env_get_char is not a function, but a pointer to one.
This reverts commit 1b5605ca57fbb364f4d78eeee28b974ed875e888
which breaks building on all PPC boards that don't use a log buffer.
This reverts commit c0559be371b2a64b1a817088c3308688e2182f93
which is known to break booting from dataflash and NAND.
When using dhcp/bootp the "netmask" environment variable is not set
because CONFIG_BOOTP_SUBNETMASK is not defined. But usually this is
desireable, so the following patch adds this this option to the board
config.
Signed-off-by: Markus Klotzbuecher <mk@denx.de>
This patch reworks the default environment on Makalu. Now "net_nfs" for
example uses the device-tree style booting formerly know as "net_nfs_fdt".
Also the addresses in RAM were changed because of the new image booting
support, which check for image overwriting. So the addresses needed to
get adjusted.
map_physmem currently generates a warning when CONFIG_PHYS_64BIT is
enabled. This quiets the warning.
Signed-off-by: Becky Bruce <Becky.Bruce@freescale.com>
Physical addrs need to be represented by phys_addr_t, not
unsigned long. Otherwise, systems that use CONFIG_PHYS_64BIT
are going to fail mightily.
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
When applying the AT91CAP9 patches upstream, something transformed
the '@' character into the ' <at> ' sequence.
The patch below restores the original form in all the places where
it has been modified (the AT91CAP9 files, the AT91SAM9260 files which
were copied from AT91CAP9, and a couple of other files where the
' <at> ' sequence was present).
Signed-off-by: Stelian Pop <stelian@popies.net>
When doing the AT91CAP9/AT91SAM9 port, a number of header files were
copied from the Linux kernel sources. This patch explicitly specifies
this origin for all the copied headers, and for those missing copyright
information, adds it.
Additionaly, the header file 'at91sam926x_mc.h' has been superceeded
in the latest kernel sources by 'at91sam9_smc.h'.
The copyright information has been confirmed by the AT91 Linux kernel
maintainer, Andrew Victor <avictor.za@gmail.com>.
According to schematics and to RedBoot sources, the MX31ADS uses a 32768Hz
oscillator as a SKIL source. Fix previously wrongly assumed 32000Hz value.
Also fix a typo when verifying a jumper configuration. While at it, make
two needlessly global functions static.
Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
Add logbuffer to reserved LMB areas to prevent initrd allocation
from overlaping with it.
Make sure to use correct logbuffer base address.
Signed-off-by: Marian Balakowicz <m8@semihalf.com>
This patch adds fdt (flattened device tree) support to all remaining AMCC
eval boards. Most newer boards already support device tree. With this patch,
all AMCC boards now enable device tree passing from U-Boot to Linux
arch/powerpc kernels.
This patch adds fdt (flattened device tree) support to the AMCC
Acadia eval board. This increases the image size and it doesn't
fit anymore into 256kByte. Since we didn't want to remove features
from the configuration, we decided to increase the U-Boot image size
(add one flash sector).
Also changed the default environment definition to make it
independent of such changes.
Add support for booting with a device tree blob. This is needed to boot
ARCH=powerpc kernels. Also add support for setting the eth0 mac address
via the ethaddr variable.
Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu>
These same settings are used on MPC8349ITX, and
improve performance on MPC8349EMDS.
Signed-off-by: Lee Nipper <lee.nipper@freescale.com>
Fix incorrect mask to enable all 64MB of onboard flash.
Previously U-Boot incorrectly mapped only 8MB of flash, this
patch correctly maps all the available flash.
Signed-off-by: Jeremy McNicoll <jeremy.mcnicoll@windriver.com>
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
The ethernet hang is caused by receiving buffer in DRAM is not
yet ready due to access cycles require longer time in DRAM.
Relocate DMA buffer descriptors from DRAM to internal SRAM.
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
Signed-off-by: Luigi Comio Mantellini <luigi.mantellini@idf-hit.com>
MPC8610HPCD board adds -O2 gcc option to PLATFORM_CPPFLAGS
causing overriding default -Os option. New gcc (ver. 4.2.2)
produces warnings while compiling net/net.c file with -O2
option. The patch is an attempt to fix this.
All the 85xx and 86xx UM describe the register as timing_cfg_3
not as ext_refrec.
Rename init_addr and init_ext_addr to match the docs between
85xx and 86xx. Both now use 'init_addr' and 'init_ext_addr'.
LWMON5 DSPIC POST uses the watch-dog scratch register. So, make
the CFG_DSPIC_TEST_ADDR definition more readable.
Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
Arithmetic expressions do not get evaluated under stringification. Remove
default network configuration, add DHCP command support. Thanks to Felix
Radensky for reporting.
Since we didn't want to remove features from the configuration, we
decided to increase the U-Boot image size (add one flash sector).
This patch enables SPI and MC13783/RTC support for the Litekit board.
Signed-off-by: Magnus Lilja <lilja.magnus@gmail.com>
This patch removes the unknown flash message information:
'## Unknown FLASH on Bank 1 - Size = 0xdeadbeef = -286261248 MB'
This unknown flash message is caused by PromJet.
Some of the board user is unhappy with this information.
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
