This patch add support for rockchip dwc3 controller, which corresponding
to the two type-C port on rk3399 evb.
Only support usb2.0 currently for we have not enable the usb3.0 phy
driver and PD(fusb302) driver.
Signed-off-by: MengDongyang <daniel.meng@rock-chips.com>
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
There are a few boards that use CONFIG_ISO_STRING as part of a sanity
check during firmware update at run time. Move this string to Kconfig.
Convert CONFIG_MIP405T from SYS_EXTRA_OPTIONS to a real config
There are two boards, MIP405 and MIP405T that have a few differences.
Start by checking for CONFIG_TARGET_MIP405. Then introduce
CONFIG_TARGET_MIP405T and use that not CONFIG_MIP405T. Next, convert
also convert the usage of CONFIG_ISO_STRING to be based on Kconfig.
Move the config IDENT_STRING to Kconfig and migrate all boards
[sivadur: Migrate zynq boards]
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
[trini: Update configs, add some default to sunxi Kconfig]
Convert CONFIG_SPL_YMODEM_SUPPORT to Kconfig
Move this option to Kconfig and tidy up existing uses.
This option is not used. Drop it.
CONFIG_SPL_NET_VCI_STRING
There are a few options which use lower case. We should use upper case for
all CONFIG options.
[trini: Add usbtty/nand hunk to include/configs/spear3xx_evb.h]
At present TPL uses the same options as SPL support. In a few cases the board
config enables or disables the SPL options depending on whether
CONFIG_TPL_BUILD is defined.
With the move to Kconfig, options are determined for the whole build and
(without a hack like an #undef in a header file) cannot be controlled in this
way.
Create new TPL options for these and update users. This will allow Kconfig
conversion to proceed for these boards.
This option does not exist in U-Boot. Drop it.
Currently, the UniPhier platform calls several init functions in the
following order:
[1] spl_board_init()
[2] board_early_init_f()
[3] board_init()
[4] board_early_init_r()
[5] board_late_init()
The serial console is not ready at the point of [2], so we want to
avoid using [2] from the view point of debuggability. Fortunately,
all of the initialization in [2] can be delayed until [3]. I see no
good reason to split into [3] and [4]. So, merge [2] through [4].
We can use checkboard() stub to show additional board information,
so misc_init_f() should not be used for this purpose.
This driver has not been converted to Driver Model, and it is an
obstacle to migrate other block device drivers. Remove it for now.
The UniPhier SoCs already use a DM-based EHCI driver, so now
ARCH_UNIPHIER can select DM_USB.
These two changes must be done atomically because removing the
legacy driver causes a build error.
move VERSION_VARIABLE from board config file into a
Kconfig option.
In some cases we were missing CONFIG_USB=y so enable that when needed.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Provide version of struct efi_mem_desc in efi_get_memory_map().
EFI_BOOT_SERVICES.GetMemoryMap() in UEFI specification v2.6 defines
memory descriptor version to 1. Linux kernel also expects descriptor
version to be 1 and prints following warning during boot if its not:
Unexpected EFI_MEMORY_DESCRIPTOR version 0
Signed-off-by: Mian Yousaf Kaukab <yousaf.kaukab@gmail.com>
The u-boot endian macros map directly to system endian
macros on OpenBSD.
Signed-off-by: Jonathan Gray <jsg@jsg.id.au>
Line up comments for readibility.
As bootargs is hard-coded for the default behavior on the
omap3_pandora, only set the bootargs if distro_bootcmd fails to
load. This leaves distro_bootcmd free to use alternate boot arguments.
Signed-off-by: Vagrant Cascadian <vagrant@debian.org>
Add support for using distro_bootcmd to the omap3_pandora target,
falling back to prior behavior.
Move this option to Kconfig and set its default value to 4; this
increases the number of supported CPUs for some boards.
It consumes 1KB memory per CPU for PSCI stack, but it should not
be a big deal, given the amount of memory used for the modern OSes.
Reviewed-by: Alexander Graf <agraf@suse.de>
Add ARCH_SUPPORT_PSCI as a non-configurable option that platforms
can select. Then, move CONFIG_ARMV7_PSCI, which is automatically
enabled if both ARMV7_NONSEC and ARCH_SUPPORT_PSCI are enabled.
