path: root/include
2012-01-05Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
* 'master' of git://git.denx.de/u-boot-arm: tegra2: Optimize out-of-tree build for Ventana. tegra: Move boards over to use arch-level board UART function tegra: Add support for UART init in cpu board.c tegra: Add a function mux feature tegra: add clock_ll_start_uart() to enable UART prior to reloc tegra: Move clock_early_init() to arch_cpu_init() tegra: Move cpu_init_cp15() to arch_cpu_init() arm: Tegra: Fix Harmony and Ventana builds in u-boot-tegra/master tegra: Fix build error in plutux, medcom tegra2: Add Avionic Design Medcom support. tegra2: Add Avionic Design Plutux support. tegra2: Add common Avionic Design Tamonten support. tegra2: Move tegra2_mmc_init() prototype to public header. tegra2: Change CONFIG_SYS_TEXT_BASE to 0x00108000. tegra2: Always build with USE_PRIVATE_LIBGCC=yes. tegra2: Plumb in SPI/UART switch code tegra2: spi: Support SPI / UART switch tegra2: Implement SPI / UART GPIO switch tegra2: Enable SPI environment on Seaboard tegra2: config: Enable SPI flash on Seaboard tegra2: spi: Add SPI driver for Tegra2 SOC tegra2: Add UARTB support tegra2: Tidy UART selection arm, davinci: Fix build warnings for cam_enc_4xx Devkit8000: Switch over to enable_gpmc_cs_config arm, davinci: Add support for generating AIS images to the Makefile mkimage: Fix variable length header support arm, da850evm: Add an SPL for SPI boot arm, davinci: Add SPL support for DA850 SoCs sf: Add spi_boot() to allow booting from SPI flash in an SPL spl: display_options.o is required for SPI flash support in SPL ARM: omap3: add support to Technexion twister board ARM: omap3: added common configuration for Technexion TAM3517 vision2: Fix checkpatch warning
2012-01-05env: remove value from boolean definesIgor Grinberg
Several boolean defines have a value assigned. Remove the value as defining the symbol is enough. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-01-05common.h: remove value from bool definesIgor Grinberg
Several boolean defines have a value assigned. Remove the value as defining the symbol is enough. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-01-05fpga: add definition for Xilinx Spartan-6 XC6SLX4Stefano Babic
2012-01-05phy: add phy_smsc_init() declarationVladimir Zapolskiy
This trivial change removes a compilation warning: ----8<---- phy.c: In function 'phy_init': phy.c:448:2: warning: implicit declaration of function 'phy_smsc_init' ----8<---- Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Acked-by: Marek Vasut <marek.vasut@gmail.com>
2011-12-24arm: Tegra: Fix Harmony and Ventana builds in u-boot-tegra/masterTom Warren
Seaboard changes have removed the need for common/board.o in the Makefile. Propagate this change to the other Tegra2 builds. Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-24tegra: Fix build error in plutux, medcomSimon Glass
We need to define CONFIG_ENV_IS_NOWHERE to avoid this error: cmd_nvedit.c:69:3: error: #error Define one of CONFIG_ENV_IS_IN_... Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-24tegra2: Add Avionic Design Medcom support.Thierry Reding
The Medcom is a 16:9 15" terminal that is used for patient infotainment in hospitals. Changes in v3: * Remove unused implementation of gpio_config_uart(). * Implement MMC/SD card detection. * Drop board_mmc_getcd() which is now implemented by common Tegra2 code. * Add MAINTAINERS entry. Changes in v2: * No longer override the default CONFIG_SYS_TEXT_BASE setting. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-24tegra2: Add Avionic Design Plutux support.Thierry Reding
The Plutux is a set-top box device based on the Tamonten processor module. It can be connected to a display via an HDMI output. Changes in v3: * Remove unused implementation of gpio_config_uart(). * Implement MMC/SD card detection. * Drop board_mmc_getcd() which is now implemented by common Tegra2 code. * Add MAINTAINERS entry. Changes in v2: * No longer override the default CONFIG_SYS_TEXT_BASE setting. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-24tegra2: Change CONFIG_SYS_TEXT_BASE to 0x00108000.Thierry Reding
NVIDIA's flashing tools assume that the bootloader is loaded at address 0x00108000. Instead of requiring non-standard builds of those tools which allow a load address of 0x00E08000, this commit just switches all Tegra2 boards to use the standard load address. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Tested-by: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-24tegra2: Enable SPI environment on SeaboardSimon Glass
This uses the SPI flash on Seaboard to store an 8KB environment. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-24tegra2: config: Enable SPI flash on SeaboardSimon Glass
The Seaboard includes a Winbond 4MB flash part. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-24arm, da850evm: Add an SPL for SPI bootChristian Riesch
Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Heiko Schocher <hs@denx.de> Cc: Sandeep Paulraj <s-paulraj@ti.com> Cc: Tom Rini <trini@ti.com> Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
2011-12-24sf: Add spi_boot() to allow booting from SPI flash in an SPLChristian Riesch
Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Heiko Schocher <hs@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Scott Wood <scottwood@freescale.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-12-24ARM: omap3: add support to Technexion twister boardStefano Babic
The twister board is a development board using the TAM3517 SOM. Support for NAND, 2 Ethernet (EMAC and SMC911), USB (EHCI_OMAP). Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Tapani Utrianen <tapani@technexion.com> CC: Tom Rini <tom.rini@gmail.com> CC: Sandeep Paulraj <s-paulraj@ti.com>
2011-12-24ARM: omap3: added common configuration for Technexion TAM3517Stefano Babic
The TAM3517 is a SOM module that can be used on custom boards. The patch add a common configuration file that is included by the boards using this module. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Tapani Utrianen <tapani@technexion.com> CC: Tom Rini <tom.rini@gmail.com> CC: Sandeep Paulraj <s-paulraj@ti.com>
2011-12-23Merge branch 'next' of ../nextWolfgang Denk
* 'next' of ../next: mkenvimage: Add version info switch (-V) mkenvimage: Fix getopt() error handling mkenvimage: Fix some typos phy: add Micrel KS8721BL phy definition net: introduce per device index mvgbe: remove setting of ethaddr within the driver x86: Add support for specifying an initrd with the zboot command x86: Refactor the zboot innards so they can be reused with a vboot image x86: Add infrastructure to extract an e820 table from the coreboot tables x86: Add support for booting Linux using the 32 bit boot protocol x86: Clean up the x86 zimage code in preparation to extend it x86: Import code from coreboot's libpayload to parse the coreboot table x86: Initial commit for running as a coreboot payload CHECKPATCH: ./board/esd/hh405/logo_320_240_8bpp.c CHECKPATCH: ./board/esd/hh405/logo_1024_768_8bpp.c CHECKPATCH: ./board/esd/hh405/logo_320_240_4bpp.c CHECKPATCH: ./board/esd/hh405/logo_640_480_24bpp.c CHECKPATCH: ./board/esd/apc405/logo_640_480_24bpp.c CHECKPATCH: ./board/esd/voh405/logo_320_240_4bpp.c CHECKPATCH: ./board/esd/voh405/logo_640_480_24bpp.c CHECKPATCH: ./board/esd/hh405/fpgadata.c CHECKPATCH: ./board/esd/pci405/fpgadata.c CHECKPATCH: ./board/esd/tasreg/fpgadata.c CHECKPATCH: ./board/esd/apc405/fpgadata.c CHECKPATCH: ./board/esd/voh405/fpgadata.c CHECKPATCH: ./board/esd/ash405/fpgadata.c CHECKPATCH: ./board/esd/dasa_sim/fpgadata.c CHECKPATCH: ./board/esd/ar405/fpgadata_xl30.c CHECKPATCH: ./board/esd/ar405/fpgadata.c CHECKPATCH: ./board/esd/plu405/fpgadata.c CHECKPATCH: ./board/esd/wuh405/fpgadata.c CHECKPATCH: ./board/esd/cpci405/fpgadata_cpci405.c CHECKPATCH: ./board/esd/cpci405/fpgadata_cpci405ab.c CHECKPATCH: ./board/esd/cpci405/fpgadata_cpci4052.c CHECKPATCH: ./board/esd/canbt/fpgadata.c CHECKPATCH: ./board/esd/du405/fpgadata.c CHECKPATCH: ./board/esd/cpciiser4/fpgadata.c CHECKPATCH: ./board/dave/PPChameleonEVB/fpgadata.c avr32:mmu.c: fix printf() length modifier fat.c: fix printf() length modifier cmd_sf.c: fix printf() length modifier Make printf and vprintf safe from buffer overruns vsprintf: Move function documentation into header file Add safe vsnprintf and snprintf library functions Move vsprintf functions into their own header Conflicts: tools/mkenvimage.c Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-12-20usb: s3c_udc_otg: fix GCC 4.6 build warningsAnatolij Gustschin
Fix: In file included from s3c_udc_otg.c:216:0: s3c_udc_otg_xfer_dma.c: In function 'complete_tx': s3c_udc_otg_xfer_dma.c:280:33: warning: variable 'is_short' set but not used s3c_udc_otg_xfer_dma.c:280:6: warning: variable 'ep_tsr' set but not used s3c_udc_otg_xfer_dma.c: In function 's3c_udc_irq': s3c_udc_otg_xfer_dma.c:469:16: warning: variable 'flags' set but not used s3c_udc_otg_xfer_dma.c:468:18: warning: variable 'gintmsk' set but not used s3c_udc_otg_xfer_dma.c: In function 's3c_queue': s3c_udc_otg_xfer_dma.c:582:14: warning: variable 'gintsts' set but not used s3c_udc_otg_xfer_dma.c:581:16: warning: variable 'flags' set but not used s3c_udc_otg_xfer_dma.c: In function 's3c_ep0_read': s3c_udc_otg_xfer_dma.c:778:6: warning: variable 'ret' set but not used s3c_udc_otg_xfer_dma.c: In function 's3c_udc_set_halt': s3c_udc_otg_xfer_dma.c:1020:16: warning: variable 'flags' set but not used s3c_udc_otg_xfer_dma.c: In function 's3c_ep0_setup': s3c_udc_otg_xfer_dma.c:1258:13: warning: initialization from incompatible pointer type [enabled by default] s3c_udc_otg_xfer_dma.c:1239:16: warning: variable 'is_in' set but not used s3c_udc_otg_xfer_dma.c:1239:9: warning: variable 'bytes' set but not used s3c_udc_otg.c: In function 'usb_gadget_register_driver': s3c_udc_otg.c:292:16: warning: variable 'flags' set but not used s3c_udc_otg.c: In function 'usb_gadget_unregister_driver': s3c_udc_otg.c:338:16: warning: variable 'flags' set but not used s3c_udc_otg.c: In function 's3c_ep_enable': s3c_udc_otg.c:582:16: warning: variable 'flags' set but not used s3c_udc_otg.c: In function 's3c_ep_disable': s3c_udc_otg.c:646:16: warning: variable 'flags' set but not used s3c_udc_otg.c: In function 's3c_dequeue': s3c_udc_otg.c:704:16: warning: variable 'flags' set but not used Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Remy Bohmer <linux@bohmer.net>
2011-12-20net: introduce per device indexMichael Walle
Instead of counting the device index everytime a functions needs it, store it in the eth_device struct. eth_register() keeps track of the indices and updates the device's index number. This simplifies some functions in net/eth.c. Additionally, a network driver can now query its index, eg. to get the correct environment ethaddr name. Signed-off-by: Michael Walle <michael@walle.cc> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Mike Frysinger <vapier@gentoo.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-12-19ARM: tny_a9260: re-add MACH_TYPE_TNY_A9G20 and MACH_TYPE_TNY_A9260Anatolij Gustschin
MACH_TYPE_TNY_A9G20 and MACH_TYPE_TNY_A9260 were removed from mach-types.h. Add them to the board config file. Signed-off-by: Anatolij Gustschin <agust@denx.de> Acked-by: Simon Glass <sjg@chromium.org>
2011-12-19ARM: sbc35_a9g20: re-add MACH_TYPE_SBC35_A9G20Anatolij Gustschin
MACH_TYPE_SBC35_A9G20 was removed from mach-types.h. Add it to the board config file. Signed-off-by: Anatolij Gustschin <agust@denx.de> Acked-by: Simon Glass <sjg@chromium.org>
2011-12-19Coding Style cleanupWolfgang Denk
Fix trailing white space, indentation by spaces instead of TABs, excessive blank lines, trailing blank lines. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-12-19x86: Initial commit for running as a coreboot payloadGabe Black
Add a target for running u-boot as a coreboot payload in boards.cfg, a board, CPU and a config. This is a skeleton implementation which always reports the size of memory as 64 MB. Signed-off-by: Gabe Black <gabeblack@chromium.org>
2011-12-17vsprintf: Move function documentation into header fileSimon Glass
Now that this is not in common.h, perhaps it is acceptable to move this documentation into the header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-12-17Add safe vsnprintf and snprintf library functionsSonny Rao
From: Sonny Rao <sonnyrao@chromium.org> These functions are useful in U-Boot because they allow a graceful failure rather than an unpredictable stack overflow when printf() buffers are exceeded. Mostly copied from the Linux kernel. I copied vscnprintf and scnprintf so we can change printf and vprintf to use the safe implementation but still return the correct values. (Simon Glass <sjg@chromium.org> modified this commit a little) Signed-off-by: Sonny Rao <sonnyrao@chromium.org>
2011-12-17Move vsprintf functions into their own headerSimon Glass
common.h is very large, so before changing the vsprintf functions, move the prototypes into their own header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-12-16USB: Use (get|put)_unaligned for accessing wMaxPacketSizeTom Rini
In 9792987721c7980453fe6447c3fa6593b44f8458 Stefan describes a usecase where the previous behavior of leaving wMaxPacketSize be unaligned caused fatal problems. The initial fix for this problem was incomplete however as it showed another cases of non-aligned access that previously worked implicitly. This switches to making sure that all access of wMaxPacketSize are done via (get|put)_unaligned. In order to maintain a level of readability to the code in some cases we now use a variable for the value of wMaxPacketSize and in others, a macro. Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Remy Bohmer <linux@bohmer.net> OpenRISC: Tested-by: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi> Beagleboard xM, Pandaboard run-tested, s5p_goni build-tested. Signed-off-by: Tom Rini <trini@ti.com>
2011-12-16usb:gadget:s5p Enable the USB Gadget framework at Exynos4210 (C210 Universal)Lukasz Majewski
This commit enables support for USB Gadgets on the Exynos4210 (C210 Universal) reference target. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> CC: Remy Bohmer <linux@bohmer.net>
2011-12-16USB: ULPI: clean a mixup of return typesIgor Grinberg
Clean a mixup between u32 and int as a return type for functions returning error values. Use int as it is native (and widely used) return type. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Simon Glass <sjg@chromium.org>
2011-12-16USB: ULPI: switch argument type from u8 to unsignedIgor Grinberg
There is no benefit in using u8, so switch to unsigned to reduce the binary image size (by 20 bytes). Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Simon Glass <sjg@chromium.org>
2011-12-12pm9g45: init serial console before relocationAsen Dimov
The early messages can be seen on the debug console. Signed-off-by: Asen Chavdarov Dimov <dimov@ronetix.at>
2011-12-12pm9261: init serial console before relocationAsen Dimov
2011-12-12pm9263: init serial console before relocationAsen Dimov
2011-12-12mpc5200: digsy_mtc: Fix extension board detectionAnatolij Gustschin
Switch to extension board detection using pci_find_device() instead of detecting by i2c access to EEPROM device on extension board. This is a cleaner detection method since EEPROM addresses can be different on different board revisions. This also avoids "i2c_read: failed to address chip" error messages in the boot log on boards without extension board which may confuse users. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-12-12Merge branch 'master' of git://git.denx.de/u-boot-usbWolfgang Denk
* 'master' of git://git.denx.de/u-boot-usb: USB: efikamx: Enable USB on EfikaMX and EfikaSB USB: Add generic ULPI layer and a viewport USB: EHCI: Allow EHCI post-powerup configuration in board files USB: mx51evk: add end enable USB host support on port 1 USB: mx53loco: add end enable USB host support on port 1 USB: MX5: Add MX5 usb post-init callback USB: MX5: Abstract out mx51 USB pixmux configuration USB: MX5: add generic USB EHCI support for mx51 and mx53 USB: MX5: add helper functions to enable USB clocks usb:gadget:s5p Enable the USB Gadget framework at GONI usb:gadget:s5p USB Device Controller (UDC) implementation ehci: speed up initialization usb: add help for missing start subcommand cosmetic: remove excess whitespace from usb command help usb: align usb_endpoint_descriptor to 16-bit boundary usbtty: init endpoints prior to startup events pxa: convert pxa27x_udc to use read and write functions pxa: activate the first usb host port on pxa27x by default pxa: fix usb host register mismatch ehci-fsl: correct size of ehci caplength USB: Add usb_event_poll() to get keyboards working with EHCI USB: gadaget: add Marvell controller support USB: Fix complaints about strict aliasing in OHCI-HCD USB: Drop dead code from usb_kbd.c USB: Rework usb_kbd.c USB: Add functionality to poll the USB keyboard via control EP
2011-12-11USB: efikamx: Enable USB on EfikaMX and EfikaSBMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Remy Bohmer <linux@bohmer.net> Cc: Wolfgang Grandegger <wg@denx.de> Cc: Jason Liu <r64343@freescale.com>
2011-12-11USB: Add generic ULPI layer and a viewportJana Rapava
Add partial ULPI specification implementation that should be enough to interface the ULPI PHYs in the boot loader context. Add a viewport implementation for Chipidea/ARC based controllers. Signed-off-by: Jana Rapava <fermata7@gmail.com> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Cc: Remy Bohmer <linux@bohmer.net> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Grandegger <wg@denx.de> Cc: Simon Glass <sjg@chromium.org>
2011-12-11USB: mx51evk: add end enable USB host support on port 1Wolfgang Grandegger
Signed-off-by: Wolfgang Grandegger <wg@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Remy Bohmer <linux@bohmer.net> Cc: Wolfgang Grandegger <wg@denx.de> Cc: Jason Liu <r64343@freescale.com>
2011-12-11USB: mx53loco: add end enable USB host support on port 1Wolfgang Grandegger
2011-12-11USB: MX5: Abstract out mx51 USB pixmux configurationMarek Vasut
2011-12-11USB: MX5: add generic USB EHCI support for mx51 and mx53Wolfgang Grandegger
It's derived from ehci-mxc and uses the header files of the ehci-fsl interface. The callback board_ehci_hcd_init() has been introduced to allow for board-specific setup when USB is started. Signed-off-by: Wolfgang Grandegger <wg@denx.de> CC: Stefano Babic <sbabic@denx.de> CC: Remy Bohmer <linux@bohmer.net>
2011-12-11usb:gadget:s5p Enable the USB Gadget framework at GONILukasz Majewski
This commit enables support for USB Gadgets on the GONI reference target. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Remy Bohmer <linux@bohmer.net>
2011-12-11usb:gadget:s5p USB Device Controller (UDC) implementationLukasz Majewski
This commit provides UDC driver support for Samsung's SoC family of processors. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Remy Bohmer <linux@bohmer.net>
2011-12-11usb: align usb_endpoint_descriptor to 16-bit boundaryStefan Kristiansson
The usb_endpoint_descriptor struct is 7 bytes large and is defined as an array (ep_desc[USB_MAXENDPOINTS]) in the usb_interface struct in include/usb.h This fact will result in that every odd index in that array will start at an uneven address, this in turn makes accesses to u16 wMaxPacketSize unaligned. Such accesses are illegal on the OpenRISC architecture (as well as other architectures) and will render a bus error. Setting the aligned(2) attribute on usb_endpoint_descriptor will force wMaxPacketSize to a 16-bit boundary. Signed-off-by: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
2011-12-11ehci-fsl: correct size of ehci caplengthWolfgang Grandegger
According to the EHCI specification the Capability Register Length has a size of 8 bits. Signed-off-by: Wolfgang Grandegger <wg@denx.de> Acked-by: Kumar Gala <galak@kernel.crashing.org>
2011-12-11USB: gadaget: add Marvell controller supportLei Wen
Signed-off-by: Lei Wen <leiwen@marvell.com>
2011-12-10sandbox: Add timer simulationMatthias Weisser
Making sleep command work Signed-off-by: Matthias Weisser <weisserm@arcor.de> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-12-10sandbox: Add improved RAM simulationMatthias Weisser
Using mmap to allocate memory from the OS for RAM simulation we can use u-boot own malloc implementation. Tested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Matthias Weisser <weisserm@arcor.de> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-12-10ARM: convert "apollon" board to use boards.cfgWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net>
2011-12-10Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
* 'master' of git://git.denx.de/u-boot-arm: M28: Cleanup memsize.o OOT build i.MX28: Move SPL to arch/arm/cpu/arm926ejs/mx28 M28: Fix typo M28: Document that units has to be set to sectors on SD bootcard i.mx: i.mx6q: add the initial support for i.mx6q ARM2 board i.mx: mxc_gpio: add the i.mx6q support i.mx: add the initial support for freescale i.MX6Q processor i.mx: introduce the armv7/imx-common folder S5PC2XX: Rename S5pc2XX to exynos tegra2: Don't use board pointer before it is set up tegra2: Remove unneeded 'dynamic ram size' message tegra2: Remove unused low-level Tegra2 UART code tegra2: Remove unneeded config option tegra2: Remove unneeded boot code tegra2: Enable instruction cache arm: Move CP15 init out of cpu_init_crit() tegra2: Simplify tegra_start() boot path tegra2: Add arch_cpu_init() to fire up Cortex-A9 tegra2: Use new GPIO APIs in gpio_config_uart() tegra2: Add support for Ventana tegra2: Modify MMC driver to handle power and cd GPIOs tegra2: Move board_mmc_init into board files
