path: root/lib/Makefile
2013-11-25Makefile: move some libraries to lib/MakefileMasahiro Yamada
2013-10-31lib: convert makefiles to Kbuild styleMasahiro Yamada
2013-06-26Add trace librarySimon Glass
Add a library which supports tracing of execution using built-in gcc features and a microsecond timer. This can be used to record a list of function which are executed, along with a timestamp for each. Later this information can be sent to the host for processing. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-20Makefile: move the common makefile line to public areaYing Zhang
Move the common makefile line shared by the SPL and non-SPL to the public area, so that we can avoid excessive SPL symbols. Some of them will be used by the SPL later. This patch is on top of the patch "common/Makefile: Add new symbol CONFIG_SPL_ENV_SUPPORT for environment in SPL". Signed-off-by: Ying Zhang <b40530@freescale.com> Acked-by: Tom Rini <trini@ti.com> Acked-by: Tom Rini <trini@ti.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-05lib: import bitrev library from the linux kernelMike Dunn
This patch adds the bitrev library from the linux kernel. This is a simple algorithm that uses an 8 bit look-up table to reverse the bits in data types of 8, 16, or 32 bit widths. The docg4 nand flash driver uses it. [port from linux kernel v3.9 commit 7ee32a6d30d1c8a3b7a07a6269da8f0a08662927] [originally added: v2.6.20 by commit a5cfc1ec58a07074dacb6aa8c79eff864c966d12] Signed-off-by: Mike Dunn <mikedunn@newsguy.com>
2013-05-01lib: consolidate hang()Andreas Bießmann
Delete all occurrences of hang() and provide a generic function. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> [trini: Modify check around puts() in hang.c slightly] Signed-off-by: Tom Rini <trini@ti.com>
2013-05-01Add SLRE - Super Light Regular Expression libraryWolfgang Denk
Downloaded from http://slre.sourceforge.net/ and adapted for U-Boot environment. Used to implement regex operations on environment variables. Code size is ~ 3.5 KiB on PPC. To enable this code, define the CONFIG_REGEX option in your board config file. Note: There are more recent versions of the SLRE library available at http://slre.googlecode.com ; unfortunately, the new code has a heavily reorked API which makes it less usable for our purposes: - the return code is strings, which are more difficult to process - we don't get any information any more which sub-string of the data was matched by the given regex - it is much more cumbersome to work with arbitrary expressions, where for example the number of substrings for capturing are not known at compile time Also, there does not seem to be any real changes or improvements of the functionality. Because of this, we deliberately stick with the older code. Note 2: the test code (built when SLRE_TEST is defined) was modified to allow for more extensive testing; now we can test the regexp matching on all lines on a text file (instead of the whole data in the file as a single block). Signed-off-by: Wolfgang Denk <wd@denx.de>
2013-04-15Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2013-04-12tpm: Add TPM command libraryChe-liang Chiou
TPM command library implements a subset of TPM commands defined in TCG Main Specification 1.2 that are useful for implementing secure boot. More TPM commands could be added out of necessity. You may exercise these commands through the 'tpm' command. However, the raw TPM commands are too primitive for writing secure boot in command interpreter scripts; so the 'tpm' command also provides helper functions to make scripting easier. For example, to define a counter in TPM non-volatile storage and initialize it to zero: $ tpm init $ tpm startup TPM_ST_CLEAR $ tpm nv_define d 0x1001 0x1 $ tpm nv_write d 0x1001 0 And then increment the counter by one: $ tpm nv_read d 0x1001 i $ setexpr.l i $i + 1 $ tpm nv_write d 0x1001 $i Signed-off-by: Che-Liang Chiou <clchiou@chromium.org>
2013-04-08omap_gpmc: add support for hw assisted BCH8Andreas Bießmann
The kernel states: ---8<--- The OMAP3 GPMC hardware BCH engine computes remainder polynomials, it does not provide automatic error location and correction: this step is implemented using the BCH library. --->8--- And we do so in u-boot. This implementation uses the same layout for BCH8 but it is fix. The current provided layout does only work with 64 Byte OOB. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Tom Rini <trini@ti.com> Cc: Ilya Yanok <ilya.yanok@cogentembedded.com> Cc: Scott Wood <scottwood@freescale.com> Cc: Mansoor Ahamed <mansoor.ahamed@ti.com> Cc: Thomas Weber <thomas.weber.linux@googlemail.com>
2013-03-15Introduce a basic initcall implementationSimon Glass
This library supports calling a list of functions one after the other. It is intended that we move to a more powerful initcall implementation as proposed by Graeme Russ <graeme.russ@gmail.com>. For now, this allows us to do the basics. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-12-13Make linux kernel string funcs available to toolsJoe Hershberger
isspace() and strim() are not in the typical user-mode string.h, so put them in a separate compilation unit so that they can be built into tools that need them independent of the other common string functions. This allows code shared by u-boot and the linux user-mode tools to link. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-12-06Introduce arch_phys_memset which works like memset but on physical memoryGabe Black
The default implementation of this function is just memset, but other implementations will be needed when physical memory isn't accessible by U-Boot using normal addressing mechanisms. Signed-off-by: Gabe Black <gabeblack@chromium.org> Signed-off-by: Che-Liang Chiou <clchiou@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2012-10-15ARM: prevent misaligned array initsAlbert ARIBAUD
Under option -munaligned-access, gcc can perform local char or 16-bit array initializations using misaligned native accesses which will throw a data abort exception. Fix files where these array initializations were unneeded, and for files known to contain such initializations, enforce gcc option -mno-unaligned-access. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> [trini: Switch to usign call cc-option for -mno-unaligned-access as Albert had done previously as that's really correct] Signed-off-by: Tom Rini <trini@ti.com>
2012-10-01OMAP: networking support for SPLIlya Yanok
This patch adds support for networking in SPL. Some devices are capable of loading SPL via network so it makes sense to load the main U-Boot binary via network too. This patch tries to use existing network code as much as possible. Unfortunately, it depends on environment which in turn depends on other code so SPL size is increased significantly. No effort was done to decouple network code and environment so far. Signed-off-by: Ilya Yanok <ilya.yanok@cogentembedded.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Tom Rini <trini@ti.com>
2012-09-29lib: add gzip lib function callbackLei Wen
Signed-off-by: Lei Wen <leiwen@marvell.com>
2012-07-07SPL: lib/Makefile: Add crc32.c to SPL buildStefan Roese
This is needed for the SPEAr SPL support, as SPEAr uses the mkimage header to wrap and validate the images (SPL & U-Boot). Signed-off-by: Stefan Roese <sr@denx.de>
2012-07-07net: use common rand()/srand() functionsMichael Walle
Replace rand() with the functions from lib/. The link-local network code stores its own seed, derived from the MAC address. Thus making it independent from calls to srand() in other modules. Signed-off-by: Michael Walle <michael@walle.cc> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2012-07-07lib: add rand() functionMichael Walle
It's a PRNG using the simple and fast xorshift method. Signed-off-by: Michael Walle <michael@walle.cc> Cc: Wolfgang Denk <wd@denx.de>
2012-05-15Add AES crypto libraryYen Lin
Add support for AES using an implementation from Karl Malbrain. This offers small code size (around 5KB on ARM) and supports 128-bit AES only. Signed-off-by: Yen Lin <yelin@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-03-29fdt: Add tests for fdtdecSimon Glass
The fdtdec_find_aliases_for_id() function is complicated enough that it really should have some tests. This does not necessarily need to be committed to U-Boot, but it might be useful. (note there are a few minor inconsistencies with this patch which will be cleaned up when the USB series is applied) Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-03-26SPL: Add YMODEM over UART load supportMatt Porter
Adds support for loading U-Boot from UART using YMODEM protocol. If YMODEM support is enabled in SPL and the romcode indicates that SPL loaded via UART then SPL will wait for start of a YMODEM transfer via the console port. Signed-off-by: Matt Porter <mporter@ti.com> Signed-off-by: Tom Rini <trini@ti.com>
2012-01-26nand: Merge BCH code from Linux nand driverChristian Hitz
[backport from linux commit 02f8c6aee8df3cdc935e9bdd4f2d020306035dbe] This patch merges the BCH ECC algorithm from the 3.0 Linux kernel. This enables U-Boot to support modern NAND flash chips that require more than 1-bit of ECC in software. Signed-off-by: Christian Hitz <christian.hitz@aizo.com> Cc: Scott Wood <scottwood@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-12-24spl: display_options.o is required for SPI flash support in SPLChristian Riesch
Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Heiko Schocher <hs@denx.de> Cc: Mike Frysinger <vapier@gentoo.org>
2011-10-26fdt: add decode helper librarySimon Glass
This library provides useful functions to drivers which want to use the fdt to control their operation. Functions are provided to: - look up and enumerate a device type (for example assigning i2c bus 0, i2c bus 1, etc.) - decode basic types from the fdt, like addresses and integers While this library is not strictly necessary, it helps to minimise the changes to a driver, in order to make it work under fdt control. Less code is required, and so the barrier to switch drivers over is lower. Additional functions to read arrays and GPIOs could be made available here also. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-17lib: add uuid_str_to_bin for use with bootp and PXE uuidJason Hobbs
Signed-off-by: Jason Hobbs <jason.hobbs@calxeda.com>
2011-07-26scaled down version of generic libraries for SPLAneesh V
Signed-off-by: Aneesh V <aneesh@ti.com>
2011-04-30zlib: split up to match original source treeMike Frysinger
While looking to upgrade to zlib-1.2.5, the current mondo merge of multiple files into a single was making things way more difficult than it should have been. Hard to pick out what has been changed to port it to U-Boot, been removed as useless, and bug fixes added after the fact. So split the single file up into the original file names, and merge non-essential changes back from the original tree (for some reason, style in code in a bunch of places was changed to U-Boot style even though this isn't "U-Boot" code). The original build style is retained -- we have a single zlib.c that includes all the other files, and that is the only file we compile. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-01-18lib: add crc7 from LinuxThomas Chou
Crc7 is used to compute mmc spi command packet checksum. Copy from linux-2.6 lib/crc7.c include/linux/crc7.h commit ad241528c4919505afccb022acbab3eeb0db4d80 Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2010-09-19Add hash table support as base for new environment codeWolfgang Denk
This implementation is based on code from uClibc-0.9.30.3 but was modified and extended for use within U-Boot. Major modifications and extensions: * hsearch() [modified / extended]: - While the standard version does not make any assumptions about the type of the stored data objects at all, this implementation works with NUL terminated strings only. - Instead of storing just pointers to the original objects, we create local copies so the caller does not need to care about the data any more. - The standard implementation does not provide a way to update an existing entry. This version will create a new entry or update an existing one when both "action == ENTER" and "item.data != NULL". - hsearch_r(): Instead of returning 1 on success, we return the index into the internal hash table, which is also guaranteed to be positive. This allows us direct access to the found hash table slot for example for functions like hdelete(). * hdelete() [added]: - The standard implementation of hsearch(3) does not provide any way to delete any entries from the hash table. We extend the code to do that. * hexport() [added]: - Export the data stored in the hash table in linearized form: Entries are exported as "name=value" strings, separated by an arbitrary (non-NUL, of course) separator character. This allows to use this function both when formatting the U-Boot environment for external storage (using '\0' as separator), but also when using it for the "printenv" command to print all variables, simply by using as '\n" as separator. This can also be used for new features like exporting the environment data as text file, including the option for later re-import. - The entries in the result list will be sorted by ascending key values. * himport() [added]: - Import linearized data into hash table. This is the inverse function to hexport(): it takes a linear list of "name=value" pairs and creates hash table entries from it. - Entries without "value", i. e. consisting of only "name" or "name=", will cause this entry to be deleted from the hash table. - The "flag" argument can be used to control the behaviour: when the H_NOCLEAR bit is set, then an existing hash table will kept, i. e. new data will be added to an existing hash table; otherwise, old data will be discarded and a new hash table will be created. - The separator character for the "name=value" pairs can be selected, so we both support importing from externally stored environment data (separated by NUL characters) and from plain text files (entries separated by newline characters). - To allow for nicely formatted text input, leading white space (sequences of SPACE and TAB chars) is ignored, and entries starting (after removal of any leading white space) with a '#' character are considered comments and ignored. - NOTE: this means that a variable name cannot start with a '#' character. - When using a non-NUL separator character, backslash is used as escape character in the value part, allowing for example fo multi-line values. - In theory, arbitrary separator characters can be used, but only '\0' and '\n' have really been tested. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-09-19Add qsort - add support for sorting data arraysWolfgang Denk
Code adapted from uClibc-0.9.30.3 Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-09-19Add basic errno support.Wolfgang Denk
Needed for hash table support; probably useful in a lot of other places as well. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
