path: root/include
2011-03-29powerpc/85xx: Handle PCIe initialization requires for P1021 class SoCsPrabhakar Kushwaha
The P1011, P1012, P1015, P1016, P1020, P1021, P1024, & P1025 SoCs require that we initialize the SERDES registers if the lanes are configured for PCIe. Additionally these devices PCIe controller do not support ASPM and we have to explicitly disable it. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-03-28powerpc/85xx: Enable various errata on P1022/P1013 SoCsJiang Yutang
Enable workaround for errata ELBC A001, ESDHC 111 & SATA A001 on P1022/P1013 SoCs. Also updated P1022DS config to properly enable CONFIG_FSL_SATA_V2. Signed-off-by: Jiang Yutang <b14898@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-03-27Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2011-03-27arm: Tegra2: Change mach-type to MACH_TYPE_SEABOARD due to mach-types.h updateTom Warren
Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-03-27S5P: universal: Enable the pwm driverMinkyu Kang
2011-03-27S5P: goni: Enable the pwm driverMinkyu Kang
2011-03-27S5P: smdkc100: Enable the pwm driverMinkyu Kang
2011-03-27ARM: S5P: pwm driver supportDonghwa Lee
This is common pwm driver of S5P. Signed-off-by: Donghwa Lee <dh09.lee@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-03-27SMDK6400: Fix CONFIG_SYS_INIT_SP_ADDR undefinedseedshope
Fix CONFIG_SYS_INIT_SP_ADDR undefined issue. Signed-off-by: Zhong Hongbo <bocui107@gmail.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-03-24powerpc/85xx: Fix PCI memory map setup on P1_P2_RDBPrabhakar Kushwaha
Update the PCIe address map to match standard FSL memory map. Additionally, fix the TLBs so the cover the PCIe address space properly so cards plugged in like an e1000 work correctly. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-03-22strmhz: Make hz unsigned to support greater than 2146 MHz clockEd Swarthout
For example, an input of 0x80000000 should print: 2147.484 instead of -2147.-483. Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-03-21mpc52xx, digsy_mtc_rev5: Fix Linux crash, if no Flash in bank 2Heiko Schocher
If no Flash is connected to cs1, Linux crashes, because reg entries are not correct adapted. Following fix is needed: - swap base addresses in CONFIG_SYS_FLASH_BANKS_LIST, as flash bank 1 is on chipselect 0 and flash bank 2 on chipselect 1 - call fdt_fixup_nor_flash_size() from ft_board_setup() Signed-off-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <hs@denx.de> cc: Werner Pfister <Pfister_Werner@intercontrol.de> cc: Detlev Zundel <dzu@denx.de>
2011-03-06powerpc/85xx: Fix pixis_reset altbank mask on MPC8536DSMatthew McClintock
Currently, pixis_reset altbank does not work properly. This patch uses the correct mask to boot into the alternate bank. Signed-off-by: Matthew McClintock <msm@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-02-21Pantheon: Add Board Support for Marvell dkb boardLei Wen
DKB is a Development Board for PANTHEON TD/TTC(pxa920/pxa910) with * Processor upto 806Mhz * LPDDR1/2 * x8/x16 SLC/MLC NAND * Footprints for eMMC & MMC x8 card With Peripherals: * Parallel LCD I/F * Audio codecs (88PM8607) * MIPI CSI-2 camera * Marvell 88W8787 802.11n/BT module * Marvell 2G/3G RF * Dual analog mics & speakers, headset jack, LED, ambient * USB2.0 HS host, OTG (mini AB) * GPIO, GPIO expander with DIP switches for easier selection * UART serial over USB, CIR This patch adds basic board support with DRAM and UART functionality Signed-off-by: Lei Wen <leiwen@marvell.com> Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2011-02-21mv: seperate kirkwood and armada from common settingLei Wen
Since there are lots of difference between kirkwood and armada series, it is better to seperate them but still keep the most common file shared by all marvell platform in the mv-common configure file. This patch move the kirkwood only driver definitoin in mv-common to the <soc_name>/config.h. This patch is tested with compilation for armada100 and guruplug. Signed-off-by: Lei Wen <leiwen@marvell.com>
2011-02-21arm: Tegra2: Add support for NVIDIA Seaboard boardTom Warren
2011-02-21arm: Tegra2: Add support for NVIDIA Harmony boardTom Warren
2011-02-21serial: Add Tegra2 serial port supportTom Warren
2011-02-21mx31pdk: Make the full boot log visibleFabio Estevam
Use board_early_init_f so that the full boot log output can be displayed. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-02-21mx31pdk: Use the new relocation schemeFabio Estevam
2011-02-19USB: Add USB RNDIS gadget protocolVitaly Kuzmichev
Port USB gadget RNDIS protocol support from linux-2.6.26 (.27 gadget stack actually has composite drivers). Signed-off-by: Vitaly Kuzmichev <vkuzmichev@mvista.com>
2011-02-19USB-CDC: Port struct net_device_statsVitaly Kuzmichev
Port struct net_device_stats and statistics collecting needed for RNDIS protocol. Signed-off-by: Vitaly Kuzmichev <vkuzmichev@mvista.com>
2011-02-19Add support for ASIX AX88772 USB 2.0 10/100Mbit Ethernet AdaptorSimon Glass
Driver originally written by NVIDIA Corporation, modified to handle odd-length packets. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-02-19Add USB host ethernet adapter supportSimon Glass
This adds support for using USB Ethernet dongles in host mode. This is just the framework - drivers will come later. A new config option called CONFIG_USB_HOST_ETHER can be defined in board config files to switch this on. The was originally written by NVIDIA and was cleaned up for release by the Chromium authors. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-02-19Fix EHCI usb submit timeout and unify with OHCISimon Glass
Changed both to use a common timeout for URB submission, since they were using different values and EHCI's was too short. Also fixed EHCI to actually check if urb submission succeeded, rather than silently continuing into the weeds. Change-Id: I7f71499ffaa05187d8e5618db2419e1606007b82 Signed-off-by: Simon Glass <sjg@chromium.org>
2011-02-15add checking the CONFIG_ENV_IS_IN_SPI_FLASH in Enbedded envYoshihiro Shimoda
Fix the problem which cannot build the U-boot, if we only set the CONFIG_ENV_IS_IN_SPI_FLASH. Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-02-12Merge branch 'master' of git://git.denx.de/u-boot-mipsWolfgang Denk
2011-02-12eNET: Move initial Global Data into CARGraeme Russ
2011-02-12sc520: Move RAM sizing code from asm to CGraeme Russ
2011-02-12x86: Use Cache-As-RAM for initial stackGraeme Russ
2011-02-12x86: Move initial gd to fixed locationGraeme Russ
2011-02-12eNET: General code cleanupGraeme Russ
2011-02-12eNET: Rearrange PAR assignmentsGraeme Russ
2011-02-12eNET: Define MMCR values in config.hGraeme Russ
2011-02-12eNET: Add RTC support to eNETGraeme Russ
The SC520 has an inbuilt MC146818 - Enable it for the eNET board
2011-02-09powerpc/85xx: corrected p1_p2_rdb EEPROM addressPriyanka Jain
Board EEPROM is used to read/save Ethernet MAC addresses. Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-02-09Merge branch 'master' of git://git.denx.de/u-boot-ppc4xxWolfgang Denk
2011-02-07ppc4xx: Add DLVision-10G board supportDirk Eibach
Board support for the Guntermann & Drunck DLVision-10G. Adds support for multiple FPGAs per board for gdsys 405ep architecture. Adds support for dual link osd hardware for gdsys 405ep. Signed-off-by: Dirk Eibach <eibach@gdsys.de> Signed-off-by: Stefan Roese <sr@denx.de>
2011-02-06Merge branch 'master' of git://git.denx.de/u-boot-mpc83xxWolfgang Denk
2011-02-06Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
2011-02-05mpc83xx: Use correct register to calculate clocks.Joakim Tjernlund
Use SPMR instead of HRCWL when calculating clocks as HCRWL may be changed and the CPU will not pick up all changes until there is a POR. u-boot will think SPMF has changed and get the clocks wrong. Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2011-02-05mpc83xx: fix pcie configuration space read/writeLeo Liu
This patch fix a problem for the pcie enumeration when the mpc83xx pcie controller is connected with switch or we use both of the two pcie controller. Signed-off-by: Leo Liu <liucai.lfn@gmail.com> fix codingstyle and compiler warning: 'pcie_priv' defined but not used Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2011-02-05MIPS: Move Inca-IP targets to boards.cfgShinya Kuribayashi
At the same time, fix up CPU_CLOCK_RATE to have the CONFIG_ prefix to work with boards.cfg. Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
2011-02-05MIPS: VCT: Fix enabling of unwanted options if networking or USB support are ↵Daniel Schwierzeck
disabled Some VCT boards lacks the support of networking or USB. Additionally that support is disabled in small image configurations. If CONFIG_CMD_NET should not used the CONFIG_CMD_NFS option have to be disabled too. Otherwise the linker fails with unresolved symbols. If CONFIG_VCT_SMALL_IMAGE is set than CONFIG_CMD_NET and CONFIG_CMD_USB are disabled at the end of vct.h. This is not adequate because CONFIG_CMD_USB enables additional options and the linker fails again with unresolved symbols. This patch adds an early check against CONFIG_VCT_SMALL_IMAGE so the additional options are only enabled if they are really needed. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
2011-02-04Merge branch 'master' of git://git.denx.de/u-boot-shWolfgang Denk
2011-02-03powerpc/85xx: Enable ECC on MPC8572DSYork Sun
Using hwconfig to turn on/off ECC, without re-compiling. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-02-03powerpc/85xx: Enable Errata command on MPC8572DSYork Sun
Also removed duplicate CONFIG_CMD_IRQ define. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-02-02Minor Coding Style Cleanup.Wolfgang Denk
2011-02-02sh: add support for sh7757lcr boardYoshihiro Shimoda
The R0P7757LC0030RL board has SH7757, 256MB DDR3-SDRAM, SPI ROM, Ethernet, and more. This patch supports the following functions: - 256MB DDR3-SDRAM - SPI ROM - Ethernet Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-02-02sh: Remove config.mk for shmin boardNobuhiro Iwamatsu
Move CONFIG_SYS_TEXT_BASE to the board's config file, and remove the unnecessary config.mk file. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
