gives -O2 flag only for building under lib/ directory. Dirty codes which I had marked as "FIX ME" in board/${BOARD}/config.mk have been deleted. Instead, CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED has been defined in include/configs/${BOARD}.h. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Sonic Zhang <sonic.zhang@analog.com>
2014-02-26arm: Switch to -mno-unaligned-access when supported by the compilerTom Rini
When we tell the compiler to optimize for ARMv7 (and ARMv6 for that matter) it assumes a default of SCTRL.A being cleared and unaligned accesses being allowed and fast at the hardware level. We set this bit and must pass along -mno-unaligned-access so that the compiler will still breakdown accesses and not trigger a data abort. To better help understand the requirements of the project with respect to unaligned memory access, the Documentation/unaligned-memory-access.txt file has been added as doc/README.unaligned-memory-access.txt and is taken from the v3.14-rc1 tag of the kernel. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Mans Rullgard <mans@mansr.com> Signed-off-by: Tom Rini <trini@ti.com>
2014-02-19kbuild: use Linux Kernel build scriptsMasahiro Yamada
Now we are ready to switch over to real Kbuild. This commit disables temporary scripts: scripts/{Makefile.build.tmp, Makefile.host.tmp} and enables real Kbuild scripts: scripts/{Makefile.build,Makefile.host,Makefile.lib}. This switch is triggered by the line in scripts/Kbuild.include -build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build.tmp obj +build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build obj We need to adjust some build scripts for U-Boot. But smaller amount of modification is preferable. Additionally, we need to fix compiler flags which are locally added or removed. In Kbuild, it is not allowed to change CFLAGS locally. Instead, ccflags-y, asflags-y, cppflags-y, CFLAGS_$(basetarget).o, CFLAGS_REMOVE_$(basetarget).o are prepared for that purpose. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
2014-02-19kbuild: change out-of-tree buildMasahiro Yamada
This commit changes the working directory where the build process occurs. Before this commit, build process occurred under the source tree for both in-tree and out-of-tree build. That's why we needed to add $(obj) prefix to all generated files in makefiles like follows: $(obj)u-boot.bin: $(obj)u-boot Here, $(obj) is empty for in-tree build, whereas it points to the output directory for out-of-tree build. And our old build system changes the current working directory with "make -C <sub-dir>" syntax when descending into the sub-directories. On the other hand, Kbuild uses a different idea to handle out-of-tree build and directory descending. The build process of Kbuild always occurs under the output tree. When "O=dir/to/store/output/files" is given, the build system changes the current working directory to that directory and restarts the make. Kbuild uses "make -f $(srctree)/scripts/Makefile.build obj=<sub-dir>" syntax for descending into sub-directories. (We can write it like "make $(obj)=<sub-dir>" with a shorthand.) This means the current working directory is always the top of the output directory. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
2014-01-08Add crc8 routineSimon Glass
Add an implementation of the CRC8 algorithm. This is required by the TPM emulation, but is probably useful to U-Boot in general. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2013-11-25Makefile: move some libraries to lib/MakefileMasahiro Yamada
2013-10-31lib: convert makefiles to Kbuild styleMasahiro Yamada
2013-06-26Add trace librarySimon Glass
Add a library which supports tracing of execution using built-in gcc features and a microsecond timer. This can be used to record a list of function which are executed, along with a timestamp for each. Later this information can be sent to the host for processing. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-20Makefile: move the common makefile line to public areaYing Zhang
Move the common makefile line shared by the SPL and non-SPL to the public area, so that we can avoid excessive SPL symbols. Some of them will be used by the SPL later. This patch is on top of the patch "common/Makefile: Add new symbol CONFIG_SPL_ENV_SUPPORT for environment in SPL". Signed-off-by: Ying Zhang <b40530@freescale.com> Acked-by: Tom Rini <trini@ti.com> Acked-by: Tom Rini <trini@ti.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-05lib: import bitrev library from the linux kernelMike Dunn
This patch adds the bitrev library from the linux kernel. This is a simple algorithm that uses an 8 bit look-up table to reverse the bits in data types of 8, 16, or 32 bit widths. The docg4 nand flash driver uses it. [port from linux kernel v3.9 commit 7ee32a6d30d1c8a3b7a07a6269da8f0a08662927] [originally added: v2.6.20 by commit a5cfc1ec58a07074dacb6aa8c79eff864c966d12] Signed-off-by: Mike Dunn <mikedunn@newsguy.com>
2013-05-01lib: consolidate hang()Andreas Bießmann
Delete all occurrences of hang() and provide a generic function. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> [trini: Modify check around puts() in hang.c slightly] Signed-off-by: Tom Rini <trini@ti.com>
2013-05-01Add SLRE - Super Light Regular Expression libraryWolfgang Denk
Downloaded from http://slre.sourceforge.net/ and adapted for U-Boot environment. Used to implement regex operations on environment variables. Code size is ~ 3.5 KiB on PPC. To enable this code, define the CONFIG_REGEX option in your board config file. Note: There are more recent versions of the SLRE library available at http://slre.googlecode.com ; unfortunately, the new code has a heavily reorked API which makes it less usable for our purposes: - the return code is strings, which are more difficult to process - we don't get any information any more which sub-string of the data was matched by the given regex - it is much more cumbersome to work with arbitrary expressions, where for example the number of substrings for capturing are not known at compile time Also, there does not seem to be any real changes or improvements of the functionality. Because of this, we deliberately stick with the older code. Note 2: the test code (built when SLRE_TEST is defined) was modified to allow for more extensive testing; now we can test the regexp matching on all lines on a text file (instead of the whole data in the file as a single block). Signed-off-by: Wolfgang Denk <wd@denx.de>
2013-04-15Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2013-04-12tpm: Add TPM command libraryChe-liang Chiou
TPM command library implements a subset of TPM commands defined in TCG Main Specification 1.2 that are useful for implementing secure boot. More TPM commands could be added out of necessity. You may exercise these commands through the 'tpm' command. However, the raw TPM commands are too primitive for writing secure boot in command interpreter scripts; so the 'tpm' command also provides helper functions to make scripting easier. For example, to define a counter in TPM non-volatile storage and initialize it to zero: $ tpm init $ tpm startup TPM_ST_CLEAR $ tpm nv_define d 0x1001 0x1 $ tpm nv_write d 0x1001 0 And then increment the counter by one: $ tpm nv_read d 0x1001 i $ setexpr.l i $i + 1 $ tpm nv_write d 0x1001 $i Signed-off-by: Che-Liang Chiou <clchiou@chromium.org>
2013-04-08omap_gpmc: add support for hw assisted BCH8Andreas Bießmann
The kernel states: ---8<--- The OMAP3 GPMC hardware BCH engine computes remainder polynomials, it does not provide automatic error location and correction: this step is implemented using the BCH library. --->8--- And we do so in u-boot. This implementation uses the same layout for BCH8 but it is fix. The current provided layout does only work with 64 Byte OOB. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Tom Rini <trini@ti.com> Cc: Ilya Yanok <ilya.yanok@cogentembedded.com> Cc: Scott Wood <scottwood@freescale.com> Cc: Mansoor Ahamed <mansoor.ahamed@ti.com> Cc: Thomas Weber <thomas.weber.linux@googlemail.com>
2013-03-15Introduce a basic initcall implementationSimon Glass
This library supports calling a list of functions one after the other. It is intended that we move to a more powerful initcall implementation as proposed by Graeme Russ <graeme.russ@gmail.com>. For now, this allows us to do the basics. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-12-13Make linux kernel string funcs available to toolsJoe Hershberger
isspace() and strim() are not in the typical user-mode string.h, so put them in a separate compilation unit so that they can be built into tools that need them independent of the other common string functions. This allows code shared by u-boot and the linux user-mode tools to link. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-12-06Introduce arch_phys_memset which works like memset but on physical memoryGabe Black
The default implementation of this function is just memset, but other implementations will be needed when physical memory isn't accessible by U-Boot using normal addressing mechanisms. Signed-off-by: Gabe Black <gabeblack@chromium.org> Signed-off-by: Che-Liang Chiou <clchiou@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2012-10-15ARM: prevent misaligned array initsAlbert ARIBAUD
Under option -munaligned-access, gcc can perform local char or 16-bit array initializations using misaligned native accesses which will throw a data abort exception. Fix files where these array initializations were unneeded, and for files known to contain such initializations, enforce gcc option -mno-unaligned-access. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> [trini: Switch to usign call cc-option for -mno-unaligned-access as Albert had done previously as that's really correct] Signed-off-by: Tom Rini <trini@ti.com>
