The new zlib code wants asm/unaligned.h, so have the Blackfin version pull
in the asm-generic/unaligned.h.
This is based on the asm-arm/unaligned.h, but made generic so all arches
that cannot do unaligned accesses can utilize it.
Coding style cleanup, update CHANGELOG.
This code has compile problems and the company does not even exist any
more. So we take the liberty to drop support for it.
Signed-off-by: Detlev Zundel <dzu@denx.de>
CC: Wolfgang Denk <wd@denx.de>
CC: Ben Warren <biggerbadderben@gmail.com>
The 36-bit build exceeds the 512k size we have. Removing FIT type image
support allows us to fit and we dont really use it.
Also enable support for CONFIG_HWCONFIG because we use this for
configuring if this hardware has a FEC or not.
syntax:
hwconfig=fec:on if hardware has an fec
hwconfig=fec:off if hardware has no fec
This patch uses gd->relocaddr variable to store uboot's relocated
address in RAM and shows it in bdinfo command.
This patch moves CONFIG_AMIGAONEG3SE style copying of the address
in board_init_f to just before relocation is actually done.
Signed-off-by: Richard Retanubun <RichardRetanubun@RuggedCom.com>
Tested-by: Detlev Zundel <dzu@denx.de>
* convert otc570 board to use c stucture SoC access
* change gpio access to at91_gpio syntax
Signed-off-by: Daniel Gorsulowski <Daniel.Gorsulowski@esd.eu>
* updates the conditional main_clock calculation (if AT91_MAIN_CLOCK defined) to c structure SoC access
* add need register flags
Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
The patch removes warnings at compile time and provides
some cleanup code:
- Removed comment on NAND (not yet supported) from lowlevel_init.S
- Removed NFMS bit definition from imx-regs.h
The bit is only related to MX.25/35 and can lead to confusion
- Moved is_soc_rev() to soc specific code (removed from mx51evk.c)
Add support for the ARM part of the mgcoge2, named suen3.
This board is based on the Marvell Kirkwood (88F6281) SoC.
As there come more board variants, common config options
are collected in include/configs/km_arm.h. Also, this board
use common code for all keymile boards, which is stored in
board/keymile/common/common.c
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
This is an i.MX25 base board with only NAND
so it uses nand_spl to boot.
Signed-off-by: John Rigby <jcrigby@gmail.com>
Tune configuration, add support for (redundant) environment in NAND.
Acked-by: Wolfgang Denk <wd@denx.de>
CC: Fred Fan <fanyefeng@gmail.com>
CC: Tom <Tom.Rix@windriver.com>
Use RMII for MX25
Add code to init gasket that enables RMII
general cleanup
move clock init to cpu_eth_init in cpu/arm926ejs/mx27/generic.c
make MX27 specific phy init conditional on CONFIG_MX27
replace call to imx_get_ahbclk with one to imx_get_fecclk
and define imx_get_fecclk in include/asm-arm/arch-mx27/clock.h
ARM926EJS core with MX31 peripherals.
Earlier Version Signed-off-by: Wolfgang Denk <wd@denx.de>
remove ifdef'd clock selection code from
serial_mxc.c and replace with call to imx_get_uartclk
Add definitions for imx_get_uartclk to imx31 and imx27
include files.
This makes it easier to add new imx platforms.
The patch adds initial support for the Freescale mx51evk board.
Network (FEC) and SD controller (fsl_esdhc) are supported.
Signed-off-by: Fred Fan <fanyefeng@gmail.com>
The esdhc controller in the mx51 processor is quite
the same as the one in some powerpc processors
(MPC83xx, MPC85xx). This patches adapts the driver
to support the arm mx51.
Some Freescale's processors of different architecture
have the same peripheral (eSDHC controller in PowerPC
and i.MX51). This patch adds accessors for
the internal registers of the SOCs, as already
implemented in the PowerPC architecture.
Most controllers can check if there is a card in the slot.
However, they require pins that could be not available because
required by other functions and the detection of a card must
be performed in another way. This patch adds a weak function
that a board can implement to add its internal custom way
to check the presence of a MMC/SD card.
The patch add header files to support the pin multiplexer
of the the Freescale i.MX51 processor.
The patch add header files to support the Freescale i.MX51
processor, setting definitions for internal registers.
The patch add initial support for the Freescale i.MX51 processor
(family arm cortex_a8).
Fetched from http://www.arm.linux.org.uk/developer/machines/download.php
And built with
repo http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm
commit aea187c46f7d03ce985e55eb1398d0776a15b928
Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
Configuration defines should be preceeded with CONFIG_SYS_. Renamed
some at91 specific defines to conform to this naming convention:
AT91_CPU_NAME to CONFIG_SYS_AT91_CPU_NAME
AT91_MAIN_CLOCK to CONFIG_SYS_AT91_MAIN_CLOCK
Signed-off-by: Achim Ehrlich <aehrlich@taskit.de>
Reindent configuration header to limit line lenght to 80 characters by
removing obvious and sometimes misleading comments.
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
Limit line length to 80 characters mostly by removing obvious and sometimes
misleading comments. Fix indentation, too.
Adds support for ethernet networking on the da830evm platform.
This platform uses an SoC EMAC interface and a 3 port ethernet
switch as a PHY with an RMII interface. The PHY also has a i2c
interface for configuring the switch functions.
Signed-off-by: Nick Thompson <nick.thompson@ge.com>
Recent kernels are using generic NAND and NOR drivers. Change
default mtdparts to reflect it.
Correct switching partitions after upgrade and make it more readable.
lib_generic/zlib.c needs include/asm/unaligned.h since commit
cd514aeb996e2f7aefbe1f78481965d9d074aed4, which broke compilation for
Coldfire/M68K. This patch adds the missing header for these
architectures.
Signed-off-by: Wolfgang Wegner <w.wegner at astro-kom.de>
zlib.c demands asm/unaligned.h. But, SH does not have these.
This commit add asm/unaligned.h and asm/unaligned-sh4a.h from Linux
kernel and modifyf for u-boot.
commit 98d92d8c9f4021629a45261ad5ec3f3595f3a27a "sbc8349: fix incorrect
comment" missed this one.
Corrected the bit field positions of the external master priority low
and the external master priority high values in the EBC configuration
register. These bit field positions differ between PPC405 and PPC440
processors
Signed-off-by: Eugene O'Brien <eugene.obrien@advantechamt.com>
and avoid e.g., two identical boards from causing random networking
conflicts when hooked up to the same network.
* new board (eb_cpux9k2)
* support for EB+CPUx9K2 board by BuS Elektronik GmbH & Co. KG
* select via make eb_cpux9k2_config
* this also demonstrates, how to use boards with AT91RM9200 cpu
in at91 arch tree
* add's at91_emac (AT91RM9200) network driver (NET_MULTI api)
* enable driver with CONFIG_DRIVER_AT91EMAC
* generic PHY initialization
* modify AT91RM9200 boards to use NET_MULTI driver
* the drivers has been tested with LXT971 Phy and DM9161 Phy at MII and RMII
interface
* prepare joining at91 and at91rm9200
* add modified copy of soc files to cpu/arm920t/at91 to make
possible to compile at91rm9200 boards in at91 tree instead
of at91rm9200
* add header files with c structure defs for AT91 MC, ST and TC
* the new cpu files are using at91 c structure soc access
* please read README.soc-at91 for details
* convert at91sam9263ek board to use c stucture SoC access
* add's a warning to all files, which need update to new SoC access
* convert common files in cpu/../at91 and a lot of drivers to use
* add a real AT91 GPIO driver instead of header inline code
* resolve the mixing of port and pins
* change board config files to use new driver
* add macros to gpio to realize backward compatibility
* add's c structures for SoC access to pheriperials head files
* add's the new temporary CONFIG_AT91_LEGACY to all board configs
This will need for backward compatiblity, while change the SoC access
to c structures. If CONFIG_AT91_LEGACY is defined, the deprecated
SoC is used.
The EVM UI extender card has a NAND device. This change will enable
saveenv to work with NAND and Linux to be booted using:
mtdparts default
nboot kernel
bootm
The patch adds EMIF-A macros for setting chip select parameters
The structure was missing a reserved entry (not listed in the manual,
actually), so the last registers had a wrong offset. This prevented
all swlocked registers to be modified as swlock is last in the structure.
Signed-off-by: Alessandro Rubini <rubini@gnudd.com>
Add support for the Cirrus EP93xx platform
Signed-off-by: Matthias Kaehlcke <matthias@kaehlcke.net>
Acked-by: Tom <Tom.Rix@windriver.com>
