path: root/include
2012-04-16Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
* 'master' of git://git.denx.de/u-boot-arm: ARM926EJS: Fix cache.c to comply with checkpatch.pl ARM926EJS: Make asm routines volatile in cache ops MX35: mx35pdk: wrong board revision ARM1136: MX35: Make asm routines volatile in cache ops ARM: add u-boot.imx as target for i.MX SOCs M28: Pull out CONFIG_APBH_DMA so it's always enabled DMA: Split the APBH DMA init into block and channel init imx: Return gpio_set_value in gpio_direction_output imx: Use GPIO_TO_PORT macro in the gpio driver instead of (gpio >> 5) imx: Add GPIO_TO_PORT macro in the mxc_gpio driver imx: Remove unneeded/repititive definitions from imx headers i.MX28: Allow coexistence of PIO and DMA mode for SD/MMC MX31: mx31pdk: drop enable_caches from board file i.MX28: Fix initial stack pointer position mx35: mx35pdk: fix when cache functions are linked mx35: flea3: fix when cache functions are linked ARM: 926ejs: use debug() for misaligned addresses ARM1136: add cache flush and invalidate operations mx6qsabrelite: Fix the serial console port mx6qsabrelite: Add boot switch setting information into the README i.MX6: mx6qsabrelite: add cache commands if cache is enabled i.MX6: implement enable_caches() i.MX6: define CACHELINE_SIZE MX53: DDR: Fix ZQHWCTRL field TZQ_CS mx28evk: Add a README file mx28: Split the README into a common part and a m28 specific part tricorder: Load kernel from ubifs tricorder: Add UBIFS cm-t35: fix Ethernet reset timing hawkboard: Add CONFIG_SPL_LIBGENERIC_SUPPORT BeagleBoard: Remove userbutton command and use gpio command instead OMAP: Move omap1510inn to Unmaintained / Orphaned
2012-04-16MX35: mx35pdk: wrong board revisionStefano Babic
The board revision is detected accessing to the pmic, that is not available before relocation (I2C). This generates the following error: CPU: Freescale i.MX35 rev 2.0 at 532 MHz. Reset cause: WDOG <reg num> = 7 is invalid. Should be less than 0 Board: MX35 PDK 1.0 The revision number is wrong, as a default value is printed (tested on a mx35pdk Rev. 2.0). Move the output in the board_late_init(), when pmic can be accessed. Signed-off-by: Stefano Babic <sbabic@denx.de>
2012-04-16M28: Pull out CONFIG_APBH_DMA so it's always enabledMarek Vasut
The ABPH DMA is now used also by the SD card. Therefore it has to be enabled even if NAND is disabled. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com>
2012-04-16i.MX28: Fix initial stack pointer positionMarek Vasut
The patch: m28evk: Use GENERATED_GBL_DATA_SIZE commit 1084606c972ea5f1d89f69bdbd978b867d0ee521 introduced usage of GENERATED_GBL_DATA_SIZE and calculation of initial stack pointer position defived from that. Due to a small typo, the SP position moved to 0x21f80, which is past the SRAM area. This didn't manifest on the real hardware as the SRAM repeats there (address bits in the CPU being ignored). Though this was caught in QEMU, where it crashed the emulator. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-04-16mx35: mx35pdk: fix when cache functions are linkedStefano Babic
2012-04-16mx35: flea3: fix when cache functions are linkedStefano Babic
2012-04-16mx6qsabrelite: Fix the serial console portFabio Estevam
On mx6qsabrelite the console is ttymxc1. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-04-16i.MX6: mx6qsabrelite: add cache commands if cache is enabledEric Nelson
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com> Acked-by: Marek Vasut <marex@denx.de>
2012-04-16i.MX6: implement enable_caches()Eric Nelson
disabled by default until drivers are fixed Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com> Acked-by: Marek Vasut <marex@denx.de>
2012-04-16tricorder: Load kernel from ubifsBernhard Walle
Signed-off-by: Bernhard Walle <walle@corscience.de>
2012-04-16tricorder: Add UBIFSBernhard Walle
Since kernel should be in a ubifs partition, we need UBIFS. The greater malloc size is needed for UBIFS. Signed-off-by: Bernhard Walle <walle@corscience.de> Squashed two commits (UBIFS enabled and malloc size increased) into one. Signed-off-by: Thomas Weber <weber@corscience.de>
2012-04-16hawkboard: Add CONFIG_SPL_LIBGENERIC_SUPPORTTom Rini
With older toolchains we need CONFIG_SPL_LIBGENERIC_SUPPORT in order for CONFIG_SPL_NAND_SUPPORT to link. Signed-off-by: Tom Rini <trini@ti.com>
2012-04-16BeagleBoard: Remove userbutton command and use gpio command insteadJoel Fernandes
Remove userbutton command and do the detection in board config file using the gpio command Signed-off-by: Joel A Fernandes <agnel.joel@gmail.com> Signed-off-by: Jason Kridner <jkridner@beagleboard.org>
2012-04-10Move bootstage timer out of lib/time.cSimon Glass
The standalone example does not have get_timer() defined, so we cannot rely on it being available. Move the timer function into boootstage.c to avoid this problem. This corrects a build breakage for the standalone example on some boards. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu>
2012-04-10configs: EB+MCF-EV123.h: Fix typo on CONFIG_SYS_HUSH_PARSERFabio Estevam
Fix typo on CONFIG_SYS_HUSH_PARSER and also add CONFIG_SYS_PROMPT_HUSH_PS2 to avoid build error. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-04-09Merge branch 'marek.vasut@gmail.com' of git://git.denx.de/u-boot-stagingWolfgang Denk
* 'marek.vasut@gmail.com' of git://git.denx.de/u-boot-staging: LMB: Fix undefined lmb_reserve() on non-lmb platforms MIPS: fix endianess handling MIPS: fix inconsistency in config option for cache operation mode MIPS: board.c: fix init of flash data in bd_info
2012-04-09Merge branch 'master' of git://git.denx.de/u-boot-netWolfgang Denk
* 'master' of git://git.denx.de/u-boot-net: net/designware: Change timeout loop implementation net/designware: Set ANAR to 0x1e1 net/designware: Program phy registers when auto-negotiation is ON net/designware: Try configuring phy on each dw_eth_init net/designware: Consecutive writes must have delay net/designware: Phy address fix net/designware: Fix the max frame length size net/designware: Fix to restore hw mac address microblaze: Wire up LL_TEMAC driver initialization microblaze: Add faked LL_TEMAC driver configuration microblaze: Enable several ethernet driver compilation net: ll_temac: Add LL TEMAC driver to u-boot Update net subsystem maintainer in doc/git-mailrc net/eth.c: fix eth_write_hwaddr() to use dev->enetaddr as fall back mvgbe: remove warning for unused methods
2012-04-09Merge branch 'master' of git://git.denx.de/u-boot-onenandWolfgang Denk
* 'master' of git://git.denx.de/u-boot-onenand: onenand: samsung: Enable OneNAND support at Samsung's Exynos4210 onenand: Replace ONENAND_IS_MLC() with ONENAND_HAS_4KB() onenand:samsung OneNAND chip probe functions added for GONI and Exynos4210 onenand:samsung Target dependent OneNAND chip probe function
2012-04-09Merge branch 'master' of git://git.denx.de/u-boot-niosWolfgang Denk
* 'master' of git://git.denx.de/u-boot-nios: nios2 - adjust gbl data off to account for bd_info nios2: implement get_ticks and get_tbclk nios2: add flush_dcache_range function
2012-04-04onenand: samsung: Enable OneNAND support at Samsung's Exynos4210Lukasz Majewski
Enable OneNAND support for Exynos4210 (C210 universal). Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com>
2012-04-04onenand: Replace ONENAND_IS_MLC() with ONENAND_HAS_4KB()Lukasz Majewski
This replacement causes 4KB page size devices to work properly with u-boot. The old ONENAND_IS_MLC() behavior has been preserved by explicit setting of ONENAND_HAS_4KB_PAGE for those devices. This change makes the onenand_base.c file more resembling the respective kernel sources. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> --- Test HW: - Samsung S5PC110 GONI - Samsung S5PC210 Universal
2012-04-04microblaze: Enable several ethernet driver compilationStephan Linz
U-Boot's multipple network supports enables to use several ethernet drivers but microblaze-generic platform config file select only one driver. Reported-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Stephan Linz <linz@li-pro.net>
2012-04-04net: ll_temac: Add LL TEMAC driver to u-bootStephan Linz
Xilinx LocalLink Tri-Mode Ether MAC driver can be used by Xilinx Microblaze or Xilinx ppc405/440 in SDMA and FIFO mode. DCR or XPS bus can be used. The driver uses and requires MII and PHYLIB. CP: 4 warnings: 'Use of volatile is usually wrong' I won't fix this, because it depends on the network driver subsystem. Reported-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Stephan Linz <linz@li-pro.net>
2012-04-04onenand:samsung Target dependent OneNAND chip probe functionLukasz Majewski
Separate callback for probing OneNAND memory chip. If no special function is defined, default implementation will be used. This approach gives more flexibility for OneNAND device probing. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2012-04-02MIPS: fix endianess handlingDaniel Schwierzeck
Make endianess of target CPU configurable. Use the new config option for dbau1550_el and pb1000 boards. Adapt linking of standalone applications to pass through endianess options to LD. Build tested with: - ELDK 4 mips_4KC- and mips4KCle - Sourcery CodeBench Lite 2011.03-93 With this patch all 26 MIPS boards can be compiled now in one step by running "MAKEALL -a mips". Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
2012-03-30Merge branch 'master' of git://git.denx.de/u-boot-usbWolfgang Denk
* 'master' of git://git.denx.de/u-boot-usb: Enable high speed support for USB device framework and usbtty
2012-03-30BOOT: Add "bootz" command to boot Linux zImage on ARMMarek Vasut
This command boots Linux zImage from where the zImage is loaded to. Passing initrd and fdt is supported. Tested on i.MX28 based DENX M28EVK Tested on PXA270 based Voipac PXA270. NOTE: This currently only supports ARM, but other architectures can be easily added by defining bootz_setup(). Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Warren <TWarren@nvidia.com> Cc: albert.u.boot@aribaud.net Cc: afleming@gmail.com, Cc: Simon Glass <sjg@chromium.org>, Cc: Stephen Warren <swarren@nvidia.com> Cc: Nicolas Pitre <nico@fluxnic.net> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de>
2012-03-30mx28evk: fix build errorAnatolij Gustschin
Fix: drivers/mmc/libmmc.o: In function `mxsmmc_send_cmd': /home/ag/git/u-boot/drivers/mmc/mxsmmc.c:210: undefined reference to `mxs_dma_desc_append' /home/ag/git/u-boot/drivers/mmc/mxsmmc.c:211: undefined reference to `mxs_dma_go' drivers/mmc/libmmc.o: In function `mxsmmc_initialize': /home/ag/git/u-boot/drivers/mmc/mxsmmc.c:306: undefined reference to `mxs_dma_desc_alloc' Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-03-30pci: declare pciauto functions in headerLinus Walleij
The FSL PCI driver uses local prototypes for pciauto_[pre|post]scan_setup_bridge(), this does not seem right, so move them to the <pci.h> file. Fixed a small extern declaration too, this is harmless but distracts the view since all other prototypes are explicitly external. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-03-30Merge branch 'agust@denx.de' of git://git.denx.de/u-boot-stagingWolfgang Denk
* 'agust@denx.de' of git://git.denx.de/u-boot-staging: lzma: fix printf warnings Remove CONFIG_SYS_EXTBDINFO from snapper9260.h cmd_pxe.c: fix strict-aliasing warnings net: smc91111: use mdelay() doc: Fix some typos in different files disk/part.c: Fix device enumeration through API mkenvimage: Really set the redundant byte when applicable mkenvimage: Don't try to detect comments in the input file mkenvimage: Use mmap() when reading from a regular file mkenvimage: Read/Write from/to stdin/out by default or if the filename is "-" mkenvimage: More error handling mkenvimage: Correct an include and add a missing one mkenvimage: correct and clarify comments and error messages MAKEALL: display SPL size if present ARMV7/Vexpress: add missing get_ticks() and get_tbclk() mkenvimage: fix usage message cmd_fat: add FAT write command fs/fat/fat_write.c: Fix GCC 4.6 warnings FAT write: Fix compile errors
2012-03-30Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
* 'master' of git://git.denx.de/u-boot-arm: (146 commits) arm: Use common .lds file where possible arm: add a common .lds link script arm: Remove unneeded setting of LDCSRIPT Define CPUDIR for the .lds link script arm: Remove zipitz2 link script Allow arch directory to contain .lds without requiring Makefile OMAP: Remove omap1610inn-based boards arch/arm/cpu/armv7/omap-common/clocks-common.c: Fix build warnings board/ti/beagle/beagle.c: Fix build warnings sdrc.c: Fix typo in do_sdrc_init() for SPL tegra: i2c: Add I2C driver tegra: fdt: i2c: Add extra I2C bindings for U-Boot tegra: i2c: Select I2C ordering for Seaboard tegra: i2c: Enable I2C on Seaboard tegra: i2c: Select number of controllers for Tegra2 boards tegra: i2c: Initialise I2C on Nvidia boards tegra: Enhance clock support to handle 16-bit clock divisors fdt: Add function to allow aliases to refer to multiple nodes tegra: Rename NV_PA_PMC_BASE to TEGRA2_PMC_BASE tegra: fdt: Enable FDT support for Ventana tegra: fdt: Enable FDT support for Seaboard tegra: usb: Enable USB on Seaboard tegra: usb: Add common USB defines for tegra2 boards tegra: usb: Add USB support to nvidia boards arm: Check for valid FDT after console is up fdt: Avoid early panic() when there is no FDT present tegra: usb: Add support for Tegra USB peripheral tegra: fdt: Add function to return peripheral/clock ID usb: Add support for txfifo threshold tegra: usb: fdt: Add USB definitions for Tegra2 Seaboard tegra: usb: fdt: Add additional device tree definitions for USB ports tegra: fdt: Add clock bindings for Tegra2 Seaboard tegra: fdt: Add clock bindings tegra: fdt: Add additional USB binding fdt: Add tegra-usb bindings file from linux fdt: Add staging area for device tree binding documentation tegra: fdt: Add device tree file for Tegra2 Seaboard from kernel tegra: fdt: Add Tegra2x device tree file from kernel arm: fdt: Add skeleton device tree file from kernel fdt: Add basic support for decoding GPIO definitions fdt: Add functions to access phandles, arrays and bools fdt: Tidy up a few fdtdec problems fdt: Add tests for fdtdec fdt: Add fdtdec_find_aliases() to deal with alias nodes arm: Tegra2: Fix ELDK42 gcc failure with inline asm stack pointer load net: fec_mxc: allow use with cache enabled net: force PKTALIGN to ARCH_DMA_MINALIGN i.MX28: Enable caches by default i.MX28: Make use of the bounce buffer i.MX28: Do data transfers via DMA in MMC driver MMC: Implement generic bounce buffer i.MX28: Add cache support to MXS NAND driver i.MX28: Add cache support into the APBH DMA driver ARM926EJS: Implement cache operations board/vpac270/onenand.c: Fix build errors nhk8815: fix build errors atmel-boards: add missing atmel_mci.h ARM: highbank: setup env from boot source register ARM: highbank: change env config to use nvram ARM: highbank: add reset support ARM: highbank: Add boot counter support ARM: highbank: change TEXT_BASE to 0x8000 ARM: highbank: fix us_to_tick calculation ARM: highbank: add missing get_tbclk ARM: highbank: fix warning for calxedaxgmac_initialize net: calxedaxgmac: fix build due to missing __aligned definition EXYNOS: Add structure for Exynos4 DMC EXYNOS: SMDK5250: Support all 4 UARTs ARM: fix s3c2410 timer code ARM: davinci: fixes for cam_enc_4xx board omap3_spi: receive transmit mode calimain, enbw_cmc: Fix typo in comments Davinci: ea20: use gpio framework to access gpios OMAP3: mt_ventoux: sets its own mtdparts OMAP3: mt_ventoux: updated timing for FPGA twl4030: fix potential power supply handling issues NAND: TI: fix warnings in omap_gpmc.c cam_enc_4xx: Rename 'images' to 'imgs' arm: Add Prep subcommand support to bootm OMAP3: twister: add support to boot Linux from SPL SPL: call cleanup_before_linux() before booting Linux OMAP3: SPL: do not call I2C init if no I2C is set. Add cache functions to SPL for armv7 devkit8000: Implement and activate direct OS boot omap/spl: change output of spl_parse_image_header omap-common/spl: Add linux boot to SPL devkit8000/spl: init GPMC for dm9000 in SPL omap-common: Add NAND SPL linux booting devkit8000: add config for spl command Add cmd_spl command mx53ard: Initialize return code with error mx53: Make PLL2 to be the parent of UART clock configs: imx: Use CONFIG_SF_DEFAULT_CS mx28evk: Provide default values for SPI bus and chip select USB: ehci-mx6: Add proper IO accessors mx6: Read silicon revision from register i.MX28: Drop __naked function from spl_mem_init mxs_spi: Return proper timeout error i.MX28: Make the stabilization delays shorter pmic_i2c: Return error in case of invalid pmic_i2c_tx_num mx6: Remove duplicate definition of ANATOP_BASE_ADDR mx6: Fix reset cause for Power On Reset case i.MX6: mx6qsabrelite: add MACH_TYPE_MX6Q_SABRELITE i.MX6: mx6q_sabrelite: add CONFIG_REVISION_TAG i.MX28: Enable additional DRAM address bits mx6q: mx6qsabrelite: setup_spi() should be called in board_init to allow use for environment mx31: add "ARM11P power gating" to get_reset_cause mx31pdk: Fix CONFIG_SYS_MEMTEST_END efikamx: Fix CONFIG_SYS_MEMTEST_END mx53smd: Fix CONFIG_SYS_MEMTEST_END mx53evk: Fix CONFIG_SYS_MEMTEST_END mx51evk: Fix CONFIG_SYS_MEMTEST_END i.MX6: mx6qsabrelite: add ext2 support imximage: Remove overwriting of flash_offset IXP: Fix GPIO_INT_ACT_LOW_SET() IXP: Fix NAND build warning on PDNB3 and SCPU IXP: Move PDNB3 and SCPU from Makefile to boards.cfg IXP: Squash warnings in IXP NPE IXP: Fix missing MACH_TYPE_{ACTUX?,PNB3,DVLHOST} IXP: Make IXP buildable with arm-linux- toolchains Examples: Properly append LDFLAGS to LD command SPL: Enable YMODEM support on BeagleBone and AM335x EVM SPL: Add YMODEM over UART load support SPL: Add README.omap3 README: document more SPL config options spl.c: Use __noreturn decorator config.mk: Check for -fstack-usage support config.mk: Make cc-option create a file under include/generated ...
2012-03-30Merge branch 'master' of git://git.denx.de/u-boot-microblazeWolfgang Denk
* 'master' of git://git.denx.de/u-boot-microblaze: microblaze: Enable phylib and mii support
2012-03-29OMAP: Remove omap1610inn-based boardsTom Rini
The CS_AUTOBOOT configurations have been broken for a long time. Kshitij Gupta is no longer at TI making these broken and orphaned boards, so remove. Signed-off-by: Tom Rini <trini@ti.com>
2012-03-29tegra: i2c: Add I2C driverYen Lin
Add basic i2c driver for Tegra2 with 8- and 16-bit address support. The driver requires CONFIG_OF_CONTROL to obtain its configuration from the device tree. (Simon Glass: sjg@chromium.org modified for upstream) Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-03-29tegra: i2c: Enable I2C on SeaboardSimon Glass
This enables I2C on Seaboard. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-03-29tegra: i2c: Select number of controllers for Tegra2 boardsSimon Glass
The Tegra 2x SOC has four ports, so define TEGRA_I2C_NUM_CONTROLLERS in the shared config file. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-03-29fdt: Add function to allow aliases to refer to multiple nodesSimon Glass
Some devices can deal with multiple compatible properties. The devices need to know which nodes to bind to which features. For example an I2C driver which supports two different controller types will want to know which type it is dealing with in each case. The new fdtdec_add_aliases_for_id() function deals with this by allowing the driver to search for additional compatible nodes for a different ID. It can then detect the new ones and perform appropriate processing. Another option considered was to return a tuple (node offset, compat id) and have the function be passed a list of compatible IDs. This is more overhead for the common case though. We may add such a function later if more drivers in U-Boot require it. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-03-29tegra: fdt: Enable FDT support for VentanaTom Warren
This switches Ventana over to use FDT for run-time config instead of CONFIG options. At present Ventana does not have its own device tree file - it just uses the Seaboard one. Signed-off-by: Tom Warren <twarren@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-03-29tegra: fdt: Enable FDT support for SeaboardSimon Glass
This switches Seaboard over to use FDT for run-time config instead of CONFIG options. USB is the only user at present. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-03-29tegra: usb: Enable USB on SeaboardSimon Glass
Seaboard has a top port which is USB host or device, and a side port which is host only. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-03-29tegra: usb: Add common USB defines for tegra2 boardsSimon Glass
All Tegra2 boards should include tegra2-common. This adds the required USB config to that file. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-03-29fdt: Avoid early panic() when there is no FDT presentSimon Glass
CONFIG_OF_CONTROL requires a valid device tree. However, we cannot call panic() before the console is set up since the message does not appear, and we get a silent failure. Remove the panic from fdtdec_check_fdt() and provide a new function to prepare the fdt for use. This will be called after the console is ready. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-03-29tegra: usb: Add support for Tegra USB peripheralSimon Glass
This adds basic support for the Tegra2 USB controller. Board files should call board_usb_init() to set things up. Configuration is performed through the FDT, with aliases used to set the order of the ports, like this fragment: aliases { /* This defines the order of our USB ports */ usb0 = "/usb@0xc5008000"; usb1 = "/usb@0xc5000000"; }; drivers/usb/host files ONLY: Acked-by: Remy Bohmer <linux@bohmer.net> Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-03-29fdt: Add basic support for decoding GPIO definitionsSimon Glass
This adds some support into fdtdec for reading GPIO definitions from the fdt. We permit up to FDT_GPIO_MAX GPIOs in the system. Each GPIO is of the form: gpio-function-name = <phandle gpio_num flags>; where: phandle is a pointer to the GPIO node gpio_num is the number of the GPIO (0 to 223) flags is a flag, as follows: bit meaning 0 0=polarity normal, 1=active low (inverted) An example is: enable-propounder-gpios = <&gpio 43 0>; which means that GPIO 43 is used to enable the propounder (setting the GPIO high), or that you can detect that the propounder is enabled by checking if the GPIO is high (the fdt does not indicate input/output). Two main functions are provided: fdtdec_decode_gpio() reads a GPIO property from an fdt node and decodes it into a structure. fdtdec_setup_gpio() sets up the GPIO by calling gpio_request for you. Both functions can cope with the property being missing, which is taken to mean that that GPIO function is not available or is not needed. [For reference, from Stephen Warren <swarren@nvidia.com>. It may be that we add this extra complexity later if needed: The correct way to parse such a GPIO property in general is: * Read the first cell. * Find the node referenced by the phandle (the controller). * Ensure property gpio-controller is present in the controller node. * Read property #gpio-cells from the controller node. * Extract #gpio-cells from the original property. * Keep processing more cells from the original property; there may be multiple GPIOs listed. According to the binding documentation in the Linux kernel, Samsung Exynos4 doesn't use this format, and while all other chips do have a flags cell, about 50% of the controllers indicate the cell is unused. ] Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-03-29fdt: Add functions to access phandles, arrays and boolsSimon Glass
Add a function to look up a property which is a phandle in a node, and another to read a fixed-length integer array from an fdt property. Also add a function to read boolean properties, although there is no actual boolean type in U-Boot. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Gerald Van Baren <vanbaren@cideas.com> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-03-29fdt: Tidy up a few fdtdec problemsSimon Glass
This fixes five trivial issues in fdtdec.c: 1. fdtdec_get_is_enabled() doesn't really need a default value 2. The fdt must be word-aligned, since otherwise it will fail on ARM 3. The compat_names[] array is missing its first element. This is needed only because the first fdt_compat_id is defined to be invalid. 4. Added a header prototype for fdtdec_next_compatible() 5. Change fdtdec_next_alias() to only increment its 'upto' parameter on success, to make the display error messages in the caller easier. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Gerald Van Baren <vanbaren@cideas.com> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-03-29fdt: Add fdtdec_find_aliases() to deal with alias nodesSimon Glass
Stephen Warren pointed out that we should use nodes whether or not they have an alias in the /aliases section. The aliases section specifies the order so far as it can, but is not essential. Operating without alisses is useful when the enumerated order of nodes does not matter (admittedly rare in U-Boot). This is considerably more complex, and it is important to keep this complexity out of driver code. This patch creates a function fdtdec_find_aliases() which returns an ordered list of node offsets for a particular compatible ID, taking account of alias nodes. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-03-29net: force PKTALIGN to ARCH_DMA_MINALIGNEric Nelson
This will prevent the need for architectures whose DMA alignment is greater than 32 to have bounce buffers. Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2012-03-29i.MX28: Make use of the bounce bufferMarek Vasut
This allows i.MX28 MMC host to fully utilize DMA transfers and caches, greatly improving speed. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <festevam@gmail.com>
2012-03-28ARM: highbank: change env config to use nvramJason Hobbs
Update the highbank config to use env from NVRAM. Also remove extra env settings as they are not used unless the default env is used. Signed-off-by: Jason Hobbs <jason.hobbs@calxeda.com> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
