path: root/include
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 1/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs A-Z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: consolidate CONFIG_SYS_HZ definitionRob Herring
According to the README, CONFIG_SYS_HZ must be 1000 and most platforms follow that. In preparation to remove CONFIG_SYS_HZ from all these platforms, provide a common definition. The platforms which use a value other than 1000 will get build warning now. These configs are: include/configs/M5271EVB.h:#define CONFIG_SYS_HZ 1000000 include/configs/balloon3.h:#define CONFIG_SYS_HZ 3250000 /* Timer @ 3250000 Hz */ include/configs/idmr.h:#define CONFIG_SYS_HZ (50000000 / 64) include/configs/mini2440.h:#define CONFIG_SYS_HZ 1562500 include/configs/mx1ads.h:#define CONFIG_SYS_HZ 3686400 include/configs/omap3_zoom2.h:#define CONFIG_SYS_HZ ((V_SCLK) / (2 << CONFIG_SYS_PTV)) include/configs/omap730p2.h:#define CONFIG_SYS_HZ ((CONFIG_SYS_CLK_FREQ)/(2 << CONFIG_SYS_PTV)) include/configs/palmld.h:#define CONFIG_SYS_HZ 3250000 /* Timer @ 3250000 Hz */ include/configs/palmtc.h:#define CONFIG_SYS_HZ 3686400 /* Timer @ 3686400 Hz */ include/configs/rsk7203.h:#define CONFIG_SYS_HZ (CONFIG_SYS_CLK_FREQ / CMT_CLK_DIVIDER) include/configs/rsk7264.h:#define CONFIG_SYS_HZ (CONFIG_SYS_CLK_FREQ / CMT_CLK_DIVIDER) include/configs/rsk7269.h:#define CONFIG_SYS_HZ (CONFIG_SYS_CLK_FREQ / CMT_CLK_DIVIDER) include/configs/scb9328.h:#define CONFIG_SYS_HZ 3686400 /* incrementer freq: 3.6864 MHz */ include/configs/versatile.h:#define CONFIG_SYS_HZ (1000000 / 256) include/configs/zipitz2.h:#define CONFIG_SYS_HZ 3250000 /* Timer @ 3250000 Hz */ Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-10-31powerpc/esdhc: Add 3.3v voltage support in esdhc capacity registerHaijun.Zhang
T4240QDS eSDHC host capabilities reigster should have VS33 bit define. Add quirk CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 to deal with capacity missing Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Haijun Zhang <Haijun.Zhang@freescale.com> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2013-10-31DWMMC: SMDK5420: Disable SMU for eMMCRajeshwari Shinde
SMDK5420 has a new Security Management Unit added for dwmmc driver, hence, configuring the control registers to support booting via eMMC. Signed-off-by: Alim Akhtar <alim.akhtar@samsung.com> Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Jaehoon Chung <jh80.chung@samsung.com> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2013-10-31mmc: dw_mmc: change the callback function name.Jaehoon Chung
To prevent the confusion, use the get_mmc_clk() instead of mmc_clk(). get_mmc_clk() is more exactly name. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2013-10-31mmc: Fix erase_grp_size for partitioned cardOliver Metz
EXT_CSD_ERASE_GROUP_DEF is lost every time after a reset or power off. Set it if device has enhanced partitions. Signed-off-by: Oliver Metz <oliver@freetz.org> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2013-10-30Merge branch 'master' of git://git.denx.de/u-boot-videoTom Rini
2013-10-30video, cfb_console: make background and foreground color configurableHeiko Schocher
make CONSOLE_BG_COL/CONSOLE_FG_COL configurable through board config file. Clear video screen in video_init(). Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Anatolij Gustschin <agust@denx.de>
2013-10-24mpc85xx: introduce the kmp204x reference design supportValentin Longchamp
This patch introduces the support for Keymile's kmp204x reference design. This design is based on Freescale's P2040/P2041 SoC. The peripherals used by this design are: - DDR3 RAM with SPD support - SPI NOR Flash as boot medium - NAND Flash - 2 PCIe busses (hosts 1 and 3) - 3 FMAN Ethernet devices (FMAN1 DTSEC1/2/5) - 3 Local Bus windows, with one dedicated to the QRIO reset/power mgmt FPGA - 2 HW I2C busses - last but not least, the mandatory serial port The board/keymile/kmp204x code is mostly based on Freescale's P2041rdb support and was changed according to our design (that means essentially removing what is not present on the designs and a few adaptations). There is currently only one prototype board that is based on this design and this patch also introduces it. The board is called kmlion1. Signed-off-by: Stefan Bigler <stefan.bigler@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> kmp204x: update the ENV #define The comments had to be refined as well as the total size Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> [York Sun: fix ddr.c] Acked-by: York Sun <yorksun@freescale.com>
2013-10-24net/fman: add a fm_enable_port functionValentin Longchamp
This can be useful if one wants to disable an interface in u-boot because u-boot should not manage it but then later reenable it for FDT fixing or if the kernel uses this interface. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> [York Sun: fix conflict in fm_eth.h] Acked-by: York Sun <yorksun@freescale.com>
2013-10-24KM: add CONFIG_KM_COMMON_ETH_INIT for km common eth initValentin Longchamp
This must be defined by a board support file that want to use the keymile common.c board_eth_init function that requires ethernet_present to be defined. Currently all the km architectures use it but the kmp204x architecture later supported in this series does use another board_eth_init function and thus does not define it. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2013-10-24KM: define CONFIG_SYS_I2C_INIT_BOARD only for concerned boardValentin Longchamp
This must be defined for all the keymile boards that use the common i2c_abort function that is used to "reset" the I2C bus. These are currently km82xx and km_arm boards. The km83xx boards use other functions and thus do not need this. This patch removes the CONFIG_SYS_I2C_INIT_BOARD from keymile-common.h and defines it for km_arm.h and km82xx.h. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2013-10-24KM: fix typo in default environmentValentin Longchamp
The ip kernel parameter had a typo in it (we've been lucky that it has worked until now). Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2013-10-24km-powerpc: move SYS_MALLOC_LEN out of keymile-common.hValentin Longchamp
It must be set to a different value for the later add kmp204x architecture, because we are restricted to 1MB SRAM. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2013-10-24powerpc/usb:Differentiate USB controller base addressramneek mehresh
Introduce different macros for storing addresses of multiple USB controllers. This is required for successful initialization and usage of multiple USB controllers inside u-boot Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com>
2013-10-24powerpc/c29xpcie: add DDR ECC on off config settingPo Liu
c29xpcie REV_A board DDR ECC chip has bad impedance in hardware, force that kind of board to be DDR ECC off when booting. Other version board config ECC on/off by hwconfig=fsl_ddr:ecc=on in uboot enviroment. Signed-off-by: Po Liu <Po.Liu@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2013-10-22arm: rmobile: armadillo-800eva: Change clock definition of SCIF and TMUNobuhiro Iwamatsu
This changes clock definition of SCIF from CONFIG_SYS_CLK_FREQ to CONFIG_SH_SCIF_CLK_FREQ, and clock definition of TMU from CONFIG_SYS_CLK_FREQ to CONFIG_SH_TMU_CLK_FREQ, Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Albert Aribaud <albert.u.boot@aribaud.net>
2013-10-22arm: rmobile: kzm9g: Change clock definition of SCIF from ↵Nobuhiro Iwamatsu
CONFIG_SYS_CLK_FREQ to CONFIG_SH_SCIF_CLK_FREQ Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Albert Aribaud <albert.u.boot@aribaud.net>
2013-10-22Merge branch 'master' of git://git.denx.de/u-boot-shTom Rini
2013-10-21Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
2013-10-20usb: udc: add udc.h include fileTroy Kisky
Move common definitions to udc.h This allows musb_udc.h to be removed as well. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2013-10-20usb: gadget: mv_udc: split mv_udc.h fileTroy Kisky
Move defines only needed by mv_udc.c to a file in the same directory. This allows usbtty to compile for mv_udc, but it still doesn't link. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2013-10-20usb: ehci-mx6: add support for otg portTroy Kisky
Previously, only host1 was supported using an index of 0. Now, otg has index 0, host1 is 1, host2 is 2, host3 is 3. Since OTG requires usbmode to be set after reset, I added CONFIG_EHCI_HCD_INIT_AFTER_RESET to nitrogen6x.h and mx6qsabreauto.h. I also added a weak function board_ehci_power to handle turning power on/off for otg. Type is type of device connected (USB stick vs Host.) Init is type of device desired. Only power up port if type == init == USB_INIT_HOST. Only return error if type != init. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2013-10-20usb: add enum usb_init_type parameter to usb_lowlevel_initTroy Kisky
This parameter will later be used to verify OTG ports. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2013-10-20usb: rename board_usb_init_type to usb_init_typeTroy Kisky
This will be used by usb_lowlevel_init so it will no longer be used by only board specific functions. Move definition of enum usb_init_type higher in file so that it will be available for usb_low_level_init. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2013-10-20usb: am437x: Add support for am437x xhci USB hostDan Murphy
Add the support for the am437x xhci usb host. The xHCI host on AM437 is connected to a usb2 phy so need to add support to enable those clocks. Signed-off-by: Dan Murphy <dmurphy@ti.com>
2013-10-20usb: dra7xx: Add support for dra7xx xhci USB hostDan Murphy
Add the support for the dra7xx xhci usb host. dra7xx does not contain an EHCI controller so the headers can be removed from the board file. The xHCI host on dra7xx is connected to a usb2 phy so need to add support to enable those clocks. Signed-off-by: Dan Murphy <dmurphy@ti.com>
2013-10-20usb: omap: Move the usb phy code to the usb/phy directoryDan Murphy
Moving the usb/phy code from xhci-omap to the usb/phy directory and moving the associated phy code over to the new file. Newer TI processors adding xHCI support will have different PHY configurations so therefore abstracting this code away will prevent messing around with the xhci-omap file itself. Signed-off-by: Dan Murphy <dmurphy@ti.com>
2013-10-20usb: omap: Move the xhci-omap header file to common locationDan Murphy
Moving the xhci-omap header to a more global location so that other code can reference this code. Signed-off-by: Dan Murphy <dmurphy@ti.com>
2013-10-20trats: Update TRATS config to support TIZEN downloadLukasz Majewski
A set of environment variables needs to be updated to provide support for TIZEN download command (tizendown). Since DFU is used as a flashing backend, it is also necessary to extent malloc pool size for DFU buffer allocation. Moreover, for compatibility reasons (Win vs. Lin) new USB idProduct number for download gadget had to be added. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Cc: Marek Vasut <marex@denx.de>
2013-10-20usb:g_dnl:f_thor: USB download function to support TIZEN's THOR protocolLukasz Majewski
Implementation of USB download function which supports THOR protocol. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Cc: Marek Vasut <marex@denx.de>
2013-10-20usb:g_dnl: Add name parameter to g_dnl_bind_fixup functionLukasz Majewski
New parameter, namely *name has been added to g_dnl_bind_fixup(). It is necessary (for compatibility reasons) to assign new USB idProduct and idVendor for different usb functions. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Cc: Marek Vasut <marex@denx.de>
2013-10-20dfu:core: Export dfu_{get|free}_buf functionsLukasz Majewski
Define the dfu_get_buf() and dfu_free_buf() as global functions. They are necessary for zero copy buffer management, when DFU backend is used for storing data. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
2013-10-20dfu:core: Find DFU alt setting number by passing its nameLukasz Majewski
New function - dfu_get_alt() - has been added to dfu core. If present, it returns alt setting's number corresponding to passed name. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
2013-10-20usb: new board-specific USB init interfaceMateusz Zalega
This commit unifies board-specific USB initialization implementations under one symbol (usb_board_init), declaration of which is available in usb.h. New API allows selective initialization of USB controllers whenever needed. Signed-off-by: Mateusz Zalega <m.zalega@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com> Cc: Marek Vasut <marex@denx.de> Cc: Lukasz Majewski <l.majewski@samsung.com>
2013-10-20nitrogen6x: add CONFIG_MV_UDCTroy Kisky
Also, add other USB related config items. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2013-10-20ARM: OMAP5: Power: Add new function to turn on SMPS10Dan Murphy
Add new functionality to turn on SMPS10 regulator. This supplies the VBUS to devices connected to the USB host ports Signed-off-by: Dan Murphy <dmurphy@ti.com>
2013-10-20temp: config: exynos5250: Enable xHCI support for Exynos5Vivek Gautam
This enables support for xHCI host controller on Exynos5 and further disables EHCI support, to make sure only one host controller is enabled at a time, since right now using two controllers at a time is not possible with current usb core infrastructure. Anyone who wants to enable EHCI support again needs to enable CONFIG_USB_EHCI, CONFIG_USB_EHCI_EXYNOS once again in exynos5-dt config. Signed-off-by: Vikas C Sajjan <vikas.sajjan@samsung.com> Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com> Cc: Julius Werner <jwerner@chromium.org> Cc: Simon Glass <sjg@chromium.org> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Dan Murphy <dmurphy@ti.com> Cc: Marek Vasut <marex@denx.de>
2013-10-20config: arm: exynos5250: Define CONFIG_SYS_CACHELINE_SIZEVivek Gautam
XHCI stack driver needs this to align buffers to CacheLine boundary. So define the same to be '64' Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com> Cc: Julius Werner <jwerner@chromium.org> Cc: Simon Glass <sjg@chromium.org> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Dan Murphy <dmurphy@ti.com> Cc: Marek Vasut <marex@denx.de>
2013-10-20exynos5: dts: Add COMPAT string data for USB 3.0 PHY and XHCIVivek Gautam
Adding required compatible string for xHCI host controller as well as USB 3.0 PHY to enable dt support for usb 3.0 on exynos5. Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com> Cc: Julius Werner <jwerner@chromium.org> Cc: Simon Glass <sjg@chromium.org> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Dan Murphy <dmurphy@ti.com> Cc: Marek Vasut <marex@denx.de>
2013-10-20USB: XHCI: Add xHCI host controller support for Exynos5Vivek Gautam
This adds driver layer for xHCI controller in Samsung's exynos5 soc. This interacts with xHCI host controller stack. Signed-off-by: Vikas C Sajjan <vikas.sajjan@samsung.com> Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com> Cc: Julius Werner <jwerner@chromium.org> Cc: Simon Glass <sjg@chromium.org> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Dan Murphy <dmurphy@ti.com> Cc: Marek Vasut <marex@denx.de>
2013-10-20USB: xHCI: Add stack support for xHCIVivek Gautam
This adds stack layer for eXtensible Host Controller Interface which facilitates use of USB 3.0 in host mode. Adapting xHCI host controller driver in linux-kernel by Sarah Sharp to needs in u-boot. Initial porting from Linux kernel version 3.4, with following top commit history of drivers/usb/host/xhci* : cf84055 xHCI: Cleanup isoc transfer ring when TD length mismatch found This adds the basic xHCI host controller driver with bare minimum features: - Control/Bulk transfer support has been added with required infrastructure for necessary xHC data structures. - Stream protocol hasn't been supported yet. - No support for quirky devices has been added. Signed-off-by: Vikas C Sajjan <vikas.sajjan@samsung.com> Signed-off-by: Julius Werner <jwerner@chromium.org> Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com> Cc: Simon Glass <sjg@chromium.org> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Dan Murphy <dmurphy@ti.com> Cc: Marek Vasut <marex@denx.de>
2013-10-20usb: Move 'bmRequestType' USB device request macros from EHCI headerVivek Gautam
Macros defining bmRequestType field of USB device request, given in table 9.2 USB 2.0 spec, are rather generic macros which can be further used by other Host controller stacks. So moving them to usb_defs header. Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com> Cc: Julius Werner <jwerner@chromium.org> Cc: Simon Glass <sjg@chromium.org> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Dan Murphy <dmurphy@ti.com> Cc: Marek Vasut <marex@denx.de>
2013-10-17Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
2013-10-17i2c: Zynq: Support for TI PCA9548 bus multiplexerMichael Burr
(Interface is not quite the same as Phillips PCA9547.) Signed-off-by: Michael Burr <michael.burr@logicpd.com> Cc: Heiko Schocher <hs@denx.de> Cc: Michal Simek <monstr@monstr.eu>
2013-10-17i2c: update config using mxc driver to new subsystemtrem
Signed-off-by: Philippe Reynes <tremyfr@yahoo.fr>
2013-10-17sh: boards: Change clock definition of SCIF and TMUNobuhiro Iwamatsu
This changes clock definition of SCIF from CONFIG_SYS_CLK_FREQ to CONFIG_SH_SCIF_CLK_FREQ, and clock definition of TMU from CONFIG_SYS_CLK_FREQ to CONFIG_SH_TMU_CLK_FREQ for boards. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Albert Aribaud <albert.u.boot@aribaud.net>
2013-10-17sh: timer: Change definition of clock of TMUNobuhiro Iwamatsu
The former SH/TMU driver had calculated timer based on CONFIG_SYS_CLK_FREQ. The newest SH/TMU newly needs calculation of the clock for TMU. This patch defines clock CONFIG_SH_TMU_CLK_FREQ for TMU and changes it to CONFIG_SH_TMU_CLK_FREQ from CONFIG_SYS_CLK_FREQ. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
