Instead of creating yet another set of MII register definitions
in the macb driver, here's a complete set of definitions for everyone
to use.
Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
Include the imi, imls and jffs commands sets by default on ATSTK1000.
Also define CONFIG_BOOTARGS to something more useful, define
CONFIG_BOOTCOMMAND and enable autoboot by default.
Copy the definition of struct stat from the Linux kernel.
Conform to the "standard" interface and use initdram() instead of
board_init_memories() on AVR32. This enables us to get rid of the
sdram_size member of the global_data struct as well.
Relocate the u-boot image into SDRAM like everyone else does. This
means that we can handle much larger .data and .bss than we used to.
Rewrite the resource management code (i.e. I/O memory, clock gating,
gpio) so it doesn't depend on any global state. This is necessary
because this code is heavily used before relocation to RAM, so we
can't write to any global variables.
As an added bonus, this makes u-boot's memory footprint a bit smaller,
although some functionality has been left out; all clocks are enabled
all the time, and there's no checking for gpio line conflicts.
Convert spaces to tabs (must have missed this one last time around),
sort the entries by address and group them together by bus
connectivity.
* Make IDE timeout configurable through ide_reset_timeout variable.
* Use Newline as "password" string
* Use just a single partition in NAND flash
Modifications to the existing code to support the new fdt command.
Enhanced the formerly private function _fdt_next_tag() to allow stepping
through the tree, used to produce a human-readable dump, and made
it part of the published interface.
Also added some comments.
Changes to David Gibson's original source to fit into u-boot's
environment. No functionality changes.
This adds the applicable libfdt source files (unmodified) and a README
to explain where the source came from.
With the updated 44x DDR2 driver the Yucca board now supports
ECC generation and checking.
Reset support
BSP autoconfig support
This patch adds some 4xx GPIO functions. It also moves some of the
common code and defines into a common 4xx GPIO header file.
This patch cleans up all the open issue of the preliminary
Acadia support.
Prevent false interrupt from hanging Linux as MSR[EE] is set
to enable interrupts by changing the PIC out of the default
pass through mode into mixed mode.
Signed-off-by: Haiying Wang <haiying.wang@freescale.com>
Also fixes some commmand for 8641 HPCN ramboot case.
Signed-off-by: Jason Jin <jason.jin@freescale.com>
This patch adds support for the new AMCC Acadia eval board.
Please note that this Acadia/405EZ support is still in a beta stage.
Still lot's of cleanup needed but we need a preliminary release now.
This patch adds support for the new AMCC 405EZ PPC. It is in
preparation for the AMCC Acadia board support.
Define CONFIG_PROG_SDRAM_TLB so that the TLB entries for the
DDR memory are dynamically programmed matching the total size
of the equipped memory (DIMM modules).
boards in terms of unification.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
(SC3 and Jupiter used to use 'addcon' instead).
Signed-off-by: Wolfgang Denk wd@denx.de
added Hush Shell,
CONFIG_CMDLINE_EDITING,
CFG_ENV_ADDR_REDUND activated
timer support
interrupt controller support
flash support
ethernet support
cache support
board information support
env support
booting image support
adding support for Xilinx ML401
