Use the GNU 'date' command to auto-generate a new U-Boot
timestamp on every compile.
This code contains some non-ascii characters in comment lines and code.
Most editors do not display those characters properly and editing those
files results always in diffs at these places which are usually not required
to be changed at all. This is error prone.
So, remove those weird characters and replace them by normal C-style
equivalents for which the proper defines were already in the header.
Signed-off-by: Remy Bohmer <linux@bohmer.net>
The default DDR freq is 400MHz or 800M data rate,
the old settings is pure wrong for the default case.
Signed-off-by: Dave Liu <daveliu@freescale.com>
Acked-by: Andy Fleming <afleming@freescale.com>
The BR_PHYS_ADDR macro is useful on all machines that have local bus
which is pretty much all 83xx/85xx/86xx chips.
Additionally most 85xx & 86xx will need it if they want to support
36-bit physical addresses.
Add define used to determine if PCI1 interface is in PCI or PCIX mode.
Convert users of the old PORDEVSR_PCI constant to use MPC85xx_PORDEVSR_PCI1
Signed-off-by: Andy Fleming <afleming@freescale.com>
Prevent further viral propogation of the unused
symbol CONFIG_L1_INIT_RAM by just removing it.
The DDR controller of 8548/8544/8568/8572/8536 processors
have the ECC data init feature, and the new DDR code is
using the feature, and we don't need the way with DMA to
init memory any more.
Introducing 64-bit (36-bit) support for the MPC8641HPCN
failed to accomodate the other two 86xx boards.
Introduce definitions for CONFIG_SYS_CCSRBAR_PHYS_{LOW,HIGH}
CONFIG_SYS_CCSR_DEFAULT_DBAT{U,L} and CONFIG_SYS_CCSR_DEFAULT_IBAT{U,L}
with nominal 32-bit values.
Acked-by: Becky Bruce <becky.bruce@freescale.com>
USB Code style patch
Signed-off-by: Michael Trimarchi <trimarchi@gandalf.sssup.it>
Signed-off-by: Remy Böhmer <linux@bohmer.net>
This patch disables some unused features from the PCI405 configuration
to keep U-Boot image size below 192k.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
This patch fix the broken boot from NOR Flash on AT91RM9200 boards, if
CONFIG_AT91RM9200 is defined and nor preloader is used.
Signed-off-by: Jens Scharsig <esw@bus-elektronik.de>
Add cfi-mtd driver, which exports CFI flash to MTD layer.
This allows CFI flash devices to be used from MTD layer.
Building of the new driver is controlled by CONFIG_FLASH_CFI_MTD
option. Initialization is done by calling cfi_mtd_init() from
flash_init().
Signed-off-by: Piotr Ziecik <kosmo@semihalf.com>
Add interface for flash verbosity control. It allows
to disable output from low-level flash API. It is useful
when calling these low-level functions from context other
than flash commands (for example the MTD/CFI interface
implmentation).
Export flash_sector_size() function from drivers/mtd/cfi_flash.c,
so that it can be used in the upcoming cfi-mtd driver.
This patch enables support for EXT2, and increases the
CONFIG_SYS_BOOTMAPSZ size for the default configuration
of the katmai boards to use them as the RAID-reference
AMCC setups.
EXT2 enabling allows one to boot kernels from the EXT2
formatted Compact Flash cards.
CONFIG_SYS_BOOTMAPSZ increasing allows one to boot the
Linux kernels, which use PAGE_SIZE of 256KB. Otherwise,
the memory area with DTB file (which is placed at the
end of the bootmap area) will turn out to be overlapped
with the BSS segment of the 256KB kernel, and zeroed
in early_init() of Linux.
Actually, increasing of the bootmap size could be done
via setting of the bootm_size U-Boot variable, but it looks
like the current U-Boot implementation have some bootm_size-
related functionality lost. In many places through the U-Boot
code the CONFIG_SYS_BOOTMAPSZ definition is used directly
(instead of trying to read the corresponding value from the
environment). The same is truth for the boot_jump_linux()
function in lib_ppc/bootm.c, where U-Boot transfers control
to Linux passing the CONFIG_SYS_BOOTMAPSZ (not bootm_size)
value to the booting kernel.
Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
Expanded OCM TLB to allow access to 64K OCM as well as 256K of
internal SRAM.
Adjusted internal SRAM initialization to match updated user
manual recommendation.
OCM & ISRAM are now mapped as follows:
physical virtual size
ISRAM 0x4_0000_0000 0xE300_0000 256k
OCM 0x4_0004_0000 0xE304_0000 64k
A single TLB was used for this mapping.
Signed-off-by: Dave Mitchell <dmitch71@gmail.com>
Added include/asm-ppc/ppc4xx-isram.h and moved internal SRAM and
L2 cache DCRs from ppc440.h to this new header.
Also converted these DCR defines from lowercase to uppercase and
modified referencing modules to use them.
The definitions of bits in SDR_CFG are incorrect, and not used within
U-Boot. Therefore, they can be removed.
The naming of the sdr_ddrdl/sdr_cfg registers do not follow conventions,
and are unused, so they can be removed too.
A definition for SDR0_DDRCFG is added.
Signed-off-by: Steven A. Falco <sfalco@harris.com>
At least some (old ?) versions of the AT91Bootstrap do not set up the
PLLB correctly to 48 MHz in order to make USB host function correctly.
This patch sets up the PLLB to the same values Linux uses, and makes USB
work ok on the following CPUs:
- AT91CAP9
- AT91SAM9260
- AT91SAM9263
This patch also defines CONFIG_USB_STORAGE and CONFIG_CMD_FAT for all
the relevant AT91CAP9/AT91SAM9 atmel boards.
Signed-off-by: Stelian Pop <stelian@popies.net>
Introduce AT91_CPU_CLOCK and use it for displaying the CPU
speed in the LCD driver.
Also make AT91_MAIN_CLOCK and AT91_MASTER_CLOCK reflect the
corresponding board clocks.
modify the CAS timings. my understanding is that these
settings decrease various wait times in the DDR interface.
Because these wait times are in clock cycles, and the DDR
clock on the 8315 RDB runs slower than on some other 83xx
platforms, we can dial down these values without a problem,
thereby decreasing the latency of memory a little.
Signed-off-by: Howard Gregory <Greg.Howard@freescale.com>
To enable UBI on Apollon you need to uncomment the CONFIG_SYS_USE_UBI
macro.
This patch adds basic UBI (Unsorted Block Image) support to U-Boot.
It's based on the Linux UBI version and basically has a "OS"
translation wrapper that defines most Linux specific calls
(spin_lock() etc.) into no-ops. Some source code parts have been
uncommented by "#ifdef UBI_LINUX". This makes it easier to compare
this version with the Linux version and simplifies future UBI
ports/bug-fixes from the Linux version.
Since we've changed the memory map of the board, be nice and
add some checking to try to catch out-of-date .dts files. We do
this by checking the CCSRBAR location in the .dts and comparing
it to the CCSRBAR location in u-boot. If they don't match, a
warning msg is printed. This isn't foolproof, but it's simple and
will catch most of the cases where an out-of-date .dts is present,
including all of the cases where a new u-boot is used with an old
standard MPC8641 .dts file as supplied with Linux.
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
This patch creates a memory map with all the devices
in 36-bit physical space, in addition to the 32-bit map.
The CCSR relocation is moved (again, sorry) to
allow for the physical address to be 36 bits - this
requires translation to be enabled. With 36-bit physical
addressing enabled, we are no longer running with VA=PA
translations. This means we have to distinguish between
the two in the config file. The existing region name is
used to indicate the virtual address, and a _PHYS variety
is created to represent the physical address.
Large physical addressing is not enabled by default.
Set CONFIG_PHYS_64BIT in the config file to turn this on.
The memory map on the 8641hpcn is modified to look more like
the 85xx boards; this is a step towards a more standardized
layout going forward. As part of this change, we now relocate
the flash.
The regions for some of the mappings were far larger than they
needed to be. I have reduced the mappings to match the
actual sizes supported by the hardware.
In addition I have removed the comments at the head
of the BAT blocks in the config file, rather than updating
them. These get horribly out of date, and it's a simple
matter to look at the defines to see what they are set to
since everything is right here in the same file.
Documentation has been changed to reflect the new map, as this
change is user visible, and affects the OS which runs post-uboot.
We define CONFIG_MONITOR_BASE_EARLY to define the initial location
of the bootpage in flash. Use this to create an early mapping
definition for the FLASH, and change the early_bats code to use this.
This change facilitates the relocation of the flash since the early
mappings are no longer tied to the final location of the flash.
Currently, that's what it is, but it's hardcoded.
There's a lot of setup and foo for the second flash
bank. The problem is, this board doesn't actually have one.
Clean this up. Also, the flash is 8M in size. Get rid
of the confusing aliased overmapping, and just map 8M.
It's currently defined twice inside in an if/else block, but
both halves set the same value. Move the define outside
the if.
Removed initialization of the driver from net/eth.c
All in-tree IBM/AMCC PPC4xx boards using the EMAC get this new CONFIG
