CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
CONFIG_SYS_CONSOLE_ENV_OVERWRITE
CONFIG_CONSOLE_SCROLL_LINES
This is not used in U-Boot. Drop it.
This should be defined in a header file so that arguments are checked.
Move it to video.h.
CONFIG_CONSOLE_EXTRA_INFO
CONFIG_VIDEO_SW_CURSOR
[trini: Re-convert, find all the cases where this is off]
CONFIG_VGA_AS_SINGLE_DEVICE
Once we migrate to driver model for video, we should be able to drop this
option.
CONFIG_SYS_CONSOLE_BG_COL
CONFIG_SYS_CONSOLE_FG_COL
CONFIG_VIDEO_CT69000
CONFIG_CFB_CONSOLE_ANSI
CONFIG_CFB_CONSOLE
This is not really a config. Rename it to avoid confusion.
Reviewed-by: Jagan Teki <jteki@openedev.com>
CONFIG_SYS_CONSOLE_IS_IN_ENV
CONFIG_CONSOLE_MUX
[trini: Re-order, re-migrate]
CONFIG_LCD
CONFIG_VIDEO
Move these option to Kconfig and tidy up existing uses.
The Power PC boards don't have a suitable common element: the common header
files don't appear to line up with the Kconfig files as far as I can tell.
This results in a lot of defconfig changes.
[trini: Re-migrate, update common/console.c logic]
Patch queue for efi - 2016-10-19
Highlights this time around:
- Add run time service (power control) support for PSCI (fixed in v3)
- Add efi gop pointer exposure
- SMBIOS support for EFI (on ARM)
- efi pool memory unmap support (needed for 4.8)
- initial x86 efi payload support (fixed up in v2)
- various bug fixes
include/tables_csum.h
Compiler attributes are more commonly __foo style tags rather than big
upper case eye sores like EFI_RUNTIME_TEXT.
Simon Glass felt quite strongly about this, so this patch converts our
existing defines over to more eye friendly ones.
These are missing in some functions. Add them to keep things consistent.
Reviewed-by: Alexander Graf <agraf@suse.de>
This is required for x86 and is also correct for ARM (since it is empty).
We can pass SMBIOS easily as EFI configuration table to an EFI payload. This
patch adds enablement for that case.
While at it, we also enable SMBIOS generation for ARM systems, since they support
EFI_LOADER.
The type 4 table generation code is very x86 centric today. Refactor things
out into the device model cpu class to allow the tables to get generated for
other architectures as well.
The CPU udevice already has a few callbacks to retreive information
about the currently running CPUs. This patch adds a new get_vendor()
call that returns the vendor of the main CPUs.
For SMBIOS tables we need to know the CPU family as well as CPU IDs. This
patches allocates some space for them in the cpu device and populates it
on x86.
The SMBIOS generation code passes pointers as u32. That causes the compiler
to warn on casts to pointers. This patch moves all address pointers to
uintptr_t instead.
Technically u32 would be enough for the current SMBIOS2 style tables, but
we may want to extend the code to SMBIOS3 in the future which is 64bit
address capable.
We want to be able to add configuration table entries from our own code as
well as from EFI payload code. Export the boot service function internally
too, so that we can reuse it.
We will need the SMBIOS generation function on ARM as well going forward,
so let's move it into a non arch specific location.
We need the checksum function without all the other table functionality
soon, so let's split it out into its own C file.
soon, so let's split it out into its own header file.
EFI allows an OS to leverage firmware drivers while the OS is running. In the
generic code we so far had to stub those implementations out, because we would
need board specific knowledge about MMIO setups for it.
However, boards can easily implement those themselves. This patch provides the
framework so that a board can implement its own versions of get_time and
reset_system which would actually do something useful.
While at it we also introduce a simple way for code to reserve MMIO pointers
as runtime available.
Currently each allocation creates a new mapping. Readding the mapping
as free memory (EFI_CONVENTIONAL_MEMORY) potentially allows to hand out
an existing mapping, thus limiting the number of mapping descriptors in
the memory map.
Mitigates a problem with current (4.8rc7) linux kernels when doing an
efi_get_memory map, resulting in an infinite loop. Space for the memory
map is reserved with allocate_pool (implicitly creating a new mapping) and
filled. If there is insufficient slack space (8 entries) in the map, the
space is freed and a new round is started, with space for one more entry.
As each round increases requirement and allocation by exactly one, there
is never enough slack space. (At least 32 entries are allocated, so as
long as there are less than 24 entries, there is enough slack).
Earlier kernels reserved no slack, and did less allocations, so this
problem was not visible.
Signed-off-by: Stefan Brüns <stefan.bruens@rwth-aachen.de>
We need a functional free_pool implementation, as otherwise each
allocate_pool causes growth of the memory descriptor table.
Different to free_pages, free_pool does not provide the size for the
to be freed allocation, thus we have to track the size ourselves.
As the only EFI requirement for pool allocation is an alignment of
8 bytes, we can keep allocating a range using the page allocator,
reserve the first 8 bytes for our bookkeeping and hand out the
remainder to the caller. This saves us from having to use any
independent data structures for tracking.
To simplify the conversion between pool allocations and the corresponding
page allocation, we create an auxiliary struct efi_pool_allocation.
Given the allocation size free_pool size can handoff freeing the page
range, which was indirectly allocated by a call to allocate_pool,
to free_pages.
We currently handle efi_allocate_pool() in our boot time service
file. In the following patch, pool allocation will receive additional
internal semantics that we should preserve inside efi_memory.c instead.
As foundation for those changes, split the function into an externally
facing efi_allocate_pool_ext() for use by payloads and an internal helper
efi_allocate_pool() in efi_memory.c that handles the actual allocation.
While at it, change the magic 0xfff / 12 constants to the more obvious
EFI_PAGE_MASK/SHIFT defines.
ARCH_UNIPHIER selects DM_USB, where CONFIG_USB_MAX_CONTROLLER_COUNT
is not used.
Move FDT_FIXUP_PARTITIONS to Kconfig and cleanup existing
uses.
Move SYS_OS_BASE to Kconfig and cleanup existing
uses.
[trini: Also migrate a4m2k]
Move SPL_OS_BOOT to Kconfig and cleanup existing
uses.
T series boards use unified RCW for sd, spi and nand boot.
Now split txxx_rcw.cfg to txxx_sd_rcw.cfg, txxx_spi_rcw.cfg
and txxx_nand_rcw.cfg for SPI/NAND/SD boot.
And modify RCW[PBI_SRC] for them:
PBI_SRC=5 for SPI 24-bit addressing
PBI_SRC=6 for SD boot
PBI_SRC=14 for IFC NAND boot
Signed-off-by: Zhao Qiang <qiang.zhao@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
The fdt_path_offset() function is not inlined in upstream libfdt. Adjust
U-Boot's version to match.
The signature for this macro has changed. Bring in the upstream version and
adjust U-Boot's usages to suit.
Update to drivers/power/pmic/palmas.c:
Signed-off-by: Keerthy <j-keerthy@ti.com>
Change-Id: I6cc9021339bfe686f9df21d61a1095ca2b3776e8
These have now landed upstream. The naming is different and in one case the
function signature has changed. Update the code to match.
This applies the following upstream commits by
Thierry Reding <treding@nvidia.com> :
604e61e fdt: Add functions to retrieve strings
8702bd1 fdt: Add a function to get the index of a string
2218387 fdt: Add a function to count strings
This includes small changes to the following functions, from upstream
commit 6d1832c:
- fdt_get_max_phandle() (upstream commit 84e0e134)
- fdt_node_check_compatible (upstream commit 53bf130b)
- fdt_setprop_inplace_namelen_partial() to remove useless brackets and
use idx instead of index
- _fdt_resize_property() to use idx instead of index
- _fdt_splice() (upstream commit d4c7c25c)
It also includes various typo fixes in libfdt.h
