Added CONFIG_NET_MULTI to all Davinci boards
Removed all calls to Davinci network driver from board code
Added cpu_eth_init() to cpu/arm926ejs/cpu.c
Chips supported:-
1. 88E6161 6 port gbe swtich with 5 integrated PHYs
2. 88E6165 6 port gbe swtich with 5 integrated PHYs
2. 88E6132 3 port gbe swtich with 2 integrated PHYs
Platform specific configuration supported for:-
default or router port vlan configuration
led_init configuration
mdip/n polarity reversal configuration
Note: This driver is supported and tested against
kirkwood egiga interface
Contributors:
Yotam Admon <yotam@marvell.com>
Michael Blostein <michaelbl@marvell.com
Reviewed by: Ronen Shitrit <rshitrit@marvell.com>
Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
Signed-off-by: Zach LeRoy <zleroy@xes-inc.com>
Acked-by: Kumar Gala <galak@kernel.crashing.org>
Add defines similar to those already used for the the 86xx architecture.
This will ease sharing of PCI code between the 85xx and 86xx
architectures.
The following changes were made to sync up the DMA code between the 85xx
and 86xx architectures which will make it easier to break out common
8xxx DMA code:
85xx:
- Don't set STRANSINT and SPCIORDER fields in SATR register. These bits
only have an affect when the SBPATMU bit is set.
- Write 0xffffffff instead of 0xfffffff to clear errors in the DMA
status register. We may as well clear all 32 bits of the register...
86xx:
- Add CONFIG_SYS_MPC86xx_DMA_ADDR define to address DMA registers
- Add clearing of errors in the DMA status register when initializing
the controller
- Clear the channel start bit in the DMA mode register after a transfer
Break out DMA structures for the Freescale MPC85xx and MPC86xx cpus to
reduce a large amount of code duplication
On MPC8569MDS board, UCC6 and UCC8 can be configured to work at SGMII mode via
UEM on PB board. Since MPC8569 supports up to 4 Gigabit Ethernet ports, we
disable UEC6 and UEC8 by default.
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
This patch supports UCC working at RMII mode on PIB board, fixup fdt blob to
support rmii in kernel. It also changes the name of enable_mpc8569mds_qe_mdio to
enalbe_mpc8569mds_qe_uec which is more accurate.
Some QE chips like 8569 need more SNUM numbers for supporting 4 UECs in RGMII-
1000 mode.
Acked-by: Timur Tabi <timur@freescale.com>
Also define the QE_RISC_ALLOCATION_RISCs to MACROs instead of using enum, and
define MAX_QE_RISC for QE based silicons.
Acked-by: Timur Tabi <Timur@freescale.com>
The patch adds support for P2020DS reference platform.
DDR3 interface uses hard-coded initialization rather than SPD
for now and was tested at 667Mhz. Some PIXIS register
definitions and associated code sections need to be fixed.
TSEC1/2/3, NOR flash, MAC/SYS ID EEPROM, PCIE1/2/3 are all
tested under u-boot.
Signed-off-by: Srikanth Srinivasan <srikanth.srinivasan@freescale.com>
Signed-off-by: Travis Wheatley <Travis.Wheatley@freescale.com>
This patch adds NAND support to the MPC5121ADS board. Please
note that the image size increased since NAND support didn't
fit in the current image size (256k).
MECP5123 is a MPC5121E based module by esd gmbh.
Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
Thos macros will be used by the esd mecp5123 board.
The CPCI750 can be built as CPCI host or adapter/target board. This patch
adds support for runtime detection of those variants.
This patch adds CONFIGs for enabling USB in mpc8536ds and also
adds usb_phy_type in CONFIG_EXTRA_ENV_SETTINGS. Also revamps its
Copyright.
Signed-off-by: Vivek Mahajan <vivek.mahajan@freescale.com>
Signed-off-by: Remy Bohmer <linux@bohmer.net>
This patch adds CONFIGs for enabling USB in mpc8315erdb and also
Copyright.
The following patch adds 85xx-specific USB support and also
revamps Copyright in immap_85xx.h
The following patch reorganizes/reworks the USB support for mpc83xx
as under:-
* Moves the 83xx USB clock init from drivers/usb/host/ehci-fsl.c to
cpu/mpx83xx/cpu_init.c
* Board specific usb_phy_type is read from the environment
* Adds USB EHCI specific structure in include/usb/ehci-fsl.h
* Copyrights revamped in most of the following files
The following patch moves 8xxx-specifc USB #defines from
drivers/usb/host/ehci-fsl.h to include/usb.
Use the standard lowercase "x" capitalization that other Freescale
architectures use for CPU defines to prevent confusion and errors
Use the standard lowercase "xx" capitalization that other Freescale
ARIA is a MPC5121E based COM Express module by Dave/DENX.
Cc: John Rigby <jcrigby@gmail.com>
Move needed definitions (register descriptions etc.) from
include/mpc512x.h into include/asm-ppc/immap_512x.h.
Instead of using a #define'd register offset, use a function that
provides the PATA controller's base address.
All the rest of include/mpc512x.h are register offset definitions
which can be eliminated by proper use of C structures.
There are only a few register offsets remaining that are needed in
cpu/mpc512x/start.S; for these we provide cpu/mpc512x/asm-offsets.h
which is intended as a temporary workaround only. In a later patch
this file will be removed, too, and then auto-generated from the
respective C structs.
- add GPIO module description
- add Address Latch Timing Register description
- add IO Control Memory Map
- add FEC Memory Map
Also change board/freescale/mpc5121ads/mpc5121ads.c and
cpu/mpc512x/iopin.c as needed.
We rename the board so we use a consistent name in U-Boot and in
Linux. Also, we use this opportunity to move the board into the
Freecale vendor directory.
In case of incorrect command invocations U-Boot used to print pretty
useless "usage" messages, for example:
=> nand markbad
Usage:
nand - NAND sub-system
In the result, the user would have to run the "help" command to get
the (available) information about correct command usage. Change this,
so that this information gets always printed.
Note that this changes the user interface of all commands, but
hopefully to the better.
The kernel stores address<->symbol names in it so things can be decoded at
runtime. Do it in U-Boot, and we get nice symbol decoding when crashing.
By changing the cmd_mtdparts to only use the MTD infrastructure and
not the direct interface to the CFI NOR FLASH driver we now need
to add the MTD infrastructure to all boards using those mtdparts
commands. This patch adds those components:
CONFIG_MTD_DEVICE (for all FLASH types)
plus
CONFIG_FLASH_CFI_MTD (for NOR FLASH)
To all board maintainers: Please test this on your platforms and
report any problems/issues found. Thanks.
Cc: Ron Madrid <info@sheldoninst.com>
Cc: Georg Schardt <schardt@team-ctech.de>
Cc: Ladislav Michl <ladis@linux-mips.org>
Cc: Martin Krause <martin.krause@tqs.de>
Cc: Gary Jennejohn <garyj@denx.de>
Cc: Ricardo Ribalda <ricardo.ribalda@uam.es>
This patch brings the U-Boot MTD infrastructure in sync with the current
Linux MTD version (2.6.30-rc3). Biggest change is the 64bit device size
support and a resync of the mtdpart.c file which has seen multiple fixes
meanwhile.
Cc: Scott Wood <scottwood@freescale.com>
Cc: Kyungmin Park <kmpark@infradead.org>
This patch adds concatenation support to the U-Boot MTD infrastructure.
By enabling CONFIG_MTD_CONCAT this MTD CFI wrapper will concatenate
all found NOR devices into one single MTD device. This can be used by
e.g by UBI to access a partition that spans over multiple NOR chips.
Enable the function and interface clocks for banks 2,3,5 and 6.
Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
Acked-by: Dirk Behme <dirk.behme@googlemail.com>
This patch assigns the u-boot system timer interrupt to
interrupt level 3, priority 6. Without this patch the interrupt
will be a level 0, priority 0, which disables it and cause
u-boot functions that relies on the timer (e.g. sleep command)
to never return.
Signed-off-by: Richard Retanubun <RichardRetanubun@RuggedCom.com>
This patch is required for Kirkwood support
may be used by other ARM architectures
With other OMAP3 boards we recently switched to CPU and Board
info API. From parallel merge, this is missing for Zoom2.
Enable it for Zoom2, too.
Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
Acked-by: Tom Rix <Tom.Rix@windriver.com>
This patch controls the large LED on the top left of the zoom2.
Zoom2 serial is in general supplied by one of the 4 UARTS on the debug board.
The default serial is from the USB connector on left side of the debug board.
The USB connector will produce 2 of the 4 UARTS. On your host pick the first
enumeration.
The details of the setting of the serial gpmc setup are not available.
The values were provided by another party.
The serial port set up is the same with Zoom1.
Baud rate 115200, 8 bit data, no parity, 1 stop bit, no flow.
The kernel bootargs are
console=ttyS3,115200n8
move s3c44b0 to arch_cpu_init and as noone use cpu_init remove it
all arm init the IRQ stack the same way
so unify it in lib_arm/interrupts.c and then call arch specific interrupt init
Also enable display of 'E'mpty sectors in "flinfo" output.
Also reserve more space for U-Boot as it will probably grow soon.
