This patch adds support for placing the RGMII bridge on the
PPC405EX(r) into MII/GMII mode and allows a board-specific
configuration to specify the bridge mode at compile-time.
Signed-off-by: Grant Erickson <gerickson@nuovations.com>
This patch completes the preprocessor mneomics for the IBM DDR2 SDRAM
controller registers (MODT and INITPLR) used by the
PowerPC405EX(r). The MMODE and MEMODE registers are unified with their
peer values used for the INITPLR MR and EMR registers,
respectively. Finally, a spelling typo is correct (MANUEL to MANUAL).
With these mnemonics in place, the CFG_SDRAM0_* magic numbers for
Kilauea are replaced by equivalent mnemonics to make it easier to
compare and contrast other 405EX(r)-based boards (e.g. during board
bring-up).
Finally, unified the SDRAM controller register dump routine such that
it can be used across all processor variants that utilize the IBM DDR2
SDRAM controller core. It produces output of the form:
PPC4xx IBM DDR2 Register Dump:
SDRAM_MB0CF[40] = 0x00006701
which is '<mnemonic>[<DCR #>] = <value>'. The DCR number is included
since it is not uncommon that the DCR values in header files get mixed
up and it helps to validate, at a glance, they match what is printed
in the user manual.
Tested on:
AMCC Kilauea/Haleakala:
- NFS Linux Boot: PASSED
- NAND Linux Boot: PASSED
Add additional DDR2 SDRAM memory controller DCR mneomnics, condition
revision ID DCR based on 405EX, and add field mnemonics for bus error
status and ECC error status registers.
This patch adds bit field mnemonics for the 405EX(r) SDR0_SRST soft reset register.
While the PowerPC 405EX(r) shares in common the AMCC/IBM DDR2 SDRAM
controller core also used in the 440SP, 440SPe, 460EX, and 460GT, in
the 405EX(r), SDRAM_MCSTAT has a different DCR value.
Its present value on the 405EX(r) causes a read back of 0xFFFFFFFF
which causes SDRAM initialization to periodically fail since it can
prematurely indicate SDRAM ready status.
Signed-off-by: Feng Kan <fkan@amcc.com>
ADS5121 Rev 3 board is now the default config
config targets are now
ads5121_config
Rev 3 board with
PCI
M41T62 on board RTC
512MB DRAM
ads5121_rev2_config
Rev 2 board with
No PCI
256MB DRAM
Signed-off-by: Martha Marx <mmarx@silicontkx.com>
Acked-by: John Rigby <jrigby@freescale.com>
Consolidate ADS5121 IO Pin configuration to one file
board/ads5121/iopin.c.
Remove pin config from cpu/mpc512x/fec.c
Newer PPC's like 440SPe, 460EX/GT can be equipped with more than 2GB of SDRAM.
To support such configurations, we "only" map the first 2GB via the TLB's. We
need some free virtual address space for the remaining peripherals like, SoC
devices, FLASH etc.
Note that ECC is currently not supported on configurations with more than 2GB
SDRAM. This is because we only map the first 2GB on such systems, and therefore
the ECC parity byte of the remaining area can't be written.
Signed-off-by: Larry Johnson <lrj@acm.org>
This PCI-X e1000 variant works by just adding in the correct
PCI IDs in the appropriate places.
(introduced by commit 391fd93ab23e15ab3dd58a54f5b609024009c378)
This patch makes SPARC targets build again. It is caused by
phys_addr_t and phys_size_t being defined in the wrong header
file. include/lmb.h need those typedefs to build.
Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
Some macros such as NAND_CTL_SETALE conflict between current and legacy
NAND, being defined by the subsystem in the former case and the board
config file in the latter.
ARM: Fix for incorrect version of patch applied when
adding support for the Lyrtech SFF-SDR board.
Signed-off-by: Hugo Villeneuve <hugo.villeneuve@lyrtech.com>
Signed-off-by: Philip Balister, OpenSDR <philip@opensdr.com>
The LMB code now uses phys_addr_t and phys_size_t. Also, there were a couple
of casting problems in the bootm code that called the LMB functions.
Signed-off-by: Andy Fleming <afleming@freescale.com>
common/env_common.c (default_env): new function that resets the environment to
the default value
common/env_common.c (env_relocate): use default_env instead of own copy
common/env_nand.c (env_relocate_spec): use default_env instead of own copy
include/environment.h: added default_env prototype
Signed-off-by: Werner Almesberger <werner@openmoko.org>
Signed-off-by: Harald Welte <laforge@openmoko.org>
This is particularly problematic now that non-NAND-specific code is
including <nand.h>, and thus all debugging code is being compiled
regardless of whether it was requested, as reported by Scott McNutt
<smcnutt@psyent.com>.
After we move the atmel_mci driver into drivers/mmc, we can't select
it with CONFIG_MMC anymore. Introduce a new symbol specifically for
this driver so that there's no ambiguity.
Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
Acked-by: Jean-Chritophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
This avoids an early global data reference.
Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
Signed-off-by: Matvejchikov Ilya <matvejchikov@gmail.com>
The compiler will help find mismatches between printf formats and
arguments if you let it. This patch adds the necessary attributes to
declarations in include/common.h, then begins to correct the resulting
compiler warnings. Some of these were bugs, e.g., "$d" instead of
"%d" and incorrect arguments. Others were just annoying, like
int-long mismatches on a system where both are 32 bits. It's worth
fixing the annoying errors to catch the real ones.
Signed-off-by: Andrew Klossner <andrew@cesa.opbu.xerox.com>
Disable SH ether driver.
The watchdog on 8610 board is enabled by setting sw[6]
to on. Once enabled, the watchdog can not be disabled
by software. So feed the dog in u-boot is necessary for
normal operation.
Signed-off-by: Jason Jin <Jason.jin@freescale.com>
Remove duplicate definitions in include/lxt971a.h.
Remove duplicate registers and bits definitions in
include/lxt971a.h for standard MII registers, and
use values in include/miiphy.h instead.
New NOR Flash board support and remove old type flash board config.
And Remove network setting from config file.
Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com>
New NOR Flash board support and remove network setting from config file.
This change helps with better handling with others
Xilinx based platform.
board/amirix/ap1000/serial.c
board/exbitgen/exbitgen.c
board/exbitgen/flash.c
board/ml2/serial.c
board/xilinx/ml300/serial.c
update mvBL-M7 config file to use UBOOT_VERSION.
Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de>
Currently, the setenv function does not return an error code.
This patch allows to test for errors.
Signed-off-by: Steve Falco <sfalco@harris.com>
fls64, __ilog2_u64, ffs64 are variants that work on an u64,
and fls is used to implement them.
Signed-off-by: Francesco Albanese <Francesco.Albanese@swisscom.com>
This patch implements a fix provided by AMCC so that the lockup upon
simultanious traffic on AHB USB OTG, USB 2.0 and SATA doesn't occur
anymore:
Set SDR0_AHB_CFG[A2P_INCR4] (bit 24) and clear SDR0_AHB_CFG[A2P_PROT2]
(bit 25) for a new 460EX errata regarding concurrent use of AHB USB OTG,
USB 2.0 host and SATA.
This errata is not officially available yet. I'll update the comment
to add the errata number later.
This patch adds support for the Lyrtech SFF-SDR board,
based on the TI DaVinci architecture (ARM926EJS).
Signed-off-by: Philip Balister <philip@balister.org>
This moves the MMC and SD Card command definitions from
include/asm/arch/mmc.h into include/mmc.h. These definitions are
given by the MMC and SD Card standards, not by any particular
architecture.
There's a lot more room for consolidation in the MMC drivers which
I'm hoping to get done eventually, but this patch is a start.
Compile-tested for all avr32 boards as well as lpc2292sodimm and
lubbock. This should cover all three mmc drivers in the tree.
ALIGN() returns the smallest aligned value greater than the passed
in address or size. Taken from Linux.
