drivers/spi/Makefile
Signed-off-by: Magnus Lilja <lilja.magnus@gmail.com>
This patch abstracts Kirkwood arch specific changes to support ehci-kirkwood driver
Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
This sets CONFIG_SYS_HZ to 1000 as required, and completely rewrites
timer code, which is now both correct and much smaller. Unused
functions like udelay_masked() have been removed as no driver uses
them, even the ones that are not currently active for this board.
mtu.h is copied literally from the kernel sources.
Signed-off-by: Alessandro Rubini <rubini@unipv.it>
Acked-by: Andrea Gallo <andrea.gallo@stericsson.com>
The evaluation kit has both Nand and OneNand, both drivers are there
and the two configurations only select a different default for the
jffs partition. This adds the OneNand driver and cleans up storage.
There is only one public release of the Nomadik chip, so the ifdef
in reset code as well as a define in the config file are not needed
This is an error in my side in the initial submission: nobody
calls it ""nmdk8815", it's "nomadik hardware kit", nhk8815, instead.
The Polaris board is based on the TrizepsIV module of
Keith & Koep (http://www.keith-koep.com).
This patch adds support for esd gmbh MEESC board.
The MEESC is based on an Atmel AT91SAM9263 SoC.
Signed-off-by: Daniel Gorsulowski <Daniel.Gorsulowski@esd.eu>
update against linux v2.6.30
To enable CAN init, CONFIG_CAN has to be defined in the board config file
and at91_can_hw_init() has to be called in the board specific code.
CAN is available on AT91SAM9263 and AT91CAP9 SoC.
Correct define typo (. -> ,)
Signed-off-by: Simon Kagstrom <simon.kagstrom@netinsight.net>
Add support for Freescale's i.MX31 PDK board (a.k.a. 3 stack board).
This patch assumes that some other program performs the actual
NAND boot.
Acked-by: Fabio Estevam <fabioestevam@yahoo.com>
Signed-off-by: HeungJun, Kim <riverful.kim@samsung.com>
CC: Dirk Behme <dirk.behme@googlemail.com>
Cc: Peter Pearse <peter.pearse@arm.com>
Kirkwood family controllers are highly integrated SOCs
based on Feroceon-88FR131/Sheeva-88SV131/arm926ejs cpu core.
SOC versions supported:-
1) 88F6281-A0 define CONFIG_KW88F6281_A0
2) 88F6192-A0 define CONFIG_KW88F6192_A0
Other supported features:-
1) get_random_hex() fucntion
2) PCI Express port initialization
3) NS16550 driver support
Contributors:
Yotam Admon <yotam@marvell.com>
Michael Blostein <michaelbl@marvell.com
Reviewed-by: Ronen Shitrit <rshitrit@marvell.com>
Acked-by: Stefan Rose <sr@denx.de>
This patch is required for Kirkwood SoC support
may be used by other ARM architectures
Signed-off-by: Matthias Ludwig <mludwig@ultratronik.de>
Reviewed-by: Ira W. Snyder <iws@ovro.caltech.edu>
Tested-by: Ira W. Snyder <iws@ovro.caltech.edu>
Acked-by: Kim Phillips <kim.phillips@freescale.com>
Defining the next two configs allows to switch the serial port from the
console using the setenv stdin and stdout
1. #define CONFIG_SERIAL_MULTI 1 /* Enable both serial ports */
2. #define CONFIG_SYS_CONSOLE_IS_IN_ENV /* determine from environment */
Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com>
Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
Initial support for Extreme Engineering Solutions XPedite5170 -
a MPC8640-based 3U VPX single board computer with a PMC/XMC
site.
DMA support is now enabled via the CONFIG_FSL_DMA define instead of the
previous CONFIG_DDR_ECC
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
We want the outbound PCI memory map to end at the 4G boundary so we
can maximize the amount of space available for inbound mappings if
we have large amounts of memory.
This matches the device tree setup in the kernel for the 36-bit physical
configs for the platforms that have one (MPC8641 HPCN & MPC8572 DS).
Unify with 83xx and 85xx and use CPU_TYPE_ENTRY. We are going to use
this to convey the # of cores and DDR width in the near future so its
good to keep in sync.
This patch adds a SPI driver for the Marvell Kirkwood SoC's.
Acked-by: Peter Pearse <peter.pearse@arm.com>
UART hardware on i.MX27 is the same as on the i.MX31 so we just
need to provide the driver with correct address of the registers.
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
This patch adds generic code to support Freescale's i.MX27 SoCs.
This patch adds the NAND SPL framework needed to boot i.MX31 boards
from NAND.
It has been tested on a i.MX31 PDK board with large page NAND. Small
page NANDs should work as well, but this has not been tested.
Note: The i.MX31 NFC uses a non-standard layout for large page NANDs,
whether this is compatible with a particular setup depends on how
the NAND device is programmed by the flash programmer (e.g. JTAG
debugger).
The patch is based on the work by Maxim Artamonov.
Signed-off-by: Maxim Artamonov <scn1874@yandex.ru>
the lowlevel init sequence is the same so unify it
this will allow you to store use it for the env and to boot directly U-Boot from
The PM9261 board is based on the AT91SAM9261-EK board.
Here is the page on Ronetix website:
http://www.ronetix.at/starter_kit_9261.html
Signed-off-by: Ilko Iliev <iliev@ronetix.at>
optimize a few the RAM init
move PSRAM init to pm9263.c
this will allow us after to make the nor lowlevel_init generic
The SPI flash define is named CONFIG_SF_DEFAULT_SPEED, not
CONFIG_SF_DEFAULT_HZ, so fix the typos in the Blackfin boards.
The latest version of U-Boot got a bit fatter in the BSS section which
caused overflows in the RAM region, so increase the monitor size.
The SPI flash layer is much stricter about sector usage than the eeprom
layer we used to use, so update the env settings to better match the
sector alignment of the flashes we use.
Signed-off-by: Vivi Li <vivi.li@analog.com>
All drivers need to be converted to CONFIG_NET_MULTI.
This patch converts the dm9000 driver.
Signed-off-by: Thomas Smits <ts.smits@gmail.com>
Signed-off-by: Remy Bohmer <linux@bohmer.net>
