Some new platform's esdhc pins don't share with other function.
The eSDHC shouldn't be disabled, even if "esdhc" isn't defined
in hwconfig env variable.
Use CONFIG_FSL_ESDHC_PIN_MUX to fix this problem.
Signed-off-by: Chenhui Zhao <b26998@freescale.com>
Signed-off-by: Li Yang <leoli@freescale.com>
Instead of a #define use a null weak function for fsl_serdes_init
Mimic support that exists on MPC8536DS on the MPC8572DS to allow booting
from NAND.
Signed-off-by: Jin Qing <b24347@freescale.com>
Neither of these parts should have the erratum this is meant to
work around. Delete it.
Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
This isn't used - delete it.
The PM854/PM856 boards are no longer maintained and thus we are removing
support for them.
Acked-by: Wolfgang Denk <wd@denx.de>
The MPC8540EVAL board is no longer maintained and thus we are removing
support for it.
The ATUM8548 board is no longer maintained and thus we are removing
support for it.
PCI is not used at all on lwmon5. So lets remove it. It saves space and
reduces boot time a bit (approx. 50ms).
Patch "Replace CONFIG_SYS_GBL_DATA_SIZE by auto-generated value"
(sha1: 25ddd1fb0a2281b182529afbc8fda5de2dc16d96)
introduce GENERATED_GBL_DATA_SIZE which is sizeof aligned gd_t
(currently 0x40).
Microblaze configs used 0x40(128) because this place also contained
board info structure which lies on the top of ram.
U-Boot is placed to the top of the ram (for example 0xd7ffffff)
and bd structure was moved out of ram.
This patch is fixing this scheme with GENERATED_BD_INFO_SIZE
which swap global data and board info structures.
For example:
Current: gd 0xd7ffffc0, bd 0xd8000000
Fixed: gd 0xd7ffffc0, bd 0xd7ffff90
Add Faraday's ftgmac100 (gigabit ethernet)
MAC controller's driver.
Signed-off-by: Macpaul Lin <macpaul@andestech.com>
The include/miiphy.h header duplicates a lot of things from linux/mii.h.
So punt all the things that overlap to keep the API simple and to make
merging between U-Boot and Linux simpler.
We have config_defaults.h which are random configuration settings that
everyone gets by default. We also have config_cmd_default.h which is a
recommended list of defaults but boards have to opt into. Now we have
config_cmd_defaults.h which is a list of defaults that everyone gets
and has to actively opt out of.
For now, we populate it with the bootm command which previously was
unable to be disabled.
Currently, only basic completion is supported (no globs), but this is
what we had previously.
This patch supports T-SH7706LSR board.
This is constitution almost same as shmin (T-SH7706LAN).
Therefore, most functions work by a change of the setting of config.
http://web.kyoto-inet.or.jp/people/takagaki/T-SH7706/T-SH7706LSR.htm
This adds support for the SHMIN SH7706 board(T-SH7706LAN).
The CPU of this board is SH7706.
There are SDRAM of 32M byte, Flash memory of 512K byte, Serial,
10Base Ether and MMC.
http://web.kyoto-inet.or.jp/people/takagaki/T-SH7706/T-SH7706.htm
After booting the u-boot, and first using some SD card (such as Sandisk 2G SD
card), because the field 'clock' of struct mmc is zero, this will cause
the read transfer is always active and SDHC DATA line is always active,
therefore, driver can't handle the next command.
Therefore, we use mmc_set_clock to setup both the data structure and HW
to the initial clock speed of 400000Hz.
Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com>
Tested-by: Stefano Babic <sbabic@denx.de>
Add reginfo as a default command for p1022ds boards
Signed-off-by: Matthew McClintock <msm@freescale.com>
This command is used to read the device ONFI parameters page.
Signed-off-by: Florian Fainelli <florian@openwrt.org>
These id tables need not be writable.
The non-reentrant versions of the hashtable functions operate on a single
shared hashtable. So if two different people try using these funcs for
two different purposes, they'll cause problems for the other.
Avoid this by converting all existing hashtable consumers over to the
reentrant versions and then punting the non-reentrant ones.
New default partitions on nor flash:
640k (firmware)
1408k (kernel)
2m (initrd)
4m (small-fs)
24320k (big-fs)
256k (dts)
Add ARM Relocation Support
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
Some DaVinci boards are using flags that are no longer valid
So remove them.
This patch adds the possibility to (optinally) write to the
flash configuration register. The Intel style CFI chips support
such a register that can be used to configure the operation
mode to a non-default value.
This method will be used by the t3corp board, which needs to
configure the DS617 Xilinx flash for async read mode.
Use common ppc4xx linker script for xilinx ppc440 and ppc405 related boards.
Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com>
This patch includes the following changes for the lwmon5 board support:
- Enable cache in SDRAM
- Use common EHCI driver instead of the PPC4xx specific OHCI driver
This can be done since only high-speed devices are connected.
- Remove cached TLB entry again after ECC setup
- Use correct define for cache enabling
(CONFIG_4xx_DCACHE instead of CONFIG_SYS_ENABLE_SDRAM_CACHE)
- Enable FIT image support
The t3corp board has an Xilinx DS617 flash chip connected to the
onboard FPGA. This patch adds support for these chips. Board
specific flash accessor functions are needed, since the chips
can only be read correctly in 16bit mode.
Additionally the FPGA chip-selects are configured for device-paced
transfers (ready is enabled).
Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
Aspenite is a Development Board for ASPEN/ARMADA168(88AP168) with
* Processor upto 1.2GHz
* Parallel 1Gb x8 DDR2-1066 MHz
* 16 Mb x16 NOR, 4Gb x8 SLC NAND, footprint for SPI NOR
* Footprints for eMMC/eSD NAND & MMC x8 card
* 4-in-1 card reader (xD, MMC/SD/MS Pro), CF True IDE socket
* SEAF memory board, subset of PISMO2
With Peripherals:
* 4.3” WVGA 24-bit LCD
* Audio codecs (AC97 & I2S), TSI
* VGA camera
* Video in via 3 RCA jacks, and HDMI type C out
* Marvell 88W8688 802.11bg/BT module
* GPS RF IC
* Dual analog mics & speakers, headset jack, LED, ambient light sensor
* USB2.0 HS host (A), OTG (micro AB)
* FE PHY, PCIE Mini Card slot
* GPIO, GPIO expander with DIP switches for easier selection UART serial over USB, CIR
This patch adds basic board support with DRAM and UART functionality
The patch is tested for boot from DRAM using XDB
Signed-off-by: Mahavir Jain <mjain@marvell.com>
Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
This patch adds commonly used macros for ARMADA100 based
baords, Also some code reshuffled and updated for typos and comments
Most of the Marvell SoCs has Multi Function Pin (MFP) configuration registers
For ex. ARMADA100.
These registers are programmed to expose the specific functionality
associated with respective SoC Pins
This driver provides configuration APIs,
using them, configuration need to be done in board specific code
for ex- following code configures MFPs 107 and 108 for UART_TX/RX functionality
int board_early_init_f(void)
u32 mfp_cfg[] = {
/* Console on UART1 */
MFP107_UART1_RXD,
MFP108_UART1_TXD,
MFP_EOC /*End of configureation*/
/* configure MFP's */
mfp_config(mfp_cfg);
return 0;
- serial console in PSC1
- 128MiB DRAM
- 32MiB Flash
- FEC Ethernet
- 2 I2C busses
- FPGA on CS3
- IDE
- VGA SMI501
