Currently, only basic completion is supported (no globs), but this is
what we had previously.
After booting the u-boot, and first using some SD card (such as Sandisk 2G SD
card), because the field 'clock' of struct mmc is zero, this will cause
the read transfer is always active and SDHC DATA line is always active,
therefore, driver can't handle the next command.
Therefore, we use mmc_set_clock to setup both the data structure and HW
to the initial clock speed of 400000Hz.
Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com>
Tested-by: Stefano Babic <sbabic@denx.de>
Add reginfo as a default command for p1022ds boards
Signed-off-by: Matthew McClintock <msm@freescale.com>
This command is used to read the device ONFI parameters page.
Signed-off-by: Florian Fainelli <florian@openwrt.org>
These id tables need not be writable.
The non-reentrant versions of the hashtable functions operate on a single
shared hashtable. So if two different people try using these funcs for
two different purposes, they'll cause problems for the other.
Avoid this by converting all existing hashtable consumers over to the
reentrant versions and then punting the non-reentrant ones.
New default partitions on nor flash:
640k (firmware)
1408k (kernel)
2m (initrd)
4m (small-fs)
24320k (big-fs)
256k (dts)
Add ARM Relocation Support
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
Some DaVinci boards are using flags that are no longer valid
So remove them.
This patch adds the possibility to (optinally) write to the
flash configuration register. The Intel style CFI chips support
such a register that can be used to configure the operation
mode to a non-default value.
This method will be used by the t3corp board, which needs to
configure the DS617 Xilinx flash for async read mode.
Use common ppc4xx linker script for xilinx ppc440 and ppc405 related boards.
Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com>
This patch includes the following changes for the lwmon5 board support:
- Enable cache in SDRAM
- Use common EHCI driver instead of the PPC4xx specific OHCI driver
This can be done since only high-speed devices are connected.
- Remove cached TLB entry again after ECC setup
- Use correct define for cache enabling
(CONFIG_4xx_DCACHE instead of CONFIG_SYS_ENABLE_SDRAM_CACHE)
- Enable FIT image support
The t3corp board has an Xilinx DS617 flash chip connected to the
onboard FPGA. This patch adds support for these chips. Board
specific flash accessor functions are needed, since the chips
can only be read correctly in 16bit mode.
Additionally the FPGA chip-selects are configured for device-paced
transfers (ready is enabled).
Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
Aspenite is a Development Board for ASPEN/ARMADA168(88AP168) with
* Processor upto 1.2GHz
* Parallel 1Gb x8 DDR2-1066 MHz
* 16 Mb x16 NOR, 4Gb x8 SLC NAND, footprint for SPI NOR
* Footprints for eMMC/eSD NAND & MMC x8 card
* 4-in-1 card reader (xD, MMC/SD/MS Pro), CF True IDE socket
* SEAF memory board, subset of PISMO2
With Peripherals:
* 4.3” WVGA 24-bit LCD
* Audio codecs (AC97 & I2S), TSI
* VGA camera
* Video in via 3 RCA jacks, and HDMI type C out
* Marvell 88W8688 802.11bg/BT module
* GPS RF IC
* Dual analog mics & speakers, headset jack, LED, ambient light sensor
* USB2.0 HS host (A), OTG (micro AB)
* FE PHY, PCIE Mini Card slot
* GPIO, GPIO expander with DIP switches for easier selection UART serial over USB, CIR
This patch adds basic board support with DRAM and UART functionality
The patch is tested for boot from DRAM using XDB
Signed-off-by: Mahavir Jain <mjain@marvell.com>
Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
This patch adds commonly used macros for ARMADA100 based
baords, Also some code reshuffled and updated for typos and comments
Most of the Marvell SoCs has Multi Function Pin (MFP) configuration registers
For ex. ARMADA100.
These registers are programmed to expose the specific functionality
associated with respective SoC Pins
This driver provides configuration APIs,
using them, configuration need to be done in board specific code
for ex- following code configures MFPs 107 and 108 for UART_TX/RX functionality
int board_early_init_f(void)
u32 mfp_cfg[] = {
/* Console on UART1 */
MFP107_UART1_RXD,
MFP108_UART1_TXD,
MFP_EOC /*End of configureation*/
/* configure MFP's */
mfp_config(mfp_cfg);
return 0;
- serial console in PSC1
- 128MiB DRAM
- 32MiB Flash
- FEC Ethernet
- 2 I2C busses
- FPGA on CS3
- IDE
- VGA SMI501
Signed-off-by: Asen Dimov <dimov@ronetix.at>
The following commit:
commit 46e91674fb4b6d06c6a4984c0b5ac7d9a16923f4
Author: Peter Tyser <ptyser@xes-inc.com>
Date: Tue Nov 3 17:52:07 2009 -0600
tsec: Force TBI PHY to 1000Mbps full duplex in SGMII mode
Removed setting Auto-Neg by default, however this is believed to be
proper default configuration for initialization of the TBI interface.
Instead we explicitly set CONFIG_TSEC_TBICR_SETTINGS for the
XPedite5370 & XPedite5500 boards that use a Broadcomm PHY which require
Auto-Neg to be disabled to function properly.
This addresses a breakage on the P2020 DS & MPC8572 DS boards when used
with an SGMII riser card. We also remove setting
CONFIG_TSEC_TBICR_SETTINGS on the P1_P2_RDB family of boards as now the
default setting is sufficient for them.
Additionally, we clean up the code a bit to remove an unnecessary second
define.
Acked-by: Peter Tyser <ptyser@xes-inc.com>
Tested-by: Peter Tyser <ptyser@xes-inc.com>
CC: Ruslan N. Araslanov <byaaka@yandex.ru>
Signed-off-by: Ruslan Araslanov <ruslan.araslanov@vitecmm.com>
Add battery charging support twl6030 driver.
Add support for battery voltage and current measurements.
Add command to get battery status and start/stop battery charging from USB.
Signed-off-by: Balaji T K <balajitk@ti.com>
Tested-by: Steve Sakoman <steve.sakoman@linaro.org>
The DM6446 does not build due to the ARM
relocation patch.
Also the board does not build in the NOR
mode. Changed default to NAND to ensure
no build failure.
While at it removed CONFIG_CMD_KGDB
This file has been synced (copy) from Linux source code.
This commit was based on kernel 2.6.32.
It updates gigabit related phy registers and basic definitions.
Signed-off-by: Macpaul Lin <macpaul@andestech.com>
Recent cleanup actions resulted in a number of config.mk files that
contained only LDSCRIPT definitions. Move these into th respective
board config files and remove the now empty config.mk files.
Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
Cc: Detlev Zundel <dzu@denx.de>
Cc: Andre Schwarz <andre.schwarz@matrix-vision.de>
Cc: Peter De Schrijver <p2@mind.be>
Acked-by: Detlev Zundel < dzu@denx.de>
Acked-by: Andre Schwarz <andre.schwarz@matrix-vision.de>
Acked-by: Heiko Schocher<hs@denx.de>
Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu>
This board uses the OMAP-L138 SOM stacked on a
custom baseboard. It supports SPI Flash, Ethernet
with RMII.
Signed-off-by: Ben Gardiner <bengardiner@nanometrics.ca>
This patch is a port of the work by Sudhakar Rajeshekhara in commit
ab3effbcad8851cc65dc5241a01c064d2030a3b2 of
git://arago-project.org/git/people/sandeep/u-boot-davinci.git.
The da850 UI board has on it an RMII PHY which can be used if the MDC line
to the MII PHY on the baseboard is disabled and the RMII PHY is enabled by
configuring the values of some GPIO pins on the IO expander of the UI board.
This patch implements disabling that line via GPIO2[6], configuring the UI
board's IO expander and setting only the pinmux settings that are needed for
RMII operation.
Tested on da850evm by adding a define for CONFIG_DRIVER_TI_EMAC_USE_RMII.
Signed-off-by: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
CC: Sandeep Paulraj <s-paulraj@ti.com>
CC: Ben Warren <biggerbadderben@gmail.com>
CC: Mike Frysinger <vapier@gentoo.org>
CC: Sughosh Ganu <urwithsughosh@gmail.com>
The patch adds basic board support for TI's OMAP-L138 based
Hawkboard. This board is pretty similar to the da850 EVM. Support for
nand and network access is added in this version.
The following bootup procedure is used.
At reset, the Rom Boot Loader(RBL), initialises the ddr and the nand
controllers and copies the second stage bootloader(nand_spl) to
RAM. The secondary bootloader then copies u-boot from a predefined
location in the nand flash to the RAM, and passes control to the
u-boot image.
Three config options are supported
* hawkboard_config - Used to create the u-boot.bin. Tftp the
u-boot.bin image to the RAM from u-boot, and flash to the nand flash
at address 0xe0000.
* hawkboard_nand_config - Used to generate the secondary
bootloader(nand_spl) image. This creates an elf file u-boot-spl
under nand_spl/. Create an AIS signed image using this file, and
flash it to the nand flash at address 0x20000. The ais file should
fit in one block.
* hawkboard_uart_config - This is same as the first image, but with
the TEXT_BASE as expected by the RBL(0xc1080000). Create the AIS
Signed-off-by: Sughosh Ganu <urwithsughosh@gmail.com>
The patch was already posted to the arago project,
but not yet to mainline. It allows to save environment into
the spi flash. Tested on LogiPD tmdxl138.
CC: Detlev Zundev <dzu@denx.de>
CC: Ben Gardiner <bengardiner@nanometrics.ca>
Currently the hardware was left in an undefined state in case Spartan3
serial load failed. This patch adds Xilinx_abort_fn to give the board
a possibility to clean up in this case.
Signed-off-by: Wolfgang Wegner <w.wegner@astro-kom.de>
