path: root/include
2013-12-16Merge branch 'master' of git://git.denx.de/u-boot-blackfinTom Rini
2013-12-16common/cmd_bootm: extend do_bootm_vxworks to support the new VxWorks boot ↵Miao Yan
interface. The next version VxWorks adopts device tree (for PowerPC and ARM) as its hardware description mechanism. For PowerPC, the boot interface conforms to the ePAPR standard, which is: void (*kernel_entry)(ulong fdt_addr, ulong r4 /* 0 */, ulong r5 /* 0 */, ulong r6 /* EPAPR_MAGIC */, ulong r7 /* IMA size */, ulong r8 /* 0 */, ulong r9 /* 0 */) For ARM, the boot interface is: void (*kernel_entry)(void *fdt_addr) Signed-off-by: Miao Yan <miao.yan@windriver.com> [trini: Fix build error when !CONFIG_OF_FDT is set, typo on PowerPC, missing extern ft_fixup_num_cores] Signed-off-by: Tom Rini <trini@ti.com>
2013-12-16blackfin: fix building error by enlarging the memory sizeSonic Zhang
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
2013-12-16blackfin: Disable commands to reduce l1 ram requirementSonic Zhang
2013-12-16blackfin: fix building error by adding macro CONFIG_SYS_I2CSonic Zhang
2013-12-16blackfin: fix build error by adding CONFIG_BFIN_SERIALSonic Zhang
2013-12-13common/config_defaults.h: make CONFIG_BOOTM_VXWORKS default configurationMiao Yan
2013-12-13kgdb: configs: remove obsolete CONFIG_KGDB_SER_INDEXVladimir Zapolskiy
The last users of CONFIG_KGDB_SER_INDEX were removed more than 3 years ago in commits 550650ddd0 and bf16500f79, either kgdb subsystem should care about this parameter or it should be gone completely. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2013-12-10Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Conflicts: board/samsung/trats2/trats2.c include/configs/exynos5250-dt.h Signed-off-by: Tom Rini <trini@ti.com>
2013-12-10Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: arch/arm/cpu/armv7/rmobile/Makefile doc/README.scrapyard Needed manual fix: arch/arm/cpu/armv7/omap-common/Makefile board/compulab/cm_t335/u-boot.lds
2013-12-10Merge branch 'spi' of git://git.denx.de/u-boot-x86Tom Rini
2013-12-10Merge branch 'master' of git://git.denx.de/u-boot-mmcTom Rini
2013-12-10Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
2013-12-10vexpress: use correct timer address on extended memory map systemsIan Campbell
Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Cc: albert.u.boot@aribaud.net
2013-12-09sandbox: spi: Enable new spi/sf layersMike Frysinger
We want to test SPI flash code in the sandbox, so enable the new drivers and the 'sf test' command. This command is used to validate the sandbox SPI / SPI flash implementation, so enable it. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2013-12-09spi_flash: Add spi_flash_probe_fdt() to locate SPI by FDT nodeSimon Glass
This allows us to put the SPI flash chip inside the SPI interface node, with U-Boot finding the correct bus and chip select automatically. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-12-09arm: at91: support for the Calao USB-A9263 board (based on AT91SAM9263)Mateusz Kulikowski
Add support for USB-A9263 board manufactured by Calao Systems (http://www.calao-systems.com/). Code is based on old U-Boot sources (2010.09) released by Calao. Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-12-09arm, at91: add siemens corvus boardHeiko Schocher
enable support for the siemens AT91SAM9G20 based board corvus. Signed-off-by: Boris Schmidt <boris.schmidt@siemens.com> Reviewed-by: Heiko Schocher <hs@denx.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-12-09arm, at91: add Siemens board taurus and axmHeiko Schocher
enable support for the siemens AT91SAM9G20 based boards taurus and axm. Signed-off-by: Roger Meier <r.meier@siemens.com> Reviewed-by: Heiko Schocher <hs@denx.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-12-09at91: switch coloured LED to gpio APIAndreas Bießmann
2013-12-09at91: nand: switch atmel_nand to generic GPIO APIAndreas Bießmann
Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Acked-by: Jens Scharsig (BuS Elektronik)<esw@bus-elektronik.de> Tested-by: Jens Scharsig (BuS Elektronik)<esw@bus-elektronik.de> Acked-by: Scott Wood <scottwood@freescale.com>
2013-12-08mmc: add Faraday FTSDC021 SDHCI controller supportKuo-Jung Su
Faraday FTSDC021 is a controller which is compliant with SDHCI v3.0, SDIO v2.0 and MMC v4.3. However this driver is only verified with SD memory cards. Signed-off-by: Kuo-Jung Su <dantesu@faraday-tech.com> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com> CC: Andy Fleming <afleming@gmail.com>
2013-12-08mmc: dw_mmc: remove the exynos specific code in dw-mmc.cJaehoon Chung
dw-mmc.c is the general driver file. So, remove the exynos specific code at dw-mmc.c. Instead, exynos specific cod can be move into exynos-dw_mmc.c. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Acked-by: Alexey Brodkin <abrodkin@synopsys.com> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com> Acked-by: Minkyu Kang <mk7.kang@samsung.com>
2013-12-06Merge branch 'u-boot-samsung/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-12-06Merge branch 'u-boot-ti/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-12-06Merge branch 'master' of git://git.denx.de/u-boot-blackfinTom Rini
2013-12-06AM3517 EVM: Enable ethernetTom Rini
2013-12-06omap4_panda: Don't use ulpi_resetRoger Quadros
Fixes this error message when USB is started. "ULPI: ulpi_reset: failed writing reset bit" It is pointless to manually reset the ULPI as the USB Host Reset and PHY RESET line should take care of that. Reported-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Roger Quadros <rogerq@ti.com>
2013-12-06omap3_beagle: Don't use ulpi_resetRoger Quadros
2013-12-06arm: arndale: disable spi bootMinkyu Kang
arndale board is booted from mmc Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Inderpal Singh <inderpal.singh@linaro.org>
2013-12-06blackfin: soft-i2c: No need to define blackfin specific soft i2c operationsSonic Zhang
Use default GPIO operations. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Acked-by: Heiko Schocher <hs@denx.de>
2013-12-06blackfin: Add missing macro CONFIG_BFIN_SERIALSonic Zhang
2013-12-06blackfin: Use ADI_GPIO2 driver other than the default ADI_GPIO1Sonic Zhang
2013-12-05driver:i2c:s3c24x0: adapt driver to new i2cPiotr Wilczek
This patch adapts the s3c24x0 driver to the new i2c framework. Config file is modified for all the boards that use the driver. Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> CC: Minkyu Kang <mk7.kang@samsung.com> CC: Heiko Schocher <hs@denx.de> CC: Inderpal Singh <inderpal.singh@linaro.org> CC: David Müller <d.mueller@elsoft.ch> CC: Chander Kashyap <k.chander@samsung.com> CC: Lukasz Majewski <l.majewski@samsung.com> Tested-by: Naveen Krishna Chatradhi <ch.naveen@samsung.com> Reviewed-by: Naveen Krishna Chatradhi <ch.naveen@samsung.com>
2013-12-04powerpc/mpc8349: Use generic mpc85xx DDR driverYork Sun
MPC8349 has been using mpc85xx DDR driver through a symbolic link to mpc85xx_ddr_gen2.c. After consolidating the drivers to a single set under driver/ddr/fsl/, the link is replaced by referring driver directly. We now can simply enable the macro and use the driver. Other mpc83xx SoCs still use their own driver. Signed-off-by: York Sun <yorksun@freescale.com>
2013-12-04powerpc/t2080qds: undef CONFIG_FSL_DDR_INTERACTIVEShengzhou Liu
Usually CONFIG_FSL_DDR_INTERACTIVE feature is used for debug. we would not enable this by default to save the limited space of u-boot. This avoid following compiling error: section .bootpg loaded at [00000000effff000,00000000effff577] overlap ssection .data loaded at [00000000efff31b8,00000000f00010c7] u-boot: section .bootpg lma 0xeffff000 adjusted to 0xf00010c8 Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2013-12-04powerpc/p1010rdb:modify the mtest start_addressZhao Qiang
In new board P1010RDB-PB, the interrupt vector table is at the start of memory. So if the start_address needs to be set a proper value. Signed-off-by: Zhao Qiang <B45475@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2013-12-04arm: am335x: Add DT (FDT) support to Siemens boardsStefan Roese
Enable FDT support for all Siemens AM335x boards. To support newer Linux kernels with DT booting. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Roger Meier <r.meier@siemens.com> Cc: Lukas Stockmann <lukas.stockmann@siemens.com> Cc: Tom Rini <trini@ti.com> Acked-by: Heiko Schocher<hs@denx.de>
2013-12-04am335x_evm: Update nandboot to use partitions and DTTom Rini
2013-12-04ARM: dra7_evm: Add SATA supportRoger Quadros
The evm has a SATA port. Enable SATA configuration and inititialize the SATA controller. Signed-off-by: Roger Quadros <rogerq@ti.com>
2013-12-04ARM: omap5_uevm: Add SATA supportRoger Quadros
The uevm has a SATA port. Inititialize the SATA controller. Signed-off-by: Roger Quadros <rogerq@ti.com>
2013-12-04ARMV7: OMAP4: Add twl6032 supportOleg Kosheliev
Added chip type detection and twl6032 support in the battery control and charge functions. Based on Balaji T K <balajitk@ti.com> patches for TI u-boot. Signed-off-by: Oleg Kosheliev <oleg.kosheliev@ti.com>
2013-12-04ARMV7: OMAP4: Add struct for twl603x dataOleg Kosheliev
The data struct is used to support different PMIC chip types. It contains the chip type and the data (e.g. registers addresses, adc multiplier) which is different for twl6030 and twl6032. Replaced some hardcoded values with the structure vars. Based on Balaji T K <balajitk@ti.com> patches for TI u-boot. Signed-off-by: Oleg Kosheliev <oleg.kosheliev@ti.com>
2013-12-04cm_t335: add support for pca9555 i2c gpio extenderIlya Ledvich
Add support for the 16 bits pca9555 i2c to gpio extender featured by the SB-T335 baseboard. Signed-off-by: Ilya Ledvich <ilya@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2013-12-04cm_t335: add support for status LEDIlya Ledvich
Add support for status LED. Use the STATUS_LED APIs for indicating a boot progress. Signed-off-by: Ilya Ledvich <ilya@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2013-12-04cm_t335: add cm_t335 board supportIlya Ledvich
Add cm_t335 board directory, config file. Enable build. Signed-off-by: Ilya Ledvich <ilya@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> [trini: Adapt Makefile] Signed-off-by: Tom Rini <trini@ti.com>
2013-12-03board: trats2: update Tizen partition definitionsPiotr Wilczek
This patch updates Tizen partions layout. Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-12-03board: trats2: fix environmental variablesPiotr Wilczek
In this patch variable names are used instead of hardcoded names Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-12-03board: trats2: remove unused defines from config filePiotr Wilczek
2013-12-03exynos: spl: Add a custom spi copy functionRajeshwari Shinde
This patch implements a custom spi_copy funtion to copy u-boot from SF to RAM. This is faster then iROM spi_copy funtion as this runs spi at 50Mhz and also in WORD mode of operation. Changed a printf in pinmux.c to debug just to avoid the compilation error in SPL. Signed-off-by: Alim Akhtar <alim.akhtar@samsung.com> Signed-off-by: Tom Wai-Hong Tam <waihong@chromium.org> Signed-off-by: Rajeshwari S Shinde <rajeshwari.s@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
