path: root/include
2007-08-16ColdFire: MCF5329 header file clean upTsiChungLiew
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
2007-08-16ColdFire: MCF5329 Update and cleanupTsiChungLiew
2007-08-16Merge branch 'denx-coldfire' into coldfire-aug2007John Rigby
2007-08-16Fix numerous bugs in the 8568 UEC supportAndy Fleming
Actually, fixed a large bug in the UEC for *all* platforms. How did this ever work? uec_init() did not follow the spec for eth_init(), and returned 0 on success. Switch it to return the link like tsec_init() (and 0 on error) The immap for the 8568 was defined based on MPC8568, rather than CONFIG_MPC8568 CONFIG_QE was off CONFIG_ETHPRIME was set to "Freescale GETH". Now is "FSL UEC0" Fixed a comment about the ranges for CONFIG_ETHPRIME if TSEC_ENET is enabled Signed-off-by: Andy Fleming <afleming@freescale.com>
2007-08-16Define tsec flag values in config filesAndy Fleming
The tsec_info structure and array has a "flags" field for each ethernet controller. This field is the only reason there are settings. Switch to defining TSECn_FLAGS for each controller in the config header, and we can greatly simplify the array, and also simplify the addition of future boards. Signed-off-by: Andy Fleming <afleming@freescale.com>
2007-08-15Merge with git://www.denx.de/git/u-boot.gitStefan Roese
2007-08-1586xx: Fix lingering CFG_CMD_* references in sbc8641d.hJon Loeliger
Remove a leftover in net/tftp.c while we're at it. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-08-14Merge with /home/wd/git/u-boot/custodian/u-boot-ppc4xxWolfgang Denk
2007-08-14Coding style cleanup. Update CHANGELOG.Wolfgang Denk
2007-08-14Merge with git://www.denx.de/git/u-boot.gitStefan Roese
2007-08-14Merge with /home/stefan/git/u-boot/zeusStefan Roese
2007-08-14ppc4xx: Add initial Zeus (PPC405EP) board supportStefan Roese
2007-08-14Add the files.Peter Pearse
2007-08-14Add MACH_TYPE records for several AT91 boards.Peter Pearse
Merge to two at45.c files into a common file, split to at45.c and spi.c Fix spelling error in DM9161 PHY Support. Initialize at91rm9200 board (and set LED). Add PIO control for at91rm9200dk LEDs and Mux. Change dataflash partition boundaries to be compatible with Linux 2.6. Signed-off-by: Peter Pearse <peter.pearse@arm.com> Signed-off-by: Ulf Samuelsson <ulf@atmel.com>
2007-08-14Merge with /home/wd/git/u-boot/custodian/u-boot-mpc85xxWolfgang Denk
2007-08-1485xxCDS: Add make targets for legacy systems.Randy Vinson
The PCI ID select values on the Arcadia main board differ depending on the version of the hardware. The standard configuration supports Rev 3.1. The legacy target supports Rev 2.x. Signed-off-by Randy Vinson <rvinson@mvista.com>
2007-08-14Add support for UEC to 8568Andy Fleming
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2007-08-14Add PCI support for MPC8568MDS boardHaiying Wang
This patch is against u-boot-mpc85xx.git of www.denx.com Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Ebony Zhu <ebony.zhu@freescale.com>
2007-08-14Fix minor 85xx warningsAndy Fleming
Some patches had inserted warnings into the build: * mpc8560ads declared data without using it * cpu_init declared ecm and immap without using it in all CONFIGs * MPC8548CDS.h had its default filenames changed so that they contained "\m" in the paths. Made the defaults not Windows-specific (or anything-specific) Signed-off-by: Andy Fleming <afleming@freescale.com>
2007-08-148548cds PCIE support.Ed Swarthout
Make the early L1 cache stack region guarded to prevent speculative fetches outside the locked range. Use _PHYS defines, not _MEM for cpu-side PCI memory mapped regions. init.S whitespace cleanup. Allow TEXT_BASE value to be specified on command line. This allows it to be set to 0xfffc0000 which cuts the uboot binary in half. Clear and enable lbc and ecm errors. Update last_busno in device-tree for pci and pcie. Remove load of obsolete cpu/mpc85xx/pci.0 Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com> Acked-by: Andy Fleming <afleming@freescale.com>
2007-08-148544ds PCIE supportEd Swarthout
PCI1 LAW mapping should use CFG_PCI1_MEM_PHY and not _BASE address. Enable LBC and ECM errors and clear error registers. Add tftpflash env var to get uboot from tftp server and flash it. Add pci/pcie convenience env vars to display register space: "run pcie3regs" to see all pcie3 ccsr registers "run pcie3cfg" to see all cfg registers Whitespace cleanup and MPC8544DS.h Enable CONFIG_INTERRUPTS. Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com> Acked-by: Andy Fleming <afleming@freescale.com>
2007-08-1485xx start.S cleanup and exception supportAndy Fleming
From: Ed Swarthout <Ed.Swarthout@freescale.com> Support external interrupts from platform to eliminate system hangs. Define CONFIG_INTERRUPTS board configure option to enable. Enable ecm, ddr, lbc, and pci/pcie error interrupts in PIC. Remove extra cpu initialization redundant with hardware initialization. Whitespace cleanup. Define and use _START_OFFSET consistent with other processors using ppc_asm.tmpl Move additional code from .text to boot page to make room for exception vectors at start of image. Handle Machine Check, External and Critical exceptions. Fix e500 machine check error determination in traps.c TEXT_BASE can now be 0xfffc_0000 - which cuts binary image in half. Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com> Acked-by: Andy Fleming <afleming@freescale.com>
2007-08-14e500 needs ppc_asm.tmp MCK_EXCEPTIONEd Swarthout
Always define MCK_EXCEPTION macro - so e500 can use it too. Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com> Acked-by: Andy Fleming <afleming@freescale.com>
2007-08-13multicast tftp: RFC2090David Updegraff
Implemented IETF RFC2090, Multicast TFTP. Initial implementation on Realtek RTL8139 and Freescale TSEC. Signed-off-by: David Updegraff <dave@cray.com> Signed-off-by: Ben Warren <bwarren@qstreams.com>
2007-08-13Add ability to take MAC address from the environment to DM9000 driverMike Rapoport
Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Ben Warren <bwarren@qstreams.com>
2007-08-13Merge with /home/wd/git/u-boot/custodian/u-boot-mpc86xxWolfgang Denk
2007-08-13Minor coding style cleanup. Update CHANGELOG.Wolfgang Denk
2007-08-13Merge commit 'remotes/wd/master'Jon Loeliger
Conflicts: MAKEALL With any luck, this is the last MAKEALL merge conflict!
2007-08-13Modify SBC8641D to use new Freescale PCI routinesJoe Hamman
PCI-Express sockets 1 and 2 verified working with Intel Pro/1000 PT adapter. Signed-off-by: Joe Hamman <joe.hamman@embeddedspecialties.com> Signde-off-by: Jon Loeliger <jdl@freescale.com>
2007-08-13ppc4xx: Fix problem in PLL clock calculationStefan Roese
This patch was originall provided by David Mitchell <dmitchell@amcc.com> and fixes a bug in the PLL clock calculation. Signed-off-by: Stefan Roese <sr@denx.de>
2007-08-12Merge with git+ssh://gemini_vpn/home/wd/git/u-boot/masterWolfgang Denk
2007-08-12Adapt board configuration and fix kernel crash on MCC200 board.Wolfgang Denk
The update procedure was modified to turn off the USB subsystem before exit for MCC200 and TRAB. This is necessary as otherwise the USB controller continues to write periodically to system memory! MCC200-specific notes: - the patch disables the magic key check for MCC200 - the patch contains the configuration changes made for the new revision of the board. Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2007-08-12Adjust default configuration of ADS5121 board.Wolfgang Denk
2007-08-12Clean up some remaining CFG_CMD_ -> CONFIG_CMD_ issues.Wolfgang Denk
2007-08-11Merge with /home/wd/git/u-boot/custodian/u-boot-fdtWolfgang Denk
2007-08-10Call ft_board_setup() from the bootm command.Gerald Van Baren
In the patch titled "Create new fdt boardsetup command..." I removed the call to ft_board_setup() from the routine fdt_chosen(), but I forgot to add a direct call back into cmd_bootm.c This fixes the oversight by adding the direct call to the bootm command. Signed-off-by: Gerald Van Baren <vanbaren@cideas.com>
2007-08-10Add fdt_find_node_by_type() and fdt_find_compatible_node() to LIBFDTGerald Van Baren
Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Acked-by: Gerald Van Baren <vanbaren@cideas.com>
2007-08-10Replace fdt_node_offset() with fdt_find_node_by_path().Gerald Van Baren
The new name matches more closely the kernel's name, which is also a much better description. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Acked-by: Gerald Van Baren <vanbaren@cideas.com>
2007-08-10Minor code clean up.Gerald Van Baren
Declare the variable fdt properly as extern. Call the "set_fn" function pointer the "short way" without the full dereferencing syntax. Signed-off-by: Gerald Van Baren <vanbaren@cideas.com>
2007-08-11add image size and descriptors for Spartan 3E FPGA chipsBruce Adler
Spartan 3E image sizes taken from Table 1-4 in Xilinx UG332 (v1.1) Signed-off by: Bruce Adler <bruce.adler@ccpu.com>
2007-08-10Add support for SBC8641D. Config files.Joe Hamman
Add support for Wind River's SBC8641D reference board. Signed-off by: Joe Hamman <joe.hamman@embeddedspecialties.com> Acked-by: Wolfgang Denk <wd@denx.de> Acked-by: Jon Loeliger <jdl@freescale.com>
2007-08-10Merge with git+ssh://sr@pollux.denx.org/home/wd/git/u-boot/from_stefanStefan Roese
2007-08-10Merge with git://www.denx.de/git/u-boot.gitStefan Roese
2007-08-10[ARM] TI DaVinci support, hopefully finalSergey Kubushyn
Add support for the following DaVinci boards: - DV_EVM - SCHMOOGIE - SONATA Changes: - Split into separate board directories - Removed changes to MTD_DEBUG (or whatever it's called) - New CONFIG_CMD party line followed - Some cosmetic fixes, cleanup etc. - Patches against the latest U-Boot tree as of now. - Fixed CONFIG_CMD_NET in net files. - Fixed CONFIG_CMD_EEPROM for schmoogie. - Made sure it compiles and works (forceenv() link problem) on SCHMOOGIE and DV_EVM. Can't check if it works on SONATA, don't have a board any more, but it at least compiles. Here is an excerpt from session log on SCHMOOGIE... U-Boot 1.2.0-g6c33c785-dirty (Aug 7 2007 - 13:07:17) DRAM: 128 MB NAND: 128 MiB In: serial Out: serial Err: serial ARM Clock : 297MHz DDR Clock : 162MHz ETH PHY : DP83848 @ 0x01 U-Boot > iprobe Valid chip addresses: 1B 38 3A 3D 3F 50 5D 6F U-Boot > ping 192.168.253.10 host 192.168.253.10 is alive U-Boot > Signed-off-by: Sergey Kubushyn <ksi@koi8.net> Acked-by: Dirk Behme <dirk.behme@gmail.com> Acked-by: Zach Sadecki <Zach.Sadecki@ripcode.com> Acked-by: Stefan Roese <sr@denx.de>
2007-08-10fsl_pci_init cleanup.Ed Swarthout
Do not enable normal errors created during probe (master abort, perr, and pcie Invalid Configuration access). Add CONFIG_PCI_NOSCAN board option to prevent bus scan. Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com> Acked-by: Andy Fleming <afleming@freescale.com>
2007-08-10cpu/86xx fixes.Jon Loeliger
Remove rev 1 fixes. Always set PICGCR_MODE. Enable machine check and provide board config option to set and handle SoC error interrupts. Include MSSSR0 in error message. Isolate a RAMBOOT bit of code with #ifdef CFG_RAMBOOT. Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com> Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-08-10Coding style cleanupStefan Roese
2007-08-10Merge with git+ssh://atlas/home/wd/git/u-boot/masterWolfgang Denk
