To improve eTSEC performance on LS1021A Rev2.0,
snooping of all transmit frames from memory and
all transmit BD memory accesses in enabled.
Signed-off-by: Alison Wang <alison.wang@freescale.com>
Reviewed-by: York Sun <yorksun@freescale.com>
Signed-off-by: Tang Yuantian <Yuantian.Tang@freescale.com>
Acked-by: Alison Wang <alison.wang@freescale.com>
Enable bootscript support in secure boot for establishing
chain of trust on LS1021atwr.
Signed-off-by: Gaurav Rana <gaurav.rana@freescale.com>
For ls1021a, Reserve secure code in to memory in case OCRAM
is needed by other usage.
Signed-off-by: Zhuoyu Zhang <Zhuoyu.Zhang@freescale.com>
1. Add USDHC, I2C, UART, 74LV, USB, QSPI support.
2. Support SPL
3. CONFIG_MX6UL_14X14_EVK_EMMC_REWORK is introduced, this board default
supports sd for usdhc2, but can do hardware rework to make usdhc2 support
emmc.
Boot Log:
U-Boot SPL 2015.07-rc3-00124-g35d727b (Jul 20 2015 - 18:40:59)
reading u-boot.img
reading u-boot.img
U-Boot 2015.07-rc3-00124-g35d727b (Jul 20 2015 - 18:40:59 +0800)
CPU: Freescale i.MX6UL rev1.0 792 MHz (running at 396 MHz)
CPU: Commercial temperature grade (0C to 95C)CPU: Thermal invalid data, fuse: 0x0
- invalid sensor device
Reset cause: POR
Board: MX6UL 14x14 EVK
I2C: ready
DRAM: 512 MiB
MMC: FSL_SDHC: 0, FSL_SDHC: 1
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: CPU Net Initialization Failed
No ethernet found.
Hit any key to stop autoboot: 0
Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
i.MX6UL's DRAM space starts from 0x80000000, same to i.MX6SX, so use
same address with i.MX6SX.
DRAM space starts from 0x80000000 for i.MX6UL, so need to
fix LOADADDR, SYS_TEXT_BASE.
Since i.MX6UL use A7 core, but not A9 core, we do not need
the erratas for i.MX6UL.
Signed-off-by: Ye.Li <B37916@freescale.com>
Add kconfig options for various SPI flashes and use them in cm-fx6 defconfig.
Cc: Jagan Teki <jteki@openedev.com>
Cc: Igor Grinberg <grinberg@compulab.co.il>
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
Add Kconfig options for USB keyboard and use them for cm-fx6.
Add USB_EHCI_MX6 option to menuconfig and use it when migrating cm-fx6 usb
config to defconfig.
Move CONFIG_CMD_* options that can be selected in menuconfig to cm-fx6
defconfig.
Implement a cm-fx6 specific board_video_skip() to provide the option to not
initialize the display.
The new function does not init display if the environment variable "panel" is
not defined, or if it is set to an unsupported value.
Collateral changes:
- Don't use the global displays array (it's CONFIG_IMX_VIDEO_SKIP specific).
- Don't use detect_hdmi(), since env controlled init makes it unnecessary.
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
1. Add DDR script for mx6qpsabreauto board.
2. On CPU3 board, enet RGMII tx clock is from internal PLL. Set the GPR5[9]
and init the enet pll output to 125Mhz.
3. On CPU3 board, SW1ABC=VDDSOC_IN, SW2=VDDARM_IN.
Build target: mx6qpsabreauto_config
Boot Log:
U-Boot 2015.07-rc2-00071-gfd985ff (Jun 29 2015 - 22:10:55 +0800)
CPU: Freescale i.MX6QP rev1.0 996 MHz (running at 792 MHz)
CPU: Automotive temperature grade (-40C to 125C) at 34C
Reset cause: POR
Board: MX6Q-Sabreauto revA
I2C: ready
DRAM: 2 GiB
PMIC: PFUZE100 ID=0x10
Flash: 32 MiB
NAND: 0 MiB
MMC: FSL_SDHC: 0
No panel detected: default to HDMI
Display: HDMI (1024x768)
In: serial
Out: serial
Err: serial
Net: FEC [PRIME]
Note:
In this patch, we still add a new config mx6qpsabreauto_config,
since SPL is not supported now, and IMX_CONFIG is needed at
build time, so add this config. Future, when SPL is converted,
this config can be removed.
Signed-off-by: Robin Gong <b38343@freescale.com>
Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
Detect the SOC and board variant at runtime and change the dtb name,
but not hardcoding the fdt_file env variable.
Take the following patch as a reference.
Íd58699b157df75f1aa0b363ea9c21add21a0c
"mx6cuboxi: Load the correct 'fdtfile' variable"
Add support for NOR flash and GPIO/I2C switch control on RevC.
- NOR support
- bank0/bank4 switch
- SD/eMMC switch
- board version
Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com>
For running Chain of Trust when doing Secure Boot from NAND,
the Bootscript header and bootscript must be copied from NAND
to RAM(DDR).
The addresses and commands for the same have been defined.
Signed-off-by: Saksham Jain <saksham@freescale.com>
Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com>
Signed-off-by: Aneesh Bansal <aneesh.bansal@freescale.com>
Secure Boot Target is added for NAND for P3041.
For mpc85xx SoCs, the core begins execution from address 0xFFFFFFFC.
In case of secure boot, this default address maps to Boot ROM.
The Boot ROM code requires that the bootloader(U-boot) must lie
in 0 to 3.5G address space i.e. 0x0 - 0xDFFFFFFF.
In case of NAND Secure Boot, CONFIG_SYS_RAMBOOT is enabled and CPC is
configured as SRAM. U-Boot binary will be located on SRAM configured
at address 0xBFF00000.
In the U-Boot code, TLB entries are created to map the virtual address
0xFFF00000 to physical address 0xBFF00000 of CPC configured as SRAM.
IFC nand ecc encode and decode mode are not correctly
set in CSOR register during nand initialization.Enable
ecc encode/decode in 4-bit mode
Signed-off-by: Jaiprakash Singh <b44839@freescale.com>
T1040D4RDB is a Freescale reference board that hosts the T1040 SoC.
T1040D4RDB is re-designed T1040RDB board with following changes :
- Support of DDR4 memory
- Support of 0x66 serdes protocol which can support following interfaces
- 2 RGMII's on DTSEC4, DTSEC5
- 1 SGMII on DTSEC3
- Support of QE-TDM
Similarily T1042D4RDB is a Freescale reference board that hosts the T1040
SoC. T1042D4RDB is re-designed T1042RDB board with following changes :
- Support for 0x86 serdes protocol which can support following interfaces
- 3 SGMII on DTSEC1, DTSEC2 & DTSEC3
- Support of DIU
Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com>
Signed-off-by: Codrin Ciubotariu <codrin.ciubotariu@freescale.com>
Signed-off-by: Wang Dongsheng <dongsheng.wang@freescale.com>
Based on Venice2, incorporates Stephen Warren's
latest P2571 pinmux table.
With Thierry Reding's 64-bit build fixes, this
will build and and boot in 64-bit on my P2571
(when used with a 32-bit AVP loader).
Signed-off-by: Tom Warren <twarren@nvidia.com>
Derived from Tegra124, modified as appropriate during T210
board bringup. Cleaned up debug statements to conserve
string space, too. This also adds misc 64-bit changes
from Thierry Reding/Stephen Warren.
Signed-off-by: Thierry Reding <treding@nvidia.com>
All based off of Tegra124. As a Tegra210 board is brought
up, these may change a bit to match the HW more closely,
but probably 90% of this is identical to T124.
Note that since T210 is a 64-bit build, it has no SPL
component, and hence no cpu.c for Tegra210.
ARMv8 requires an architected timer to be present, so it can be used
instead of the Tegra US timer. This allows for better code reuse.
For 64-bit ARM SoCs we rely on non-U-Boot code to bring up the CPU in
AArch64 mode so that we don't need the SPL. Non-cached memory is not
implemented (yet) for 64-bit ARM.
This corrects several typos in the comment block as well as some
indentions and nits in the linker_lists.h.
Enable SATA for the ZynqMP targets.
Wire up ethernet controllers and enable MII and BOOTP options.
Add xm011 DTS file and related configs and configurations.
Provide option to enable uart dcc support for zynqmp
This config can be enabled as per board config file.
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
Move CONFIG_SYS_TEXT_BASE of ZynqMP_ep to its
respective defconfig
Define a new config "zynqmp_ep" for ZynqMP instead
of xilinx_zynqmp. This defconfig supports all emulation
platforms of ZynqMP. Also renamed TARGET_XILINX_ZYNQMP
to ARCH_ZYNQMP.
The sysboot and pxe commands currently support either U-Boot formats or
raw zImages. Add support for the AArch64 Linux port's native image format
too.
As with zImage support, there is no auto-detection of the native image
format. Rather, if the image is auto-detected as a U-Boot format, U-Boot
will try to interpret it as such. Otherwise, U-Boot will fall back to a
raw/native image format, if one is enabled.
My belief is that CONFIG_CMD_BOOTZ won't ever be enabled for any AArch64
port, hence there's never a need to differentiate between CONFIG_CMD_
_BOOTI and _BOOTZ at run-time; compile-time will do. Even if this isn't
true, we want to prefer _BOOTI over _BOOTZ when defined, since _BOOTI is
definitely the native format for AArch64.
Change-Id: I83c5cc7566032afd72516de46f4e5eb7a780284a
We are getting very close to running out of space in SPL, and with the
currently Chrome OS gcc 4.9 we exceed the limit. Add a litle more space.
Enable DTS support (CONFIG_OF_LIBFDT) and select
CONFIG_FIT in defconfig.
Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com>
using http://git.ti.com/keystone-linux/boot-monitor/trees/master as
reference (tag K2_BM_15.07) the generated files do not have evm
extensions by default. So dont use -evm extension.
Reviewed-by: Murali Karicheri <m-karicheri2@ti.com>
Signed-off-by: Nishanth Menon <nm@ti.com>
Switch to using zImage instead of uImage. and while at it, start using
bootz as default. While at it, get rid of BOOTIMAGE define and start
using Linux upstream dtb file names.
Use the defaults defined in DEFAULT_LINUX_BOOT_ENV
Try to maintain as much commonality by conditionally including stuff
in armv7_common as necessary and removing the common defines from
keystone2 header.
Note: as part of this change, all keystone2 platforms will now start
using the generic u-boot prompt instead of the custom prompt.
rename the keystone2 common header into an keystone2 architecture
specific header which can then reuse the common ti_armv7 config headers.
Acked-by: Vitaly Andrianov <vitalya@ti.com>
Acked-By: Murali Karicheri <m-karicheri2@ti.com>
CONFIG_LINUX_BOOT_PARAM_ADDR is not a valid configuration option. Do
just like what the rest of the world does.
Commit bd2c4522c26d5 ("ti: armv7: enable EXT support in SPL (using
ti_armv7_common.h)") enabled thumb mode only for SPL builds, however,
All TI armv7 platforms do support thumb, and there is no reason why the
space savings cannot be exploited for u-boot as well.
Reported-by: Murali Karicheri <m-karicheri2@ti.com>
Suggested-by: Tom Rini <trini@konsulko.com>
TI armv7 based SoCs are based on two architectures - one based on OMAP
generation architecture and others based on Keystone architecture.
Many of the options are architecture specific, however a lot are common
with v7 architecture. So, step 1 will be to move out OMAP specific stuff
from ti_armv7_common into a ti_armv7_omap.h header which is then used
by all the relevant architecture headers.
CONFIG_MUSB_HDC should be CONFIG_MUSB_HCD to have any effect.
Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
Gumstix is migrating from ext3 to ext4 file system.
Signed-off-by: Adam YH Lee <adam.yh.lee@gmail.com>
Acked-by: Ash Charles <ashcharles@gmail.com>
Mainline Linux kernel commit
338a6aaabc02fa63b70441dd0e1b70aea64673c6 (ARM: dts: Introduce
STM32F429 MCU) in arch/arm/boot/dts/stm32f429.dtsi
requires U-Boot to set system clock to 180 MHz.
Signed-off-by: Antonio Borneo <borneo.antonio@gmail.com>
To: Albert Aribaud <albert.u.boot@aribaud.net>
To: Tom Rini <trini@konsulko.com>
To: Kamil Lulko <rev13@wp.pl>
Cc: u-boot@lists.denx.de
