FG IC built into the MAX8997 device (compliant to MAX17042) is enabled
at TRATS.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
MUIC IC built into the MAX8997 device is enabled at TRATS.
Default PMIC (MAX8997) initialization for Samsung's TRATS development board.
Function for calculating LDO internal register value from passed micro
Volt.
Support for MAX17042 fuel-gauge (FG), which is built into the MAX8997
power management device.
Special file - fg_battery_cell_params.h with cells characteristics
added.
The FG device will work with redesigned PMIC framework.
Support for MUIC (Micro USB Integrated Circuit) built into the MAX8997
The MUIC device will work with redesigned PMIC framework.
Now it is possible to provide specific function per PMIC/power
device instance.
New power_chrg.h file has been added to "bind" together common
information about charging battery available in the system.
The PMIC framework has been extended to support multiple instances of
the variety of devices responsible for power management.
This change allows supporting of e.g. fuel gauge, charger, MUIC (Micro USB
Interface Circuit).
Power related includes have been moved to ./include/power directory.
This is a first of a series of patches - in the future "pmic" will be
replaced with "power".
Two important issues:
1. The PMIC needs to be initialized just after malloc is configured
2. It uses list to hold information about available PMIC devices
Since the pmic_reg_read is the u32 value, the order in which bytes
are placed to form u32 value is important.
Support for big and little sensor endianess is added.
Moreover calls to [leXX|beXX]_to_cpu have been added to support
little and big endian SoCs.
define Z_NULL to (void *)0 include/u-boot/zlib.h to get rid of most of
the NULL pointer warnings.
inflate.c:942:1: warning: non-ANSI definition of function 'inflateEnd'
inflate.c:9:1: warning: non-ANSI definition of function 'inflateReset'
inflate.c:12:17: warning: Using plain integer as NULL pointer
inflate.c:12:42: warning: Using plain integer as NULL pointer
inflate.c:15:17: warning: Using plain integer as NULL pointer
inflate.c:21:19: warning: Using plain integer as NULL pointer
inflate.c:35:1: warning: non-ANSI definition of function 'inflateInit2_'
inflate.c:38:20: warning: Using plain integer as NULL pointer
inflate.c:41:17: warning: Using plain integer as NULL pointer
inflate.c:42:17: warning: Using plain integer as NULL pointer
inflate.c:50:18: warning: Using plain integer as NULL pointer
inflate.c:65:23: warning: Using plain integer as NULL pointer
inflate.c:69:21: warning: Using plain integer as NULL pointer
inflate.c:78:1: warning: non-ANSI definition of function 'inflateInit_'
inflate.c:86:1: warning: non-ANSI definition of function 'fixedtables'
inflate.c:108:26: warning: Using plain integer as NULL pointer
inflate.c:109:1: warning: non-ANSI definition of function 'updatewindow'
inflate.c:112:30: warning: Using plain integer as NULL pointer
inflate.c:339:1: warning: non-ANSI definition of function 'inflate'
inflate.c:349:17: warning: Using plain integer as NULL pointer
inflate.c:349:42: warning: Using plain integer as NULL pointer
inflate.c:350:27: warning: Using plain integer as NULL pointer
inflate.c:369:42: warning: Using plain integer as NULL pointer
inflate.c:376:32: warning: Using plain integer as NULL pointer
inflate.c:401:54: warning: Using plain integer as NULL pointer
inflate.c:419:32: warning: Using plain integer as NULL pointer
inflate.c:426:32: warning: Using plain integer as NULL pointer
inflate.c:433:32: warning: Using plain integer as NULL pointer
inflate.c:444:36: warning: Using plain integer as NULL pointer
inflate.c:449:37: warning: Using plain integer as NULL pointer
inflate.c:450:38: warning: Using plain integer as NULL pointer
inflate.c:457:40: warning: Using plain integer as NULL pointer
inflate.c:458:47: warning: Using plain integer as NULL pointer
inflate.c:480:40: warning: Using plain integer as NULL pointer
inflate.c:481:50: warning: Using plain integer as NULL pointer
inflate.c:491:37: warning: Using plain integer as NULL pointer
inflate.c:492:37: warning: Using plain integer as NULL pointer
inflate.c:501:40: warning: Using plain integer as NULL pointer
inflate.c:502:53: warning: Using plain integer as NULL pointer
inflate.c:512:37: warning: Using plain integer as NULL pointer
inflate.c:513:40: warning: Using plain integer as NULL pointer
inflate.c:525:32: warning: Using plain integer as NULL pointer
inflate.c:529:52: warning: Using plain integer as NULL pointer
inflate.c:543:54: warning: Using plain integer as NULL pointer
inflate.c:932:17: warning: Using plain integer as NULL pointer
inflate.c:932:42: warning: Using plain integer as NULL pointer
inflate.c:935:26: warning: Using plain integer as NULL pointer
inflate.c:940:19: warning: Using plain integer as NULL pointer
adler32.c:58:5: warning: non-ANSI definition of function 'adler32'
adler32.c:81:16: warning: Using plain integer as NULL pointer
zutil.c:53:9: warning: non-ANSI definition of function 'zcalloc'
zutil.c:64:9: warning: non-ANSI definition of function 'zcfree'
inffast.c:70:1: warning: non-ANSI definition of function 'inflate_fast'
inftrees.c:33:1: warning: non-ANSI definition of function 'inflate_table'
bootp.c:44:14: warning: symbol 'dhcp_state' was not declared. Should it be static?
bootp.c:45:15: warning: symbol 'dhcp_leasetime' was not declared. Should it be static?
bootp.c:46:10: warning: symbol 'NetDHCPServerIP' was not declared. Should it be static?
arp.c:30:17: warning: symbol 'NetArpWaitReplyIP' was not declared. Should it be static?
arp.c:37:16: warning: symbol 'NetArpTxPacket' was not declared. Should it be static?
arp.c:38:17: warning: symbol 'NetArpPacketBuf' was not declared. Should it be static?
atheros.c:33:19: warning: symbol 'AR8021_driver' was not declared. Should it be static?
net.c:183:7: warning: symbol 'PktBuf' was not declared. Should it be static?
net.c:159:21: warning: symbol 'net_state' was not declared. Should it be static?
ping.c:73:6: warning: symbol 'ping_start' was not declared. Should it be static?
ping.c:82:13: warning: symbol 'ping_receive' was not declared. Should it be static?
tftp.c:53:7: warning: symbol 'TftpRRQTimeoutMSecs' was not declared. Should it be static?
tftp.c:54:5: warning: symbol 'TftpRRQTimeoutCountMax' was not declared. Should it be static?
eth.c:125:19: warning: symbol 'eth_current' was not declared. Should it be static?
Note: in the ping.c fix, commit a36b12f95a29647a06b5459198684fc142482020
"net: Move PING out of net.c" mistakenly carried the ifdef CMD_PING
clause from when it was necessary to avoid warnings when it was embedded
in net.c.
include/image.h:378:1: warning: cast to restricted __be32
include/image.h:381:1: warning: cast to restricted __be32
include/image.h:382:1: warning: cast to restricted __be32
include/image.h:383:1: warning: cast to restricted __be32
fix by annotating image header integers big endian.
hack to avoid:
/opt/gcc-4.6.3-nolibc/powerpc-linux/bin/../lib/gcc/powerpc-linux/4.6.3/include/stddef.h:413:9: warning: preprocessor token offsetof redefined
u-boot/include/linux/stddef.h:20:9: this was the original definition
tried protecting with __KERNEL__, and #including compiler.h first.
Even tried include dir reordering to no avail:
+++ b/config.mk
@@ -194,7 +194,11 @@ OBJCFLAGS += --gap-fill=0xff
gccincdir := $(shell $(CC) -print-file-name=include)
CPPFLAGS := $(DBGFLAGS) $(OPTFLAGS) $(RELFLAGS) \
- -D__KERNEL__
+ -D__KERNEL__ \
+ -I $(gccincdir) \
+ -nostdinc
+# -isystem $(gccincdir) \
# Enable garbage collection of un-used sections for SPL
ifeq ($(CONFIG_SPL_BUILD),y)
@@ -227,8 +231,7 @@ CPPFLAGS += -I$(OBJTREE)/include2 -I$(OBJTREE)/include
endif
CPPFLAGS += -I$(TOPDIR)/include
-CPPFLAGS += -fno-builtin -ffreestanding -nostdinc \
- -isystem $(gccincdir) -pipe $(PLATFORM_CPPFLAGS)
+CPPFLAGS += -fno-builtin -ffreestanding -pipe $(PLATFORM_CPPFLAGS)
redefined
include/linux/unaligned/generic.h:5:9: warning: preprocessor token __force redefined
include/linux/compiler.h:10:10: this was the original definition
fixup __force definitions in compat.h code appears to be placed
there as a cover up from a code import from linux when u-boot didn't yet
have a compiler.h, introduced by commit
b1b4e89a0f3b75854c39a62cae41bad56d210adf "Add LZO decompressor support".
redefined
include/linux/compat.h:4:9: warning: preprocessor token __user redefined
include/linux/compiler.h:7:10: this was the original definition
include/linux/compat.h:5:9: warning: preprocessor token __iomem redefined
include/linux/compiler.h:12:10: this was the original definition
fixup __iomem, __user definitions in compat.h code appears to be placed
932394ac43e2e778e664eeb6e456fecd0fae6e59 "Rewrite of NAND code based on
what is in 2.6.12 Linux kernel".
u-boot's byteorder headers did not contain endianness attributions
for use with sparse, causing a lot of false positives. Import the
kernel's latest definitions, and enable them by including compiler.h
and types.h. They come with 'const' added for some swab functions, so
fix those up, too:
include/linux/byteorder/big_endian.h:46:2: warning: passing argument 1 of '__swab64p' discards 'const' qualifier from pointer target type [enabled by default]
Also, note: u-boot's historic __BYTE_ORDER definition has been
preserved (for the time being at least).
We also remove ad-hoc barrier() definitions, since we're including
compiler.h in files that hadn't in the past:
macb.c:54:0: warning: "barrier" redefined [enabled by default]
In addition, including compiler.h in byteorder changes the 'noinline'
definition to expand to __attribute__((noinline)). This fixes
arch/powerpc/lib/bootm.c:
bootm.c:329:16: error: attribute '__attribute__': unknown attribute
bootm.c:329:16: error: expected ')' before '__attribute__'
bootm.c:329:25: error: expected identifier or '(' before ')' token
powerpc sparse builds yield:
include/common.h:356:22: error: marked inline, but without a definition
the unknown-reason inlining without a definition is considered obsolete
given it was part of the 2002 initial commit, and no arm version was
'fixed.'
also fixed:
ydirectenv.h:60:0: warning: "inline" redefined [enabled by default]
and:
Configuring for devconcenter - Board: intip, Options: DEVCONCENTER
make[1]: *** [4xx_ibm_ddr2_autocalib.o] Error 1
make: *** [arch/powerpc/cpu/ppc4xx/libppc4xx.o] Error 2
powerpc-fsl-linux-size: './u-boot': No such file
4xx_ibm_ddr2_autocalib.c: In function 'DQS_autocalibration':
include/asm/ppc4xx-sdram.h:1407:13: sorry, unimplemented: inlining failed in call to 'ppc4xx_ibm_ddr2_register_dump': function body not available
4xx_ibm_ddr2_autocalib.c:1243:32: sorry, unimplemented: called from here
and:
In file included from crc32.c:50:0:
crc32table.h:4:1: warning: implicit declaration of function '___constant_swab32' [-Wimplicit-function-declaration]
crc32table.h:4:1: error: initializer element is not constant
crc32table.h:4:1: error: (near initialization for 'crc32table_le[0]')
[trini: Remove '#endif' in include/common.h around setenv portion]
When the generic filesystem load command "fsload" was written, I felt
that "load" was too generic of a name for it, since many other similar
commands already existed. However, it turns out that there is already
an "fsload" command, so that name cannot be used. Rename the new
"fsload" to plain "load" to avoid the conflict. At least anyone who's
used a Basic interpreter should feel familiar with the name!
Commit 045fa1e "fs: add filesystem switch libary, implement ls and
fsload commands" unified the implementation of fatload and ext*load
with the new command fsload. However, this altered the interpretation
of command-line numbers from always being base-16, to requiring a "0x"
prefix for base-16 numbers. Enhance do_fsload() to allow commands to
specify which base to use.
Use base 0, thus requiring a "0x" prefix for the new fsload command.
This feels much cleaner than assuming base 16.
Use base 16 for the pre-existing fatload and ext*load to prevent a
change in behaviour.
Use base 16 exclusively for the loadaddr environment variable, since
that variable is interpreted in multiple places, so we don't want the
behaviour to change.
Update command help text to make it clear where numbers are assumed to
be hex, and where an explicit "0x" prefix is required.
Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
* add CONFIG_SYS_CACHELINE_SIZE to eb_cpux9k2 board config header
* dissable dcache (CONFIG_SYS_DCACHE_OFF) for eb_cpux9k2
Signed-off-by: Jens Scharsig (BuS Elektronik) <esw@bus-elektronik.de>
Enable AHCI driver for Intel SATA devices.
Writes in u-boot are so rare, and the logic to know when is
the last write and do a flush only there is sufficiently
difficult. Just do a flush after every write. This incurs,
usually, one extra flush when the rare writes do happen.
Signed-off-by: Marc Jones <marc.jones@chromium.org>
In the structure returned by the ATA identify device command, there are two
fields which describe the device capacity. One is a 32 bit data type which
reports the number of sectors as a 28 bit LBA, and the other is a 64 bit data
type which is for a 48 bit LBA. If the device doesn't support 48 bit LBAs,
the small value is the only value with the correct size. If it supports more,
if the number of sectors is small enough to fit into 28 bits, both fields
reflect the correct value. If it's too large, the smaller field has 28 bits of
1s, 0xfffffff, and the other field has the correct value.
The AHCI driver is implemented by attaching to the generic SCSI code and
translating on the fly between SCSI binary data structures and AHCI data
structures. It responds to requests to execute specific SCSI commands by
executing the equivalent AHCI commands and then crafting a response which
matches what a SCSI disk would send.
The AHCI driver now considers both fields and chooses the correct one when
implementing both the SCSI READ CAPACITY (10) and READ CAPACITY (16) commands.
Signed-off-by: Gabe Black <gabeblack@chromium.org>
- print the correct speed
- print all the AHCI capability flags
(information taken from Linux kernel driver)
- clean up some comments
For example, this might show the following string:
AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x3 impl SATA mode
Signed-off-by: Stefan Reinauer <reinauer@chromium.org>
Commit-Ready: Stefan Reinauer <reinauer@chromium.org>
Tested-by: Stefan Reinauer <reinauer@chromium.org>
Add a new function to find out the number of available SCSI disks. Also
set the 'scsidevs' environment variable after each scan.
This includes were outside an #ifdef CONFIG_PPC, but there is not reason
to exclude powerpc from using them.
Move the declaration outside the #ifdef.
We add CONFIG_ENV_VARS_UBOOT_CONFIG,
CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG and CONFIG_BOARD_LATE_INIT to set
the variables and then fdtfile and findfdt to make us of this. It is
now possible to do 'run findfdt' to have fdtfile be set to the value of
the dtb file to load for the board we are running on.
CONFIG_ENV_VARS_UBOOT_CONFIG creates environment variables indicating
which configuration U-Boot was built for. Some U-Boot binaries run on
multiple boards, and hence this information may not uniquley describe
the HW that U-Boot is actually running on. Another patch introduces
environment variable board_name to represent that. In order to avoid
scripts having to check $board_name, use it if set, and then fall back
to using $board, make CONFIG_ENV_VARS_UBOOT_CONFIG also set a default
value for board_name, so that variable is always available.
Commit 1db7377a70a8d931c32648e717695133120d5456 fixes the gen_atmel_mci driver
to be able to use multi block access for avr32. Therefore remove the setting
which forces single block access.
This also adds a huge performace gain for mmc access:
---8<---
Loading file "/boot/uImage" from mmc device 0:1
1830666 bytes read in 1293 ms (1.3 MiB/s)
--->8---
vs.
---8<---
1830666 bytes read in 237 ms (7.4 MiB/s)
--->8---
Cc: haavard.skinnemoen@atmel.com
Cc: hans-christian.egtvedt@atmel.com
Cc: mpfj@mimc.co.uk
Cc: alex.raimondi@miromico.ch
Cc: julien.may@miromico.ch
Cc: egtvedt@samfundet.no
Cc: havard@skinnemoen.net
Signed-off-by: Raphael Assenat <raph@8d.com>
[trini: Squash boards.cfg / MAINTAINERS change into main patch]
Based on previous work by: Alistair Buxton <a.j.buxton@gmail.com>
Signed-off-by: Pali Rohár <pali.rohar@gmail.com>
Cc: Ивайло Димитров <freemangordon@abv.bg>
* Code copied from linux kernel 3.0.0 from file include/linux/i2c/twl.h
* commit 6523b148b44be38d89c2ee9865d34da30d9f5f1c
Implement "ls" and "fsload" commands that act like {fat,ext2}{ls,load},
and transparently handle either file-system. This scheme could easily be
extended to other filesystem types; I only didn't do it for zfs because
I don't have any filesystems of that type to test with.
Replace the implementation of {fat,ext[24]}{ls,load} with this new code
too.
This makes the FAT and ext4 filesystem implementations build if
CONFIG_FS_{FAT,EXT4} are defined, rather than basing the build on
whether CONFIG_CMD_{FAT,EXT*} are defined. This will allow the
filesystems to be built separately from the filesystem-specific commands
that use them. This paves the way for the creation of filesystem-generic
commands that used the filesystems, without requiring the filesystem-
specific commands.
Minor documentation changes are made for this change.
The new config options are automatically selected by the old config
options to retain backwards-compatibility.
Change tegra SPL to use common SPL framework. Any tegra specific
initialization is now done in spl_board_init() instead of
board_init_f()/board_init_r(). Only one SPL boot target is supported
on tegra, which is boot to RAM image. jump_to_image_no_args() must be
overridden on tegra so the host CPU can be initialized.
Signed-off-by: Allen Martin <amartin@nvidia.com>
Tested-by: Lucas Stach <dev@lynxeye.de>
Signed-off-by: Tom Warren <twarren@nvidia.com>
For Tegra, the SPL and main U-Boot are concatenated together to form a
single memory image. Hence, the maximum SPL size is the different in
TEXT_BASE for SPL and main U-Boot. Instead of manually calculating
SPL_MAX_SIZE based on those two TEXT_BASE, which can lead to errors if
one TEXT_BASE is changed without updating SPL_MAX_SIZE, simply perform
the calculation automatically.
Acked-by: Allen Martin <amartin@nvidia.com>
Add the missing bits to the Tegra NAND driver to make ONFI detection work
properly.
Also add it to the Tegra default config, as it seems to be a reasonable thing
to have it available on all boards that use any kind of NAND.
Signed-off-by: Lucas Stach <dev@lynxeye.de>
Acked-by: Scott Wood <scottwood@freescale.com>
The device tree already contains the required configuration for both the
USB1 and USB3 ports. Enable the required configuration options to enable
both these ports, which in turn allows the USB1 port to be used.
Note that on a true Seaboard, this port is typically used as a device
port hosting Tegra's USB recovery protocol. However, on the Springbank
derivative, this port is the only external USB port, so we enable it as
a host port so that USB peripherals may be used. Enabling this port in
U-Boot as a host port doesn't prevent the port from reverting to a
device port when the CPU is reset into recovery mode.
The ULPI port is routed onto pins on the mini PCI Express connector. A
standard breakout board may be used to access the port.
* Add required DT entries to configure the ULPI port.
* Setup up the ULPI pinmux in the board code.
* Enable multiple USB controller and ULPI support in the board config.
Currently, Tegra's default environment uses non-standard variables to define
where boot scripts should load the kernel, FDT, and initrd. This change both
changes the variable names to match those described in U-Boot's README, and
shuffles their values around a little so that the values make a little more
sense; see comments in the patch for rationale behind the values chosen.
Note that this patch does remove the old non-standard variable "fdt_load" from
the default environment, so this patch requires people to change their boot
scripts.
This define indicates the size of the memory region where it is safe
to place data passed to the Linux kernel (ATAGs, DTB, initrd). The
value needs to be:
a) Less than or equal to RAM size.
b) Small enough that the area is not within the kernel's highmem region,
since the kernel cannot access ATAGs/DTB/initrd from highmem.
c) Large enough to hold the kernel+DTB+initrd.
256M seems large enough for (c) in most circumstances, and small enough
to satisfy (a) and (b) across any possible Tegra board. Note that the
user can override this value via environment variable "bootm_mapsize"
if needed.
The advantage of defining BOOTMAPSZ is that we no longer need to define
variable fdt_high in the default environment. Previously, we defined
this to prevent the DTB from being relocated to the very end of RAM,
which on most Tegra systems is within highmem, and hence which would
cause boot failures. A user can still define this variable themselves
if they want the FDT to be either left in-place wherever loaded, or
copied to some other specific location. Similarly, there should no
longer be a strict requirement for the user to define initrd_high if
using an initrd.
This adds board support for the Toradex Colibri T20 module.
Working functions:
- SD card boot
- USB boot
- Network
- NAND environment
This patch remove the env saving in NAND as so far the
NAND driver is not ported to the M54418TWR platform.
Signed-off-by: Jason Jin <Jason.jin@freescale.com>
These boards have long reached EOL, and there has been no indication
of any active users of such hardware for years. Get rid of the dead
weight.
Cc: Wolfgang Grandegger <wg@denx.de>
