Grant user the permission to change the bootargs can be very
dangerous, so add config 'CONFIG_APPEND_BOOTARGS' to guard the
bootargs appending feature.
Test: bootargs can't be appended if "CONFIG_APPEND_BOOTARGS" is
not set.
Change-Id: I6d6879415ca251c806b56490290e5032aef24277
Signed-off-by: Ji Luo <ji.luo@nxp.com>
Add fastboot commands "fastboot oem at-get-vboot-unlock-challenge"
and "fastboot oem at-unlock-vboot" to support the authenticated
unlock feature for Android Things devices. Use software random
numbers generator to generate the 16 bytes random challenge, it
should be replaced with hardware encrypted random generator when
the TEE part is ready.
Test: Generate unlock challenge by:
./avbtool make_atx_unlock_credential
--output=atx_unlock_credential.bin
--intermediate_key_certificate=atx_pik_certificate.bin
--unlock_key_certificate=atx_puk_certificate.bin
--challenge=my_generated_challenge.bin
--unlock_key=testkey_atx_puk.pem
validated the unlock credential successfully on imx7d_pico
and AIY.
Change-Id: I4b8cee87c9e96924169479b65020a081136681f6
Some redundant codes are added after cherry-picking android
related commits from imx_v2017.03, remove them in this commit.
Test: build and boot pass on imx6q_sabresd.
Move the A/B slot check to SPL, the A/B slot switch
workflow is just like what we have in libavb_ab.
Test: A/B select works fine on imx8m.
Change-Id: Ie3d827a9be0298b491bf2bc8d48833597fd70e90
Signed-off-by: Luo Ji <ji.luo@nxp.com>
Android Things will load dtb from a single partition like
"oem_bootloader" and we are going to sync normal Android
with Android Things. But just keep loading dtb from bootimage
before everything is ready.
Change-Id: I205528b1485d3e8e9961f19812f380a2b11b991b
Porting the android AVB lib from imx u-boot v2017.03
Signed-off-by: Ye Li <ye.li@nxp.com>
Add CONFIG prefix to DYNAMIC_CRC_TABLE and implement it in
Kconfig.
Signed-off-by: Faiz Abbas <faiz_abbas@ti.com>
config_fallback.h has some logic that checks a variety of options
and selects LIB_UUID if it hasn't already been selected. This
will all LIB_UUID in Kconfig and select this option for the list
of options to allow us to remove the logic from fallbacks
config_fallbacks.h had some logic to automatically select
LIB_RAND if RANDOM_UUID or CMD_UUID were set if LIB_HW_RAND wasn't
already selected. By migrating LIB_HW_RAND to Kconfig, we can
remove this check from config_fallbacks.h and put it into Kconfig
Reviewed-by: Lukasz Majewski <lukma@denx.de>
[trini: Turn into a choice, add NET_RANDOM_ETHADDR]
The sunXi arm64 build has overflown, leading to the main U-boot binary
overwriting the environment when flashing the new image, or even worse,
overwriting itself when we're calling saveenv.
Disable this option that is not critical until we can adress the issue
properly.
Reviewed-by: Andre Przywara <andre.przywara@arm.com>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Reviewed-by: Jagan Teki <jagan@openedev.com>
Freescale (NXP) boards have lots of defconfig files per board.
I used "imply PANIC_HANG" for them.
Reviewed-by: York Sun <york.sun@nxp.com>
Add support for S35392A RTC. The driver supports both U-Boot driver
models.
Signed-off-by: Nandor Han <nandor.han@ge.com>
Signed-off-by: Martyn Welch <martyn.welch@collabora.co.uk>
Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
This is needed for BTRFS.
Signed-off-by: Marek Behun <marek.behun@nic.cz>
create mode 100644 lib/crc32c.c
Add Kconfig option SPL_GZIP and SPL_ZLIB to enable gunzip support for
SPL boot, eg. falcon boot compressed kernel image.
Signed-off-by: York Sun <york.sun@nxp.com>
CONFIG_BCH
s/notes/nodes
With the changes to split SPL/TPL for the RK3368, I apparently missed
some needed adjustments to the RK3188 Kconfig and rock_defconfig.
This fixes build-issues for the rock board after applying the RK3368
enablement (and SPL/TPL) set that resulted from TPL_SERIAL_SUPPORT,
TPL_ROCKCHIP_BACK_TO_BROM and TPL_TINY_MEMSET being separate symbols
now.
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
The above CONFIG options are in Kconfig, and now have correct depends and
inter-dependencies. Migrate these to configs/ from include/configs/. In the
case of CMD_UBIFS also change it to be a default y if CMD_UBI.
CONFIG_LZMA
CONFIG_CMD_AES
CONFIG_AES
[trini: Add select AES to CMD_AES]
Create a new Kconfig entry to allow CMD_UBIFS selection from Kconfig and
add an hidden LZO option that can be selected by CMD_UBIFS.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Acked-by: Jagan Teki <jagan@openedev.com>
Expose the RBTREE feature through Kconfig and select this option from the
MTD_UBI option.
[Rebased on master]
Signed-off-by: Jagan Teki <jagan@openedev.com>
Most of the time the optimised memset() is what we want. For extreme
situations such as TPL it may be too large. For example on the 'rock'
board, using a simple loop saves a useful 48 bytes. With gcc 4.9 and
the rodata bug, this patch is enough to reduce the TPL image below the
limit.
Reviewed-by: Heiko Stuebner <heiko@sntech.de>
So far CONFIG_MD5SUM would need to be set by a board's include file.
Since the command is really generic, move it over to Kconfig to allow
it to be defined by either a board's defconfig, menuconfig or some
config snippet merged via mergeconfig.sh.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
We can pass SMBIOS easily as EFI configuration table to an EFI payload. This
patch adds enablement for that case.
While at it, we also enable SMBIOS generation for ARM systems, since they support
EFI_LOADER.
We will need the SMBIOS generation function on ARM as well going forward,
so let's move it into a non arch specific location.
Move FDT_FIXUP_PARTITIONS to Kconfig and cleanup existing
uses.
The device tree overlays are a good way to deal with user-modifyable
boards or boards with some kind of an expansion mechanism where we can
easily plug new board in (like the BBB, the Raspberry Pi or the CHIP).
Add a new function to merge overlays with a base device tree.
This patch decouples U-Boot binary from the toolchain on systems where
private libgcc is available. Instead of pulling in functions provided
by the libgcc from the toolchain, U-Boot will use it's own set of libgcc
functions. These functions are usually imported from Linux kernel, which
also uses it's own libgcc functions instead of the ones provided by the
toolchain.
This patch solves a rather common problem. The toolchain can usually
generate code for many variants of target architecture and often even
different endianness. The libgcc on the other hand is usually compiled
for one particular configuration and the functions provided by it may
or may not be suited for use in U-Boot. This can manifest in two ways,
either the U-Boot fails to compile altogether and linker will complain
or, in the much worse case, the resulting U-Boot will build, but will
misbehave in very subtle and hard to debug ways.
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Now that we have all the bits and pieces ready for EFI payload loading
support, hook them up in Makefiles and KConfigs so that we can build.
[trini: Enable only when we of OF_LIBFDT, disable on kwb and colibri_pxa270]
Add an option to enable libfdt in SPL. This can be useful when decoding
FIT files in SPL.
We need to make sure this option is not enabled in SPL by this change.
Also this option needs to be enabled in host builds. Si add a new
IMAGE_USE_LIBFDT #define which can be used in files that are built on the
host but must also build for U-Boot and SPL.
Correct spelling of "U-Boot" shall be used in all written text
(documentation, comments in source files etc.).
Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
Enabling this function always removes some class of string saftey issues.
The size change here in general is about 400 bytes and this seems a reasonable
trade-off.
Cc: Peng Fan <peng.fan@nxp.com>
Cc: Peter Robinson <pbrobinson@gmail.com>
Cc: Fabio Estevam <fabio.estevam@freescale.com>
Cc: Adrian Alonso <aalonso@freescale.com>
Cc: Hans de Goede <hdegoede@redhat.com>
This patch adds a small printf() version that supports all basic formats.
Its intented to be used in U-Boot SPL versions on platforms with very
limited internal RAM sizes.
To enable it, just define CONFIG_USE_TINY_PRINTF in your defconfig. This
will result in the SPL using this tiny function and the main U-Boot
still using the full-blown printf() function.
This code was copied from:
http://www.sparetimelabs.com/printfrevisited
With mostly only coding style related changes so that its checkpatch
clean.
The size reduction is about 2.5KiB. Here a comparison for the db-mv784mp-gp
(Marvell AXP) SPL:
Without this patch:
58963 18536 1928 79427 13643 ./spl/u-boot-spl
With this patch:
56542 18536 1956 77034 12cea ./spl/u-boot-spl
Note:
To make it possible to compile tiny-printf.c instead of vsprintf.c when
CONFIG_USE_TINY_PRINTF is defined, the functions printf() and vprintf() are
moved from common/console.c into vsprintf.c in this patch.
Now that all TPM drivers use driver model, we can drop the special driver
model CONFIG option.
Acked-by: Christophe Ricard<christophe-h.ricard@st.com>
This patch adds support for LZ4-compressed FIT image contents. This
algorithm has a slightly worse compression ration than LZO while being
nearly twice as fast to decompress. When loading images from a fast
storage medium this usually results in a boot time win.
Sandbox-tested only since I don't have a U-Boot development system set
up right now. The code was imported unchanged from coreboot where it's
proven to work, though. I'm mostly interested in getting this recognized
by mkImage for use in a downstream project.
Signed-off-by: Julius Werner <jwerner@chromium.org>
Add new Kconfig options for TPMs in preparation for moving boards to use
Kconfig for TPM configuration.
When running as an EFI application, U-Boot must request memory from EFI,
and provide access to the boot services U-Boot needs.
Add library code to perform these tasks. This includes efi_main() which is
the entry point from EFI. U-Boot is built as a shared library.
Drystone provides a convenient sanity check that the CPU is running at full
speed. Add this as a command which can be enabled as needed.
Note: I investigated using Coremark for this but there was a license
agreement and I could not work out if it was GPL-compatible.
Instead of selecting REGEX when NET is enabled, make it the default, but
allow boards that are tiny to disable it and lose functionality on all
but the first Ethernet adapter.
cm-bf548, bf538f-ezkit, and bf533-stamp need this. None appear to have
more than one Ethernet interface.
Commit 9ba9e85f3f1c (net: Fix NET_RANDOM_ETHADDR dependencies)
accidentally dropped CONFIG_LIB_RAND defines for 14 Blackfin boards.
Prior to that commit, those boards defined CONFIG_LIB_RAND, but not
CONFIG_NET_RANDOM_ETHADDR. So, commit 9ba9e85f3f1c should not have
touched them, but in fact it ripped CONFIG_LIB_RAND off from all the
header files, which caused undefined reference to srand and rand.
CONFIG_LIB_RAND=y must be revived for such boards.
BTW, this commit indeed makes it better, but even with this fix,
three boards (bf533-stamp, bf538f-ezkit, cm-bf548) still can not
build due to region 'ram' overflowed error. This was cause by
commit 6eed3786c68c (net: Move the CMD_NET config to defconfigs)
because CMD_NET selects NET, and NET selects REGEX. Eventually,
some boards were newly enabled with CONFIG_REGEX, increasing the
memory footprint. A patch is expected to fix the build error.
NET_RANDOM_ETHADDR depends on lib/rand.c. This patch adds dependency to
Kconfig to ensure that library is also compiled.
Remove the definitions from Blackfin boards' include/configs.
Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com>
Having this as a Kconfig allows it to be a dependent feature.
Move this over to Kconfig and tidy up.
Currently only normal hashing is supported using hardware acceleration.
Added support for progressive hashing using hardware.
Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com>
Signed-off-by: Gaurav Rana <gaurav.rana@freescale.com>
CC: Simon Glass <sjg@chromium.org>
Reviewed-by: York Sun <yorksun@freescale.com>
Kconfig option added for devices which support RSA Verification.
1. RSA_SOFTWARE_EXP
Enables driver for supporting RSA Modular Exponentiation in Software
2. RSA_FREESCALE_EXP
Enables driver for supporting RSA Modular Exponentiation using Freescale specific
driver
The above drivers use RSA uclass
(Removed duplicate line in Kconfig comment)
Change-Id: I7663c4d5350e2bfc3dfa2696f70ef777d6ccc6f6
