Move FDT_FIXUP_PARTITIONS to Kconfig and cleanup existing
uses.
The device tree overlays are a good way to deal with user-modifyable
boards or boards with some kind of an expansion mechanism where we can
easily plug new board in (like the BBB, the Raspberry Pi or the CHIP).
Add a new function to merge overlays with a base device tree.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
This patch decouples U-Boot binary from the toolchain on systems where
private libgcc is available. Instead of pulling in functions provided
by the libgcc from the toolchain, U-Boot will use it's own set of libgcc
functions. These functions are usually imported from Linux kernel, which
also uses it's own libgcc functions instead of the ones provided by the
toolchain.
This patch solves a rather common problem. The toolchain can usually
generate code for many variants of target architecture and often even
different endianness. The libgcc on the other hand is usually compiled
for one particular configuration and the functions provided by it may
or may not be suited for use in U-Boot. This can manifest in two ways,
either the U-Boot fails to compile altogether and linker will complain
or, in the much worse case, the resulting U-Boot will build, but will
misbehave in very subtle and hard to debug ways.
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Now that we have all the bits and pieces ready for EFI payload loading
support, hook them up in Makefiles and KConfigs so that we can build.
[trini: Enable only when we of OF_LIBFDT, disable on kwb and colibri_pxa270]
Add an option to enable libfdt in SPL. This can be useful when decoding
FIT files in SPL.
We need to make sure this option is not enabled in SPL by this change.
Also this option needs to be enabled in host builds. Si add a new
IMAGE_USE_LIBFDT #define which can be used in files that are built on the
host but must also build for U-Boot and SPL.
Correct spelling of "U-Boot" shall be used in all written text
(documentation, comments in source files etc.).
Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
Enabling this function always removes some class of string saftey issues.
The size change here in general is about 400 bytes and this seems a reasonable
trade-off.
Cc: Peng Fan <peng.fan@nxp.com>
Cc: Peter Robinson <pbrobinson@gmail.com>
Cc: Fabio Estevam <fabio.estevam@freescale.com>
Cc: Adrian Alonso <aalonso@freescale.com>
Cc: Hans de Goede <hdegoede@redhat.com>
This patch adds a small printf() version that supports all basic formats.
Its intented to be used in U-Boot SPL versions on platforms with very
limited internal RAM sizes.
To enable it, just define CONFIG_USE_TINY_PRINTF in your defconfig. This
will result in the SPL using this tiny function and the main U-Boot
still using the full-blown printf() function.
This code was copied from:
http://www.sparetimelabs.com/printfrevisited
With mostly only coding style related changes so that its checkpatch
clean.
The size reduction is about 2.5KiB. Here a comparison for the db-mv784mp-gp
(Marvell AXP) SPL:
Without this patch:
58963 18536 1928 79427 13643 ./spl/u-boot-spl
With this patch:
56542 18536 1956 77034 12cea ./spl/u-boot-spl
Note:
To make it possible to compile tiny-printf.c instead of vsprintf.c when
CONFIG_USE_TINY_PRINTF is defined, the functions printf() and vprintf() are
moved from common/console.c into vsprintf.c in this patch.
Now that all TPM drivers use driver model, we can drop the special driver
model CONFIG option.
Acked-by: Christophe Ricard<christophe-h.ricard@st.com>
This patch adds support for LZ4-compressed FIT image contents. This
algorithm has a slightly worse compression ration than LZO while being
nearly twice as fast to decompress. When loading images from a fast
storage medium this usually results in a boot time win.
Sandbox-tested only since I don't have a U-Boot development system set
up right now. The code was imported unchanged from coreboot where it's
proven to work, though. I'm mostly interested in getting this recognized
by mkImage for use in a downstream project.
Signed-off-by: Julius Werner <jwerner@chromium.org>
Add new Kconfig options for TPMs in preparation for moving boards to use
Kconfig for TPM configuration.
When running as an EFI application, U-Boot must request memory from EFI,
and provide access to the boot services U-Boot needs.
Add library code to perform these tasks. This includes efi_main() which is
the entry point from EFI. U-Boot is built as a shared library.
Drystone provides a convenient sanity check that the CPU is running at full
speed. Add this as a command which can be enabled as needed.
Note: I investigated using Coremark for this but there was a license
agreement and I could not work out if it was GPL-compatible.
Instead of selecting REGEX when NET is enabled, make it the default, but
allow boards that are tiny to disable it and lose functionality on all
but the first Ethernet adapter.
cm-bf548, bf538f-ezkit, and bf533-stamp need this. None appear to have
more than one Ethernet interface.
Commit 9ba9e85f3f1c (net: Fix NET_RANDOM_ETHADDR dependencies)
accidentally dropped CONFIG_LIB_RAND defines for 14 Blackfin boards.
Prior to that commit, those boards defined CONFIG_LIB_RAND, but not
CONFIG_NET_RANDOM_ETHADDR. So, commit 9ba9e85f3f1c should not have
touched them, but in fact it ripped CONFIG_LIB_RAND off from all the
header files, which caused undefined reference to srand and rand.
CONFIG_LIB_RAND=y must be revived for such boards.
BTW, this commit indeed makes it better, but even with this fix,
three boards (bf533-stamp, bf538f-ezkit, cm-bf548) still can not
build due to region 'ram' overflowed error. This was cause by
commit 6eed3786c68c (net: Move the CMD_NET config to defconfigs)
because CMD_NET selects NET, and NET selects REGEX. Eventually,
some boards were newly enabled with CONFIG_REGEX, increasing the
memory footprint. A patch is expected to fix the build error.
NET_RANDOM_ETHADDR depends on lib/rand.c. This patch adds dependency to
Kconfig to ensure that library is also compiled.
Remove the definitions from Blackfin boards' include/configs.
Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com>
Having this as a Kconfig allows it to be a dependent feature.
Move this over to Kconfig and tidy up.
Currently only normal hashing is supported using hardware acceleration.
Added support for progressive hashing using hardware.
Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com>
Signed-off-by: Gaurav Rana <gaurav.rana@freescale.com>
CC: Simon Glass <sjg@chromium.org>
Reviewed-by: York Sun <yorksun@freescale.com>
Kconfig option added for devices which support RSA Verification.
1. RSA_SOFTWARE_EXP
Enables driver for supporting RSA Modular Exponentiation in Software
2. RSA_FREESCALE_EXP
Enables driver for supporting RSA Modular Exponentiation using Freescale specific
driver
The above drivers use RSA uclass
(Removed duplicate line in Kconfig comment)
Change-Id: I7663c4d5350e2bfc3dfa2696f70ef777d6ccc6f6
For FIT signature based approach to work, RSA library needs to be selected.
The FIT_SIGNATURE option in Kconfig is modified to automatically select RSA.
Selecting RSA compiles the RSA library required for image verification.
The private libgcc is supported only on ARM, MIPS, PowerPC, SH, x86.
Those architectures should "select" HAVE_PRIVATE_LIBGCC and
CONFIG_USE_PRIVATE_LIBGCC should depend on it.
Currently, this option is enabled on Tegra boards and x86 architecture.
Move the definition from header files to Kconfig.
Cc: Stephen Warren <swarren@nvidia.com>
Cc: Tom Warren <twarren@nvidia.com>
CONFIG_SYS_HZ is always defined as 1000 in config_fallbacks.h
(but some boards still have redundant definitions).
This commit moves the definition and the document in README to
Kconfig. Since lib/Kconfig can assure that CONFIG_SYS_HZ is 1000,
the sanity check in lib/time.c should be removed.
If this option is enabled, the objects under lib/ directory
are compiled with speed optimization, not size optimization.
(Currently, only used by some Blackfin boards.)
This would be useful to start moving various config options.
