tools/Makefile
Without this patch, SPD access will fail which leads to DDR init fail.
Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com>
Tested-by: Chris Packham <judge.packham@gmail.com>
Acked-by: York Sun <yorksun@freescale.com>
LCD4 needs a slightly different GPIO configuration than the
original LWMON5 variant. GPIO49 needs to be configured to a
default output value of 0 (permanent voltage supply).
Additionally lcd4 also needs to enable the LSB transmitter.
For most boards which define CONFIG_SPL_PAD_TO,
it is defined in config header files.
Currently, there exists only one exception, cam_enc_4xx board.
This patch moves CONFIG_SPL_PAD_TO definition
from board/ait/cam_enc_4xx/config.mk
to include/configs/cam_enc_4xx.h.
With this modification, we can delete a glue code
in the top level config.mk:
ifneq ($(CONFIG_SPL_PAD_TO),)
CPPFLAGS += -DCONFIG_SPL_PAD_TO=$(CONFIG_SPL_PAD_TO)
endif
libata already has similar functions as implemented in the ahci code.
Refactor the code to use the libata variants and remove the dependency on
ata.h. Convert some defines to use the version from libata.h. Also, remove
some unnecessary memset's of bss data.
This is a step toward hopefully merging ahci.c and dw_ahsata.c which are
essentially the same driver.
Reviewed-by: Tom Rini <trini@ti.com>
Replace hard-coded register values with proper defines for PORT_SCR_STAT
register.
gcc allows extensions to be non compiler specific by defining
__* macros for the attributes supported by gcc. Having a
different definition causes many warnings during the build
(cdefs.h on FreeBSD uses __attribute((__pure__)) where u-boot
uses __attribute__((pure)) for example). Do not redefine
these macros to suppress these warnings.
This patch ignores the checkpatch warning:
WARNING: __packed is preferred over __attribute__((packed))
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
Somewhere along the line of refactoring the am335x header files, the
kernel image load was lost, so put it back in.
Separating the configuration file for Virtual
Target and real hardware Cyclone V development kit
Signed-off-by: Chin Liang See <clsee@altera.com>
Reviewed-by: Pavel Machek <pavel@denx.de>
Cc: Pavel Machek <pavel@denx.de>
Cc: Dinh Nguyen <dinguyen@altera.com>
Cc: Tom Rini <trini@ti.com>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
drivers/serial/serial.c
The conflict above was a trivial case of adding one init
function in each branch, and manually resolved in merge.
Drop unused CONFIG_NET_MULTI
Signed-off-by: Bo Shen <voice.shen@gmail.com>
This adds the "test_compression" command when building the sandbox. This
tests the existing compression and decompression routines for simple
sanity and for buffer overflow conditions.
Add mkimage support for generating and verifying MXS bootstream.
The implementation here is mostly a glue code between MXSSB v0.4
and mkimage, but the long-term goal is to rectify this and merge
MXSSB with mkimage more tightly. Once this code is properly in
U-Boot, MXSSB shall be deprecated in favor of mkimage-mxsimage
support.
Note that the mxsimage generator needs libcrypto from OpenSSL, I
therefore enabled the libcrypto/libssl unconditionally.
MXSSB: http://git.denx.de/?p=mxssb.git;a=summary
The code is based on research presented at:
http://www.rockbox.org/wiki/SbFileFormat
Cc: Fabio Estevam <fabio.estevam@freescale.com>
Cc: Otavio Salvador <otavio@ossystems.com.br>
This patch add new functions to pmic max77686 to set voltage and mode.
Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com>
Acked-by: Rajeshwari Shinde <rajeshwari.s@samsung.com>
Acked-by: Tom Rini <trini@ti.com>
Arndale board is based on samsung's exynos5250 soc.
Signed-off-by: Inderpal Singh <inderpal.singh@linaro.org>
Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org>
The MMC driver relies on this block now.
add support for the am335x based boards from siemens:
dxr2:
- DDR3 128MiB
- NAND 256MiB
- Ethernet with external Switch SMSC LAN9303
- no PMIC
- internal Watchdog
- DFU support
pxm2:
- DDR2 512 MiB
- NAND 1024 MiB
- PMIC
- PHY atheros ar803x
- USB Host
- internal Watchdog
- DFU support
rut:
- DDR3 256 MiB
- NAND 256 MiB
- PMIC
- PHY natsemi dp83630
- external Watchdog
- DFU support
Signed-off-by: Roger Meier <r.meier@siemens.com>
Signed-off-by: Samuel Egli <samuel.egli@siemens.com>
Cc: Pascal Bach <pascal.bach@siemens.com>
Acked-by: Anatolij Gustschin <agust@denx.de>
Re-group the general options to note things that can be removed safely
to reduce binary size when not required, and expand the comment about
what commands we do include to note it could be replaced with a specific
list of required one. While at it, move the CMD parts of various
blocks IP to the end of the list for consistency.
While in here, drop CONFIG_BOOTP_DEFAULT as it is unused in the code.
After examining both TRMs and doing some experimentation, we can rely on
using the start of the download area for CONFIG_SPL_TEXT_BASE and then
move SRAM_SCRATCH_SPACE_ADDR up, just like am335x. This is required for
peripheral boot modes such as UART.
We only need this library when we're doing "disk" access to MMC/SD.
Update comment around the rest of CONFIG_SPL_LIB* to note that the
others are always required.
We had been allowing the max size to be larger than actually allowed by
the ROM. Expand the commentary here to explain why we set these
locations.
Now that IGEP base boards default environment use
the bootz command to boot a zImage instead of a
uImage, it makes sense to add support to supply a
raw initrd image to the kernel if needed.
Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
Use CONFIG_MACH_TYPE generic macro to set the machine type
number in the common arm code instead of setting it in the
board code.
Signed-off-by: Oleksandr Tyshchenko <oleksandr.tyshchenko@ti.com>
Since config.mk is deprecated, remove this file,
and move CONFIG_SYS_TEXT_BASE define to config file.
With the new include structure for TI platforms, we need to not define
our own CONFIG_SYS_PROMPT and also need to include
<configs/omap5_common.h> much sooner, so do both of these. Also drop
the unused CONFIG_NET_MULTI
Update the Makefiles so that all boards can use the same spl generation tool
updating an ubi partition needs a completely erased mtd partition,
see:
http://lists.infradead.org/pipermail/linux-mtd/2011-May/035416.html
So, add partubi alt setting for the dfu_alt_info environment
variable to mark this partition as an ubi partition. In case we
update an ubi partition, we erase after flashing the image into the
partition, the remaining sektors.
Cc: Pantelis Antoniou <panto@antoniou-consulting.com>
Cc: Lukasz Majewski <l.majewski@samsung.com>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Cc: Scott Wood <scottwood@freescale.com>
Add the USB ehci support for the OMAP5 uEVM.
Configure the uEVM mux data
Add the flags to build the appropriate modules
Add the usb call backs to initialize the EHCI controller
Signed-off-by: Dan Murphy <dmurphy@ti.com>
- fix adresses in env settings in config header
- add missing CONFIG_STANDALONE_LOAD_ADDR to eb_cpux9k2 config header
- remove jffs2 support, board doesn't use this anymore
- add ubifs support
- change sizes and start for partitions
Signed-off-by: Jens Scharsig (BuS Elektronik) <esw@bus-elektronik.de>
remove the config.mk file
move text base define to board config file for following boards
- at91sam9m10g45ek
- at91sam9x5ek
Signed-off-by: Bo Shen <voice.shen@atmel.com>
fix typo error for CONFIG_ENV_IS_NOWHERE from CONIG_ENV_IS_NOWHERE
The CONFIG_MAX_NAND_CHIPS never used, remove it
No where define LCD_TEST_PATTERN, so no need undefine
Since kernel code current use many dev_xxx() instead of using printk. To
compatible, move those dev_xxx from usb driver to linux/compat.h. Then all
driver code can use dev_err, dev_info and dev_vdbg.
This patch also removed duplicated macro definitions in usb driver.
Signed-off-by: Josh Wu <josh.wu@atmel.com>
Acked-by: Scott Wood <scottwood@freescale.com>
