path: root/include
2008-05-14environment: fix bug introduced by commit a8409f4f1ac8Wolfgang Denk
env_get_char is not a function, but a pointer to one. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-05-14Merge branch 'master' of git://www.denx.de/git/u-boot-ppc4xxWolfgang Denk
2008-05-14environment: cleanup prototype declarations of env functions.Wolfgang Denk
2008-05-13Makefile: fix "error: version_autogenerated.h: No such file or directory"Wolfgang Denk
2008-05-13ppc4xx: Add 405EX(r) revision C PVR definitions and detection codeStefan Roese
2008-05-12Merge branch 'master' of /home/wd/git/u-boot/custodiansWolfgang Denk
2008-05-12Revert "Avoid initrd and logbuffer area overlaps"Wolfgang Denk
This reverts commit 1b5605ca57fbb364f4d78eeee28b974ed875e888 which breaks building on all PPC boards that don't use a log buffer.
2008-05-12Revert "Change env_get_char from a global function ptr to a function."Wolfgang Denk
This reverts commit c0559be371b2a64b1a817088c3308688e2182f93 which is known to break booting from dataflash and NAND.
2008-05-10ppc4xx: Kilauea: Add CONFIG_BOOTP_SUBNETMASK to Kilauea board configMarkus Klotzbücher
When using dhcp/bootp the "netmask" environment variable is not set because CONFIG_BOOTP_SUBNETMASK is not defined. But usually this is desireable, so the following patch adds this this option to the board config. Signed-off-by: Markus Klotzbuecher <mk@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2008-05-10ppc4xx: Update Makalu defconfig to use device-tree booting as defaultStefan Roese
This patch reworks the default environment on Makalu. Now "net_nfs" for example uses the device-tree style booting formerly know as "net_nfs_fdt". Also the addresses in RAM were changed because of the new image booting support, which check for image overwriting. So the addresses needed to get adjusted. Signed-off-by: Stefan Roese <sr@denx.de>
2008-05-10PPC: fix map_physmem build warningBecky Bruce
map_physmem currently generates a warning when CONFIG_PHYS_64BIT is enabled. This quiets the warning. Signed-off-by: Becky Bruce <Becky.Bruce@freescale.com>
2008-05-10Update pci code to use phys_addr_tBecky Bruce
Physical addrs need to be represented by phys_addr_t, not unsigned long. Otherwise, systems that use CONFIG_PHYS_64BIT are going to fail mightily. Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
2008-05-10Merge branch 'master' of git://www.denx.de/git/u-boot-mpc83xxWolfgang Denk
2008-05-10Fix @ -> <at> substitutionStelian Pop
When applying the AT91CAP9 patches upstream, something transformed the '@' character into the ' <at> ' sequence. The patch below restores the original form in all the places where it has been modified (the AT91CAP9 files, the AT91SAM9260 files which were copied from AT91CAP9, and a couple of other files where the ' <at> ' sequence was present). Signed-off-by: Stelian Pop <stelian@popies.net>
2008-05-10Update origin and copyright information in arch-at91sam9 header filesStelian Pop
When doing the AT91CAP9/AT91SAM9 port, a number of header files were copied from the Linux kernel sources. This patch explicitly specifies this origin for all the copied headers, and for those missing copyright information, adds it. Additionaly, the header file 'at91sam926x_mc.h' has been superceeded in the latest kernel sources by 'at91sam9_smc.h'. The copyright information has been confirmed by the AT91 Linux kernel maintainer, Andrew Victor <avictor.za@gmail.com>. Signed-off-by: Stelian Pop <stelian@popies.net>
2008-05-10mx31ads: fix 32kHz clock handlingGuennadi Liakhovetski
According to schematics and to RedBoot sources, the MX31ADS uses a 32768Hz oscillator as a SKIL source. Fix previously wrongly assumed 32000Hz value. Also fix a typo when verifying a jumper configuration. While at it, make two needlessly global functions static. Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2008-05-10Avoid initrd and logbuffer area overlapsMarian Balakowicz
Add logbuffer to reserved LMB areas to prevent initrd allocation from overlaping with it. Make sure to use correct logbuffer base address. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-05-09Merge branch 'master' of /home/wd/git/u-boot/master/Wolfgang Denk
2008-05-09microblaze: Repare intc handlingMichal Simek
2008-05-09include/gitignore: update to all architecturesJean-Christophe PLAGNIOL-VILLARD
2008-05-08ppc4xx: Kilauea: Fix incorrect FPGA FIFO addressStefan Roese
2008-05-08ppc4xx: Add fdt support to all remaining AMCC PPC4xx eval boardsStefan Roese
This patch adds fdt (flattened device tree) support to all remaining AMCC eval boards. Most newer boards already support device tree. With this patch, all AMCC boards now enable device tree passing from U-Boot to Linux arch/powerpc kernels. Signed-off-by: Stefan Roese <sr@denx.de>
2008-05-08ppc4xx: acadia: Add fdt support and fix section overlap problemStefan Roese
This patch adds fdt (flattened device tree) support to the AMCC Acadia eval board. This increases the image size and it doesn't fit anymore into 256kByte. Since we didn't want to remove features from the configuration, we decided to increase the U-Boot image size (add one flash sector). Also changed the default environment definition to make it independent of such changes. Signed-off-by: Stefan Roese <sr@denx.de>
2008-05-08ppc4xx: Add device tree support to AMCC YosemiteIra Snyder
Add support for booting with a device tree blob. This is needed to boot ARCH=powerpc kernels. Also add support for setting the eth0 mac address via the ethaddr variable. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Stefan Roese <sr@denx.de>
2008-05-06mpc83xx: system performance settings for MPC8349EMDS.Lee Nipper
These same settings are used on MPC8349ITX, and improve performance on MPC8349EMDS. Signed-off-by: Lee Nipper <lee.nipper@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-05-04kb9202 board: fix build problem.Wolfgang Denk
2008-05-04SBC8548: fix address mask to allow 64M flashJeremy McNicoll
Fix incorrect mask to enable all 64MB of onboard flash. Previously U-Boot incorrectly mapped only 8MB of flash, this patch correctly maps all the available flash. Signed-off-by: Jeremy McNicoll <jeremy.mcnicoll@windriver.com>
2008-05-04Fix misspelled commentMarcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
2008-04-30ColdFire: Fix ethernet hang issue for mcf547x_8xTsiChung Liew
The ethernet hang is caused by receiving buffer in DRAM is not yet ready due to access cycles require longer time in DRAM. Relocate DMA buffer descriptors from DRAM to internal SRAM. Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-04-30ColdFire: Fix compilation issue caused by new changes in fsl_i2c.cTsiChung Liew
Signed-off-by: Luigi Comio Mantellini <luigi.mantellini@idf-hit.com> Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-04-30Fix warnings while compiling net/net.c for MPC8610HPCD boardAnatolij Gustschin
MPC8610HPCD board adds -O2 gcc option to PLATFORM_CPPFLAGS causing overriding default -Os option. New gcc (ver. 4.2.2) produces warnings while compiling net/net.c file with -O2 option. The patch is an attempt to fix this. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2008-04-29Merge branch 'master' of git://www.denx.de/git/u-boot-ppc4xxWolfgang Denk
2008-04-2985xx/86xx: Rename ext_refrec to timing_cfg_3 to match docsKumar Gala
All the 85xx and 86xx UM describe the register as timing_cfg_3 not as ext_refrec. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-04-2985xx/86xx: Rename DDR init address and init extended address registerKumar Gala
Rename init_addr and init_ext_addr to match the docs between 85xx and 86xx. Both now use 'init_addr' and 'init_ext_addr'. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-04-29lwmon5: minor clean-up to include/configs/lwmon5.hYuri Tikhonov
LWMON5 DSPIC POST uses the watch-dog scratch register. So, make the CFG_DSPIC_TEST_ADDR definition more readable. Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-04-29ppc4xx: Fix CFG_MONITOR_LEN on Katmai failsave this timeStefan Roese
2008-04-29ppc4xx: Fix Katmai CFG_MONITOR_LENStefan Roese
2008-04-28NAND: fix some strict-aliasing compiler warningsWolfgang Denk
2008-04-28Merge branch 'master' of git+ssh://10.10.0.7/home/wd/git/u-boot/masterWolfgang Denk
2008-04-28ppc4xx: Fix compile warning of hcu4 boardStefan Roese
2008-04-28MPC8323ERDB: fix implicit declaration of function 'mac_read_from_eeprom'Wolfgang Denk
2008-04-28mx31ads: fix loadaddr environment variable defineGuennadi Liakhovetski
Arithmetic expressions do not get evaluated under stringification. Remove default network configuration, add DHCP command support. Thanks to Felix Radensky for reporting. Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2008-04-28katmai: fix section overlap problemWolfgang Denk
Since we didn't want to remove features from the configuration, we decided to increase the U-Boot image size (add one flash sector). Also changed the default environment definition to make it independent of such changes. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2008-04-26i.MX31: Enable SPI and MC13783/RTC support for the Litekit boardMagnus Lilja
This patch enables SPI and MC13783/RTC support for the Litekit board. Signed-off-by: Magnus Lilja <lilja.magnus@gmail.com>
2008-04-26MPC8544DS: Removes the unknown flash message informationRoy Zang
This patch removes the unknown flash message information: '## Unknown FLASH on Bank 1 - Size = 0xdeadbeef = -286261248 MB' This unknown flash message is caused by PromJet. Some of the board user is unhappy with this information. Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-04-26Merge branch 'master' of git://www.denx.de/git/u-boot-mpc83xxWolfgang Denk
2008-04-26Merge branch 'master' of git://www.denx.de/git/u-boot-ppc4xxWolfgang Denk
2008-04-25mpc83xx: bump loadaddr over fdtaddr to 0x500000Kim Phillips
this seems as a good compromise between human memory, typing, and last but not least, to accommodate for current and future kernel bloat. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Acked-by: Dave Liu <daveliu@freescale.com>
