Mostly reusing DDR3 driver, this patch adds DDR4 SPD handling, register
calculation and programming.
Signed-off-by: York Sun <yorksun@freescale.com>
For fsl-lsch3 NOR flash boot, IFC CS0 needs to be binded with address
within 32-bit at fist. After u-boot relocates to DDR, CS0 can be binded
to higher address to support large space.
CC: Prabhakar Kushwaha <prabhakar@freescale.com>
add CONFIG_QE, CONFIG_U_QE and CONFIG_SYS_QE_FW_ADDR into
"include/configs/T1040RDB.h"
Signed-off-by: Zhao Qiang <B45475@freescale.com>
Reviewed-by: York Sun <yorksun@freescale.com>
CONFIG_SYS_QE_FMAN_FW_ADDR is used to both Fman and QE for microcode address.
Now using CONFIG_SYS_FMAN_FW_ADDR for Fman microcode address,
and CONFIG_SYS_QE_FW_ADDR for QE microcode address.
In case of secure boot from NAND, the DDR is initialized by the
BootROM using the config words (CF_WORDS) in the CF_HEADER
and u-boot image is copied from NAND to DDR by the BootROM.
So, CONFIG_SYS_RAMBOOT has been defined for Secure Boot from NAND
Signed-off-by: Aneesh Bansal <aneesh.bansal@freescale.com>
Add NOR, SPI and SD secure boot targets for BSC9132QDS.
Changes:
- Debug TLB entry is not required for Secure Boot Target.
The workaround for IFC errata A003399 was not enabled
in case of secure boot. So, secure boot from NOR was not
working.
So, CONFIG_SYS_RAMBOOT has been defined for Secure Boot from NAND.
For KVM we have a special PV machine type called "ppce500". This machine
is inspired by the MPC8544DS board, but implements a lot less features
than that one.
It also provides more PCI slots and is supposed to be enumerated by
device tree only.
This patch adds support for the generic ppce500 machine and tries to
rely solely on device tree for device enumeration.
Acked-by: Scott Wood <scottwood@freescale.com>
This patch adds a helper function that can be used to interpret most
"ranges" properties in the device tree.
It reads the n'th range out of a "ranges" array and returns the node's
virtual address of the range, the physical address that range starts at
and the size of the range.
We already have a nice helper to give us a property cell value with default
fall back from a path. Split that into two helpers - one for the old path
based lookup and one to give us a value based on a node offset.
Tegra's crypto.c uses apply_cbc_chain_data() to sign the warm restart
code. This function was recently moved into the core aes.c and made
static, which prevents the Tegra code from compiling. Make it public
again to avoid the compile errors:
arch/arm/cpu/tegra20-common/crypto.c: In function ‘sign_object’:
arch/arm/cpu/tegra20-common/crypto.c:74:3: warning: implicit declaration of function ‘apply_cbc_chain_data’ [-Wimplicit-function-declaration]
arch/arm/cpu/built-in.o: In function `sign_object':
.../arch/arm/cpu/tegra20-common/crypto.c:74: undefined reference to `apply_cbc_chain_data'
.../arch/arm/cpu/tegra20-common/crypto.c:78: undefined reference to `apply_cbc_chain_data'
Fixes: 6e7b9f4fa0ae ("aes: Move the AES-128-CBC encryption function to common code")
Enough time has passed since this board was moved to Orphan. Remove.
- Remove board/lubbock/*
- Remove include/configs/lubbock.h
- Cleanup defined(CONFIG_LUBBOCK)
- Move the entry from boards.cfg to doc/README.scrapyard
- Remove include/configs/EVB64260.h
- Remove the entry from boards.cfg
- Remove board/mousse/*
- Remove include/configs/MOUSSE.h
- Clean-up defined(CONFIG_MOUSSE)
- Remove board/rsdproto/*
- Remove include/configs/rsdproto.h
- Remove board/rpxsuper/*
- Remove include/configs/RPXsuper.h
Enough time has passed since these boards were moved to Orphan. Remove.
- Remove board/RPXlite/*
- Remove board/RPXClassic/*
- Remove include/configs/RPXlite.h
- Remove include/configs/RPXClassic.h
- Clean-up defined(CONFIG_RPXCLASSIC)
- Remove include/configs/{ADS860.h,FADS823.h,FADS850SAR.h,FADS860T.h}
- Cleanup defined(CONFIG_ADS), defined(CONFIG_MPC823FADS),
defined(CONFIG_MPC850SAR), defined(CONFIG_SYS_DAUGHTERBOARD)
- Remove the entries from boards.cfg
- Remove board/genietv/*
- Remove include/configs/GENIETV.h
- Clean-up if defined(CONFIG_GENIETV)
- Remove board/mbx8xx/*
- Remove include/configs/{MBX.h,MBX860T.h}
- Clean-up if defined(CONFIG_MBX)
- Move the entries from boards.cfg to doc/README.scrapyard
- Remove board/nx823/*
- Remove include/configs/NX823.h
- Clean-up ifdef(CONFIG_NX823)
Cc: Scott Wood <scottwood@freescale.com>
Add CONFIG_SYS_GENERIC_BOARD to use common/board_[fr].c for kzm9g.
Signed-off-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp>
Acked-by: Heiko Schocher <hs@denx.de>
Commit d016dc42cedbf6102e100fa9ecb58462edfb14f8 changed the layout of BCH8 SW
on omap3 boards. We need to adopt the ecc layout for the nand_spl_simle
driver to avoid wrong ecc errors.
Signed-off-by: Andreas Bießmann <andreas.biessmann@corscience.de>
Cc: Thomas Weber <thomas.weber@corscience.de>
arch/arm/cpu/arm926ejs/mxs/Makefile
include/configs/trats.h
include/configs/trats2.h
include/mmc.h
This patch add gicv3 support to uboot armv8 platform.
Changes for v2:
- rename arm/cpu/armv8/gic.S with arm/lib/gic_64.S
- move smp_kick_all_cpus() from gic.S to start.S, it would be
implementation dependent.
- Each core initialize it's own ReDistributor instead of master
initializeing all ReDistributors. This is advised by arnab.basu
<arnab.basu@freescale.com>.
Signed-off-by: David Feng <fenghua@phytium.com.cn>
Since MX6 is Cortex-A9 r2p10, enable software workaround
for errata 794072 and 761320.
Signed-off-by: Nitin Garg <nitin.garg@freescale.com>
Clock Manager driver will be called to reconfigure all the
clocks setting based on user input. The input are passed to
Preloader through handoff files
Signed-off-by: Chin Liang See <clsee@altera.com>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Cc: Tom Rini <trini@ti.com>
CC: Pavel Machek <pavel@denx.de>
Cc: Dinh Nguyen <dinguyen@altera.com>
Acked-by: Pavel Machek <pavel@denx.de>
arch/arm/cpu/arm926ejs/mxs/mxsimage.mx23.cfg
arch/arm/cpu/arm926ejs/mxs/mxsimage.mx28.cfg
This change enables automatically uuid generation by command gpt.
In case of updating partitions layout user don't need to care about
generate uuid manually.
Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com>
Cc: Piotr Wilczek <p.wilczek@samsung.com>
Cc: Stephen Warren <swarren@nvidia.com>
Cc: Lukasz Majewski <l.majewski@samsung.com>
Cc: trini@ti.com
Those commands basis on implementation of random UUID generator version 4
which is described in RFC4122. The same algorithm is used for generation
both ids but string representation is different as below.
char: 0 9 14 19 24 36
xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
UUID: be be be be be
GUID: le le le be be
Commands usage:
- uuid [<varname>]
- guid [<varname>]
The result is saved in environment as a "varname" variable if argument is given,
if not then it is printed.
New config:
- CONFIG_CMD_UUID
Cc: trini@ti.com
This patch adds support to generate UUID (Universally Unique Identifier)
in version 4 based on RFC4122, which is randomly.
Source: https://www.ietf.org/rfc/rfc4122.txt
Changes:
- new configs:
- CONFIG_LIB_UUID for compile lib/uuid.c
- CONFIG_RANDOM_UUID for functions gen_rand_uuid() and gen_rand_uuid_str()
- add configs dependency to include/config_fallbacks.h for lib uuid.
lib/uuid.c:
- add gen_rand_uuid() - this function writes 16 bytes len binary representation
of UUID v4 to the memory at given address.
- add gen_rand_uuid_str() - this function writes 37 bytes len hexadecimal
ASCII string representation of UUID v4 to the memory at given address.
[trini: Add CONFIG_EFI_PARTITION to fallbacks]
Changes in lib/uuid.c to:
- uuid_str_to_bin()
- uuid_bin_to_str()
New parameter is added to specify input/output string format in listed functions
This change allows easy recognize which UUID type is or should be stored in given
string array. Binary data of UUID and GUID is always stored in big endian, only
string representations are different as follows.
String byte: 0 36
String char: xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
string UUID: be be be be be
string GUID: le le le be be
This patch also updates functions calls and declarations in a whole code.
Cc: trini@ti.com
This commit introduces cleanup for uuid library.
Changes:
- move uuid<->string conversion functions into lib/uuid.c so they can be
used by code outside part_efi.c.
- rename uuid_string() to uuid_bin_to_str() for consistency with existing
uuid_str_to_bin()
- add an error return code to uuid_str_to_bin()
- update existing code to the new library functions.
Cc: trini@ti.com
The u-boot's image TEXT_BASE needs to be changed to 0x43e00000 from 0x78100000.
This change provides compatibility with other trats2 (RD_PQ) devices
(http://download.tizen.org/releases/system/).
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
Some eMMC chips may need the RST_n_FUNCTION bit set to a non-zero value
in order for warm reset of the system to work. Details on this being
required will be part of the eMMC datasheet. Also add using this
command to the dra7xx README.
* Whitespace fix by panto
Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
CC: Fabio Estevam <fabio.estevam@freescale.com>
The DRAM size can be easily detected at runtime on i.MX53. Implement
such detection on M53EVK and adjust the rest of the macros accordingly
to use the detected values.
An important thing to note here is that we had to override the function
for trimming the effective DRAM address, get_effective_memsize(). That
is because the function uses CONFIG_MAX_MEM_MAPPED as the upper bound of
the available DRAM and we don't have gd->bd->bi_dram[0].size set up at
the time the function is called, thus we cannot put this into the macro
CONFIG_MAX_MEM_MAPPED . Instead, we use custom override where we use the
size of the first DRAM block which we just detected.
Cc: Fabio Estevam <fabio.estevam@freescale.com>
Fix memory access slowness on i.MX53 M53EVK board. Let us inspect the
issue: First of all, the i.MX53 CPU has two memory banks mapped at
0x7000_0000 and 0xb000_0000 and each of those can hold up to 1GiB of
DRAM memory. Notice that the memory area is not continuous. On M53EVK,
each of the banks contain 512MiB of DRAM, which makes a total of 1GiB
of memory available to the system.
The problem is how the relocation of U-Boot is treated on i.MX53 . The
U-Boot is placed at the ((start of first DRAM partition) + (gd->ram_size)) .
This in turn poses a problem, since in our case, the gd->ram_size is 1GiB,
the first DRAM bank starts at 0x7000_0000 and contains 512MiB of memory.
Thus, with this algorithm, U-Boot is placed at offset:
0x7000_0000 + 1GiB - sizeof(u-boot and some small margin)
This is past the DRAM available in the first bank on M53EVK, but is still
within the address range of the first DRAM bank. Because of the memory
wrap-around, the data can still be read and written to this area, but the
access is much slower.
There were two ideas how to solve this problem, first was to map both of
the available DRAM chunks next to one another by using MMU, second was to
define CONFIG_VERY_BIG_RAM and CONFIG_MAX_MEM_MAPPED to size of the memory
in the first DRAM bank. We choose the later because it turns out the former
is not applicable afterall. The former cannot be used in case Linux kernel
was loaded into the second DRAM bank area, which would be remapped and one
would try booting the kernel, since at some point before the kernel is started,
the MMU would be turned off, which would destroy the mapping and hang the
system.
such detection on MX53QSB and adjust the rest of the macros accordingly
Fix memory access slowness on i.MX53 MX53QSB board. Let us inspect the
DRAM memory. Notice that the memory area is not continuous. On MX53QSB,
This is past the DRAM available in the first bank on MX53QSB, but is still
system.
Add support for PCIe on MX6 SabreSDP board and enable the support
in the config file.
Cc: Liu Ying <Ying.Liu@freescale.com>
Use of PCIe on SABRE Lite and Nitrogen6x boards
is atypical and requires the use of custom daughter
boards.
Use in U-Boot is even rarer, so this patch removes it from
the standard configuration.
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
CONFIG_BOOT_INTERNAL is not used anywhere, so let's remove it.
Add yet another OCOTP driver for this i.MX family. This time, it's a driver for
the OCOTP variant found in the i.MX23 and i.MX28. This version of OCOTP is too
different from the i.MX6 one that I could not use the mxc_ocotp.c driver without
making it into a big pile of #ifdef . This driver implements the regular fuse
command interface, but due to the IP blocks' limitation, we support only READ
and PROG functions.
