path: root/lib/Makefile
2018-04-28spl: Split sprintf, strto* from SPL serial in KconfigAlex Kiernan
When SPL serial is disabled, callers who need sprintf or strtoul fail because their inclusion is guarded by CONFIG_SPL_SERIAL_SUPPORT/ CONFIG_TPL_SERIAL_SUPPORT. Split printf, sprintf and strto into their own entries and then select all of them if SERIAL_SUPPORT is enabled to match the current behaviour. Include panic.o unconditionally as it can be called from anywhere which uses BUG_ON(). Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
2018-03-19optee: Add lib entries for sharing OPTEE code across portsBryan O'Donoghue
This patch adds code to lib to enable sharing of useful OPTEE code between board-ports and architectures. The code on lib/optee/optee.c comes from the TI omap2 port. Eventually the OMAP2 code will be patched to include the shared code. The intention here is to add more useful OPTEE specific code as more functionality gets added. Signed-off-by: Bryan O'Donoghue <bryan.odonoghue@linaro.org> Cc: Harinarayan Bhatta <harinarayan@ti.com> Cc: Andrew F. Davis <afd@ti.com> Cc: Tom Rini <trini@konsulko.com> Cc: Kever Yang <kever.yang@rock-chips.com> Cc: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Cc: Peng Fan <peng.fan@nxp.com> Tested-by: Peng Fan <peng.fan@nxp.com>
2018-01-22efi_driver: EFI block driverHeinrich Schuchardt
This patch provides * a uclass for EFI drivers * a EFI driver for block devices For each EFI driver the uclass * creates a handle * adds the driver binding protocol The uclass provides the bind, start, and stop entry points for the driver binding protocol. In bind() and stop() it checks if the controller implements the protocol supported by the EFI driver. In the start() function it calls the bind() function of the EFI driver. In the stop() function it destroys the child controllers. The EFI block driver binds to controllers implementing the block io protocol. When the bind function of the EFI block driver is called it creates a new U-Boot block device. It installs child handles for all partitions and installs the simple file protocol on these. The read and write functions of the EFI block driver delegate calls to the controller that it is bound to. A usage example is as following: U-Boot loads the iPXE snp.efi executable. iPXE connects an iSCSI drive and exposes a handle with the block IO protocol. It calls ConnectController. Now the EFI block driver installs the partitions with the simple file protocol. iPXE uses the simple file protocol to load Grub or the Linux Kernel. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> [agraf: add comment on calloc len] Signed-off-by: Alexander Graf <agraf@suse.de>
2017-10-05lib: allow building lzo for the SPLJean-Jacques Hiblot
Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-10-02lib: Add CRC32-CMarek BehĂșn
This is needed for BTRFS. Signed-off-by: Marek Behun <marek.behun@nic.cz> create mode 100644 lib/crc32c.c
2017-09-18efi_selftest: provide an EFI selftest applicationHeinrich Schuchardt
A testing framework for the EFI API is provided. It can be executed with the 'bootefi selftest' command. It is coded in a way that at a later stage we may turn it into a standalone EFI application. The current build system does not allow this yet. All tests use a driver model and are run in three phases: setup, execute, teardown. A test may be setup and executed at boottime, it may be setup at boottime and executed at runtime, or it may be setup and executed at runtime. After executing all tests the system is reset. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2017-09-14lib: at91: Add logo files used via API of DM_VIDEOWenyou Yang
In order to display the company's logo via the API of DM_VIDEO, and add the logo files of both Atmel and Microchip. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-12lib: add some utf16 handling helpersRob Clark
We'll eventually want these in a few places in efi_loader, and also vsprintf. Signed-off-by: Rob Clark <robdclark@gmail.com>
2017-09-11spl: fit: Eanble GZIP support for image decompressionYork Sun
Add Kconfig option SPL_GZIP and SPL_ZLIB to enable gunzip support for SPL boot, eg. falcon boot compressed kernel image. Signed-off-by: York Sun <york.sun@nxp.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-13lib: spl: differentiate between TPL and SPL for libfdt/of_control/of_platdataPhilipp Tomsich
This splits the compilation of code modules for TPL and SPL for OF_CONTROL (and related) features between TPL and SPL. The typical use-case of this is a TPL stage that uses OF_PLATDATA at TPL and provides full OF_CONTROL at SPL (e.g. on the RK3368). Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-06-01dm: Add a function to create a 'live' device treeSimon Glass
This function converts the flat device tree into a hierarchical one with C structures and pointers. This is easier to access. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22lib: move hash CONFIG options to KconfigTom Rini
Commit 94e3c8c4fd7b ("crypto/fsl - Add progressive hashing support using hardware acceleration.") created entries for CONFIG_SHA1, CONFIG_SHA256, CONFIG_SHA_HW_ACCEL, and CONFIG_SHA_PROG_HW_ACCEL. However, no defconfig has migrated to it. Complete the move by first adding additional logic to various Kconfig files to select this when required and then use the moveconfig tool. In many cases we can select these because they are required to implement other drivers. We also correct how we include the various hashing algorithms in SPL. This commit was generated as follows (after Kconfig additions): [1] tools/moveconfig.py -y SHA1 SHA256 SHA_HW_ACCEL [2] tools/moveconfig.py -y SHA_PROG_HW_ACCEL Note: We cannot move SHA_HW_ACCEL and SHA_PROG_HW_ACCEL simultaneously because there is dependency between them. Cc: Poonam Aggrwal <poonam.aggrwal@freescale.com> Cc: Naveen Burmi <NaveenBurmi@freescale.com> Cc: Po Liu <po.liu@freescale.com> Cc: Shengzhou Liu <Shengzhou.Liu@freescale.com> Cc: Priyanka Jain <Priyanka.Jain@freescale.com> Cc: Shaohui Xie <Shaohui.Xie@freescale.com> Cc: Chunhe Lan <Chunhe.Lan@freescale.com> Cc: Chander Kashyap <k.chander@samsung.com> Cc: Steve Rae <steve.rae@raedomain.com> Cc: Dirk Eibach <eibach@gdsys.de> Cc: Feng Li <feng.li_2@nxp.com> Cc: Alison Wang <alison.wang@freescale.com> Cc: Sumit Garg <sumit.garg@nxp.com> Cc: Mingkai Hu <Mingkai.Hu@freescale.com> Cc: York Sun <york.sun@nxp.com> Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Cc: Jaehoon Chung <jh80.chung@samsung.com> Cc: Akshay Saraswat <akshay.s@samsung.com> Cc: Heiko Schocher <hs@denx.de> Cc: Jagan Teki <jagan@amarulasolutions.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-19x86: Move smbios generation into arch independent directoryAlexander Graf
We will need the SMBIOS generation function on ARM as well going forward, so let's move it into a non arch specific location. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-19x86: Move table csum into separate fileAlexander Graf
We need the checksum function without all the other table functionality soon, so let's split it out into its own C file. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-10-08spl: saveenv: adding saveenv support in SPLB, Ravi
By default saveenv option is not supported for SPL. This patch enable the support for save environment variable for SPL build. Enable save environment support in SPL after setenv. By default the saveenv option is not provided in SPL, but some boards need this support in 'Falcon' boot, where SPL need to boot from different images based on environment variable set by OS. For example OS may set "reboot_image" environment variable to "recovery" inorder to boot recovery image by SPL. The SPL read "reboot_image" and act accordingly and change the reboot_image to default mode using setenv and save the environemnt. Signed-off-by: Ravi Babu <ravibabu@ti.com> Reviewed-by: Simon Glass <sig@chromium.org> change in v1: - dropped SUPPORT, use CONFIG_SPL_SAVEENV - updates the comments in mmc_private.h
2016-09-16Use separate options for TPL supportSimon Glass
At present TPL uses the same options as SPL support. In a few cases the board config enables or disables the SPL options depending on whether CONFIG_TPL_BUILD is defined. With the move to Kconfig, options are determined for the whole build and (without a hack like an #undef in a header file) cannot be controlled in this way. Create new TPL options for these and update users. This will allow Kconfig conversion to proceed for these boards. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-07-14dm: Don't include fdtdec functions when of-platdata is enabledSimon Glass
We cannot access the device tree in this case, so avoid compiling in the various device-tree helper functions. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-06-12verified-boot: Minimal support for booting U-Boot proper from SPLTeddy Reed
This allows a board to configure verified boot within the SPL using a FIT or FIT with external data. It also allows the SPL to perform signature verification without needing relocation. The board configuration will need to add the following feature defines: CONFIG_SPL_CRYPTO_SUPPORT CONFIG_SPL_HASH_SUPPORT CONFIG_SPL_SHA256 In this example, SHA256 is the only selected hashing algorithm. And the following booleans: CONFIG_SPL=y CONFIG_SPL_DM=y CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_FIT=y CONFIG_SPL_OF_CONTROL=y CONFIG_SPL_OF_LIBFDT=y CONFIG_SPL_FIT_SIGNATURE=y Signed-off-by: Teddy Reed <teddy.reed@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Andreas Dannenberg <dannenberg@ti.com> Acked-by: Sumit Garg <sumit.garg@nxp.com>
2016-06-06lib: make strmhz available in SPLChris Packham
When setting up a DDR controller it is useful to be able to display frequencies in a readable form. Make the strmhz() function available in SPL builds provided there is full vsprintf available. Reviewed-by: Tony O'Brien <tony.obrien@alliedtelesis.co.nz> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Chris Packham <judge.packham@gmail.com>
2016-03-15efi_loader: hook up in build environmentAlexander Graf
Now that we have all the bits and pieces ready for EFI payload loading support, hook them up in Makefiles and KConfigs so that we can build. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> [trini: Enable only when we of OF_LIBFDT, disable on kwb and colibri_pxa270] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-03-14fdt: Allow libfdt to be used in SPLSimon Glass
Add an option to enable libfdt in SPL. This can be useful when decoding FIT files in SPL. We need to make sure this option is not enabled in SPL by this change. Also this option needs to be enabled in host builds. Si add a new IMAGE_USE_LIBFDT #define which can be used in files that are built on the host but must also build for U-Boot and SPL. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-02-15Makefile: remove BUILD_TAG from KBUILD_CFLAGSStephen Warren
If BUILD_TAG is part of KBUILD_CFLAGS, then any time the value changes, all files get rebuilt. In a continuous integration environment, the value will change every build. This wastes time, assuming that incremental builds would otherwise occur. To solve this, remove BUILD_TAG from KBUILD_CFLAGS and add it to CFLAGS for just the one file that uses it. This does have the disadvantage that if any other files want to use the flag, we'll need to duplicate this custom CFLAGS setup logic. However, it seems unlikely we'll need this. An alternative would be to add BUILD_TAG to the "local version" and remove the special case code from display_options.c. However, that would affect the format of the U-Boot signon message, which may negatively affect people looking for specific data there. The approach of using file-specific CFLAGS was suggested by Masahiro Yamada. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-12-13lib: split out strtoxxxx functions out of vsprintf.cSjoerd Simons
To allow the various string to number conversion functions to be used when using tiny-printf,split them out into their own file which gets build regardless of what printf implementation is used. Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
2015-12-13lib: Split panic functions out of vsprintf.cSjoerd Simons
To allow panic and panic_str to still be used when using tiny-printf, split them out into their own file which gets build regardless of what printf implementation is used. Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
2015-11-23lib/tiny-printf.c: Add tiny printf function for space limited environmentsStefan Roese
This patch adds a small printf() version that supports all basic formats. Its intented to be used in U-Boot SPL versions on platforms with very limited internal RAM sizes. To enable it, just define CONFIG_USE_TINY_PRINTF in your defconfig. This will result in the SPL using this tiny function and the main U-Boot still using the full-blown printf() function. This code was copied from: http://www.sparetimelabs.com/printfrevisited With mostly only coding style related changes so that its checkpatch clean. The size reduction is about 2.5KiB. Here a comparison for the db-mv784mp-gp (Marvell AXP) SPL: Without this patch: 58963 18536 1928 79427 13643 ./spl/u-boot-spl With this patch: 56542 18536 1956 77034 12cea ./spl/u-boot-spl Note: To make it possible to compile tiny-printf.c instead of vsprintf.c when CONFIG_USE_TINY_PRINTF is defined, the functions printf() and vprintf() are moved from common/console.c into vsprintf.c in this patch. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Hans de Goede <hdegoede@redhat.com> Cc: Tom Rini <trini@konsulko.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net>
2015-11-19Add a circular memory buffer implementationSimon Glass
This will be used to support console recording. It provides for a circular buffer which can be written at the head and read from the tail. It supports avoiding data copying by providing raw access to the data. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-10-11Add support for LZ4 decompression algorithmJulius Werner
This patch adds support for LZ4-compressed FIT image contents. This algorithm has a slightly worse compression ration than LZO while being nearly twice as fast to decompress. When loading images from a fast storage medium this usually results in a boot time win. Sandbox-tested only since I don't have a U-Boot development system set up right now. The code was imported unchanged from coreboot where it's proven to work, though. I'm mostly interested in getting this recognized by mkImage for use in a downstream project. Signed-off-by: Julius Werner <jwerner@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2015-08-18of: clean up OF_CONTROL ifdef conditionalsMasahiro Yamada
We have flipped CONFIG_SPL_DISABLE_OF_CONTROL. We have cleansing devices, $(SPL_) and CONFIG_IS_ENABLED(), so we are ready to clear away the ugly logic in include/fdtdec.h: #ifdef CONFIG_OF_CONTROL # if defined(CONFIG_SPL_BUILD) && !defined(SPL_OF_CONTROL) # define OF_CONTROL 0 # else # define OF_CONTROL 1 # endif #else # define OF_CONTROL 0 #endif Now CONFIG_IS_ENABLED(OF_CONTROL) is the substitute. It refers to CONFIG_OF_CONTROL for U-boot proper and CONFIG_SPL_OF_CONTROL for SPL. Also, we no longer have to cancel CONFIG_OF_CONTROL in include/config_uncmd_spl.h and scripts/Makefile.spl. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2015-08-18of: flip CONFIG_SPL_DISABLE_OF_CONTROL into CONFIG_SPL_OF_CONTROLMasahiro Yamada
As we discussed a couple of times, negative CONFIG options make our life difficult; CONFIG_SYS_NO_FLASH, CONFIG_SYS_DCACHE_OFF, ... and here is another one. Now, there are three boards enabling OF_CONTROL on SPL: - socfpga_arria5_defconfig - socfpga_cyclone5_defconfig - socfpga_socrates_defconfig This commit adds CONFIG_SPL_OF_CONTROL for them and deletes CONFIG_SPL_DISABLE_OF_CONTROL from the other boards to invert the logic. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-08-05efi: Add start-up library codeSimon Glass
When running as an EFI application, U-Boot must request memory from EFI, and provide access to the boot services U-Boot needs. Add library code to perform these tasks. This includes efi_main() which is the entry point from EFI. U-Boot is built as a shared library. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-07-21Add rivest cipher 4 (rc4) implementationSimon Glass
Add an implementation of RC4. This will be used by Rockchip booting but may be useful in other situations. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-07-21Drop CONFIG_ERRNO_STR from SPLSimon Glass
This bloats the code size quite a bit and is less useful in SPL where there is no command line. Avoid including this code in SPL. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-07-21Add a dhrystone benchmark commandSimon Glass
Drystone provides a convenient sanity check that the CPU is running at full speed. Add this as a command which can be enabled as needed. Note: I investigated using Coremark for this but there was a license agreement and I could not work out if it was GPL-compatible. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-23fdt: Allow FDT functions to be built for SPLSimon Glass
Remove the implicit assumption that SPL does not support device tree. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-12-11lib: errno: introduce errno_str(): returns errno related messagePrzemyslaw Marczak
The functions error's numbers are standarized - but the error messages are not. The errors are often handled with unclear error messages, so why not use an errno standarized messages. Advantages: - This could decrease the binary size. - Appended with a detailed information, the error message will be clear. This commit introduces new function: - const char *errno_to_str(int errno) The functions returns a pointer to the errno corresponding text message: - if errno is null or positive number - a pointer to "Success" message - if errno is negative - a pointer to errno related message Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Reviewed-by: Tom Rini <trini@ti.com>
2014-12-08libfdt: move CONFIG_OF_LIBFDT and CONFIG_FIT to lib/MakefileMasahiro Yamada
2014-12-08libfdt: descend from lib/ to lib/libfdt/Masahiro Yamada
2014-12-08lib: bzip2: move bzip2 files to lib/bzip2/ directoryMasahiro Yamada
2014-08-25lib, linux: move linux specific defines to linux/compat.hHeiko Schocher
- move linux specific defines from usb and video code into linux/compat.h - move common linux specific defines from include/ubi_uboot.h to linux/compat.h - add for new mtd/ubi/ubifs sync new needed linux specific defines to linux/compat.h Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Marek Vasut <marex@denx.de> Cc: Anatolij Gustschin <agust@denx.de> [trini: Add spin_lock_irqsave/spin_unlock_irqrestore dummies from usb/lin_gadet_compat.h] Signed-off-by: Tom Rini <trini@ti.com>
2014-08-25lib, list_sort: add list_sort from linux 3.14Heiko Schocher
from linux 3.14: commit 455c6fdbd219161bd09b1165f11699d6d73de11c Author: Linus Torvalds <torvalds@linux-foundation.org> Date: Sun Mar 30 20:40:15 2014 -0700 Linux 3.14 Needed for the MTD/UBI/UBIFS resync Just copied the files from Linux, and added in the c-file the "#define __UBOOT__" for adding U-Boot special code. In this case we use this just for adding including U-Boot headers. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Marek Vasut <marex@denx.de> Cc: Sergey Lapin <slapin@ossfans.org> Cc: Scott Wood <scottwood@freescale.com> Cc: Tom Rini <trini@ti.com>
2014-06-23lib, fdt: move fdtdec_get_int() out of lib/fdtdec.cHeiko Schocher
move fdtdec_get_int() out of lib/fdtdec.c into lib/fdtdec_common.c as this function is also used, if CONFIG_OF_CONTROL is not used. Poped up on the ids8313 board using signed FIT images, and activating CONFIG_SYS_GENERIC_BOARD. Without this patch it shows on boot: No valid FDT found - please append one to U-Boot binary, use u-boot-dtb.bin or define CONFIG_OF_EMBED. For sandbox, use -d <file.dtb> With this patch, it boots again with CONFIG_SYS_GENERIC_BOARD enabled. Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@ti.com>
2014-05-23eMMC: add support for operations in RPMB partitionPierre Aubert
This patch adds functions for read, write and authentication key programming for the Replay Protected Memory Block partition in the eMMC. Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com> Signed-off-by: Pierre Aubert <p.aubert@staubli.com>
2014-04-02lib: uuid: add functions to generate UUID version 4Przemyslaw Marczak
This patch adds support to generate UUID (Universally Unique Identifier) in version 4 based on RFC4122, which is randomly. Source: https://www.ietf.org/rfc/rfc4122.txt Changes: - new configs: - CONFIG_LIB_UUID for compile lib/uuid.c - CONFIG_RANDOM_UUID for functions gen_rand_uuid() and gen_rand_uuid_str() - add configs dependency to include/config_fallbacks.h for lib uuid. lib/uuid.c: - add gen_rand_uuid() - this function writes 16 bytes len binary representation of UUID v4 to the memory at given address. - add gen_rand_uuid_str() - this function writes 37 bytes len hexadecimal ASCII string representation of UUID v4 to the memory at given address. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Stephen Warren <swarren@nvidia.com> Cc: Lukasz Majewski <l.majewski@samsung.com> [trini: Add CONFIG_EFI_PARTITION to fallbacks] Signed-off-by: Tom Rini <trini@ti.com>
2014-04-02part_efi: move uuid<->string conversion functions into lib/uuid.cPrzemyslaw Marczak
This commit introduces cleanup for uuid library. Changes: - move uuid<->string conversion functions into lib/uuid.c so they can be used by code outside part_efi.c. - rename uuid_string() to uuid_bin_to_str() for consistency with existing uuid_str_to_bin() - add an error return code to uuid_str_to_bin() - update existing code to the new library functions. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Stephen Warren <swarren@nvidia.com> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: trini@ti.com
2014-03-28lib: rand: introduce new configs: CONFIG_LIB_RAND and CONFIG_LIB_HW_RANDPrzemyslaw Marczak
New configs: - CONFIG_LIB_RAND - to enable implementation of rand library in lib/rand.c - CONFIG_LIB_HW_RAND - to enable hardware based implementations of lib rand Other changes: - add CONFIG_LIB_RAND to boards configs which needs rand() - put only one rand.o dependency in lib/Makefile CONFIG_LIB_HW_RAND should be defined for drivers which implements rand library (declared in include/common.h): - void srand(unsigned int seed) - unsigned int rand(void) - unsigned int rand_r(unsigned int *seedp) Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Michael Walle <michael@walle.cc> Cc: Tom Rini <trini@ti.com> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-03-07kbuild, blackfin: Add CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEEDMasahiro Yamada
Many (but not all) of Blackfin boards give -O2 option to compile under lib/ directory. That means lib/ should be speed-optimized, whereas other parts should be size-optimized. We want to keep the same behavior, but do not want to parse board/*/config.mk again and again. We've got no choice but to invent a new method. CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED, if it is enabled, gives -O2 flag only for building under lib/ directory. Dirty codes which I had marked as "FIX ME" in board/${BOARD}/config.mk have been deleted. Instead, CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED has been defined in include/configs/${BOARD}.h. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Sonic Zhang <sonic.zhang@analog.com>
2014-02-26arm: Switch to -mno-unaligned-access when supported by the compilerTom Rini
When we tell the compiler to optimize for ARMv7 (and ARMv6 for that matter) it assumes a default of SCTRL.A being cleared and unaligned accesses being allowed and fast at the hardware level. We set this bit and must pass along -mno-unaligned-access so that the compiler will still breakdown accesses and not trigger a data abort. To better help understand the requirements of the project with respect to unaligned memory access, the Documentation/unaligned-memory-access.txt file has been added as doc/README.unaligned-memory-access.txt and is taken from the v3.14-rc1 tag of the kernel. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Mans Rullgard <mans@mansr.com> Signed-off-by: Tom Rini <trini@ti.com>
2014-02-19kbuild: use Linux Kernel build scriptsMasahiro Yamada
Now we are ready to switch over to real Kbuild. This commit disables temporary scripts: scripts/{Makefile.build.tmp, Makefile.host.tmp} and enables real Kbuild scripts: scripts/{Makefile.build,Makefile.host,Makefile.lib}. This switch is triggered by the line in scripts/Kbuild.include -build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build.tmp obj +build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build obj We need to adjust some build scripts for U-Boot. But smaller amount of modification is preferable. Additionally, we need to fix compiler flags which are locally added or removed. In Kbuild, it is not allowed to change CFLAGS locally. Instead, ccflags-y, asflags-y, cppflags-y, CFLAGS_$(basetarget).o, CFLAGS_REMOVE_$(basetarget).o are prepared for that purpose. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
2014-02-19kbuild: change out-of-tree buildMasahiro Yamada
This commit changes the working directory where the build process occurs. Before this commit, build process occurred under the source tree for both in-tree and out-of-tree build. That's why we needed to add $(obj) prefix to all generated files in makefiles like follows: $(obj)u-boot.bin: $(obj)u-boot Here, $(obj) is empty for in-tree build, whereas it points to the output directory for out-of-tree build. And our old build system changes the current working directory with "make -C <sub-dir>" syntax when descending into the sub-directories. On the other hand, Kbuild uses a different idea to handle out-of-tree build and directory descending. The build process of Kbuild always occurs under the output tree. When "O=dir/to/store/output/files" is given, the build system changes the current working directory to that directory and restarts the make. Kbuild uses "make -f $(srctree)/scripts/Makefile.build obj=<sub-dir>" syntax for descending into sub-directories. (We can write it like "make $(obj)=<sub-dir>" with a shorthand.) This means the current working directory is always the top of the output directory. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
