path: root/include
2007-02-21[PATCH v3] Add sync to ensure flash_write_cmd is fully finishedHaiying Wang
Some CPUs like PPC, BLACKFIN need sync() to ensure cfi flash write command is fully finished. The sync() is defined in each CPU's io.h file. For those CPUs which do not need sync for now, a dummy sync() is defined in their io.h as well. Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
2007-02-20Merge with /home/stefan/git/u-boot/denx-merge-srStefan Roese
2007-02-20[PATCH] Add support for the AMCC Katmai (440SPe) eval boardStefan Roese
2007-02-20[PATCH] PPC4xx: Add 440SP(e) DDR2 SPD DIMM supportStefan Roese
This patch adds support for the DDR2 controller used on the 440SP and 440SPe. It is tested on the Katmai (440SPe) eval board and works fine with the following DIMM modules: - Corsair CM2X512-5400C4 (512MByte per DIMM) - Kingston ValueRAM KVR667D2N5/512 (512MByte per DIMM) - Kingston ValueRAM KVR667D2N5K2/2G (1GByte per DIMM) This patch also adds the nice functionality to dynamically create the TLB entries for the SDRAM (tlb.c). So we should never run into such problems with wrong (too short) TLB initialization again on these platforms. Signed-off-by: Stefan Roese <sr@denx.de>
2007-02-20[PATCH] PPC4xx: Add support for multiple I2C bussesStefan Roese
This patch adds support for multiple I2C busses on the PPC4xx platforms. Define CONFIG_I2C_MULTI_BUS in the board config file to make use of this feature. It also merges the 405 and 440 i2c header files into one common file 4xx_i2c.h. Also the 4xx i2c reset procedure is reworked since I experienced some problems with the first access on the 440SPe Katmai board. Signed-off-by: Stefan Roese <sr@denx.de>
2007-02-20[PATCH 9_9] Use "void *" not "unsigned long *" for block dev read_write ↵Grant Likely
buffer pointers Block device read/write is anonymous data; there is no need to use a typed pointer. void * is fine. Also add a hook for block_read functions Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-02-20[PATCH 8_9] Add block_write hook to block_dev_desc_tGrant Likely
Preparation for future patches which support block device writing Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-02-20[PATCH 3_9] Move buffer print code from md command to common functionGrant Likely
Printing a buffer is a darn useful thing. Move the buffer print code into print_buffer() in lib_generic/ Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-02-20[PATCH 1_4] Merge common get_dev() routines for block devicesGrant Likely
Each of the filesystem drivers duplicate the get_dev routine. This change merges them into a single function in part.c Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-02-19[PATCH] Update Sequoia EBC configuration (NOR FLASH)Stefan Roese
As spotted by Matthias Fuchs, the READY input should not be enabled for the NOR FLASH on the Sequoia board. Signed-off-by: Stefan Roese <sr@denx.de>
2007-02-16Merge with /home/tur/git/u-boot#motionproWolfgang Denk
2007-02-09[Motion-PRO] Preliminary support for the Motion-PRO board.Bartlomiej Sieka
2007-02-07[PATCH] Update some AMCC 4xx board config files (set initrd_high)Stefan Roese
Some boards that can have more than 768MBytes of SDRAM need to set "initrd_high", so that the initrd can be accessed by the Linux kernel. Signed-off-by: Stefan Roese <sr@denx.de>
2007-02-01[PATCH] Remove PCI-PNP configuration from Sequoia/Rainier config fileStefan Roese
When PCI PNP is enabled the pci pnp configuration routine is called which sets the PCI_CACHE_SIZE_LINE to 8. This seems to generate some problems with some PCI cards. For now disable the PCI PNP configuration. Signed-off-by: Stefan Roese <sr@denx.de>
2007-01-31[PATCH] Update 440EPx/440GRx cpu detectionStefan Roese
2007-01-31[PATCH] Add support for esd mecp5200 boardStefan Roese
Signed-off-by: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
2007-01-31[PATCH] Remove unneccessary yellowstone board config fileStefan Roese
2007-01-30Merge with /home/sr/git/u-boot/denx-merge-srWolfgang Denk
2007-01-30[PATCH] Update Sequoia (440EPx) config fileStefan Roese
The config file now handles the 2nd target, the Rainier (440GRx) evaluation board better. Additionally the PPC input clock was adjusted to match the correct value of 33.0 MHz. Signed-off-by: Stefan Roese <sr@denx.de>
2007-01-30[PATCH] Merge Yosemite & Yellowstone board portsStefan Roese
Now the AMCC eval boards Yosemite (440EP) and Yellowstone (440GR) share one config file and all board specific files. This way we don't have to maintain two different sets of files for nearly identical boards. Signed-off-by: Stefan Roese <sr@denx.de>
2007-01-30[PATCH] Update Prodrive SCPU (PDNB3 variant) boardStefan Roese
SCPU doesn't use redundant environment in flash. Signed-off-by: Stefan Roese <sr@denx.de>
2007-01-30[PATCH] alpr: Update alpr board config fileStefan Roese
2007-01-24Add port for the lpc2292sodimm evaluation board from EmbeddedArtistsGary Jennejohn
2007-01-24Merge with /home/tur/proj/idmr/u-bootWolfgang Denk
2007-01-23[iDMR] Add MTD and JFFS2 support, also add default partition definition.Bartlomiej Sieka
2007-01-23[iDMR] Using MII-related commands on iDRM board doesn't work now (e.g.,Bartlomiej Sieka
"mii device" results in "Unexpected exception"). Fixing this properly requires some clean-up in the FEC drivers infrastructure for ColdFire, so this commit disables MII commads for now.
2007-01-23[ColdFire MCF5271 family] Add CPU detection based on the value of ChipBartlomiej Sieka
Identification Register (CIR).
2007-01-19Merge with /home/hs/SC3/u-boot-devWolfgang Denk
2007-01-19[PATCH] SC3 board: added CFG_CMD_AUTOSCRIPT.Heiko Schocher
2007-01-19[PATCH] CFI: define CFG_WRITE_SWAPPED_DATA for the CFI-Flash driverHeiko Schocher
if you must swap the bytes between reading/writing. (Needed for the SC3 board) Signed-off-by: Heiko Schocher <hs@denx.de>
2007-01-18[PATCH] Add support for Prodrive SCPU (PDNB3 variant) boardStefan Roese
2007-01-18[PATCH] Update Prodrive P3Mx supportStefan Roese
2007-01-18[PATCH] Add missing Taishan config fileStefan Roese
2007-01-18[PATCH] Fix: Compilerwarnings for SC3 board.Heiko Schocher
The EBC Configuration Register is now by CFG_EBC_CFG definable Added JFFS2 support for the SC3 board. Signed-off-by: Heiko Schocher <hs@denx.de>
2007-01-16Raname solidcard3 into sc3; add redundant env for sc3Wolfgang Denk
2007-01-16Update default environment for Solidcard3Wolfgang Denk
2007-01-15Merge with /home/hs/SC3/u-bootWolfgang Denk
Some code cleanup.
2007-01-15Merge with /home/hs/MAN/u-boot-devWolfgang Denk
2007-01-13Merge with git+ssh://sr@pollux.denx.org/home/sr/git/u-boot/denx-merge-srStefan Roese
2007-01-13[PATCH] Update 440SP(e) cpu revisionsStefan Roese
Also display enabled/disabled RAID 6 support for 440SP/440SPe PPC's. Signed-off-by: Stefan Roese <sr@denx.de>
2007-01-13[PATCH] Update Yellowstone (440GR) to display board rev and PCI bus speedStefan Roese
Now the board revision and the current PCI bus speed are printed after the board message. Also the EBC initialising is now done via defines in the board config file. Signed-off-by: Stefan Roese <sr@denx.de>
2007-01-13[PATCH] Update Yosemite (440EP) to display board rev and PCI bus speedStefan Roese
2007-01-11 Added support for the SOLIDCARD III board from EurodesignHeiko Schocher
2007-01-10Adjusted default environment for cam5200 board.Reinhard Thies
2007-01-10Merge with /home/m8/git/u-boot/Detlev Zundel
2007-01-10CAM5200 flash driver modifications:Marian Balakowicz
- use CFI driver (replaces custom flash driver) for main 'cam5200' target - add second build target 'cam5200_niosflash' which still uses custom driver
2007-01-09SPC1920: cleanup memory contoller setupMarkus Klotzbuecher
2007-01-09Fix the cpu speed setup to work with all boards.Markus Klotzbuecher
