The default bootargs in the Atmel AT91 boards uses the old
name of the Atmel NAND driver, at91_nand. Kernels 2.6.28 and newer
use atmel_nand. This changes those values to match the newer kernels.
Signed-off-by: Justin Waters <justin.waters@timesys.com>
AT91sam9g20 is an evolution of the at91sam9260 with a faster clock speed.
The AT91SAM9G20-EK board is an updated revision of the AT91SAM9260-EK board.
It is essentially the same, with a few minor differences.
Here is the chip page on Atmel website:
http://www.atmel.com/dyn/products/product_card.asp?part_id=4337
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Total5200 and digsy MTC use I2C port 2 pins as a ATA chip select.
To avoid adding board-specific ifdefs to cpu/mpc5xxx/ide.c new
define CONFIG_SYS_ATA_CS_ON_I2C2 was introduced. It is used by
Total5200 and will be used by digsy MTC and other boards with
ATA CS on I2C pins.
Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com>
This patch adds support for the kmsupx4 board from Keymile,
based on a Freescale MPC852T CPU
- serial console on SMC1
- 32 MB SDRAM
- 32 MB NOR Flash
- Ethernet over SCC3
- I2C Bitbang
renaming the "mgsuvd" board port into "km8xx", because
there come more similar boards from keymile.
Compiling the mgsuvd board with "make mgsuvd_config"
remains.
- added to keymile-common.h:
- bootcount support
- COMMAND HISTORY
- CONFIG_AUTO_COMPLETE
- CONFIG_SYS_FLASH_PROTECTION
- JFFS2 support
- CONFIG_VERSION_VARIABLE
- extracted common I2C settings for all boards
- common default environment settings summarized
with the new CONFIG_SYS_DELAYED_ICACHE config option, ICache
is not enabled before code runs from RAM.
Size of one environment sector is 0x20000.
Fix indentation broken by symbol renames. "Sort" driver related definitons.
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
Default gzip bootm size is 8MB. Some platforms require
more than 8MB
Read and store OMAP3 die ID in U-Boot environment.
Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
The rtl8139 driver use pci_mem_to_phys. So it need PCI system memory
registration.
Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com>
We can built 'make sh7785lcr_32bit_config'. And add new command "pmb"
for this mode. This command changes PMB for using 512MB system memory.
Some register value was hardcoded for System memory size 128MB and
memory offset 0x08000000. This patch fixed the problem.
This adds tsec12ioovcr to include/asm-ppc/immap_85xx.h (was reserved.)
Signed-off-by: Sergey Kubushyn <ksi@koi8.net>
lib_ppc/board.c
- HRCW update
HRCWH_BOOTSEQ_DISABLE not HRCWH_BOOTSEQ_NORMAL
HRCWH_LALE_EARLY added
- DDR-SDRAM settings modified. This solves sporadically
problems with this memory.
- CS1 now 128 MB window size
- CS3 now 512 MB window size
- PRAM activated
- MTDPARTS_DEFAULT defined
- CONFIG_HOSTNAME added
- MONITOR_LEN now 384 KB
it is possible that some board variants have different DDR II
RAM sizes. So we autodetect the size of the assembled RAM.
This patch adds I2C support for the Keymile kmeter1 board.
It uses the First I2C Controller from the CPU, for
accessing 4 temperature sensors, an eeprom with IVM data
and the booteeprom over a pca9547 mux.
The previous version rebooted forever with DDR bigger than 256MB.
Access the DS1339 RTC chip is on I2C1 bus.
Allow DHCP.
Signed-off-by: Valeriy Glushkov <gvv@lstec.com>
The "eet" variant of the imx31_phycore board has an OLED display, using a
s6e63d6 display controller on the first SPI interface, using GPIO57 as a
chip-select for it. With this configuration you can display 256 colour BMP
images in 16-bit RGB (RGB565) LCD mode.
Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
This patch also simplifies some ifdefs in lcd.c, introduces a generic
vidinfo_t, which new drivers are encouraged to use and old drivers to switch
over to.
Acked-by: Anatolij Gustschin <agust@denx.de>
This is a driver for the S6E63D6 SPI OLED display controller from Samsung.
It only provides access to controller's registers so the client can freely
configure it.
This is a minimal driver, so far only managing output. It will
be used by the mxc_spi.c driver.
On MPC8377E-RDB and MPC8378E-RDB boards we have PCIe and mini-PCIe
slots. Let's support them.
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
This is just a handy routine that reports last PCI busno: we walk
down all the hoses and return last hose's last_busno.
Will be used by PCI/PCIe initialization code.
Currently, we get 256MB as the default, but since all the 86xx
board configs define a 2G BAT mapping for RAM, raise default
to 2G.
Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
Acked-by: Jon Loeliger <jdl@freescale.com>
NetLoop polls every cycle with getenv some environment variables.
This is horribly slow, especially when the environment is big.
This patch reads only the environment variables in NetLoop,
when they were changed.
Also moved the init part of the NetLoop function in a seperate
function.
The file was generated from building versatile_defconfig.
Compiling dbau1x00 and gth2 boards with GCC-4.2, you would see new warnings
like this:
skuribay@ubuntu:u-boot.git$ ./MAKEALL dbau1000
Configuring for dbau1x00 board...
au1x00_eth.c: In function 'au1x00_send':
au1x00_eth.c:158: warning: passing argument 1 of 'virt_to_phys' discards qualifiers from pointer target type
au1x00_eth.c: In function 'au1x00_recv':
au1x00_eth.c:211: warning: passing argument 1 of 'virt_to_phys' discards qualifiers from pointer target type
au1x00_eth.c: In function 'au1x00_init':
au1x00_eth.c:252: warning: passing argument 1 of 'virt_to_phys' discards qualifiers from pointer target type
We're passing a volatile pointer to a function which is expecting a non-
volatile pointer. That's potentially dangerous, so gcc warns about it.
Confirmed with ELDK 4.2 (GCC 4.2.2) and Sourcey G++ 4.2 (GCC 4.2.3).
To fix this, we add a volatile attribute to the argument in question.
The virt_to_phys function in Linux kernel also does the same thing.
Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
Clean up OMAP3 MMC code:
* Convert register access to struct & readx/writex style
* Replace hardcode values by macros
* Remove macro defined twice
This patch adds OMAP3 cpu type auto detection based on OMAP3 register
and removes hardcoded values.
Signed-off-by: Steve Sakoman <sakoman@gmail.com>
With BeagleBoard revision C some HW changes are introduced (e.g. PinMUX)
which might need different software handling. For this, GPIO pin 171 (GPIO
module 6, offset 11) can be used to check for board revision. If this pin
is low, we have a rev C board. Else it must be a revision Ax or Bx board.
To handle board differences you can call function beagle_get_revision().
E.g.:
if (beagle_get_revision()) {
/* do special revision C stuff here */
Serial driver via the EmbeddedICE macrocell's DCC channel using
co-processor 14.
It does include a timeout to ensure that the system does not
totally freeze when there is nothing connected to read.
