Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
Fix some missing declaration in header.
Signed-off-by: Macpaul Lin <macpaul@andestech.com>
Add missing definitions in header file according to datasheet.
Un-nestted the register structure in ftsmc020.h
Support registers definitions of ftsdmc021 SDRAM controller.
ftahbc020s.h provides basic definitions of this controller
to help a SoC which use this AHB Controller could
do scalable software settings in lowlevel_init.S.
commit 25ddd1fb0a2281b182529afbc8fda5de2dc16d96 left remnants of
many comments about CONFIG_SYS_GBL_DATA_SIZE.
Signed-off-by: Michael Jones <michael.jones@matrix-vision.de>
as checkpatch proposes to use strict_strtoul instead of
simple_strtoul, introduce it.
Ported this function from Linux 2.6.38 commit ID:
521cb40b0c44418a4fd36dc633f575813d59a43d
cc: Wolfgang Denk <wd@denx.de>
cc: Detlev Zundel <dzu@denx.de>
cc: Valentin Longchamp <valentin.longchamp@keymile.com>
cc: Holger Brunck <holger.brunck@keymile.com>
Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
This is needed for the upcoming TFTP server implementation.
This also simplifies PingHandler() and fixes rxhand_f documentation.
Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it>
Acked-by: Detlev Zundel <dzu@denx.de>
APM errata CHIP_21 for the 405EX/EXr (from the rev 1.09 document dated
4/27/11) states that rev D processors may wake up with the wrong feature
set. This patch implements the APM-proposed workaround.
To enable this patch for your board, add the appropriate define for your
CPU to your board header file. See kilauea.h for more information. The
following variants are supported:
#define CONFIG_SYS_4xx_CHIP_21_405EX_NO_SECURITY
#define CONFIG_SYS_4xx_CHIP_21_405EX_SECURITY
#define CONFIG_SYS_4xx_CHIP_21_405EXr_NO_SECURITY
#define CONFIG_SYS_4xx_CHIP_21_405EXr_SECURITY
Please note that if you select the wrong define, your board will not
boot, and JTAG will be required to recover.
Tested on custom boards using:
CONFIG_SYS_4xx_CHIP_21_405EX_NO_SECURITY <sfalco@harris.com>
CONFIG_SYS_4xx_CHIP_21_405EX_SECURITY <eibach@gdsys.de>
Signed-off-by: Steve Falco <sfalco@harris.com>
Acked-by: Dirk Eibach <eibach@gdsys.de>
Signed-off-by: Clint Adams <clint@debian.org>
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Cc: Prafulla Wadaskar <prafulla@marvell.com>
Cc: Julian Pidancet <julian.pidancet@citrix.com>
Though the OpenRD-Base only has one gigabit Ethernet port,
both the OpenRD-Client and OpenRD-Ultimate each have two.
On the Ultimate, the PHY addresses are consecutive, but
on the Client they are not.
(based on
<62a0952ce368acc725063a00a5ec680a639d6c27.1301040318.git.julian.pidancet@citrix.com>
<ad0a2dc1e422698b005d6f0ceb6dd6f75a87e00a.1301040318.git.julian.pidancet@citrix.com>
The asm/arch/config.h header define CONFIG_NR_DRAM_BANKS_MAX, which is
needed to configure DRAM banks.
This patch move the asm/arch/config.h header inclusion above the DRAM
banks configuration.
Additionally this patch fix a typo.
Signed-off-by: Simon Guinot <sguinot@lacie.com>
Collect all keymile specific common headers in include/configs/km.
cc: Prafulla Wadaskar <prafulla@marvell.com>
cc: Kim Phillips <kim.phillips@freescale.com>
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
Acked-by: Heiko Schocher <hs@denx.de>
The initial_boot_bank can be set when more than one application is
used in a bootpackage. But a value n <> 0 never led to booting from
bank n. Instead, bank 0 was booted. This patch fixes this.
Signed-off-by: Thomas Herzmann <thomas.herzmann@keymile.com>
commit 91a3c14c (ppc, mgcoge: add DIP switch detection)
introduces an compile error due to an missing define in the
mgcoge2ne.h. DIP switch detection is valid for both boards.
cc: Heiko Schocher <hs@denx.de>
On mgcoge3ne a new environment variable bobcatreset is used.
So this patch adds a possibility to add board specific
environment variables in general and this specific variable
for mgcoge3ne.
Reserved bit was changed according to the processors manual.
This patch adds support for the MPC8247 based board mgcoge3ne.
Additionaly mgcoge2ne board supprot was removed, because due
to the mgcoge3ne, this board is obsolete and not longer
maintained.
The board is similar to mgcoge. The difference is that
a NUMONYX flash is used and a different SDRAM (256MB).
Also introduce CONFIG_KM_82XX to collect ppc82xx common
settings and remove staticness from the common set_pin function.
Introduce a struct for the BFTICU FPGA to increase the readability of
the code. And the define CONFIG_SYS_BFTICU_BASE was removed because
the CONFIG_SYS_FPGA_BASE is already the base value for BFTICU registers.
Signed-off-by: Andreas Huber <andreas.huber@keymile.com>
The changes introduced by commit 0abddf8 ``cmd_ide: enhance new
feature "CONFIG_IDE_AHB"'' caused compiler warnings like
cmd_ide.c: In function 'ide_init':
cmd_ide.c:716: warning: assignment from incompatible pointer type
Constify the respective function arguments to fix this.
Although most IDE controller is designed to be connected to PCI bridge,
there are still some IDE controller support AHB interface for SoC design.
The driver implementation of these IDE-AHB controllers differ from other
IDE-PCI controller, some additional registers and commands access is required
during CMD/DATA I/O. Hence a configuration "CONFIG_IDE_AHB" in cmd_ide.c is
required to be defined to support these kinds of SoC controllers. Such as
Faraday's FTIDE020 series and Global Unichip's UINF-0301.
In order to support boardId / hwkey lists, the u-boot default
environment has been updated: Added a script checkboardidlist
which checks the list of boardId / hwkey if the boadrId / hwkey
of the IVM is included in that list. This feature is used if you
got different HW variants but you only want to create one boot
package. E.g. supx5 board series.
Add:
- introduce "bootrunner" environment variable
This allows to execute consecutive different commands
specified in the list "subbootcmd". If one command fails
the command serie will stop.
- introduce environment variable "develop", "ramfs" and "release"
Each variable is one way to boot our linux. "develop" is for
development purpose and boots the SW via NFS. "release" is for
booting the linux image from flash, "ramfs" allows to load an SW
image via tftp into ram and executes from there
- introduce "addmem" variable, this command adds the used memory
for linux to the bootargs
- introduce "addvar" variable, this command adress for the /var
directory to the kernel command line
- introduce "setramfspram" and "setrootfsaddr" these calculation
were done if "ramfs" was used (only for debugging)
- introduce "tftpramfs" used for "ramfs" to load the image into
RAM (only for debugging)
Remove unneeded stuff:
- CONFIG_IO_MUXING is obsolete for keymile boards
- CONFIG_KM_DEF_ENV_PRIVATE is also obsolete
- define CONFIG_SYS_TEXT_BASE in board configs only
This patch adds last_stage_init to all keymile boards. And
in the last stage init some environment variables for u-boot
were set. Currently these are pnvramaddr, pram and var address.
Acked-by: Kim Phillips <kim.phillips@freescale.com>
define KM_IVM_BUS and KM_ENV_BUS macros
KM_IVM_BUS is used to define the EEprom_ivm environment variable.
These macros allow the reuse of these I2C addresses in other code
locations.
remove unneeded code
On first HW versions the BOCO FPGA was behind a MUX device. These
HW versions are not supported anymore. And therefore this code can
be removed.
added LED initialization for SUEN3
The bootstat LED required to be initialized so to have a green
colour after start-up.
This is needed by the relocation code and is not the same for
our ARM BEC and thus needs to be defined.
remove memsize variable
An environment variable for memsize is not needed.
this can be get via the board info struct.
remove unneeded double access to bi_dram[i].size field
Signed-off-by: Luca Haab <luca.haab@keymile.com>
For the kmsupx5 a new header file was introduced km8321-common.h.
Now the common stuff from tuxa1, tuda1 and suvd3 was removed and
the new header file included.
The defines CONFIG_SYS_PIGGY_BASE and CONFIG_SYS_PIGGY_SIZE are
confusing. Because they actually describe the KMBEC FPGA values.
The KMBEC FPGA can be PRIO on kmeter1 or upio on mgcoge. Therefore
all the defines were renamed.
remove unneeded variable CONFIG_KM_DEF_NETDEV, as it is
already declared in keymile-common.h
This patch renames the suen3 defines and functions to KM_KIRKWOOD
which is more generic and more precise, because these values
and functions where used by all suenX boards and not only suen3.
Signed-off-by: Lukas Roggli <lukas.roggli@keymile.com>
The Keymile SUPx5 board series is based on a PBEC8321 but
contains an additional PBUS FPGA (LPXF) on local bus CS2.
Signed-off-by: Thomas Reufer <thomas.reufer@keymile.com>
First step for a cleanup of all header files for km8321 boards.
The mgcoge2 board from keymile deploys two different processors.
An ARM based Kirkwood for the "unit" part of the SW and a PPC for
the "ne" part of the SW. Therefore in Linux and U-Boot the names
for the board are mgcoge2un and mgcoge2ne. This patch adds the
mgcoge2ne part of the board. The ppc part of mgboge2 is quite
similar to mgcoge, therefore a generic header km82xx-common.h
was introduced to collect all similiarities. Currently the only
difference is that mgcoge2ne has a 64 MB numonyx NOR flash with
a single die. The mgcoge has a dual die flash 2*32MB from spansion.
