As the upcoming driver model integration takes up some more precious flash
space first make sure to drop expensive LZMA support.
Cover-Letter: Fixes several spelling errors for the words "resetting",
"extended", "occur", and "multiple".
Signed-off-by: Vagrant Cascadian <vagrant@debian.org>
Not all networks have a DHCP server configured properly, so these
scripts make it easier to boot in that scenario.
The LCD isn't supported in U-Boot and the LCD is now configured in
the device tree, so this code is pointless.
V2: Eliminiate erroneous newline.
Unify the partitions of each chip then it will be more easy for us to
write scripts, tools or guides for rockchip chips.
Those extra partitions mostly are used to be compatible with our
internal loaders (such as miniloader which was same as spl, or
android loader then we can support dual boot)
Signed-off-by: Jacob Chen <jacob2.chen@rock-chips.com>
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
rk3399 has two mmc dev controller:
mmc 0: SD card;
mmc 1: EMMC
U-Boot will scan the mmc boot device configured by CONFIG_SYS_MMC_ENV_DEV,
since evb has emmc on board, let's set the EMMC as default.
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
I am not sure why this limit is changing. But my kernel
doesn't load when it's above 256. This was testing on the
rock2 board.
Signed-off-by: Sandy Patterson <apatterson@sightlogix.com>
Updated commit subject:
Mostly by adding MACH_SUN50I to some existing #ifdefs enable support
for the the HCI0 USB host controller on the A64.
Fix up some minor 64-bit hiccups on the way.
Add the bare minimum DT bits to the A64 .dtsi and enable the controllers
and the PHY on the Pine64.
This is limited to the first USB controller at the moment, which is
connected to the lower USB socket on the Pine64 board.
[Andre: remove unneeded defines, enable OHCI, add commit message]
Signed-off-by: Amit Singh Tomar <amittomer25@gmail.com>
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
ARCH_SUNXI selects DM_USB, where CONFIG_USB_MAX_CONTROLLER_COUNT
is not used.
CONFIG_SUNXI -> CONFIG_ARCH_SUNXI
and removed CONFIG_SUNIX from config_whitelist.txt
Cc: Ian Campbell <ijc@hellion.org.uk>
Cc: Hans de Goede <hdegoede@redhat.com>
Signed-off-by: Jagan Teki <jteki@openedev.com>
Enable an early debug UART to debug problems when an ICE or other
debug mechanism is not available.
Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com>
Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
If 'ethaddr' is not set, we will get the ethernet address from AT24MAC,
and set it to 'ethaddr' variable.
Signed-off-by: Songjun Wu <songjun.wu@microchip.com>
Reviewed-by: Andreas Bießmann <biessmann@corscience.de>
Move the config options from the include/configs/sama5d2_xplained.h
to configs/sama5d2_xplained_*_defconfig.
Reviewed-by: Andreas Bießmann <andreas@biessmann.org>
common/Kconfig
configs/dms-ba16_defconfig
Introduce CONFIG_PCI_PNP in Kconfig and move over boards' defconfig
to use that.
[trini: Re-generate configs and include/configs/ changes]
Add 'PCI' as a menu option and migrate all existing users.
icorem6qdl> mtdparts
device nand0 <nand>, # parts = 6
0: spl 0x00200000 0x00000000 0
1: uboot 0x00200000 0x00200000 0
2: env 0x00100000 0x00400000 0
3: kernel 0x00400000 0x00500000 0
4: dtb 0x00100000 0x00900000 0
5: rootfs 0x1f600000 0x00a00000 0
Cc: Peng Fan <peng.fan@nxp.com>
Cc: Matteo Lisi <matteo.lisi@engicam.com>
Cc: Michael Trimarchi <michael@amarulasolutions.com>
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Enable MTD device, partition and command support.
Add NAND support for Engicam i.CoreM6 qdl board.
Boot Log:
U-Boot SPL 2016.09-rc2-30755-gd3dc581-dirty (Sep 28 2016 - 23:00:43)
Trying to boot from NAND
NAND : 512 MiB
U-Boot 2016.09-rc2-30755-gd3dc581-dirty (Sep 28 2016 - 23:00:43 +0530)
CPU: Freescale i.MX6SOLO rev1.3 at 792MHz
CPU: Industrial temperature grade (-40C to 105C) at 55C
Reset cause: WDOG
Model: Engicam i.CoreM6 DualLite/Solo Starter Kit
DRAM: 256 MiB
NAND: 512 MiB
MMC: FSL_SDHC: 0
In: serial
Out: serial
Err: serial
Net: FEC [PRIME]
Hit any key to stop autoboot: 0
icorem6qdl>
Cc: Scott Wood <oss@buserror.net>
Add DM_GPIO, DM_MMC support for u-boot and disable for SPL.
Cc: Fabio Estevam <fabio.estevam@nxp.com>
Add imx6qdl clock header defines support from Linux.
"clk: imx: Add clock support for imx6qp"
(sha1: ee36027427c769b0b9e5e205fe43aced93d6aa66)
Add enet support for engicam icorem6 qdl starter kit.
- Add pinmux settings
- Add board_eth_init
TFTP log:
Net: FEC [PRIME]
icorem6qdl> tftpboot {fdt_addr} imx6dl-icore.dtb
Using FEC device
TFTP from server 192.168.2.96; our IP address is 192.168.2.75
Filename 'imx6dl-icore.dtb'.
Load address: 0x0
Loading: ######
1.3 MiB/s
done
Bytes transferred = 28976 (7130 hex)
CACHE: Misaligned operation at range [00000000, 00007130]
icorem6qdl>
Boot Log for i.CoreM6 DualLite/Solo Starter Kit:
U-Boot SPL 2016.09-rc2-30739-gd1fa290 (Sep 17 2016 - 00:37:46)
Trying to boot from MMC1
U-Boot 2016.09-rc2-30739-gd1fa290 (Sep 17 2016 - 00:37:46 +0530)
CPU: Industrial temperature grade (-40C to 105C) at 31C
Reset cause: POR
DRAM: 256 MiB
MMC: FSL_SDHC: 0
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: CPU Net Initialization Failed
No ethernet found.
switch to partitions #0, OK
mmc0 is current device
reading boot.scr
** Unable to read file boot.scr **
reading zImage
6741808 bytes read in 341 ms (18.9 MiB/s)
Booting from mmc ...
reading imx6dl-icore.dtb
30600 bytes read in 19 ms (1.5 MiB/s)
Booting using the fdt blob at 0x18000000
Using Device Tree in place at 18000000, end 1800a787
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
Boot Log for i.CoreM6 Quad/Dual Starter Kit:
CPU: Freescale i.MX6Q rev1.2 at 792MHz
CPU: Industrial temperature grade (-40C to 105C) at 28C
Reset cause: POR
DRAM: 512 MiB
MMC: FSL_SDHC: 0
In: serial
Out: serial
Err: serial
No ethernet found.
icorem6qdl>
Acked-by: Peng Fan <peng.fan@nxp.com>
- Add DEFAULT_FDT_FILE kconfig entry
- Move CONFIG_DEFAULT_FDT_FILE from include/configs to defconfigs
CONFIG_SYS_STDIO_DEREGISTER
This option should never be enabled in SPL, so use
CONFIG_IS_ENABLED(SYS_STDIO_DEREGISTER) when checking the option.
[trini: Re-sync]
CONFIG_USB_KEYBOARD
[trini: Fixup MPC86* configs]
CONFIG_SYS_CONSOLE_INFO_QUIET
[trini: Make this default n, re-run the migration]
CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
CONFIG_SYS_CONSOLE_ENV_OVERWRITE
CONFIG_CONSOLE_SCROLL_LINES
This is not used in U-Boot. Drop it.
This should be defined in a header file so that arguments are checked.
Move it to video.h.
CONFIG_CONSOLE_EXTRA_INFO
CONFIG_VIDEO_SW_CURSOR
[trini: Re-convert, find all the cases where this is off]
CONFIG_VGA_AS_SINGLE_DEVICE
Once we migrate to driver model for video, we should be able to drop this
option.
CONFIG_SYS_CONSOLE_BG_COL
CONFIG_SYS_CONSOLE_FG_COL
CONFIG_VIDEO_CT69000
CONFIG_CFB_CONSOLE_ANSI
CONFIG_CFB_CONSOLE
This is not really a config. Rename it to avoid confusion.
Reviewed-by: Jagan Teki <jteki@openedev.com>
CONFIG_SYS_CONSOLE_IS_IN_ENV
CONFIG_CONSOLE_MUX
[trini: Re-order, re-migrate]
CONFIG_LCD
CONFIG_VIDEO
