When u-boot initializes the RAM (early in boot) it looks for the "pram"
env variable to know which is area it cannot use. If the "pram" env variable
is not found, the default CONFIG_PRAM value is used.
This value used to be 0 (no protection at all). This patch sets it to a
value that covers PHRAM and PNVRAM that must be protected in our case.
Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
Reviewed-by: York Sun <yorksun@freescale.com>
Add deep sleep support in SPI/SD boot. The destination address
second stage uboot image is loaded to is changed because
currently this address will be used by kernel which means
we can't reserve it for resume.
Entry point to kernel is still placed in second stage uboot.
Signed-off-by: Tang Yuantian <Yuantian.Tang@freescale.com>
T1042 has internal display interface unit (DIU) for driving video.
T1042RDB supports video mode via
-LCD using TI enconder
-HDMI type interface via HDMI encoder
Chrontel, CH7301C encoder which is I2C programmable is used
as HDMI connector on T1042RDB.
This patch add support to
-enable Video interface for T1042RDB
-route qixis multiplexing to enable DIU-HDMI interface on board
-program DIU pixel clock gerenartor for T1042
-program HDMI encoder via I2C on board
This patch refer to the upstream diu patch
(337b0c52b3296f371d04aef71a833e09110e0e6b) for T1040qds.
Signed-off-by: Jason Jin <Jason.Jin@freescale.com>
Signed-off-by: Wang Dongsheng <dongsheng.wang@freescale.com>
[York Sun: resolve conflict and move changes to T104xRDB.h]
The ch7301 encoder not only used in t1040qds platform, so we split
it for t1042rdb and LSx platform.
Kernel address is normally stored as a string argument of bootm or bootz.
This function is taken out from boot_get_kernel() of bootm.c, which can be
reused by others.
Signed-off-by: Bryan Wu <pengw@nvidia.com>
[trini: Fix warnings with CONFIG_FIT]
Replace the custom $bootcmd with that from <config_distro_bootcmd.h>.
There should be no functional change, since the new generic $bootcmd was
derived strongly from tegra-common-post.h, after which this part of
rpi_b.h was modelled.
The #defines to enable/disable U-Boot commands/features were moved
earlier in rpi_b.h, so they are set up before config_distro_bootcmd.h
is included, since it tests whether certain features should be included
based on those defines.
derived strongly from tegra-common-post.h.
This generic $bootcmd, and associated support macros, automatically
searches a defined set of storage devices (or network protocols) for an
extlinux configuration file or U-Boot boot script in various standardized
locations. Distros that install such a boot config file/script in those
standard locations will get easy-to-set-up booting on HW that enables
this generic $bootcmd.
Boards can define the set of devices from which boot is attempted, and
the order in which they are attempted. Users may later customize this
set/order by edting $boot_targets.
Users may interrupt the boot process and boot from a specific device
simply by executing e.g.:
$ run bootcmd_mmc1
or:
$ run bootcmd_pxe
This patch was originally written by Dennis Gilmore based on Tegra and
rpi_b boot scripts. I have made the following modifications since then:
* Boards must define the BOOT_TARGET_DEVICES macro in order to specify
the set of devices (and order) from which to attempt boot. If needed,
we can define a default directly in config_distro_bootcmd.h.
* Removed $env_import and related variables; nothing used them, and I
think it's better for boards to pre-load an environment customization
file using CONFIG_PREBOOT if they need.
* Renamed a bunch of variables to suit my whims:-)
Signed-off-by: Dennis Gilmore <dennis@ausil.us>
The following configs are not defined at all.
- CONFIG_OMAP1510
- CONFIG_OMAP_1510P1
- CONFIG_OMAP_SX1
- CONFIG_OMAP3_DMA
- CONFIG_OMAP3_ZOOM2
- CONFIG_OMAP_INNOVATOR
Cc: Tom Rini <trini@ti.com>
This brings in changes up to commit f9e91a48 in the libfdt repo.
Mostly this is whitespace/minor changes. But there are a few new
features:
- fdt_size_cells() and fdt_address_cells()
- fdt_resize()
Since libfdt now has an fdt_resize() function, we need to rename the
U-Boot one.
After the clean up performed in the commit 1151b7ac10b81ecbb the DFU subsystem
requires absolute patch for correct operation.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
Remove the verified boot limitation that only allows a single
RSA public exponent of 65537 (F4). This change allows use with
existing PKI infrastructure and has been tested with HSM-based
PKI.
Change the configuration OF tree format to store the RSA public
exponent as a 64 bit integer and implement backward compatibility
for verified boot configuration trees without this extra field.
Parameterise vboot_test.sh to test different public exponents.
Mathematics and other hard work by Andrew Bott.
Tested with the following public exponents: 3, 5, 17, 257, 39981,
50457, 65537 and 4294967297.
Signed-off-by: Andrew Bott <Andrew.Bott@ipaccess.com>
Signed-off-by: Andrew Wishart <Andrew.Wishart@ipaccess.com>
Signed-off-by: Neil Piercy <Neil.Piercy@ipaccess.com>
Signed-off-by: Michael van der Westhuizen <michael@smart-africa.com>
echi-rmobile does not support xHCI. This removes xHCI address
from address table. And this revise a value of CONFIG_USB_MAX_CONTROLLER_COUNT
for lager board and koelsh board.
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
This allows SPI Flash to be programmed using DFU.
This allows the backend to free any resources allocated during the
relevant dfu_fill_entity_*() call. This will soon be used by the
SF backend.
CONFIG_SYS_DFU_DATA_BUF_SIZE may be large to allow for FAT/ext layouts
to transfer large files. However, this means that individual write
operations will take a long time. Allow backends to specify a maximum
buffer size, so that each write operation is limited to a smaller data
block. This prevents the DFU protocol from timing out when e.g. writing
to SPI flash. I would guess that NAND might benefit from setting this
value too, but I can't test that.
Devices are not all identified by a single integer. To support
this, defer the parsing of the device string to the IO backed, so that
it can apply the appropriate rules.
SPI devices are specified as controller:chip_select. SPI/SF support will
be added soon.
MMC devices can also be specified as controller[.hwpart][:partition] in
many commands, although we don't support that syntax in DFU.
DFU read support appears to rely upon dfu->read_medium() updating the
passed-by-reference len parameter to indicate the remaining size
available for reading.
dfu_read_medium_mmc() never does this, and the implementation of
dfu_read_medium_nand() will only work if called just once; it hard-codes
the value to the total size of the NAND device irrespective of read
offset.
I believe that overloading dfu->read_medium() is confusing. As such,
this patch introduces a new function dfu->get_medium_size() which can
be used to explicitly find out the medium size, and nothing else.
dfu_read() is modified to use this function to set the initial value for
dfu->r_left, rather than attempting to use the side-effects of
dfu->read_medium() for this purpose.
Due to this change, dfu_read() must initially set dfu->b_left to 0, since
no data has been read.
dfu_read_buffer_fill() must also be modified not to adjust dfu->r_left
when simply copying data from dfu->i_buf_start to the upload request
buffer. r_left represents the amount of data left to be read from HW.
That value is not affected by the memcpy(), but only by calls to
dfu->read_medium().
After this change, I can read from either a 4MB or 1.5MB chunk of a 4MB
eMMC boot partion with CONFIG_SYS_DFU_DATA_BUF_SIZE==1MB. Without this
change, attempting to do that would result in DFU read returning no data
at all due to r_left never being set.
These commands may be used to determine the size of a file without
actually reading the whole file content into memory. This may be used
to determine if the file will fit into the memory buffer that will
contain it. In particular, the DFU code will use it for this purpose
in the next commit.
Messages to afleming@freescale.com now bounce, and should be
directed to my personal address at afleming@gmail.com
Signed-off-by: Andy Fleming <afleming@gmail.com>
The booting of the board is now protected by the CPU watchdog.
A failure during the boot phase will end up in board reset.
Signed-off-by: Rainer Boschung <rainer.boschung@keymile.com>
Function to inititialize the cpu watchdog added.
[York Sun: Add prototype in watchdog.h]
Add callback with __weak annotation to allow setup of environment
partition number in runtime from a board file.
Propagate mmc_switch_part() return value into init_mmc_for_env() instead
of -1 in case of failure.
Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il>
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
Add missing mmc_get_env_addr() prototype in environment.h
Add configuration register definition, this register only
exists on MCI IP version >= 0x300.
Signed-off-by: Bo Shen <voice.shen@atmel.com>
The mode register is different between MCI IP version.
So, according to MCI IP version to set the mode register.
This patch add Marvell kirkwood MVSDIO/MMC driver
and enable it for Sheevaplugs and OpenRD boards.
Signed-off-by: Gerald Kerma <drEagle@doukki.net>
Now CONFIG_SPL and CONFIG_TPL are defined in Kconfig.
Remove the redundant definition in config headers.
CONFIG_${ARCH} is defined by Kconfig.
This commit enables Kconfig.
Going forward, we use Kconfig for the board configuration.
mkconfig will never be used. Nor will include/config.mk be generated.
Kconfig must be adjusted for U-Boot because our situation is
a little more complicated than Linux Kernel.
We have to generate multiple boot images (Normal, SPL, TPL)
from one source tree.
Each image needs its own configuration input.
Usage:
Run "make <board>_defconfig" to do the board configuration.
It will create the .config file and additionally spl/.config, tpl/.config
if SPL, TPL is enabled, respectively.
You can use "make config", "make menuconfig" etc. to create
a new .config or modify the existing one.
Use "make spl/config", "make spl/menuconfig" etc. for spl/.config
and do likewise for tpl/.config file.
The generic syntax of configuration targets for SPL, TPL is:
<target_image>/<config_command>
Here, <target_image> is either 'spl' or 'tpl'
<config_command> is 'config', 'menuconfig', 'xconfig', etc.
When the configuration is done, run "make".
(Or "make <board>_defconfig all" will do the configuration and build
in one time.)
For futher information of how Kconfig works in U-Boot,
please read the comment block of scripts/multiconfig.py.
By the way, there is another item worth remarking here:
coexistence of Kconfig and board herder files.
Prior to Kconfig, we used C headers to define a set of configs.
We expect a very long term to migrate from C headers to Kconfig.
Two different infractructure must coexist in the interim.
In our former configuration scheme, include/autoconf.mk was generated
for use in makefiles.
It is still generated under include/, spl/include/, tpl/include/ directory
for the Normal, SPL, TPL image, respectively.
We are about to switch to Kconfig in the next commit.
But there are something to get done beforehand.
In Kconfig, include/generated/autoconf.h defines boolean
CONFIG macros as 1.
CONFIG_SPL and CONFIG_TPL, if defined, must be set to 1.
Otherwise, when switching to Kconfig, the build log
would be sprinkled with warning messages like this:
warning: "CONFIG_SPL" redefined [enabled by default]
Import
- scripts/kconfig/*
- include/linux/kconfig.h
from Linux 3.16-rc7.
Some architecture needs extra device tree setup. Instead of adding
yet another hook, convert arch_fixup_memory_node to be a generic
FDT fixup function.
[maz: collapsed 3 patches into one, rewrote commit message]
Signed-off-by: Ma Haijun <mahaijuns@gmail.com>
Acked-by: Ian Campbell <ijc@hellion.org.uk>
This patch moves some board specific NAND configs:
- TO: individual board config files using these configs.
So that each board can independently set the value as per its design.
Following configs are affected in this patch:
CONFIG_SYS_NAND_U_BOOT_OFFS: <refer doc/README.nand>
CONFIG_CMD_SPL_NAND_OFS: <refer doc/README.falcon>
CONFIG_SYS_NAND_SPL_KERNEL_OFFS: <refer doc/README.falcon>
CONFIG_CMD_SPL_WRITE_SIZE: <refer doc/README.falcon>
This patch also updates documentation for few of above NAND configs.
Signed-off-by: Pekon Gupta <pekon@ti.com>
PISMO_xx macros were used to define 'Platform Independent Storage MOdule'
related GPMC configurations. This patch
- Replaces these OMAP3 specific macros with generic CONFIG_xx macros as provided
by current u-boot infrastructure.
- Removes unused redundant macros, which are no longer required after
merging of common platform code in following commit
commit a0a37183bd75e74608bc78c8d0e2a34454f95a91
ARM: omap: merge GPMC initialization code for all platform
| Macro | Reason for removal |
| PISMO1_NOR_BASE | duplicate of CONFIG_SYS_FLASH_BASE |
| PISMO1_NAND_BASE| duplicate of CONFIG_SYS_NAND_BASE |
| PISMO1_ONEN_BASE| duplicate of CONFIG_SYS_ONENAND_BASE |
| PISMO1_NAND_SIZE| GPMC accesses NAND device via I/O mapped registers so |
| | configuring GPMC chip-select for smallest allowable |
| | segment (GPMC_SIZE_16M) is enough. |
| PISMO1_ONEN_SIZE| OneNAND uses a fixed GPMC chip-select address-space of |
| | 128MB (GPMC_SIZE_128M) |
| PISMO1_NOR | Unused Macros |
| PISMO1_NAND | |
| PISMO2_CS0 | |
| PISMO2_CS1 | |
| PISMO1_ONENAND | |
| PISMO2_NAND_CS0 | |
| PISMO2_NAND_CS1 | |
| PISMO1_NOR_BASE | |
| PISMO1_NAND_BASE| |
| PISMO2_CS0_BASE | |
Fixes commit a0a37183bd75e74608bc78c8d0e2a34454f95a91
1) NAND device are not directly memory-mapped to CPU address-space, they are
indirectly accessed via following GPMC registers:
- GPMC_NAND_COMMAND_x
- GPMC_NAND_ADDRESS_x
- GPMC_NAND_DATA_x
Therefore from CPU's point of view, NAND address-map can be limited to just
above register addresses. But GPMC chip-select address-map can be configured
in granularity of 16MB only.
So this patch uses GPMC_SIZE_16M for all NAND devices.
2) NOR device are directly memory-mapped to CPU address-space, so its
address-map size depends on actual addressable region in NOR FLASH device.
So this patch uses CONFIG_SYS_FLASH_SIZE to derive GPMC chip-select address-map
size configuration.
This patch adds Keystone2 k2e_evm evaluation board support.
Signed-off-by: Hao Zhang <hzhang@ti.com>
Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
This patch adds clock definitions and commands to support Keystone2
K2E SOC.
This patch adds a common config header file for all the Keystone II
EVM platforms. It combines a lot of general definitions in one file.
The common header included in the EVM should be specific configuration
header.
Acked-by: Murali Karicheri <m-karicheri2@ti.com>
This patch moves K2HK board directory to a common Keystone II board
directory. The Board related common functions are moved to a common
keystone board file.
Use KS2_ prefix in all definitions, for that replace K2HK_ prefix and
add KS2_ prefix where it's needed. It requires to change names also
in places where they're used. Align lines and remove redundant
definitions in kardware-k2hk.h at the same time.
Using common KS2_ prefix helps resolve redundant redefinitions and
adds opportunity to use KS2_ definition across a project not thinking about
what SoC should be used. It's more convenient and we don't need to worry
about the SoC type in common files, hardware.h will think about that.
The hardware.h decides definitions of what SoC to use.
